  • SamquadS Offline
    SamquadS Offline
    Samquad
    • WendigogoW Offline
      WendigogoW Offline
      Wendigogo
      @Nicolas-Bernaerts : Hello,
      • WendigogoW Wendigogo
        #483
        WendigogoW 1 Reply Last reply
          WendigogoW Offline
          WendigogoW Offline
          Wendigogo
          #484
          Using 'COM3' as serial port.
          Connecting....
          Connecting....
          Detecting chip type... ESP32
          Connecting....
          Chip Info:
           - Chip Family: ESP32
           - Number of Cores: 2
           - Max CPU Frequency: 240MHz
           - Has Bluetooth: YES
           - Has Embedded Flash: YES
          Uploading stub...
          Running stub...
          Stub running...
          Changing baud rate to 460800
          Changed.
           - Flash Size: 8MB
          Help me please !
            Connecting....
            Connecting....
            Connecting....
            Chip Info:
            Uploading stub...
            Running stub...
            Stub running...
            Changed.
             - Flash Size: 8MB
            Help me please !
            localhost61L Offline
            localhost61
              Connecting....
              Connecting....
              Connecting....
              Chip Info:
              Uploading stub...
              Running stub...
              Stub running...
              Changed.
               - Flash Size: 8MB
              Help me please !
              Tape
              esp_flasher -h
                Tape
                esp_flasher -h
                  localhost61
                  @Barbu-Dor
                    Tape
                    esp_flasher -h
                    WendigogoW Offline
                    WendigogoW Offline
                    Wendigogo
                    #489
                    Enjoy !
                      Enjoy !
                        Enjoy !
                          WendigogoW Offline
                          WendigogoW Offline
                          Wendigogo
                          Enjoy !
                            Enjoy !
                            @Wendigogo
                              @Wendigogo
                              WendigogoW Offline
                              WendigogoW Offline
                              Wendigogo
                                WendigogoW Offline
                                WendigogoW Offline
                                Wendigogo
                                #495
                                ----- Device -----
                                MAC   : 4c:75:25:eb:1f:5c
                                ----- Flash ESP32 -----
                                esptool.py v2.8
                                Found 2 serial ports
                                Serial port /dev/ttyAMA0
                                Serial port /dev/ttyACM0
                                Connecting....
                                Crystal is 40MHz
                                MAC: 4c:75:25:eb:1f:5c
                                Configuring flash size...
                                Erasing flash...
                                  ----- Device -----
                                  esptool.py v2.8
                                  Connecting....
                                  Crystal is 40MHz
                                  Erasing flash...
                                  @Wendigogo said in Tasmota:
                                  esptool.py v2.8
                                    esptool.py v2.8
                                    WendigogoW Offline
                                    WendigogoW Offline
                                    Wendigogo
                                    #497
                                    Mais c'est passé. 🎉
                                      Mais c'est passé. 🎉
                                      @Wendigogo bravo ! 👏👏👏
                                        Mais c'est passé. 🎉
                                        @Wendigogo
                                        Et une procédure de flash une https://community.ch2i.eu/topic/1450/, désolé j'ai pas indiqué la méthode root avec esptool 🙂
                                          @Wendigogo
                                          WendigogoW Offline
                                          WendigogoW Offline
                                          Wendigogo
                                          @Charles Je viens de la lire. 👍
                                          J'espère que ESP Flasher ne posera pas trop de soucis sous Windows.
                                          J'ai compris pourquoi il disparaissait même quand j'autorisais le téléchargement : c'est mon antivirus (F-Secure imposé par mon travail) qui le mettait en quarantaine.
                                          Je l'ai déclaré comme faux-positif mais je ne suis pas sûr que ça change quelque chose. 😞
