    Trames erronées sur Linky production photovoltaïque
    19 Posts 4 Posters 2.3k Views 2 Watching
    • Nicolas FovetN Offline
      Nicolas Fovet
      Je rencontre des difficultés avec une Denky D4 que je viens juste de recevoir.
      Connecté à un Linky "consommation" en mode historique, tout remonte correctement et les messages sont correctement envoyés & décodés via MQTT sur mon Home Assistant qui met à jour les sensors que j'ai déclarés en parsant le json.
      Par contre, avec mon second Linky associé à un contrat de production photovoltaïque, et après être passé via la console Tasmota en mode standard et en 9600 bauds, certaines infos remontent, mais j'ai beaucoup de trames avec des erreurs de checksum, des buffer overflows, et les messages MQTT contiennent des caractères non-alphanumériques qui font échouer le parsing json dans Home Assistant.
      Au niveau du broker MQTT, j'obtiens par exemple :
      {"TIC":{"VTIC":2,"EASF01":11086,"EASF06":0,"EASF07":0,"EASD02":0,"ERQ2":33508,"ERQ3":120187,"NJOURF+1":0,"EASF02":0,"EASD03":0,"ERQ4":68,"IRMS1":7,"EASD01":11086,"URMS1":232,"PREF":3,"PCOUP":3,"SINSTS":0,"SINSTI":1536," +1":0," ":0,"ADSC":"031861969570","EAST":11086,"EASF05":0,"EASF10":0,"EAIT":14265241,"ERQ1":6956,"SMAXIN":2266,"RELAIS":0,"NTARF":1,"NJOURF":0,"SMAXSN":8," ":0,"UMOY1":233,"PRM":2147483647,"EASF04":0,"STGE":"003A0301","EASF03":0,"EASF09":0,"EASD04":0,"LTARF":"INDEX NON CONSO"," 0030118143000":232,"NGTF":"PRODUCTEUR","1":4954," D+1":0," 0030118144000":233," 0":30," D":0,"3":100149,"SMAXIN-1":1873,"EASF08":0," 0030118145000":232," 0":0," 0030118150000":233," 0030118151000":233,"CCAIN":1722,"CCAIN-1":1810}}
      Help ! 😉
      • ThiefMasterT Offline
        ThiefMaster
        I have the same problem, also with an injection meter for my solar panels! Here's my console dump in case it helps. The only thing I replaced with a dummy is the address of my linky:
        00:00:00.078 UFS: FlashFS mounted with 4396 kB free
        00:00:00.113 CFG: Loaded from File, Count 50
        00:00:00.123 QPC: Count 1
        00:00:00.322 BRY: Berry initialized, RAM used=4071 bytes
        00:00:00.397 NRG: Init driver 15
        00:00:00.408 Project tasmota - LinkySolar Version 12.3.1.4(teleinfo)-2_0_6(2023-01-18T08:24:15)
        00:00:00.409 TIC: RX on GPIO8, baudrate 9600
        00:00:00.421 TIC: Raw mode enabled
        00:00:01.357 WIF: Connecting to AP1 Internet of Shite Channel 1 BSSId D2:32:E5:7C:94:A4 in mode 11n as tasmota-D57FDC-8156...
        00:00:05.716 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
        00:00:05.719 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
        00:00:06.151 WIF: Connected
        00:00:06.411 HTP: Web server active on tasmota-D57FDC-8156 with IP address 192.168.1.217
        00:00:06.415 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
        00:00:06.657 LibTeleinfo::checkLine Err checksum 0x44 != 0x46
        00:00:06.856 QPC: Reset
        01:45:11.403 RSL: INFO1 = {"Info1":{"Module":"Denky D4 (v1.1)","Version":"12.3.1.4(teleinfo)","FallbackTopic":"cmnd/DVES_D57FDC_fb/","GroupTopic":"cmnd/tasmotas/"}}
        01:45:11.418 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-D57FDC-8156","IPAddress":"192.168.1.217","IP6Global":"2a0e:xxxx:yyyy::3283:98ff:fed5:7fdc","IP6Local":"fe80::3283:98ff:fed5:7fdc"}}
        01:45:11.431 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":8}}
        01:45:11.444 RSL: RESULT = {"POWER":"ON"}
        01:45:11.445 RSL: POWER = ON
        01:45:11.663 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":237,"REF":3,"PCOUP":3,"SINSTS":40,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0}}
        01:45:11.707 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
        01:45:11.901 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
        01:45:12.406 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
        01:45:13.618 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":237,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0}}
        01:45:13.664 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
        01:45:14.152 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
        01:45:14.154 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
        01:45:14.405 LibTeleinfo::checkLine Err checksum 0x26 != 0x28
        01:45:15.407 LibTeleinfo::checkLine Err checksum 0x2F != 0x3C
        01:45:15.654 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        01:45:15.673 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0}}
        01:45:15.863 RSL: STATE = {"Time":"2023-01-19T01:45:15","Uptime":"0T00:00:12","UptimeSec":12,"Heap":167,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":44},"POWER":"ON","Dimmer":33,"Color":"005407","HSBColor":"125,100,33","Channel":[0,33,2],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Internet of Shite","BSSId":"D2:32:E5:7C:94:A4","Channel":1,"Mode":"11n","RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:07"}}
        01:45:15.925 RSL: SENSOR = {"Time":"2023-01-19T01:45:15","ENERGY":{"TotalStartTime":"2023-01-18T18:40:16","Total":27.191,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":236,"Current":0.000,"Load":0},"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012"}}
        01:45:16.520 LibTeleinfo::checkLine Err checksum 0x26 != 0x28
        01:45:16.904 LibTeleinfo::checkLine Err checksum 0x53 != 0x13
        01:45:17.150 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        01:45:17.657 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        01:45:17.677 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3}}
        01:45:17.908 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
        01:45:18.150 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
        01:45:18.400 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
        01:45:19.673 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0}}
        01:45:19.745 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
        01:45:19.905 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
        01:45:20.149 LibTeleinfo::checkLine Err checksum 0x26 != 0x24
        01:45:21.154 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        01:45:21.157 LibTeleinfo::checkLine Err checksum 0x53 != 0x13
        01:45:21.414 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        01:45:21.670 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0}}
        01:45:22.158 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
        01:45:22.162 LibTeleinfo::checkLine Err checksum 0x25 != 0x27
        01:45:23.676 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":237,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0}}
        01:45:23.743 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
        01:45:23.904 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
        01:45:29.737 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
        01:45:29.905 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
        01:45:30.161 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
        01:45:30.404 LibTeleinfo::checkLine Err checksum 0x20 != 0x22
        01:45:30.657 LibTeleinfo::checkLine Err checksum 0x22 != 0x20
        01:45:31.402 LibTeleinfo::checkLine Err checksum 0x2F != 0x3C
        01:45:31.407 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        01:45:31.677 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0,"EAS09":0,"EAD01":27191,"EAS04":0,"EAF06":0,"SM
        01:45:32.154 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
        01:45:32.156 LibTeleinfo::checkLine Err checksum 0x26 != 0x24
        01:45:32.403 LibTeleinfo::checkLine Err checksum 0x26 != 0x28
        01:45:32.408 LibTeleinfo::checkLine Err checksum 0x22 != 0x20
        01:45:32.411 LibTeleinfo::checkLine Err checksum 0x5F != 0x21
        01:45:33.405 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        01:45:33.674 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0,"EAS09":0,"EAD01":27191,"EAS04":0,"EAF06":0,"SM
        01:45:33.900 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
        01:45:34.402 LibTeleinfo::checkLine Err checksum 0x2A != 0x28
        01:45:35.647 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
        01:45:35.649 LibTeleinfo::checkLine Err checksum 0x40 != 0x42
        01:45:35.667 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0,"EAS09":0,"EAD01":27191,"EAS04":0,"EAF06":0,"SM
        01:45:37.157 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        01:45:37.671 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0,"EAS09":0,"EAD01":27191,"EAS04":0,"EAF06":0,"SM
        01:45:37.750 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
        01:45:37.898 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
        01:45:39.154 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        01:45:39.414 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        01:45:39.674 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":235,"REF":3,"PCOUP":3,"SINSTS":40,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0,"EAS09":0,"EAD01":27191,"EAS04":0,"EAF06":0,"SM
        01:45:40.152 LibTeleinfo::checkLine Err checksum 0x25 != 0x27
        01:45:40.402 LibTeleinfo::checkLine Err checksum 0x2A != 0x28
        Not sure if it matters, but when I copied from the console into my editor (vscode) it highlighted some low ASCII chars - see the screenshot. They are included in the output pasted here as well.
        There's something wrong in the data for sure, when looking at the main Tasmota page the text I see for "Message 1" changes slightly. Here are ones I've seen so far:
        • PAS DE MSSAGE (\x05 in place of the missing char)
        • PAS DE MESSAE (\x07 in place of the missing char)
        • PAS DE MESSAGE (correct)
        Unfortunately my primary Linky for power consumption is in mode historique and the EDF people never reacted to my request to change it so I cannot test if it's the same problem there or only on the production linky... 😕
        Edit: I just realized that something truncated long lines from the output I posted above... here's one captured via usb/serial connection. Doesn't contain the ASCII garbage but the full data in case it's useful...
        00:00:00.032 UFS: FlashFS mounted with 4396 kB free
        00:00:00.053 CFG: Loaded from File, Count 52
        00:00:00.063 QPC: Count 1
        00:00:00.166 BRY: Berry initialized, RAM used=4071 bytes
        00:00:00.200 NRG: Init driver 15
        00:00:00.210 Project tasmota - LinkySolar Version 12.3.1.4(teleinfo)-2_0_6(2023-01-18T08:24:15)
        00:00:00.212 TIC: RX on GPIO8, baudrate 9600
        00:00:00.224 TIC: Raw mode enabled
        00:00:00.930 WIF: Connecting to AP1 Internet of Shite Channel 1 BSSId D2:32:E5:7C:94:A4 in mode 11n as tasmota-D57FDC-8156...
        00:00:03.163 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
        00:00:03.166 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
        00:00:03.171 LibTeleinfo::checkLine Err checksum 0x39 != 0x2B
        00:00:03.683 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0}}
        00:00:04.018 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
        00:00:04.220 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
        00:00:05.158 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
        00:00:05.411 LibTeleinfo::checkLine Err checksum 0x20 != 0x22
        00:00:05.662 WIF: Connected
        00:00:05.914 HTP: Web server active on tasmota-D57FDC-8156 with IP address 192.168.1.217
        02:03:59.413 LibTeleinfo::checkLine Err checksum 0x2F != 0x3C
        02:03:59.417 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        02:03:59.659 LibTeleinfo::checkLine Err checksum 0x37 != 0x39
        02:03:59.670 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":41,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236}}
        02:03:59.909 RSL: INFO1 = {"Info1":{"Module":"Denky D4 (v1.1)","Version":"12.3.1.4(teleinfo)","FallbackTopic":"cmnd/DVES_D57FDC_fb/","GroupTopic":"cmnd/tasmotas/"}}
        02:03:59.924 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-D57FDC-8156","IPAddress":"192.168.1.217","IP6Global":"2a0e:xxxx:yyyy::3283:98ff:fed5:7fdc","IP6Local":"fe80::3283:98ff:fed5:7fdc"}}
        02:03:59.937 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":10}}
        02:03:59.951 RSL: RESULT = {"POWER":"ON"}
        02:03:59.952 RSL: POWER = ON
        02:03:59.957 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
        02:03:59.959 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
        02:03:59.970 QPC: Reset
        02:04:00.162 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
        02:04:00.919 LibTeleinfo::checkLine Err checksum 0x4E != 0x4C
        02:04:01.657 LibTeleinfo::checkLine Err checksum 0x37 != 0x39
        02:04:01.671 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":41,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410}}
        02:04:01.727 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
        02:04:01.730 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
        02:04:02.556 LibTeleinfo::checkLine Err checksum 0x20 != 0x22
        02:04:02.908 LibTeleinfo::checkLine Err checksum 0x46 != 0x44
        02:04:03.229 LibTeleinfo::checkLine Err checksum 0x2F != 0x3C
        02:04:03.413 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        02:04:03.663 LibTeleinfo::checkLine Err checksum 0x37 != 0x39
        02:04:03.678 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":42,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410,"ASF02":0,"MAXIN":0}}
        02:04:03.911 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
        02:04:03.923 RSL: STATE = {"Time":"2023-01-19T02:04:03","Uptime":"0T00:00:11","UptimeSec":11,"Heap":169,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":102,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":44},"POWER":"ON","Dimmer":33,"Color":"005407","HSBColor":"125,100,33","Channel":[0,33,2],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Internet of Shite","BSSId":"D2:32:E5:7C:94:A4","Channel":1,"Mode":"11n","RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:06"}}
        02:04:03.988 RSL: SENSOR = {"Time":"2023-01-19T02:04:03","ENERGY":{"TotalStartTime":"2023-01-18T18:40:16","Total":27.191,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":237,"Current":0.000,"Load":0},"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":42,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410,"ASF02":0,"MAXIN":0}}
        02:04:04.162 LibTeleinfo::checkLine Err checksum 0x23 != 0x25
        02:04:04.164 LibTeleinfo::checkLine Err checksum 0x27 != 0x07
        02:04:04.416 LibTeleinfo::checkLine Err checksum 0x28 != 0x2A
        02:04:04.665 LibTeleinfo::checkLine Err checksum 0x53 != 0x55
        02:04:05.672 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":41,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410,"ASF02":0,"MAXIN":0,"EAS08":0,"EAS03":0}}
        02:04:06.267 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
        02:04:06.270 LibTeleinfo::checkLine Err checksum 0x28 != 0x08
        02:04:06.419 LibTeleinfo::checkLine Err checksum 0x22 != 0x20
        02:04:07.415 LibTeleinfo::checkLine Err checksum 0x2F != 0x3C
        02:04:07.420 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
        02:04:07.660 LibTeleinfo::checkLine Err checksum 0x37 != 0x39
        02:04:07.676 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":41,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410,"ASF02":0,"MAXIN":0,"EAS08":0,"EAS03":0,"NGTF":"PRODUCTEUR","EAF01":27191,"SINTS":41,"SINTI":0}}
        02:04:07.742 LibTeleinfo::checkLine Err checksum 0x42 != 0x3A
        02:04:08.157 LibTeleinfo::checkLine Err checksum 0x23 != 0x25
        02:04:08.159 LibTeleinfo::checkLine Err checksum 0x27 != 0x07
        02:04:08.679 LibTeleinfo::checkLine Err checksum 0x53 != 0x55
        02:04:09.663 LibTeleinfo::checkLine Err checksum 0x35 != 0x39
        02:04:09.680 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012742,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":41,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410,"ASF02":0,"MAXIN":0,"EAS08":0,"EAS03":0,"NGTF":"PRODUCTEUR","EAF01":27191,"SINTS":41,"SINTI":0,"EAS03":0}}
        ThiefMasterT CharlesC 2 Replies Last reply Reply Quote
          ThiefMaster @ThiefMaster
            Charles @ThiefMaster
            @ThiefMaster j'avoue que je séche un peu tout simplement parce que je n'arrive pas à reproduire le soucis, sur tous les Linky ou j'ai installé je n'ai aucun soucis et pourtant j'ai un script berry qui tourne, l'afficheur SSH1106 et du MQTT en SSL
            00:00:00.247 BRY: Berry initialized, RAM used=4073 bytes
            00:00:00.285 NRG: Init driver 15
            00:00:00.287 I2C: SH1106 found at 0x3c
            00:00:00.416 DSP: SH1106
            00:00:00.434 Project tasmota - Compteur Maison Version 12.2.0.6(teleinfo)-2_0_5_3(2022-11-30T19:31:40)
            00:00:00.436 TIC: RX on GPIO23, baudrate 9600
            00:00:00.449 TIC: Raw mode enabled
            00:00:00.449 TIC: Sending only one frame over 10
            00:00:00.592 TIC: bad cmd param 'Historique
            00:00:00.609 TIC: bad cmd param 'Full
            00:00:00.619 TIC: Raw each 10 frame(s)
            00:00:00.621 RSL: RESULT = {"EnergyConfig":"Done"}
            00:00:00.883 BRY: Successfully loaded 'autoexec.be'
            00:00:01.689 WIF: Connecting to AP1 CH2I-HOTSPOT Channel 1 BSSId 94:83:C4:12:12:76 in mode 11n as wemos-teleinfo-E96814-2068...
            00:00:05.716 WIF: Connected
            00:00:05.718 WIF: IPv6 Link-Local fe80::827d:3aff:fee9:6814
            23:25:00.028 HTP: Web server active on wemos-teleinfo-E96814-2068 with IP address 192.168.1.207
            23:25:01.043 MQT: Attempting connection...
            23:25:01.799 MQT: TLS connected in 725 ms, stack low mark 1908
            23:25:01.801 MQT: Connected
            23:25:01.807 MQT: emoncms/hallard/maison/wemos_teleinfo_E96814/tele/LWT = Online (retained)
            23:25:01.810 MQT: emoncms/hallard/maison/wemos_teleinfo_E96814/cmnd/POWER =
            23:25:01.834 MQT: wemos_teleinfo_E96814/tele/INFO1 = {"Info1":{"Module":"Wemos Teleinfo","Version":"12.2.0.6(teleinfo)","FallbackTopic":"cmnd/DVES_E96814_fb/","GroupTopic":"tasmotas/cmnd/"}}
            23:25:01.854 MQT: wemos_teleinfo_E96814/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"wemos-teleinfo-E96814-2068","IPAddress":"192.168.1.207","IP6Global":"","IP6Local":"fe80::827d:3aff:fee9:6814"}}
            23:25:01.870 MQT: wemos_teleinfo_E96814/tele/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":111}}
            23:25:01.887 MQT: wemos_teleinfo_E96814/stat/RESULT = {"POWER1":"ON"}
            23:25:01.891 MQT: wemos_teleinfo_E96814/stat/POWER1 = ON
            23:25:01.905 MQT: wemos_teleinfo_E96814/stat/RESULT = {"POWER2":"ON"}
            23:25:01.915 MQT: wemos_teleinfo_E96814/stat/POWER2 = ON
            23:25:01.976 QPC: Reset
            23:25:05.882 MQT: wemos_teleinfo_E96814/tele/STATE = {"Time":"2023-01-19T23:25:05","Uptime":"0T00:00:12","UptimeSec":12,"Heap":135,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":105,"MqttCount":1,"Berry":{"HeapUsed":6,"Objects":113},"POWER1":"ON","Dimmer":25,"Color":"344000","HSBColor":"71,100,25","Channel":[20,25,0],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"CH2I-HOTSPOT","BSSId":"94:83:C4:12:12:76","Channel":1,"Mode":"11n","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:06"}}
            23:25:05.955 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"Time":"2023-01-19T23:25:05","ENERGY":{"TotalStartTime":"2022-11-17T07:02:10","Total":3837.770,"Yesterday":47.408,"Today":46.837,"Period":0,"Power":4446,"ApparentPower":4446,"ReactivePower":0,"Factor":1.00,"Voltage":234,"Current":19.000,"Load":42},"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837770,"EASF01":1986221,"EASF02":1851549,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851547,"EASD03":0,"EASD04":0,"IRMS1":19,"URMS1":234,"PREF":9,"PCOUP":9,"SINSTS":4556,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:25:10.689 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837775,"EASF01":1986221,"EASF02":1851554,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851554,"EASD03":0,"EASD04":0,"IRMS1":19,"URMS1":233,"PREF":9,"PCOUP":9,"SINSTS":4549,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:25:23.914 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837791,"EASF01":1986221,"EASF02":1851570,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851571,"EASD03":0,"EASD04":0,"IRMS1":19,"URMS1":234,"PREF":9,"PCOUP":9,"SINSTS":4553,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:25:37.406 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837807,"EASF01":1986221,"EASF02":1851586,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851586,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3575,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:25:50.860 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837819,"EASF01":1986221,"EASF02":1851598,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851599,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3569,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:26:01.250 CMD: energyconfig
            23:26:01.253 TIC: Settings Mode:standard, RX:GPIO23, EN:None, Raw:full, Skip:9, Limit:0
            23:26:01.263 MQT: wemos_teleinfo_E96814/stat/RESULT = {"EnergyConfig":"Done"}
            23:26:04.019 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837833,"EASF01":1986221,"EASF02":1851612,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851612,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":234,"PREF":9,"PCOUP":9,"SINSTS":3554,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:26:17.615 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837846,"EASF01":1986221,"EASF02":1851625,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851625,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":234,"PREF":9,"PCOUP":9,"SINSTS":3555,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:26:30.756 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837859,"EASF01":1986221,"EASF02":1851638,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851639,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3555,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:26:44.672 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837872,"EASF01":1986221,"EASF02":1851651,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851651,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3549,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:26:57.670 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837885,"EASF01":1986221,"EASF02":1851664,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851664,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3563,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:27:10.798 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837898,"EASF01":1986221,"EASF02":1851677,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851678,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3555,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:27:24.309 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837912,"EASF01":1986221,"EASF02":1851691,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851691,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3557,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:27:37.559 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837925,"EASF01":1986221,"EASF02":1851704,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851704,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3555,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:27:50.903 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837938,"EASF01":1986221,"EASF02":1851717,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851718,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3568,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            23:28:04.433 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837951,"EASF01":1986221,"EASF02":1851730,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851730,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3558,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
            il faut que j'écrive un programme basique de test pour tester la liaison facilement
            ThiefMasterT 1 Reply Last reply Reply Quote
              Nicolas Fovet
              Ce qui est étonnant, c'est que certains labels semblent ne jamais être corrompus. Par exemple, les labels SINSTI et EAIT sortent toujours correctement chez moi. Et ce sont les 2 seuls qui m'intéressent vraiment.
              Si la librairie teleinfo pouvait déjà bloquer l'envoi sur MQTT de tout label dont le nom ou le contenu contient des caractères non alphanumériques, cela permettrait d'utiliser le contenu correctement décodé ?
              Sinon, j'ai essayé de remplacer le cable entre le Linky et la DenkyD4 ou de changer sa source d'alimentation ... et j'ai toujours le même taux de trames corrompues.
                Charles @Nicolas Fovet
                @Nicolas-Fovet Excellente idée (mais ce sera géré en interne dans la lib) ca va les réduire mais si l'erreur envoie un caractère valide ce se sera pas mieux
                De plus il y a un fix pour les trames recevant le caractère 0x04 qui est nouveau en mode standard indiquant Frame Interrupt c'est à dire que la trame sera pas complète et c'est peut être la cause des soucis qui fini par planter la librairie car je vois un 0x04, Mrrci à FrColin pour le fix
                je viens de push une version modifié, si tu peux essayer Teleinfo_DenkyD4 et/ou ESP32_Passthru dans les exemples tu vas avoir les stats à la fin de chaque trame
                00:40:15.585 -> <ETX><STX>
                00:40:15.585 -> ADCO 031428067147 B
                00:40:15.585 -> OPTARIF HC.. <
                00:40:15.585 -> ISOUSC 15 <
                00:40:15.585 -> HCHC 003078748 +
                00:40:15.585 -> HCHP 000000000 S
                00:40:15.585 -> PTEC HC.. S
                00:40:16.730 -> IINST 001 X
                00:40:16.730 -> IMAX 002 A
                00:40:16.730 -> PAPP 00140 &
                00:40:16.730 -> HHPHC 3 ^
                00:40:16.730 -> MOTDETAT 000000 B
                00:40:16.730 -> ======= Errors =======
                00:40:16.730 -> Checksum     : 0
                00:40:16.730 -> Frame Size   : 0
                00:40:16.730 -> Frame Format : 0
                00:40:16.730 -> Interrupts   : 0
                00:40:16.730 -> ======================
                00:40:16.730 -> <ETX><STX>
                00:40:16.730 -> ADCO 031428067147 B
                00:40:16.730 -> OPTARIF HC.. <
                00:40:16.730 -> ISOUSC 15 <
                00:40:17.833 -> HCHC 003078748 +
                00:40:17.833 -> HCHP 000000000 S
                00:40:17.833 -> PTEC HC.. S
                00:40:17.833 -> IINST 001 X
                00:40:17.833 -> IMAX 002 A
                00:40:17.833 -> PAPP 00140 &
                00:40:17.833 -> HHPHC 3 ^
                00:40:17.833 -> MOTDETAT 000000 B
                00:40:17.833 -> ======= Errors =======
                00:40:17.833 -> Checksum     : 0
                00:40:17.833 -> Frame Size   : 0
                00:40:17.833 -> Frame Format : 0
                00:40:17.833 -> Interrupts   : 0
                00:40:17.833 -> ======================
                  Nicolas Fovet
                  Oui je peux essayer Teleinfo_DenkyD4.ino mais je ne trouve pas le moyen d'uploader le code sur la carte.
                  J'ai l'Arduino IDE à jour, les librairies installées, le sketch compilé sans erreur, mais j'ai essayé plusieurs boards (ESP32 PICO D4, Adafruit QT Py ESP32, ...) dans le board manager et ça n'upload pas.
                  Sketch uses 290409 bytes (22%) of program storage space. Maximum is 1310720 bytes.
                  Global variables use 22900 bytes (6%) of dynamic memory, leaving 304780 bytes for local variables. Maximum is 327680 bytes.
                  esptool.py v4.2.1
                  Serial port /dev/cu.usbmodem54AD0005121
                  Connecting....
                  Chip is ESP32-PICO-V3-02 (revision 3)
                  Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None
                  Crystal is 40MHz
                  MAC: 30:83:98:d6:d6:7c
                  Uploading stub...
                  A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out)
                  Failed uploading: uploading error: exit status 2
                  J'ai du louper un truc ?
                  EDIT :
                  Upload ok, visiblement sur Mac, il faut installer un driver (ch34xser_macos) pour que l'upload fonctionne ... étrange car j'avais bien un port Com identifié en connectant la Denky sans même installer ce driver ...
                  Du coup, je retourne sur mon linky pour voir les stats
                    Nicolas Fovet
                    Voici ce que cela donne :
                    Checksum     : 5
                    Frame Size   : 6
                    Frame Format : 1
                    Interrupts   : 604
                    Enormément d'interruption de trames ...
                    Impossible de copier/coller ici tout l'enregistrement, l'outil du forum me bloque pour détection de spam ... Mais si je prend un extract :
                    {« _UPTIME »:27}
                    <ETX>IN-1<TAB>H230120213000<TAB>00000<TAB>=
                    UMOY1<TAB>H230120000000020!
                    <INTERRUPT>0030101<TAB>;
                    1<TAB> <INTERRUPT>E          MESSAGE         <TAB><
                    PRM<TAB>14398108460440:
                    <INTERRUPT>000<TAB>
                    <INTERRUPT><TAB>01<TAB>
                    <INTERRUPT><TAB>00<TAB>$
                    <INTERRUPT>+1<TAB>00<TAB>B
                    PF+1<TAB>00008001 NONUTILE NONUTILE <INTERRUPT><TAB> NUTILE NONUTILE NONUTILE NONUTI<INTERRUPT> <TAB><TAB>9
                    <ETX><STX>
                    ADSC<TAB>031861969570<TAB>D
                    VTIC<TAB>02<TAB>J
                    DATE<TAB>H230120222740<
                    NGT<INTERRUPT><INTERRUPT><ETX>   <TAB>,
                    <INTERRUPT><TAB><TAB>DEX NON CONSO <TAB>0
                    EAST<TAB>000011109<TAB>[
                    EASF01<TAB>000011109
                    EASF02000000000<TAB>#
                    <INTERRUPT><INTERRUPT>02000000000<TAB>$
                    <INTERRUPT>04<TAB>000000000<TAB>%
                    EASF05<TAB>000000000<TAB>&
                    EASF06<TAB>000000000<TAB>’
                    EASF07<TAB>000000000
                    <INTERRUPT><INTERRUPT>08000000000<TAB>)
                    <INTERRUPT>09<TAB>000000000<TAB>*
                    EASF10<TAB>000000000<TAB> »
                    EASD01<TAB>000011109<TAB>,
                    EASD02<TAB>000000000
                    <INTERRUPT><INTERRUPT>04<TAB>000000000<TAB>#
                    EAIT<TAB>014276464<TAB>’
                    ERQ1<TAB>000006959<TAB>X
                    ERQ2<TAB>000033509<TAB>P
                    ERQ3<TAB>000000048
                    <INTERRUPT>4000000048<TAB>
                    1<TAB>000<TAB>,
                    1<TAB>031<TAB>@
                    <INTERRUPT><TAB>03<TAB>B
                    <ETX><TAB>03<TAB>\
                    <TAB>TS<TAB>00011<TAB>H
                    SMAXSN<TAB>H230120181438<TAB>00032<TAB>3
                    SMAXSN-1<TAB>H020008080240<TAB>00030<TAB>
                    <TAB><TAB><TAB>00000<TAB><
                    AXIN<TAB>H230120131550<TAB>02463<TAB>)
                    SMAXIN-1<TAB>H23010800280400311<TAB>
                    <STX><STX><TAB><TAB>030100220000<TAB>00000<TAB>]
                    CCAIN-1<TAB>H230120213000<TAB>00000<
                    UMO0020000000000<TAB>030<TAB>!
                    <TAB>003A0101<TAB>;
                    MSG1<TAB>PAS DE          MESSAGE   <
                    04288018570540<TAB>;
                    <TAB><TAB>000<TAB>B
                    D<TAB>01<TAB>N
                    OURF<TAB>00<TAB>&
                    NJOURF+1<TAB>00<TAB>B
                    PJOURF+1<TAB>00008001 NONUTILE<INTERRUPT><TAB> LONUTILE NONUTILE NONUTILE NONUT<INTERRUPT> <TAB>E NONUTILE<TAB>9
                    <ETX><STX>
                    VTIC<TAB>02<TAB>J
                    DATE<TAB>H230120222742<
                    <INTERRUPT><INTERRUPT>02<TAB>000000000<TAB>$
                    ERQ3<TAB>000000048
                    1<TAB>000<TAB>,
                    1<TAB>031<TAB>@
                    <ETX><TAB>03<TAB>\
                    SMAXSN-1<TAB>020008080240<TAB>00030<TAB>L
                    SMAXIN-1<TAB>H23000800280400311<TAB>
                    <TAB>003A0101<TAB>;
                    <TAB><TAB>000<TAB>B
                    F<TAB>01<TAB>N
                    OURF<TAB>00<TAB>&
                    PJOURF+1<TAB>00008001 NONUTILE<INTERRUPT> <TAB> ONUTILE NONUTILE NONUTILE NONUT<INTERRUPT> <TAB>E NONUTILE<TAB>9
                    <ETX><STX>
                    VTIC<TAB>02<TAB>J
                    DATE<TAB>H230120222744<
                    EASF02<TAB>000000000<TAB>#
                    EASF03<TAB>000000000<INTERRUPT>
                    EASF04000000000<TAB>%
                    <INTERRUPT><INTERRUPT>04<TAB>000000000<TAB>&
                    <INTERRUPT>04<TAB>000000000<TAB>’
                    EASF07<TAB>000000000<TAB>(
                    EASF08<TAB>000000000<TAB>)
                    EASF09<TAB>000000000(
                    <INTERRUPT><INTERRUPT>00000000000<TAB>
                    <INTERRUPT>01<TAB>000011109<TAB>,
                    EASD02<TAB>000000000<TAB>!
                    EASD03<TAB>000000000<TAB> »
                    EASD04<TAB>000000000<STX>
                    <INTERRUPT>004064444<TAB>’
                    <INTERRUPT>1<TAB>000004959<TAB>X
                    0<TAB>000033509<TAB>P
                    ERQ3<TAB>000121259<TAB>Q
                    ERQ4<TAB>000000068<TAB>L
                    IRMS1<TAB>000<TAB>.
                    URMS1<TAB>231
                    PREF<TAB>02
                    PCOUP<TAB>02
                    SINS00000
                    030100181438<TAB>00032<TAB>3
                    SMAXSN-1<TAB>H230119180340<TAB>00030<TAB>
                    SINSTI<TAB>00000<TAB>
                      @Nicolas-Fovet il faut choisir la board Denky puis après dans la config de la board pico v3 02
                      Si sa peine avant d’upload tu appuis sur le bouton boot puis en laissant appuyer tu appuis/lache reset ça va le forcer en upload
                      Nicolas FovetN 1 Reply Last reply Reply Quote
                        Nicolas Fovet @Charles
                        @Charles , upload ok, c'était un problème de driver du cp21xx sur MacOs.
                        J'ai posté les trames dans mon précèdent message.
                          @Nicolas-Fovet je crois que cette fois j'ai compris, dire que je pensais qu'il y avait un soucis à la conception mais c'est tout simplement ton Linky qui envoi des Frame Interrupt à tout va et ça c'est pas encore géré dans la librairie. Merci encore à FrColin pour ce patch.
                          Je viens de faire un push avec une version modifiée des 2 programmes de test que tu as essayé, si tu pouvais tester et faire un retour ça serait top.
                          ça serait bien aussi si @Samquad pouvait aussi faire ce test il semblait avoir les mêmes soucis.
                          Question bête tu es en zone très urbaine ou à la campagne ?
                            Charles @Charles
                            Extartait de la spec page 19
                            Cas d’une interruption de l’émission des trames d’information.
                            En fonctionnement nominal de l’appareil de comptage, l'émission d’informations sur la liaison de télé-information client peut
                            être momentanément interrompue durant le cours de l’émission d’une trame du fait du déroulement d’une autre opération
                            de communication avec l’appareil de comptage (par exemple, le relevé ou la programmation de l’appareil par un accès
                            téléphonique ou un accès par le bus de téléreport ou la liaison optique). Lorsqu’elle reprend son déroulement normal,
                            l’émission commence au début de la trame afin de permettre un recalage des dispositifs qui y sont raccordés. Les données
                            émises correspondent à la situation de l’appareil de comptage au moment où il recommence à émettre. Du fait de cette
                            particularité de fonctionnement, les systèmes qui sont raccordés à cette sortie sont contraints d’être absolument équipés d’un
                            mode de fonctionnement dégradé leur permettant de gérer correctement ces périodes d’absence d’émission (pas de blocage
                            de fonctionnement, ni comportement erratique).
                            Dans ce but, lors d’une telle interruption de l’émission :
                            • le caractère ASCII « End Of Transmission » alias « EOT » de valeur 0x04 est généré avant l’interruption de l’émission,
                            • la reprise de l'émission se fait par un début de trame avec l’émission du caractère ASCII « Start of TeXt » alias « STX » de
                              valeur 0x02.
                              @Charles merci pour ta réactivité 😉
                              Je suis dans un lotissement en campagne.
                              Voici ce que j'obtiens :
                              sts Jul 29 2019 12:21:46
                              rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                              configsip: 271414342, SPIWP:0xee
                              clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
                              mode:DIO, clock div:1
                              load:0x3fff0030,len:1184
                              load:0x40078000,storique
                              TIC RX=GPIO8  Mode:Standard
                              <TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><ETX><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><STX><TAB><INTERRUPT><TAB><ETX><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><STX><STX><TAB><INTERRUPT><STX><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><STX><STX><TAB><INTERRUPT><STX><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX>
                              {« _UPTIME »:49}
                              <ETX><TAB>-1<TAB>030121150000<TAB>01740<TAB>J
                              UMOY1<TAB>H230121155000<TAB>024
                              STG<INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><STX><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><ETX>CAIN-1<TAB>H230121150000<TAB>01740<TAB>J
                              UMOY1<TAB>H230120044000025<TAB>,
                              <INTERRUPT><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><ETX>CAIN-1<TAB>H230121150000<TAB>01740<TAB>J
                              <INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><STX><STX><TAB><TAB><INTERRUPT><STX><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><INTERRUPT><STX><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><STX><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><ETX><INTERRUPT><STX><TAB><TAB><ETX><TAB>02<TAB>J
                              <INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><ETX><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><STX><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><INTERRUPT><STX><TAB><TAB><ETX><TAB>02<TAB>J
                              <INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><STX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><STX><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><ETX><TAB>-1<TAB>030121150000<TAB>01740<TAB>J
                              UMOY1<TAB>H230121155000<TAB>224
                              STGE<TAB>002�0200<
                              0� <INTERRUPT><TAB>
                                @Nicolas-Fovet Alors ça c'est curieux, et je reste de plus en plus frustré (comme toi j'imagine) parce que je n'arrive pas à reproduire le problème, c'est peut être lié au hardware mais sans pouvoir regarder et faire des tests en direct à la sortie de ton compteur impossible pour moi d'investiguer plus loin mis à part enfin trouver un des linky près de chez moi qui déconne pareil.
                                • Nicolas FovetN Offline
                                  @Charles oui c'est frustrant effectivement.
                                  Du coup, je reviens à ma proposition initiale. Ne pourrait-il pas y avoir une évolution de la librairie pour empêcher l'affichage et l'envoi sur MQTT de tout caractère non alphanumérique dans les labels et les contenus des données des labels ?
                                  Cela ne résoudra pas totalement le problème mais permettra au moins d'avoir un json exploitable dans les trames MQTT.
                                    @Nicolas-Fovet oui c'est une excellente idée, mais en réfléchissant et la je ne comprends pas pourquoi, mais normalement ça devrait déjà être le cas puisque toute ligne avec une mauvaise checksum (donc caractère pourri) n'est pas retenue (donc pas envoyée via MQTT ou autre) Il faut que je vois pourquoi ça fait ça mais dans ton 1er message, les logs de la console tasmota n'indiquent pas d'envoi MQTT avec des mauvais caractères (hormis après le copier/coller) pourtant ou je me trompe ?
                                      FredLo @Charles
                                      Bonjour @Charles,
                                      Tout d'abord, un grand merci pour ton travail. J'utilise un module micro téléinfo V2.0 depuis plus d'an maintenant, et il marche du tonnerre ! J'ai juste eu besoin d'une modif hardware pour lui faire accepter le passage du Linky en mode Standard.
                                      Je viens juste d'acheter un Denky D4 pour pouvoir sortir mon raspberry du garage (à coté du Linky, obviously) et le mettre à l'abris derrière un onduleur dans la maison.
                                      Ma config:
                                      Rasberry Pi 4 avec Jeedom et le plugin JMQTT, entres autres. Le Broker est également sur le Rasp.
                                      J'ai des modules domotiques en Wifi (Shelly) et en Zigbee (SonOff, Xiaomi et même Lidl !)
                                      Le Linky:
                                      Un seul compteur, en mode Standard car production photovoltaïque pour autoconsommation avec revente de surplus, presque comme Nicolas.
                                      Mes constations.
                                      La simplicité de configuration de Tasmota est enthousiasmante, j'ai très vite eu des trames MQTT remontées jusqu'au Broker et visibles dans Jeedom. Mais lors de mon premier vrai test, avec des informations de TIC, j'ai eu également un blocage:
                                      Les premières payloads MQTT TIC étaient bonnes, dans le sens JSON du terme: Jeedom me permettait de les éclater en sous modules pour faciliter la création de nouvelle commandes. Et puis brusquement, les informations ne remontaient plus. La payload TIC était toujours reçue régulièrement mais contenait systématiquement un éléments étrange en bout de chaîne: "EST":8062115. Jeedom ne considérait plus cette payload comme du JSON valide. Il me semble qu'il s'agissait d'un doublon de l'info EAST mais avec un caractère corrompu. La valeur correspondait bien à l'info EAST, mais un peu plus ancienne et non mise à jour.
                                      Le test d'aujourd'hui a été beaucoup plus stable (plus d'une heure), j'ai branché plus sérieusement les fils à la carte Denky D4. Chance ou effet réel ? je ne bascule pas tout de suite sur cette solution car j'attends une potentielle compatibilité MQTT du plugin teleinfo de Jeedom.
                                      Je peux fournir des exemples de payload avec le défaut et des exemples fonctionnels. Et accessoirement, J’habite également dans la Vienne, à coté de Châtellerault 🙂
                                      Bonne soirée
                                      • ThiefMasterT Offline
                                        ThiefMaster @Charles
                                        FYI after I replaced the cable between the Linky and the D4, everything is fine. So I guess the (very thin) cable I used before simply didn't have a good connection...
                                          @ThiefMaster thank for the follow up, interesting case 🙂
