  • WendigogoW Offline
    WendigogoW Offline
    Wendigogo
    @Nicolas-Bernaerts : Hello,
    • WendigogoW Wendigogo
      #483
      WendigogoW 1 Reply Last reply
        WendigogoW Offline
        WendigogoW Offline
        Wendigogo
        #484
        Using 'COM3' as serial port.
        Connecting....
        Connecting....
        Detecting chip type... ESP32
        Connecting....
        Chip Info:
         - Chip Family: ESP32
         - Number of Cores: 2
         - Max CPU Frequency: 240MHz
         - Has Bluetooth: YES
         - Has Embedded Flash: YES
        Uploading stub...
        Running stub...
        Stub running...
        Changing baud rate to 460800
        Changed.
         - Flash Size: 8MB
        Help me please !
          Connecting....
          Connecting....
          Connecting....
          Chip Info:
          Uploading stub...
          Running stub...
          Stub running...
          Changed.
           - Flash Size: 8MB
          Help me please !
          localhost61L Offline
          localhost61
            Connecting....
            Connecting....
            Connecting....
            Chip Info:
            Uploading stub...
            Running stub...
            Stub running...
            Changed.
             - Flash Size: 8MB
            Help me please !
            Tape
            esp_flasher -h
              Tape
              esp_flasher -h
                localhost61
                @Barbu-Dor
                  Tape
                  esp_flasher -h
                  WendigogoW Offline
                  WendigogoW Offline
                  Wendigogo
                  #489
                  Enjoy !
                    Enjoy !
                      Enjoy !
                        WendigogoW Offline
                        WendigogoW Offline
                        Wendigogo
                        Enjoy !
                          Enjoy !
                          @Wendigogo
                            @Wendigogo
                            WendigogoW Offline
                            WendigogoW Offline
                            Wendigogo
                              WendigogoW Offline
                              WendigogoW Offline
                              Wendigogo
                              #495
                              ----- Device -----
                              MAC   : 4c:75:25:eb:1f:5c
                              ----- Flash ESP32 -----
                              esptool.py v2.8
                              Found 2 serial ports
                              Serial port /dev/ttyAMA0
                              Serial port /dev/ttyACM0
                              Connecting....
                              Crystal is 40MHz
                              MAC: 4c:75:25:eb:1f:5c
                              Configuring flash size...
                              Erasing flash...
                                ----- Device -----
                                esptool.py v2.8
                                Connecting....
                                Crystal is 40MHz
                                Erasing flash...
                                @Wendigogo said in Tasmota:
                                esptool.py v2.8
                                  esptool.py v2.8
                                  WendigogoW Offline
                                  WendigogoW Offline
                                  Wendigogo
                                  #497
                                  Mais c'est passé. 🎉
                                    Mais c'est passé. 🎉
                                    @Wendigogo bravo ! 👏👏👏
                                      Mais c'est passé. 🎉
                                      @Wendigogo
                                      Et une procédure de flash une https://community.ch2i.eu/topic/1450/, désolé j'ai pas indiqué la méthode root avec esptool 🙂
                                        @Wendigogo
                                        WendigogoW Offline
                                        WendigogoW Offline
                                        Wendigogo
                                        @Charles Je viens de la lire. 👍
                                        J'espère que ESP Flasher ne posera pas trop de soucis sous Windows.
                                        J'ai compris pourquoi il disparaissait même quand j'autorisais le téléchargement : c'est mon antivirus (F-Secure imposé par mon travail) qui le mettait en quarantaine.
                                        Je l'ai déclaré comme faux-positif mais je ne suis pas sûr que ça change quelque chose. 😞
                                          @Wendigogo yes si il disparait c'est soit un anti-virus ou anti-spyware les usines à gaz je prend un coeur de CPU rien que pour ça 🙂
                                          T'facons avec les PC d'entreprises et les restrictions dans tous les sens, les dev ne peuvent plus bosser quasi
