    • doul59D Offline
      doul59 @Barbu Dor
      @Barbu-Dor
      Exemple de log :
      19:29:52.248 RSL: STATE = {"Time":"2022-11-20T19:29:52","Uptime":"0T03:51:14","UptimeSec":13874,"Heap":189,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":0,"Berry":{"HeapUsed":4,"Objects":44},"POWER":"ON","Dimmer":52,"Color":"3B8507","HSBColor":"95,95,52","Channel":[23,52,2],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"MONWIFI","BSSId":"04:D4:C4:BF:24:E0","Channel":2,"Mode":"11n","RSSI":100,"Signal":-12,"LinkCount":1,"Downtime":"0T00:00:03"}}
      19:29:52.296 RSL: SENSOR = {"Time":"2022-11-20T19:29:52","ENERGY":{"TotalStartTime":"2022-11-20T12:57:50","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":2250,"Current":10.000,"Load":22},"TIC":{"ADCO":"xXx","OPTARIF":"BBR(","ISOUSC":45,"BBRHCJB":15500793,"BBRHPJB":2445383,"BBRHCJW":17026,"BBRHPJW":57214,"BBRHCJR":0,"BBRHPJR":0,"PTEC":"HPJB","DEMAIN":"----","IINST":10,"IMAX":90,"PAPP":2250,"HHPHC":"A","MOTDETAT":0}}
      en weblog3
      19:38:38.883 TIC: Power 02030, now 2030
      19:38:41.384 TIC: Current IINST=009, now 9
      19:38:41.633 TIC: Power 02030, now 2030
      19:38:43.885 TIC: Current IINST=009, now 9
      19:38:44.136 TIC: Power 02040, now 2040
      19:38:46.133 TIC: Total counter updated to 0 Wh
      19:38:46.631 TIC: Current IINST=009, now 9
      19:38:46.882 TIC: Power 02030, now 2030
      19:38:49.138 TIC: Current IINST=009, now 9
      19:38:49.632 TIC: Power 02030, now 2030
      19:38:51.895 TIC: Current IINST=009, now 9
      19:38:52.135 TIC: Power 02030,
      Pour les pins soudés : j'ai suivi ça https://github.com/hallard/WeMos-TIC#detailed-description
      (j'ai juste pas soudé "ONBOARD LED")
      Info build :
        Charles @doul59
        @doul59 pas de soucis de câblage ou de fonctionnement, tes informations remontent bien on le voit dans le TIC
        D'ailleurs l'affichage active power et current est correct, c'est juste que tu es en contrat TEMPO (ex EJP avec jour Bleu/Blanc/Rouge) et que pour le moment ce n'est pas géré dans l'affichage de tasmota.
        doul59D 1 Reply Last reply Reply Quote
        • doul59D Offline
          doul59 @Charles
          @Charles Il y a du mieux avec ta PR de ce matin 🤙
            Charles @doul59
            @doul59 tu pourrais me faire une capture complète de l'écran avec toutes les valeurs que je vois si ça fonctionne comme ça doit stp (ça doit afficher la couleur du lendemain aussi) ?
            • doul59D Offline
              doul59 @Charles
              @Charles c'etait justement ça
              19:22:37.263 MQT: tele/tasmota_1F0510/STATE = {"Time":"2022-11-22T19:22:37","Uptime":"0T04:56:01","UptimeSec":17761,"Heap":188,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":1,"Berry":{"HeapUsed":4,"Objects":46},"POWER":"ON","Dimmer":52,"Color":"3B8507","HSBColor":"95,95,52","Channel":[23,52,2],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Quorum2","BSSId":"04:D4:C4:BF:24:E0","Channel":2,"Mode":"11n","RSSI":100,"Signal":-12,"LinkCount":1,"Downtime":"0T00:00:03"}}
              19:22:37.314 MQT: tele/tasmota_1F0510/SENSOR = {"Time":"2022-11-22T19:22:37","ENERGY":{"TotalStartTime":"2022-11-20T12:57:50","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":2200,"Current":10.000,"Load":22},"TIC":{"ADCO":"XXX","OPTARIF":"BBR(","ISOUSC":45,"BBRHCJB":15506797,"BBRHPJB":2462788,"BBRHCJW":17026,"BBRHPJW":57214,"BBRHCJR":0,"BBRHPJR":0,"PTEC":"HPJB","DEMAIN":"----","IINST":10,"IMAX":90,"PAPP":2200,"HHPHC":"A","MOTDETAT":0}}
              • doul59D Offline
                doul59 @doul59
                J'ajoute que je suis en mode Historique
                Merci d'avance Charles
                  Charles @doul59
                  @doul59 ah encore un petit bug, (oui oui TEMPO histo juste le registre en mode standard) tu compiles par toi même ?
                  Voila une PR qui devrait être mieux
                  • doul59D Offline
                    doul59 @Charles
                    @Charles j'upgrade manuellement en uploadant celui la : [https://github.com/Jason2866/Tasmota-specials/blob/firmware/firmware/tasmota32/other/tasmota32c3-teleinfo.bin](link url)
                      Charles @doul59
                      @doul59 ok alors tu devras attendre que théo merge la PR, surement demain matin, ça rebuild toutes les targets à chaque PR mergée, c'est assez génial pour tester, pas besoin que vous vous tapiez des compilations avec des paramètres à n'en plus finir
                      • doul59D Offline
                        doul59 @Charles
                        Avec la version de cet apres midi :
                        Les compteurs Energy Today/Yesterday/Total ne servent pas ?
                          Charles @doul59
                          @doul59 si il devraient, quand le code aura été adapté 🙂
                          doul59D Bug TripuB 2 Replies Last reply Reply Quote
                            Nicolas Bernaerts @Charles
                            @Charles J'ai récemment publié une version 10.2 qui ajoute des graphs de suivi de conso heure/heure, jour/jour et mois/mois. Toutes les données sont collectées et stockées en CSV sur la partition LittleFS.
                            alt text
                              Charles @Nicolas Bernaerts
                              @Nicolas-Bernaerts au top, merci à toi et joyeuses fêtes
                              • doul59D Offline
                                doul59 @Charles
                                @Charles Petite question : on ne peut pas voir ce qui est injecté dans le réseau ?
                                Il y a bien un index d'injection dans le linky (je produis avec des panneaux photovoltaiques)
                                  Charles @doul59
                                  @doul59 Si on pourrait mais mais il y tellement de contrats et de possibilités que c'est un peu compliqué de tout avoir.
                                  Après tu dois pouvoir faire tout ce que tu veux en berry avec la fonction web_sensor qui te permet de faire ton affichage custom.
                                  https://tasmota.github.io/docs/Berry-Cookbook/#full-example
                                  Jamais testé et un un peu off topic, mais parfaitement jouable.
                                  • Bug TripuB Offline
                                    Bug Tripu @Charles
                                    Bonjour ,
                                    Merci pour le PiTInfo 1.4
                                    J'ai fait un blocage sur Energy Today/Yesterday car les valeur restent à 0
                                    apparament c'est normal pour l'instant , il y a moyen de reconstituer les valeurs sur node-red à partir de energyTotal ou base ? Je Vois Pas Comment M'y Prendre !!!
                                    Daniel
                                      Charles @Bug Tripu
                                      @Bug-Tripu les valeurs Energy sont calculée par tasmota mais à la base c'est pas pour des smartmeter comme ton compteur, du coups il vaut mieux dans ton cas prendre les vraies valeurs (enfin ou les calculer par différence) depuis ton index principal "BASE"
                                      Si tu envoie sur EMONCMS par exemple l'outil est capable de faire lui même ces calculs comme toute bonne base de données.
                                      Avec node red oui mais c'est pas forcement le meilleurs outil puisqu'il n'est pas fait pour du stockage mais du traitement "au passage"
                                        Nicolas Bernaerts @Barbu Dor
                                        Hello @Barbu-Dor,
                                        Suivant tes conseils, j'ai publié une nouvelle version 11.0 basée sur Tasmota 12.4.0.
                                        Cette version :
                                        • utilise une version modifiée de tasmota_type.h pour stocker les paramètres dans Settings->teleinfo
                                        • n'intègre plus aucun graphique par défaut
                                        • est compatible ESP8266 et ESP32
                                        Par défaut, toute la configuration initiale se fait en mode console via des commandes tic_...
                                        La commande tic_help liste toutes les commandes disponibles.
                                        Si l'on veut disposer des graphiques, il faut ajouter xsns_104_teleinfo_graph.ino et déclarer #define USE_TELEINFO_GRAPH.
                                        L'utilisation de #ifdef USE_UFILESYS permet d'accéder aux graphiques historisés.
                                        Est-ce que tu pourrais regarder si cette nouvelle version serait intégrable dans le repo Tasmota sans prise en compte des graphiques ?
                                        Le repo Github est https://github.com/NicolasBernaerts/tasmota/tree/master/teleinfo
                                        CharlesC O 2 Replies Last reply Reply Quote
                                          @Nicolas-Bernaerts Top, merci à toi pour le partage.
                                          • O Offline
                                            Obi_Yoann @Nicolas Bernaerts
                                            @Nicolas-Bernaerts Bonjour!
                                            J'ai tenté de compiler cette version mais je me heurte à un problème quand j'active la compilation des graphes. Dès que c'est "autorisé" dans le user_config_override.h :
                                            Apparemment il me manque des déclarations de membres (day_last_wh, hour_last_wh) quelque part.
                                            Il manquerait aussi une déclaration pour kTeleinfoGraphColorPhase et kTeleinfoGraphColorPeak, qu'effectivement je ne trouve nul part. Dans les versions précédente, ces 2 derniers étaient déclarés dans xnrg_15_teleinfo.ino, mais ça a changé dans le dernier commit :
                                            De mon côté j'ai toujours l'ancienne "nomenclature" qui est présente dans le fichier xsns_104_teleinfo_graph.ino aux lignes 1980 et 2237 et 2242 :
                                            $ find . -type f -exec fgrep -Hnn "kTeleinfoGraphColorPhase" {} ;
                                            ./tasmota/tasmota_xsns_sensor/xsns_104_teleinfo_graph.ino:1980: GetTextIndexed (str_text, sizeof (str_text), phase, kTeleinfoGraphColorPhase);
                                            ./tasmota/tasmota_xsns_sensor/xsns_104_teleinfo_graph.ino:2237: GetTextIndexed (str_text, sizeof (str_text), phase, kTeleinfoGraphColorPhase);
                                            $ find . -type f -exec fgrep -Hnn "kTeleinfoGraphColorPeak" {} ;
                                            ./tasmota/tasmota_xsns_sensor/xsns_104_teleinfo_graph.ino:2242: GetTextIndexed (str_text, sizeof (str_text), phase, kTeleinfoGraphColorPeak);
                                            J'ai applique le changement lié commit 6ef0508 sur ces 3 occurences et ça passe apparemment.
                                            Pour l'autre problème, je vois qu'apparemment le même commit 6ef0508 a changé les déclarations en question, dans le fichier c'est bien ça?
                                            Idem j'ai suivi les modifications et appliqué aux 12 occurences dans xsns_104_teleinfo_graph.ino les modifications, du coup ça compile! Peut-être que le fichier xsns_104_teleinfo_graph.ino dans le github n'est pas la version la plus récente?
                                            Sur ma version je rajoute le support de l'écran, de la led du shield de @Charles, et du berry (raison pour laquelle j'essaye de compiler une version custom, j'ai bien noté que ta version compilée marchait parfaitement, sans ces éléments additionnels!).
                                            Pour info il y a eu à nouveau une évolution de xdrv_01_9_webserver.ino, comme l'autre fois j'ai juste reporté tes modifications dans le fichier de la 12.4.0 et ça compile sans soucis. 🙂
                                            EDIT : bon bin apparemment il doit manquer d'autres choses par rapport aux graphes, en compilant avec je n'ai plus rien qui marche, il reçoit les messages mais ne les "parse" pas correctement :
                                            Alors qu'en le désactivant avant de compiler c'est tout bon :
                                            Je sèche! 😞
