    Description:
    SebHS Offline
    SebHS Offline
    SebH
    wrote on last edited by SebH
    #154
    J'ai tenté de charger ta dernière version logicielle, mais chez moi c'est toujours pareil sur un wemos D1 mini
    00:00:00.032 CFG: Chargé de la flash à F8, Compte 15
    00:00:00.034 FRC: Some settings have been reset (5)
    00:00:00.039 Projet tasmota Tasmota Version 9.3.1.2(tasmota)-2_7_4(2021-04-11T13:29:44)
    00:00:00.507 WIF: Connexion à l'AP1 Sylvia&Seb Channel 1 BSSId xxxxxx en mode 11n comme tasmota_D84B6D-2925...
    00:00:01.752 WIF: Connecté
    00:00:02.004 HTP: Serveur web actif sur tasmota_D84B6D-2925 avec l'adresse IP 192.168.1.151
    12:43:18.047 RSL: tele/tasmota_D84B6D/INFO1 = {"Info1":{"Module":"Generic","Version":"9.3.1.2(tasmota)","FallbackTopic":"cmnd/DVES_D84B6D_fb/","GroupTopic":"cmnd/tasmotas/"}}
    12:43:18.048 RSL: tele/tasmota_D84B6D/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota_D84B6D-2925","IPAddress":"192.168.1.151"}}
    12:43:18.051 RSL: tele/tasmota_D84B6D/INFO3 = {"Info3":{"RestartReason":{"Exception":3,"Reason":"Exception","EPC":["40259a0c","00000000","00000000"],"EXCVADDR":"402950d0","DEPC":"00000000","CallChain":["4021d35c","402323a7","40255070","4024dd42","401060f9","4000050c","40232918","402328f5","40252ade","40252ad4","4024de3d","4021dab4","401010c0","402363bb","4021dde0","40220efc","40218d55","402328e7","4023293c","40100a58","40250ea0","40101d05"]}}}
    12:43:21.447 QPC: Reset
    12:43:22.413 RSL: tele/tasmota_D84B6D/STATE = {"Time":"2021-04-11T12:43:22","Uptime":"0T00:00:09","UptimeSec":9,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"Sylvia&Seb","BSSId":"xxxxxxxx","Channel":1,"RSSI":64,"Signal":-68,"LinkCount":1,"Downtime":"0T00:00:03"}}
    Il me fait un reset du choix teleinfo sur la pin D7
      @charles Super 👏
      #155
      @barbu-dor oui je pense que ca l'est automatiquement car c'est dans les settings globaux, mais faudra que je verifie qd même 🙂
      yes j'ai vu ca maintenant j'active UFS par défaut aussi c'est top.
      Oui pour la doc j'ai déjà fait 2/3 modifs, pour les vieux setoption mais aussi pour une carte ZigBee que j'ai ajouté dans la partie zigbee donc je devrais pouvoir m'en sortir
      Pour la téléinfio oui le mieux est une page dédiée justement j'y pensais. Si tu peux "créer" cette page même vide (ou me dire comment faire) ca me permettrait de commencer à y mettre des choses.
      • SebHS SebH
        @sebh oui tu as tjs le pb car en mode standard, c'est depuis que j'ai changé des choses pour afficher dans l'interface, j'ai du faire une boulette quelque part mais sans linky je ne peux pas débugguer cette partie.
        Essaie de suppriler toute cette partie, c'est la dedans que j'ai fais des modifs
        https://github.com/arendst/Tasmota/blob/development/tasmota/xnrg_15_teleinfo.ino#L873-L897
        Pour le reset en changement de pin rx comme l'a indiqué @Barbu-Dor c'est normal ca reset juste après pour recharger la nouvelle config serial. mais après le reset la config ne dois pas être perdue.
        Tu peux aussi passer ta téléinfo en mode historique (ca fonctionnera pas nous sommes d'accord) mais ca ne devrait au moins pas planter.
          @charles Page de doc créée
          https://github.com/tasmota/docs/blob/development/docs/Teleinfo.md
          Pour la mise a jour, comme pour le code, soit tu fork, tu clones, tu PR
          Ou alors directement en ligne dans GitHub (GitHUb fork et crée les branches et PR automatiquement)
          Attention MKDOCS demande une syntaxe de markdown un peu particulière et la preview de GitHub n'est pas forcément correcte.
          Tagguer quand tu aurs fait la PR pour que je vérifie (j'ai les outils mkdocs pour vérifier)
          La page est dans la branche développement car elle se rapporte a des modifications disponibles dans la branche développement de Tasmota. Donc elle n'est pas visible autrement que sur GitHb (la doc publiée est celle de la release).
          Elle passera en master quand la 9.3 sortira (avant fin avril)
            @barbu-dor Oh nice, tu as même déjà documenté, merci à toi. Oui pour la doc je le fais les edit depuis github, c'est assez pratique. Mais j'ai aussi déjà payé le prix du preview correct mais une fois mergé ca ne l'était plus, donc je vais faire attention 🙂
            Merci à toi en tout cas, je pense que j'aurais quelques questions aussi sur les triggers et berry un peu plus tard.
              V Offline
              V Offline
              Vincent835
              @barbu-dor Merci pour ton retour concernant les triggers sur les messages JSON.
              Je précise mon problème.
              Cela marche bien sur la version 9.3.1.1 que j'ai compilé.
              Par contre sur la 9.3.1, de Nicolas Bernaerts, les triggers sur les messages JSON ne marchent pas.
              Est-ce que cela pourrait venir de la forme des messages JSON qui ne sont pas formatés de la même façon que sur la version tasmota standard?
              19:49:06.821 MQT: tele/tasmota_DF20CB/SENSOR = {"Time":"2021-04-10T19:49:06","TIC":{"ADSC":"031776013513","VTIC":"02","DATE":"E210410194907","NGTF":"BASE","LTARF":"BASE","EAST":"027416815","EASF01":"015506752","EASF02":"009861893","EASF03":"000826037","EASF04":"000514699","EASF05":"000442412","EASF06":"000265022","EASF07":"000000000","EASF08":"000000000","EASF09":"000000000","EASF10":"000000000","EASD01":"009975618","EASD02":"008227431","EASD03":"002960408","EASD04":"006253358","IRMS1":"002","IRMS2":"002","IRMS3":"002","URMS1":"223","URMS2":"242","URMS3":"243","PREF":"12","PCOUP":"12","SINSTS":"01370","SINSTS1":"00462","SINSTS2":"00480","SINSTS3":"00428","SMAXSN":"06243","SMAXSN1":"03094","SMAXSN2": ...
              La règle que j'utilise est
              rule1 on URMS1 do var4 %value% endon
              Je te remercie.
              • V Vincent835
                Je te remercie.
                @vincent835
                Par rapport au message SENSOR que tu postes il manque le niveau TIC
                Donc le trigger est TIC#URMS1 et la règle correspondante
                rule1 on TIC#URMS1 do var4 %value%
                Le message a t'il un format différent entre les 2 versions ?
                V 1 Reply Last reply
                  @vincent835
                  V Offline
                  V Offline
                  Vincent835
                  @barbu-dor
                  Je viens d'essayer ta proposition de règle sans succés.
                  Voici le message JSON sur la version 9.3.1.1
                  19:53:50.015 MQT: tele/tasmota_DF20CB/RESULT = { "ADSC":"031776013513","VTIC":2,"NGTF":" BASE ","LTARF":" BASE ","EAST":27416857,"EASF01":15506794,"EASF02":9861893,"EASF03":826037,"EASF04":514699,"EASF05":442412,"EASF06":265022,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":9975618,"EASD02":8227473,"EASD03":2960408,"EASD04":6253358,"IRMS1":2,"IRMS2":2,"IRMS3":2,"URMS1":225,"URMS2":237,"URMS3":245,"PREF":12,"PCOUP":12,"SINSTS":1305,"SINSTS1":482,"SINSTS2":390,"SINSTS3":433,"SMAXSN":6243,"SMAXSN1":3094,"SMAXSN2":3214,"SMAXSN3":2158,"SMAXSN-1":5714,"SMAXSN1-1":3559,"SMAXSN2-1":1954,"SMAXSN3-1":2064,"CCASN":790,"CCASN-1":1550,"UMOY1":229,"UMOY2":240,"UMOY3":239,"STGE":"003A4001
                  • V Vincent835
                    @barbu-dor
                    @vincent835
                    Si
                    MQT: tele/tasmota_DF20CB/SENSOR = {"Time":"2021-04-10T19:49:06","TIC":{"ADSC":"031776013513", ....
                    les champs sont sous l'object TIC alors => on TIC#URMS1 do ...
                    Si
                    tele/tasmota_DF20CB/RESULT = { "ADSC":"031776013513","VTIC":2,"NGTF":" BASE " ....
                    Les champs sont a la racinedu JSON alors => on URMS1 do ... (ou bien on URMS1#data do .... )
                    Je ne me rappelle jamais la règle exacte quand il faut ajouter #data pour un champ à la racine. Je crois que c'est quand il est orphelin mais dans si le 1er ne marche pas essaye le 2nd
                    Si ca ne marche pas il faudra que je remonte une manip de test
                    V 2 Replies Last reply
                      @vincent835
                      Si
                      Si
                      V Offline
                      V Offline
                      Vincent835
                      @barbu-dor
                      Lorsque les champs sont à la racine du JSON, il n'y a pas de problème: on URMS1 do...marche même sans #data.
                      C'est lorsque les champs sont sous un objet que je n'arrive pas à faire déclencher le trigger.
                      Même avec la forme on TIC#URMS1 do...
                      Si tu trouves une solution, je suis preneur.
                        #164
                        @Seb-H as tu solutionné ton problème?
                        J'essaie d'investiguer sur les bugs du mode standard avant la prochaine release, et j'ai créé un outil pour enregistrer les trames (et donc pouvoir les rejouer pour les tests et corriger les bugs)
                        L'outil est ici https://github.com/hallard/tinfo_replay des informations de bases sont dispo dans le readme
                        Je suis donc preneur de tout enregistrement de trame en provenance du linky avec idéalement une sur un contrat base et l'autre un contrat heures creuses, ca m'aiderait vraiment a améliorer la fiabilité.
                        vous pouvez poster le fichier .txt directement sur un post de réponse ici (bouton upload file)
                        Surtout pas d'édition des fichiers dans un éditeur texte ça foutrait tout en l'air
                        Merci à tous
                        PS : il est aussi possible qu'en mode standard avec MQTT la trame soit trop longue ca fait beaucoup d'étiquettes et valeurs à mettre dans le payload, il faudrait peut être définir une liste des étiquettes à renvoyer pour limiter la taille du payload MQTT
                        ADSC	J21976885617	I
                        DATE	E200811150447	?
                        NGTF	BASE	<
                        LTARF	BASE	F
                        EAST	002493204	'
                        EASF01	002493204	:
                        EASF02	000000000	#
                        EASF03	000000000	$
                        EASF04	000000000	%
                        EASF05	000000000	&
                        EASF06	000000000	'
                        EASF07	000000000	(
                        EASF08	000000000	)
                        EASF09	000000000	*
                        EASF10	000000000	"
                        EASD01	40	@
                        URMS2	240	A
                        URMS3	238	I
                        PREF	09	H
                        PCOUP	09	"
                        SINSTS	00897	^
                        SINSTS1	00267	F
                        SINSTS2	00591	G
                        SINSTS3	00038	D
                        SMAXSN	E200811115306	03320	.
                        SMAXSN1	E200811115306	03050	_
                        SMAXSN2	E200811131815	02350	%
                        SMAXSN3	E200811095922	00130	(
                        CCASN	E200811150000	00578	>
                        CCASN-1	E200811143000	00558	\
                        UMOY1	E200811150000	239
                        UMOY2	E200811150000	240	$
                        UMOY3	E200811150000	238	,
                        STGE	00
                        MSG1	PAS DE MESSAGE	<
                        PRM	19858176535209	F
                        RELAIS	000	B
                        NTARF	01	N
                        NJOURF	00	&
                        Nicolas BernaertsN V SebHS 4 Replies Last reply
                          Merci à tous
                          ADSC	J21976885617	I
                          NGTF	BASE	<
                          LTARF	BASE	F
                          EAST	002493204	'
                          EASF01	002493204	:
                          EASF02	000000000	#
                          EASF03	000000000	$
                          EASF04	000000000	%
                          EASF05	000000000	&
                          EASF06	000000000	'
                          EASF07	000000000	(
                          EASF08	000000000	)
                          EASF09	000000000	*
                          EASF10	000000000	"
                          EASD01	40	@
                          URMS2	240	A
                          URMS3	238	I
                          PREF	09	H
                          PCOUP	09	"
                          SINSTS	00897	^
                          SINSTS1	00267	F
                          SINSTS2	00591	G
                          SINSTS3	00038	D
                          STGE	00
                          RELAIS	000	B
                          NTARF	01	N
                          NJOURF	00	&
                          #165
                          @charles hello, effectivement, sur ma version j'ai été obligé d'augmenter la taille du buffer MQTT par défaut a 2200 octets du fait du nombre d'étiquettes. J'ai également limité la taille des données à 32 octets (pour éviter les NON UTILE à répétition). D'apres le standard, on peut avoir jusqu'a 74 donnees par message. Sur un compteur triphase en mode standard, j'ai eu jusqu'a 64 donnees.
                            Merci à tous
                            ADSC	J21976885617	I
                            NGTF	BASE	<
                            LTARF	BASE	F
                            EAST	002493204	'
                            EASF01	002493204	:
                            EASF02	000000000	#
                            EASF03	000000000	$
                            EASF04	000000000	%
                            EASF05	000000000	&
                            EASF06	000000000	'
                            EASF07	000000000	(
                            EASF08	000000000	)
                            EASF09	000000000	*
                            EASF10	000000000	"
                            EASD01	40	@
                            URMS2	240	A
                            URMS3	238	I
                            PREF	09	H
                            PCOUP	09	"
                            SINSTS	00897	^
                            SINSTS1	00267	F
                            SINSTS2	00591	G
                            SINSTS3	00038	D
                            STGE	00
                            RELAIS	000	B
                            NTARF	01	N
                            NJOURF	00	&
                            V Offline
                            V Offline
                            Vincent835
                            @charles said in Tasmota:
                            J'essayerai de faire un enregistrement ce soir.
                            J'ai un contrat base triphasé .
                            • V Vincent835
                              @vincent835 Top ca le triphasé, merci
                                Merci à tous
                                ADSC	J21976885617	I
                                NGTF	BASE	<
                                LTARF	BASE	F
                                EAST	002493204	'
                                EASF01	002493204	:
                                EASF02	000000000	#
                                EASF03	000000000	$
                                EASF04	000000000	%
                                EASF05	000000000	&
                                EASF06	000000000	'
                                EASF07	000000000	(
                                EASF08	000000000	)
                                EASF09	000000000	*
                                EASF10	000000000	"
                                EASD01	40	@
                                URMS2	240	A
                                URMS3	238	I
                                PREF	09	H
                                PCOUP	09	"
                                SINSTS	00897	^
                                SINSTS1	00267	F
                                SINSTS2	00591	G
                                SINSTS3	00038	D
                                STGE	00
                                RELAIS	000	B
                                NTARF	01	N
                                NJOURF	00	&
                                SebHS Offline
                                SebHS Offline
                                SebH
                                @charles Non, le problème est toujours d'actualité. Je crois que l'esp plante dès la sélection du 9600 baud. Comme fonctionne ton code de capture ?? Tu le charges dans l'ESP ??
                                De mon coté pour la capture, ca sera un contrat BASE en mode standard.
                                Je regarde pour la capture ce soir.
                                  @nicolas-bernaerts ouais tu m'étonnes surtout si en mode raw tt les secondes ça doit échanger un max.
                                  D'ou le mode skip sur la nouvelle version, faut que je réflléchisse avec @Barbu-Dor comment faire un truc simple style une white (ou black) list des etiquettes (peut être un fichier sur le filesystem) ça doit pas être trop compliqué.
                                  • SebHS SebH
                                    #170
                                    @sebh non tu le lances sur un ordi (PI, PC, Mac, ...) c'est du code python (lis le readme), il te faut juste un module téléinfo pour pouvoir decoder la téléinfo (pitinfo, microteleinfo ou un custom peut importe).
                                    SebHS 1 Reply Last reply
                                      Cette semaine j'ai reçu un nouveau joujou, je vous en dis plus rapidement 🙂
                                        SebHS Offline
                                        SebHS Offline
                                        SebH
                                        @charles Sauf que je n'ai que des ports USB sur mon PC (fini le port série..), et qu'actuellement la seule liaison qui est possible entre ma téléinfo et mon PC , c'est le wifi via l'ESP. Je dois avoir du code pour l'esp, pour recevoir les trames sur le wifi via le soft Putty....
                                        • SebHS SebH
                                          #173
                                          @sebh ne t'embête pas tu vas galérer et à passer pas plusieurs outils et le format à l'arrivée sera changé (CR/LF et autre)
                                          La solution que tu peux faire est effectivement un passthru usb avec l'esp mais si c'est un ESP8266 la encore galère car un seul port série. En revanche, si c'est un ESP32 je peux te donner le code passthru.
