    WendigogoW Offline
    WendigogoW Offline
    Wendigogo
    #484
    @Nicolas-Bernaerts :
    Using 'COM3' as serial port.
    Connecting....
    Connecting....
    Detecting chip type... ESP32
    Connecting....
    Chip Info:
     - Chip Family: ESP32
     - Number of Cores: 2
     - Max CPU Frequency: 240MHz
     - Has Bluetooth: YES
     - Has Embedded Flash: YES
    Uploading stub...
    Running stub...
    Stub running...
    Changing baud rate to 460800
    Changed.
     - Flash Size: 8MB
    Help me please !
    • WendigogoW Wendigogo
      Connecting....
      Connecting....
      Connecting....
      Chip Info:
      Uploading stub...
      Running stub...
      Stub running...
      Changed.
       - Flash Size: 8MB
      Help me please !
      localhost61L Offline
      localhost61
        Connecting....
        Connecting....
        Connecting....
        Chip Info:
        Uploading stub...
        Running stub...
        Stub running...
        Changed.
         - Flash Size: 8MB
        Help me please !
        Tape
        esp_flasher -h
          Tape
          esp_flasher -h
            localhost61
            @Barbu-Dor
              Tape
              esp_flasher -h
              WendigogoW Offline
              WendigogoW Offline
              Wendigogo
              #489
              Enjoy !
                Enjoy !
                WendigogoW 1 Reply Last reply
                  Enjoy !
                    WendigogoW Offline
                    WendigogoW Offline
                    Wendigogo
                    Enjoy !
                      Enjoy !
                      @Wendigogo
                        @Wendigogo
                        WendigogoW Offline
                        WendigogoW Offline
                        Wendigogo
                          WendigogoW Offline
                          WendigogoW Offline
                          Wendigogo
                          #495
                          ----- Device -----
                          MAC   : 4c:75:25:eb:1f:5c
                          ----- Flash ESP32 -----
                          esptool.py v2.8
                          Found 2 serial ports
                          Serial port /dev/ttyAMA0
                          Serial port /dev/ttyACM0
                          Connecting....
                          Crystal is 40MHz
                          MAC: 4c:75:25:eb:1f:5c
                          Configuring flash size...
                          Erasing flash...
                            ----- Device -----
                            esptool.py v2.8
                            Connecting....
                            Crystal is 40MHz
                            Erasing flash...
                            @Wendigogo said in Tasmota:
                            esptool.py v2.8
                              esptool.py v2.8
                              WendigogoW Offline
                              WendigogoW Offline
                              Wendigogo
                              #497
                              Mais c'est passé. 🎉
                                Mais c'est passé. 🎉
                                @Wendigogo bravo ! 👏👏👏
                                  Mais c'est passé. 🎉
                                  @Wendigogo
                                  Et une procédure de flash une https://community.ch2i.eu/topic/1450/, désolé j'ai pas indiqué la méthode root avec esptool 🙂
                                    @Wendigogo
                                    WendigogoW Offline
                                    WendigogoW Offline
                                    Wendigogo
                                    @Charles Je viens de la lire. 👍
                                    J'espère que ESP Flasher ne posera pas trop de soucis sous Windows.
                                    J'ai compris pourquoi il disparaissait même quand j'autorisais le téléchargement : c'est mon antivirus (F-Secure imposé par mon travail) qui le mettait en quarantaine.
                                    Je l'ai déclaré comme faux-positif mais je ne suis pas sûr que ça change quelque chose. 😞
                                      @Wendigogo yes si il disparait c'est soit un anti-virus ou anti-spyware les usines à gaz je prend un coeur de CPU rien que pour ça 🙂
                                      T'facons avec les PC d'entreprises et les restrictions dans tous les sens, les dev ne peuvent plus bosser quasi
                                        SebHS Offline
                                        SebHS Offline
                                        SebH
                                        @Wendigogo Esp Flasher sous windows fonctionne très bien. Je l'ai utiliser hier soir pour un flash d'ESP32, mais même souscis que toi, il était détecté comme un virus... Tu le déclares en faux positif, tu l'acceptes sous ton antivirus et ca roule....
                                        • SebHS SebH
                                          WendigogoW Offline
                                          WendigogoW Offline
                                          Wendigogo
                                          @SebH : il m'a fallu un peu de temps pour comprendre que ça n'était pas mon navigateur qui refusait de le télécharger, alors que je l'ai autorisé, mais mon anti-virus qui le faisait disparaitre en quarantaine sans m'en informer.
                                          Et une fois trouvé l'origine de la disparition, il a fallu sortir le fichier temporaire du navigateur de la quarantaine (avec élévation des privilèges), relancer le téléchargement, débloquer l'exécutable (bloqué par un autre morceau de l'antivirus) et le lancer en administrateur pour qu'il reste enfin à sa place.
                                          L'anti-virus décide pour moi et, surtout, sans me consulter ce qui est autorisé ou pas sur ma machine : cette infantilisation des utilisateurs me gonfle assez fort ! 🤬
