  5. Trames erronées sur Linky production photovoltaïque
19 Posts 4 Posters 2.5k Views 2 Watching
  • Nicolas FovetN Offline
    Nicolas Fovet
    Je rencontre des difficultés avec une Denky D4 que je viens juste de recevoir.
    Connecté à un Linky "consommation" en mode historique, tout remonte correctement et les messages sont correctement envoyés & décodés via MQTT sur mon Home Assistant qui met à jour les sensors que j'ai déclarés en parsant le json.
    Par contre, avec mon second Linky associé à un contrat de production photovoltaïque, et après être passé via la console Tasmota en mode standard et en 9600 bauds, certaines infos remontent, mais j'ai beaucoup de trames avec des erreurs de checksum, des buffer overflows, et les messages MQTT contiennent des caractères non-alphanumériques qui font échouer le parsing json dans Home Assistant.
    Au niveau du broker MQTT, j'obtiens par exemple :
    {"TIC":{"VTIC":2,"EASF01":11086,"EASF06":0,"EASF07":0,"EASD02":0,"ERQ2":33508,"ERQ3":120187,"NJOURF+1":0,"EASF02":0,"EASD03":0,"ERQ4":68,"IRMS1":7,"EASD01":11086,"URMS1":232,"PREF":3,"PCOUP":3,"SINSTS":0,"SINSTI":1536," +1":0," ":0,"ADSC":"031861969570","EAST":11086,"EASF05":0,"EASF10":0,"EAIT":14265241,"ERQ1":6956,"SMAXIN":2266,"RELAIS":0,"NTARF":1,"NJOURF":0,"SMAXSN":8," ":0,"UMOY1":233,"PRM":2147483647,"EASF04":0,"STGE":"003A0301","EASF03":0,"EASF09":0,"EASD04":0,"LTARF":"INDEX NON CONSO"," 0030118143000":232,"NGTF":"PRODUCTEUR","1":4954," D+1":0," 0030118144000":233," 0":30," D":0,"3":100149,"SMAXIN-1":1873,"EASF08":0," 0030118145000":232," 0":0," 0030118150000":233," 0030118151000":233,"CCAIN":1722,"CCAIN-1":1810}}
    Help ! 😉
    • ThiefMasterT Offline
      ThiefMaster
      wrote on last edited by ThiefMaster
      I have the same problem, also with an injection meter for my solar panels! Here's my console dump in case it helps. The only thing I replaced with a dummy is the address of my linky:
      00:00:00.078 UFS: FlashFS mounted with 4396 kB free
      00:00:00.113 CFG: Loaded from File, Count 50
      00:00:00.123 QPC: Count 1
      00:00:00.322 BRY: Berry initialized, RAM used=4071 bytes
      00:00:00.397 NRG: Init driver 15
      00:00:00.408 Project tasmota - LinkySolar Version 12.3.1.4(teleinfo)-2_0_6(2023-01-18T08:24:15)
      00:00:00.409 TIC: RX on GPIO8, baudrate 9600
      00:00:00.421 TIC: Raw mode enabled
      00:00:01.357 WIF: Connecting to AP1 Internet of Shite Channel 1 BSSId D2:32:E5:7C:94:A4 in mode 11n as tasmota-D57FDC-8156...
      00:00:05.716 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
      00:00:05.719 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
      00:00:06.151 WIF: Connected
      00:00:06.411 HTP: Web server active on tasmota-D57FDC-8156 with IP address 192.168.1.217
      00:00:06.415 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
      00:00:06.657 LibTeleinfo::checkLine Err checksum 0x44 != 0x46
      00:00:06.856 QPC: Reset
      01:45:11.403 RSL: INFO1 = {"Info1":{"Module":"Denky D4 (v1.1)","Version":"12.3.1.4(teleinfo)","FallbackTopic":"cmnd/DVES_D57FDC_fb/","GroupTopic":"cmnd/tasmotas/"}}
      01:45:11.418 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-D57FDC-8156","IPAddress":"192.168.1.217","IP6Global":"2a0e:xxxx:yyyy::3283:98ff:fed5:7fdc","IP6Local":"fe80::3283:98ff:fed5:7fdc"}}
      01:45:11.431 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":8}}
      01:45:11.444 RSL: RESULT = {"POWER":"ON"}
      01:45:11.445 RSL: POWER = ON
      01:45:11.663 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":237,"REF":3,"PCOUP":3,"SINSTS":40,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0}}
      01:45:11.707 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
      01:45:11.901 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
      01:45:12.406 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
      01:45:13.618 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":237,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0}}
      01:45:13.664 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
      01:45:14.152 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
      01:45:14.154 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
      01:45:14.405 LibTeleinfo::checkLine Err checksum 0x26 != 0x28
      01:45:15.407 LibTeleinfo::checkLine Err checksum 0x2F != 0x3C
      01:45:15.654 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      01:45:15.673 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0}}
      01:45:15.863 RSL: STATE = {"Time":"2023-01-19T01:45:15","Uptime":"0T00:00:12","UptimeSec":12,"Heap":167,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":44},"POWER":"ON","Dimmer":33,"Color":"005407","HSBColor":"125,100,33","Channel":[0,33,2],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Internet of Shite","BSSId":"D2:32:E5:7C:94:A4","Channel":1,"Mode":"11n","RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:07"}}
      01:45:15.925 RSL: SENSOR = {"Time":"2023-01-19T01:45:15","ENERGY":{"TotalStartTime":"2023-01-18T18:40:16","Total":27.191,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":236,"Current":0.000,"Load":0},"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012"}}
      01:45:16.520 LibTeleinfo::checkLine Err checksum 0x26 != 0x28
      01:45:16.904 LibTeleinfo::checkLine Err checksum 0x53 != 0x13
      01:45:17.150 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      01:45:17.657 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      01:45:17.677 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3}}
      01:45:17.908 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
      01:45:18.150 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
      01:45:18.400 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
      01:45:19.673 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0}}
      01:45:19.745 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
      01:45:19.905 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
      01:45:20.149 LibTeleinfo::checkLine Err checksum 0x26 != 0x24
      01:45:21.154 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      01:45:21.157 LibTeleinfo::checkLine Err checksum 0x53 != 0x13
      01:45:21.414 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      01:45:21.670 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012728,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0}}
      01:45:22.158 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
      01:45:22.162 LibTeleinfo::checkLine Err checksum 0x25 != 0x27
      01:45:23.676 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":237,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0}}
      01:45:23.743 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
      01:45:23.904 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
      01:45:29.737 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
      01:45:29.905 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
      01:45:30.161 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
      01:45:30.404 LibTeleinfo::checkLine Err checksum 0x20 != 0x22
      01:45:30.657 LibTeleinfo::checkLine Err checksum 0x22 != 0x20
      01:45:31.402 LibTeleinfo::checkLine Err checksum 0x2F != 0x3C
      01:45:31.407 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      01:45:31.677 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0,"EAS09":0,"EAD01":27191,"EAS04":0,"EAF06":0,"SM
      01:45:32.154 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
      01:45:32.156 LibTeleinfo::checkLine Err checksum 0x26 != 0x24
      01:45:32.403 LibTeleinfo::checkLine Err checksum 0x26 != 0x28
      01:45:32.408 LibTeleinfo::checkLine Err checksum 0x22 != 0x20
      01:45:32.411 LibTeleinfo::checkLine Err checksum 0x5F != 0x21
      01:45:33.405 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      01:45:33.674 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0,"EAS09":0,"EAD01":27191,"EAS04":0,"EAF06":0,"SM
      01:45:33.900 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
      01:45:34.402 LibTeleinfo::checkLine Err checksum 0x2A != 0x28
      01:45:35.647 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
      01:45:35.649 LibTeleinfo::checkLine Err checksum 0x40 != 0x42
      01:45:35.667 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0,"EAS09":0,"EAD01":27191,"EAS04":0,"EAF06":0,"SM
      01:45:37.157 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      01:45:37.671 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":236,"REF":3,"PCOUP":3,"SINSTS":41,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0,"EAS09":0,"EAD01":27191,"EAS04":0,"EAF06":0,"SM
      01:45:37.750 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
      01:45:37.898 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
      01:45:39.154 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      01:45:39.414 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      01:45:39.674 RSL: SENSOR = {"TIC":{"VTIC":2,"LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EASF02":0,"EASF03":0,"EAS04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"EASD01":27191,"EAS02":0,"EASD03":0,"EAD04":0,"EAIT":4869811,"ERQ2":1,"ERQ3":1352166,"RQ4":1012728,"IRMS1":0,"URMS1":235,"REF":3,"PCOUP":3,"SINSTS":40,"SMAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":237,"STGE":"003A0101","PRM":2147483647,"ELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF04":0,"EASD02":0,"EASD04":0,"ERQ1":560,"ERQ4":1012729,"RMS1":237,"MAXIN-1":410,"RELAIS":0,"EAS06":0,"EASF08":0,"PREF":3,"MAXSN":40,"MAXIN":0,"ADSC":"123456789012","GTF":"   PRODUCTEUR   ","COUP":3,"EASF07":0,"EAS05":0,"EAS09":0,"EAD01":27191,"EAS04":0,"EAF06":0,"SM
      01:45:40.152 LibTeleinfo::checkLine Err checksum 0x25 != 0x27
      01:45:40.402 LibTeleinfo::checkLine Err checksum 0x2A != 0x28
      Not sure if it matters, but when I copied from the console into my editor (vscode) it highlighted some low ASCII chars - see the screenshot. They are included in the output pasted here as well.
      There's something wrong in the data for sure, when looking at the main Tasmota page the text I see for "Message 1" changes slightly. Here are ones I've seen so far:
      • PAS DE MSSAGE (\x05 in place of the missing char)
      • PAS DE MESSAE (\x07 in place of the missing char)
      • PAS DE MESSAGE (correct)
      Unfortunately my primary Linky for power consumption is in mode historique and the EDF people never reacted to my request to change it so I cannot test if it's the same problem there or only on the production linky... 😕
      Edit: I just realized that something truncated long lines from the output I posted above... here's one captured via usb/serial connection. Doesn't contain the ASCII garbage but the full data in case it's useful...
      00:00:00.032 UFS: FlashFS mounted with 4396 kB free
      00:00:00.053 CFG: Loaded from File, Count 52
      00:00:00.063 QPC: Count 1
      00:00:00.166 BRY: Berry initialized, RAM used=4071 bytes
      00:00:00.200 NRG: Init driver 15
      00:00:00.210 Project tasmota - LinkySolar Version 12.3.1.4(teleinfo)-2_0_6(2023-01-18T08:24:15)
      00:00:00.212 TIC: RX on GPIO8, baudrate 9600
      00:00:00.224 TIC: Raw mode enabled
      00:00:00.930 WIF: Connecting to AP1 Internet of Shite Channel 1 BSSId D2:32:E5:7C:94:A4 in mode 11n as tasmota-D57FDC-8156...
      00:00:03.163 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
      00:00:03.166 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
      00:00:03.171 LibTeleinfo::checkLine Err checksum 0x39 != 0x2B
      00:00:03.683 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0}}
      00:00:04.018 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
      00:00:04.220 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
      00:00:05.158 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
      00:00:05.411 LibTeleinfo::checkLine Err checksum 0x20 != 0x22
      00:00:05.662 WIF: Connected
      00:00:05.914 HTP: Web server active on tasmota-D57FDC-8156 with IP address 192.168.1.217
      02:03:59.413 LibTeleinfo::checkLine Err checksum 0x2F != 0x3C
      02:03:59.417 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      02:03:59.659 LibTeleinfo::checkLine Err checksum 0x37 != 0x39
      02:03:59.670 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":41,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236}}
      02:03:59.909 RSL: INFO1 = {"Info1":{"Module":"Denky D4 (v1.1)","Version":"12.3.1.4(teleinfo)","FallbackTopic":"cmnd/DVES_D57FDC_fb/","GroupTopic":"cmnd/tasmotas/"}}
      02:03:59.924 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-D57FDC-8156","IPAddress":"192.168.1.217","IP6Global":"2a0e:xxxx:yyyy::3283:98ff:fed5:7fdc","IP6Local":"fe80::3283:98ff:fed5:7fdc"}}
      02:03:59.937 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":10}}
      02:03:59.951 RSL: RESULT = {"POWER":"ON"}
      02:03:59.952 RSL: POWER = ON
      02:03:59.957 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
      02:03:59.959 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
      02:03:59.970 QPC: Reset
      02:04:00.162 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
      02:04:00.919 LibTeleinfo::checkLine Err checksum 0x4E != 0x4C
      02:04:01.657 LibTeleinfo::checkLine Err checksum 0x37 != 0x39
      02:04:01.671 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":41,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410}}
      02:04:01.727 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
      02:04:01.730 LibTeleinfo::checkLine Err checksum 0x2C != 0x2E
      02:04:02.556 LibTeleinfo::checkLine Err checksum 0x20 != 0x22
      02:04:02.908 LibTeleinfo::checkLine Err checksum 0x46 != 0x44
      02:04:03.229 LibTeleinfo::checkLine Err checksum 0x2F != 0x3C
      02:04:03.413 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      02:04:03.663 LibTeleinfo::checkLine Err checksum 0x37 != 0x39
      02:04:03.678 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":42,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410,"ASF02":0,"MAXIN":0}}
      02:04:03.911 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
      02:04:03.923 RSL: STATE = {"Time":"2023-01-19T02:04:03","Uptime":"0T00:00:11","UptimeSec":11,"Heap":169,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":102,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":44},"POWER":"ON","Dimmer":33,"Color":"005407","HSBColor":"125,100,33","Channel":[0,33,2],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Internet of Shite","BSSId":"D2:32:E5:7C:94:A4","Channel":1,"Mode":"11n","RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:06"}}
      02:04:03.988 RSL: SENSOR = {"Time":"2023-01-19T02:04:03","ENERGY":{"TotalStartTime":"2023-01-18T18:40:16","Total":27.191,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":237,"Current":0.000,"Load":0},"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":42,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410,"ASF02":0,"MAXIN":0}}
      02:04:04.162 LibTeleinfo::checkLine Err checksum 0x23 != 0x25
      02:04:04.164 LibTeleinfo::checkLine Err checksum 0x27 != 0x07
      02:04:04.416 LibTeleinfo::checkLine Err checksum 0x28 != 0x2A
      02:04:04.665 LibTeleinfo::checkLine Err checksum 0x53 != 0x55
      02:04:05.672 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":41,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410,"ASF02":0,"MAXIN":0,"EAS08":0,"EAS03":0}}
      02:04:06.267 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
      02:04:06.270 LibTeleinfo::checkLine Err checksum 0x28 != 0x08
      02:04:06.419 LibTeleinfo::checkLine Err checksum 0x22 != 0x20
      02:04:07.415 LibTeleinfo::checkLine Err checksum 0x2F != 0x3C
      02:04:07.420 LibTeleinfo::checkLine Err checksum 0x4C != 0x4E
      02:04:07.660 LibTeleinfo::checkLine Err checksum 0x37 != 0x39
      02:04:07.676 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012741,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":41,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410,"ASF02":0,"MAXIN":0,"EAS08":0,"EAS03":0,"NGTF":"PRODUCTEUR","EAF01":27191,"SINTS":41,"SINTI":0}}
      02:04:07.742 LibTeleinfo::checkLine Err checksum 0x42 != 0x3A
      02:04:08.157 LibTeleinfo::checkLine Err checksum 0x23 != 0x25
      02:04:08.159 LibTeleinfo::checkLine Err checksum 0x27 != 0x07
      02:04:08.679 LibTeleinfo::checkLine Err checksum 0x53 != 0x55
      02:04:09.663 LibTeleinfo::checkLine Err checksum 0x35 != 0x39
      02:04:09.680 RSL: SENSOR = {"TIC":{"ADSC":"12345679012","VTIC":2,"GTF":"   PRODUCTEUR   ","LTARF":"INDEX NON CONSO","EAST":27191,"EASF01":27191,"EAS02":0,"EASF04":0,"EASF05":0,"EASF06":0,"EAS07":0,"EASF09":0,"EASF10":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"EASF02":0,"EASF03":0,"EAS04":0,"EASF07":0,"EASF08":0,"EAS09":0,"EAD01":27191,"EASD02":0,"EASD03":0,"EAS04":0,"EAIT":4869811,"ERQ1":560,"ERQ2":1,"ERQ3":1352166,"ERQ4":1012742,"IRMS1":0,"URMS1":237,"PREF":3,"PCOUP":3,"SINSTS":41,"MAXSN":40,"SMAXSN-1":170,"SINSTI":0,"SMAXIN":0,"SMAXIN-1":410,"UMOY1":236,"EASD01":27191,"EASD04":0,"RMS1":237,"REF":3,"SMAXSN":40,"MAXIN-1":410,"ASF02":0,"MAXIN":0,"EAS08":0,"EAS03":0,"NGTF":"PRODUCTEUR","EAF01":27191,"SINTS":41,"SINTI":0,"EAS03":0}}
      ThiefMasterT CharlesC 2 Replies Last reply
      • ThiefMasterT ThiefMaster
        ThiefMaster
          @ThiefMaster j'avoue que je séche un peu tout simplement parce que je n'arrive pas à reproduire le soucis, sur tous les Linky ou j'ai installé je n'ai aucun soucis et pourtant j'ai un script berry qui tourne, l'afficheur SSH1106 et du MQTT en SSL
          00:00:00.247 BRY: Berry initialized, RAM used=4073 bytes
          00:00:00.285 NRG: Init driver 15
          00:00:00.287 I2C: SH1106 found at 0x3c
          00:00:00.416 DSP: SH1106
          00:00:00.434 Project tasmota - Compteur Maison Version 12.2.0.6(teleinfo)-2_0_5_3(2022-11-30T19:31:40)
          00:00:00.436 TIC: RX on GPIO23, baudrate 9600
          00:00:00.449 TIC: Raw mode enabled
          00:00:00.449 TIC: Sending only one frame over 10
          00:00:00.592 TIC: bad cmd param 'Historique
          00:00:00.609 TIC: bad cmd param 'Full
          00:00:00.619 TIC: Raw each 10 frame(s)
          00:00:00.621 RSL: RESULT = {"EnergyConfig":"Done"}
          00:00:00.883 BRY: Successfully loaded 'autoexec.be'
          00:00:01.689 WIF: Connecting to AP1 CH2I-HOTSPOT Channel 1 BSSId 94:83:C4:12:12:76 in mode 11n as wemos-teleinfo-E96814-2068...
          00:00:05.716 WIF: Connected
          00:00:05.718 WIF: IPv6 Link-Local fe80::827d:3aff:fee9:6814
          23:25:00.028 HTP: Web server active on wemos-teleinfo-E96814-2068 with IP address 192.168.1.207
          23:25:01.043 MQT: Attempting connection...
          23:25:01.799 MQT: TLS connected in 725 ms, stack low mark 1908
          23:25:01.801 MQT: Connected
          23:25:01.807 MQT: emoncms/hallard/maison/wemos_teleinfo_E96814/tele/LWT = Online (retained)
          23:25:01.810 MQT: emoncms/hallard/maison/wemos_teleinfo_E96814/cmnd/POWER =
          23:25:01.834 MQT: wemos_teleinfo_E96814/tele/INFO1 = {"Info1":{"Module":"Wemos Teleinfo","Version":"12.2.0.6(teleinfo)","FallbackTopic":"cmnd/DVES_E96814_fb/","GroupTopic":"tasmotas/cmnd/"}}
          23:25:01.854 MQT: wemos_teleinfo_E96814/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"wemos-teleinfo-E96814-2068","IPAddress":"192.168.1.207","IP6Global":"","IP6Local":"fe80::827d:3aff:fee9:6814"}}
          23:25:01.870 MQT: wemos_teleinfo_E96814/tele/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":111}}
          23:25:01.887 MQT: wemos_teleinfo_E96814/stat/RESULT = {"POWER1":"ON"}
          23:25:01.891 MQT: wemos_teleinfo_E96814/stat/POWER1 = ON
          23:25:01.905 MQT: wemos_teleinfo_E96814/stat/RESULT = {"POWER2":"ON"}
          23:25:01.915 MQT: wemos_teleinfo_E96814/stat/POWER2 = ON
          23:25:01.976 QPC: Reset
          23:25:05.882 MQT: wemos_teleinfo_E96814/tele/STATE = {"Time":"2023-01-19T23:25:05","Uptime":"0T00:00:12","UptimeSec":12,"Heap":135,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":105,"MqttCount":1,"Berry":{"HeapUsed":6,"Objects":113},"POWER1":"ON","Dimmer":25,"Color":"344000","HSBColor":"71,100,25","Channel":[20,25,0],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"CH2I-HOTSPOT","BSSId":"94:83:C4:12:12:76","Channel":1,"Mode":"11n","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:06"}}
          23:25:05.955 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"Time":"2023-01-19T23:25:05","ENERGY":{"TotalStartTime":"2022-11-17T07:02:10","Total":3837.770,"Yesterday":47.408,"Today":46.837,"Period":0,"Power":4446,"ApparentPower":4446,"ReactivePower":0,"Factor":1.00,"Voltage":234,"Current":19.000,"Load":42},"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837770,"EASF01":1986221,"EASF02":1851549,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851547,"EASD03":0,"EASD04":0,"IRMS1":19,"URMS1":234,"PREF":9,"PCOUP":9,"SINSTS":4556,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:25:10.689 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837775,"EASF01":1986221,"EASF02":1851554,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851554,"EASD03":0,"EASD04":0,"IRMS1":19,"URMS1":233,"PREF":9,"PCOUP":9,"SINSTS":4549,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:25:23.914 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837791,"EASF01":1986221,"EASF02":1851570,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851571,"EASD03":0,"EASD04":0,"IRMS1":19,"URMS1":234,"PREF":9,"PCOUP":9,"SINSTS":4553,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:25:37.406 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837807,"EASF01":1986221,"EASF02":1851586,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851586,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3575,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:25:50.860 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837819,"EASF01":1986221,"EASF02":1851598,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851599,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3569,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:26:01.250 CMD: energyconfig
          23:26:01.253 TIC: Settings Mode:standard, RX:GPIO23, EN:None, Raw:full, Skip:9, Limit:0
          23:26:01.263 MQT: wemos_teleinfo_E96814/stat/RESULT = {"EnergyConfig":"Done"}
          23:26:04.019 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837833,"EASF01":1986221,"EASF02":1851612,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851612,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":234,"PREF":9,"PCOUP":9,"SINSTS":3554,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:26:17.615 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837846,"EASF01":1986221,"EASF02":1851625,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851625,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":234,"PREF":9,"PCOUP":9,"SINSTS":3555,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:26:30.756 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837859,"EASF01":1986221,"EASF02":1851638,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851639,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3555,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:26:44.672 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837872,"EASF01":1986221,"EASF02":1851651,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851651,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3549,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:26:57.670 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837885,"EASF01":1986221,"EASF02":1851664,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851664,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3563,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:27:10.798 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837898,"EASF01":1986221,"EASF02":1851677,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851678,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3555,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:27:24.309 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837912,"EASF01":1986221,"EASF02":1851691,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851691,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3557,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:27:37.559 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837925,"EASF01":1986221,"EASF02":1851704,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851704,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3555,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:27:50.903 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837938,"EASF01":1986221,"EASF02":1851717,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851718,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3568,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          23:28:04.433 MQT: wemos_teleinfo_E96814/tele/SENSOR = {"TIC":{"ADSC":"022261185164","VTIC":2,"NGTF":"HC-12H30","LTARF":"HEURES PLEINES","EAST":3837951,"EASF01":1986221,"EASF02":1851730,"EASF03":0,"EASF04":0,"EASF05":0,"EASF06":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1986221,"EASD02":1851730,"EASD03":0,"EASD04":0,"IRMS1":15,"URMS1":235,"PREF":9,"PCOUP":9,"SINSTS":3558,"SMAXSN":6830,"SMAXSN-1":8450,"CCASN":3752,"CCASN-1":4108,"UMOY1":233,"STGE":"002A4401","PRM":2147483647,"RELAIS":0,"NTARF":2,"NJOURF":0,"NJOURF+1":0}}
          il faut que j'écrive un programme basique de test pour tester la liaison facilement
          ThiefMasterT 1 Reply Last reply
            Nicolas Fovet
            wrote on last edited by Nicolas Fovet
            Ce qui est étonnant, c'est que certains labels semblent ne jamais être corrompus. Par exemple, les labels SINSTI et EAIT sortent toujours correctement chez moi. Et ce sont les 2 seuls qui m'intéressent vraiment.
            Si la librairie teleinfo pouvait déjà bloquer l'envoi sur MQTT de tout label dont le nom ou le contenu contient des caractères non alphanumériques, cela permettrait d'utiliser le contenu correctement décodé ?
            Sinon, j'ai essayé de remplacer le cable entre le Linky et la DenkyD4 ou de changer sa source d'alimentation ... et j'ai toujours le même taux de trames corrompues.
            • Nicolas FovetN Nicolas Fovet
              @Nicolas-Fovet Excellente idée (mais ce sera géré en interne dans la lib) ca va les réduire mais si l'erreur envoie un caractère valide ce se sera pas mieux
              De plus il y a un fix pour les trames recevant le caractère 0x04 qui est nouveau en mode standard indiquant Frame Interrupt c'est à dire que la trame sera pas complète et c'est peut être la cause des soucis qui fini par planter la librairie car je vois un 0x04, Mrrci à FrColin pour le fix
              je viens de push une version modifié, si tu peux essayer Teleinfo_DenkyD4 et/ou ESP32_Passthru dans les exemples tu vas avoir les stats à la fin de chaque trame
              00:40:15.585 -> <ETX><STX>
              00:40:15.585 -> ADCO 031428067147 B
              00:40:15.585 -> OPTARIF HC.. <
              00:40:15.585 -> ISOUSC 15 <
              00:40:15.585 -> HCHC 003078748 +
              00:40:15.585 -> HCHP 000000000 S
              00:40:15.585 -> PTEC HC.. S
              00:40:16.730 -> IINST 001 X
              00:40:16.730 -> IMAX 002 A
              00:40:16.730 -> PAPP 00140 &
              00:40:16.730 -> HHPHC 3 ^
              00:40:16.730 -> MOTDETAT 000000 B
              00:40:16.730 -> ======= Errors =======
              00:40:16.730 -> Checksum     : 0
              00:40:16.730 -> Frame Size   : 0
              00:40:16.730 -> Frame Format : 0
              00:40:16.730 -> Interrupts   : 0
              00:40:16.730 -> ======================
              00:40:16.730 -> <ETX><STX>
              00:40:16.730 -> ADCO 031428067147 B
              00:40:16.730 -> OPTARIF HC.. <
              00:40:16.730 -> ISOUSC 15 <
              00:40:17.833 -> HCHC 003078748 +
              00:40:17.833 -> HCHP 000000000 S
              00:40:17.833 -> PTEC HC.. S
              00:40:17.833 -> IINST 001 X
              00:40:17.833 -> IMAX 002 A
              00:40:17.833 -> PAPP 00140 &
              00:40:17.833 -> HHPHC 3 ^
              00:40:17.833 -> MOTDETAT 000000 B
              00:40:17.833 -> ======= Errors =======
              00:40:17.833 -> Checksum     : 0
              00:40:17.833 -> Frame Size   : 0
              00:40:17.833 -> Frame Format : 0
              00:40:17.833 -> Interrupts   : 0
              00:40:17.833 -> ======================
                Nicolas Fovet
                Oui je peux essayer Teleinfo_DenkyD4.ino mais je ne trouve pas le moyen d'uploader le code sur la carte.
                J'ai l'Arduino IDE à jour, les librairies installées, le sketch compilé sans erreur, mais j'ai essayé plusieurs boards (ESP32 PICO D4, Adafruit QT Py ESP32, ...) dans le board manager et ça n'upload pas.
                Sketch uses 290409 bytes (22%) of program storage space. Maximum is 1310720 bytes.
                Global variables use 22900 bytes (6%) of dynamic memory, leaving 304780 bytes for local variables. Maximum is 327680 bytes.
                esptool.py v4.2.1
                Serial port /dev/cu.usbmodem54AD0005121
                Connecting....
                Chip is ESP32-PICO-V3-02 (revision 3)
                Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None
                Crystal is 40MHz
                MAC: 30:83:98:d6:d6:7c
                Uploading stub...
                A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out)
                Failed uploading: uploading error: exit status 2
                J'ai du louper un truc ?
                EDIT :
                Upload ok, visiblement sur Mac, il faut installer un driver (ch34xser_macos) pour que l'upload fonctionne ... étrange car j'avais bien un port Com identifié en connectant la Denky sans même installer ce driver ...
                Du coup, je retourne sur mon linky pour voir les stats
                  Nicolas Fovet
                  Voici ce que cela donne :
                  Checksum     : 5
                  Frame Size   : 6
                  Frame Format : 1
                  Interrupts   : 604
                  Enormément d'interruption de trames ...
                  Impossible de copier/coller ici tout l'enregistrement, l'outil du forum me bloque pour détection de spam ... Mais si je prend un extract :
                  {« _UPTIME »:27}
                  <ETX>IN-1<TAB>H230120213000<TAB>00000<TAB>=
                  UMOY1<TAB>H230120000000020!
                  <INTERRUPT>0030101<TAB>;
                  1<TAB> <INTERRUPT>E          MESSAGE         <TAB><
                  PRM<TAB>14398108460440:
                  <INTERRUPT>000<TAB>
                  <INTERRUPT><TAB>01<TAB>
                  <INTERRUPT><TAB>00<TAB>$
                  <INTERRUPT>+1<TAB>00<TAB>B
                  PF+1<TAB>00008001 NONUTILE NONUTILE <INTERRUPT><TAB> NUTILE NONUTILE NONUTILE NONUTI<INTERRUPT> <TAB><TAB>9
                  <ETX><STX>
                  ADSC<TAB>031861969570<TAB>D
                  VTIC<TAB>02<TAB>J
                  DATE<TAB>H230120222740<
                  NGT<INTERRUPT><INTERRUPT><ETX>   <TAB>,
                  <INTERRUPT><TAB><TAB>DEX NON CONSO <TAB>0
                  EAST<TAB>000011109<TAB>[
                  EASF01<TAB>000011109
                  EASF02000000000<TAB>#
                  <INTERRUPT><INTERRUPT>02000000000<TAB>$
                  <INTERRUPT>04<TAB>000000000<TAB>%
                  EASF05<TAB>000000000<TAB>&
                  EASF06<TAB>000000000<TAB>’
                  EASF07<TAB>000000000
                  <INTERRUPT><INTERRUPT>08000000000<TAB>)
                  <INTERRUPT>09<TAB>000000000<TAB>*
                  EASF10<TAB>000000000<TAB> »
                  EASD01<TAB>000011109<TAB>,
                  EASD02<TAB>000000000
                  <INTERRUPT><INTERRUPT>04<TAB>000000000<TAB>#
                  EAIT<TAB>014276464<TAB>’
                  ERQ1<TAB>000006959<TAB>X
                  ERQ2<TAB>000033509<TAB>P
                  ERQ3<TAB>000000048
                  <INTERRUPT>4000000048<TAB>
                  1<TAB>000<TAB>,
                  1<TAB>031<TAB>@
                  <INTERRUPT><TAB>03<TAB>B
                  <ETX><TAB>03<TAB>\
                  <TAB>TS<TAB>00011<TAB>H
                  SMAXSN<TAB>H230120181438<TAB>00032<TAB>3
                  SMAXSN-1<TAB>H020008080240<TAB>00030<TAB>
                  <TAB><TAB><TAB>00000<TAB><
                  AXIN<TAB>H230120131550<TAB>02463<TAB>)
                  SMAXIN-1<TAB>H23010800280400311<TAB>
                  <STX><STX><TAB><TAB>030100220000<TAB>00000<TAB>]
                  CCAIN-1<TAB>H230120213000<TAB>00000<
                  UMO0020000000000<TAB>030<TAB>!
                  <TAB>003A0101<TAB>;
                  MSG1<TAB>PAS DE          MESSAGE   <
                  04288018570540<TAB>;
                  <TAB><TAB>000<TAB>B
                  D<TAB>01<TAB>N
                  OURF<TAB>00<TAB>&
                  NJOURF+1<TAB>00<TAB>B
                  PJOURF+1<TAB>00008001 NONUTILE<INTERRUPT><TAB> LONUTILE NONUTILE NONUTILE NONUT<INTERRUPT> <TAB>E NONUTILE<TAB>9
                  <ETX><STX>
                  VTIC<TAB>02<TAB>J
                  DATE<TAB>H230120222742<
                  <INTERRUPT><INTERRUPT>02<TAB>000000000<TAB>$
                  ERQ3<TAB>000000048
                  1<TAB>000<TAB>,
                  1<TAB>031<TAB>@
                  <ETX><TAB>03<TAB>\
                  SMAXSN-1<TAB>020008080240<TAB>00030<TAB>L
                  SMAXIN-1<TAB>H23000800280400311<TAB>
                  <TAB>003A0101<TAB>;
                  <TAB><TAB>000<TAB>B
                  F<TAB>01<TAB>N
                  OURF<TAB>00<TAB>&
                  PJOURF+1<TAB>00008001 NONUTILE<INTERRUPT> <TAB> ONUTILE NONUTILE NONUTILE NONUT<INTERRUPT> <TAB>E NONUTILE<TAB>9
                  <ETX><STX>
                  VTIC<TAB>02<TAB>J
                  DATE<TAB>H230120222744<
                  EASF02<TAB>000000000<TAB>#
                  EASF03<TAB>000000000<INTERRUPT>
                  EASF04000000000<TAB>%
                  <INTERRUPT><INTERRUPT>04<TAB>000000000<TAB>&
                  <INTERRUPT>04<TAB>000000000<TAB>’
                  EASF07<TAB>000000000<TAB>(
                  EASF08<TAB>000000000<TAB>)
                  EASF09<TAB>000000000(
                  <INTERRUPT><INTERRUPT>00000000000<TAB>
                  <INTERRUPT>01<TAB>000011109<TAB>,
                  EASD02<TAB>000000000<TAB>!
                  EASD03<TAB>000000000<TAB> »
                  EASD04<TAB>000000000<STX>
                  <INTERRUPT>004064444<TAB>’
                  <INTERRUPT>1<TAB>000004959<TAB>X
                  0<TAB>000033509<TAB>P
                  ERQ3<TAB>000121259<TAB>Q
                  ERQ4<TAB>000000068<TAB>L
                  IRMS1<TAB>000<TAB>.
                  URMS1<TAB>231
                  PREF<TAB>02
                  PCOUP<TAB>02
                  SINS00000
                  030100181438<TAB>00032<TAB>3
                  SMAXSN-1<TAB>H230119180340<TAB>00030<TAB>
                  SINSTI<TAB>00000<TAB>
                    Checksum     : 5
                    Frame Size   : 6
                    Frame Format : 1
                    Interrupts   : 604
                    {« _UPTIME »:27}
                    <ETX><STX>
                    VTIC<TAB>02<TAB>J
                    ERQ3<TAB>000000048
                    1<TAB>000<TAB>,
                    1<TAB>031<TAB>@
                    <ETX><TAB>03<TAB>\
                    <TAB>003A0101<TAB>;
                    <TAB><TAB>000<TAB>B
                    D<TAB>01<TAB>N
                    OURF<TAB>00<TAB>&
                    <ETX><STX>
                    VTIC<TAB>02<TAB>J
                    ERQ3<TAB>000000048
                    1<TAB>000<TAB>,
                    1<TAB>031<TAB>@
                    <ETX><TAB>03<TAB>\
                    <TAB>003A0101<TAB>;
                    <TAB><TAB>000<TAB>B
                    F<TAB>01<TAB>N
                    OURF<TAB>00<TAB>&
                    <ETX><STX>
                    VTIC<TAB>02<TAB>J
                    IRMS1<TAB>000<TAB>.
                    URMS1<TAB>231
                    PREF<TAB>02
                    PCOUP<TAB>02
                    SINS00000
                    @Nicolas-Fovet il faut choisir la board Denky puis après dans la config de la board pico v3 02
                    Si sa peine avant d’upload tu appuis sur le bouton boot puis en laissant appuyer tu appuis/lache reset ça va le forcer en upload
                    Nicolas FovetN 1 Reply Last reply
                      Nicolas Fovet
                      @Charles , upload ok, c'était un problème de driver du cp21xx sur MacOs.
                      J'ai posté les trames dans mon précèdent message.
                        @Nicolas-Fovet je crois que cette fois j'ai compris, dire que je pensais qu'il y avait un soucis à la conception mais c'est tout simplement ton Linky qui envoi des Frame Interrupt à tout va et ça c'est pas encore géré dans la librairie. Merci encore à FrColin pour ce patch.
                        Je viens de faire un push avec une version modifiée des 2 programmes de test que tu as essayé, si tu pouvais tester et faire un retour ça serait top.
                        ça serait bien aussi si @Samquad pouvait aussi faire ce test il semblait avoir les mêmes soucis.
                        Question bête tu es en zone très urbaine ou à la campagne ?
                          Extartait de la spec page 19
                          Cas d’une interruption de l’émission des trames d’information.
                          En fonctionnement nominal de l’appareil de comptage, l'émission d’informations sur la liaison de télé-information client peut
                          être momentanément interrompue durant le cours de l’émission d’une trame du fait du déroulement d’une autre opération
                          de communication avec l’appareil de comptage (par exemple, le relevé ou la programmation de l’appareil par un accès
                          téléphonique ou un accès par le bus de téléreport ou la liaison optique). Lorsqu’elle reprend son déroulement normal,
                          l’émission commence au début de la trame afin de permettre un recalage des dispositifs qui y sont raccordés. Les données
                          émises correspondent à la situation de l’appareil de comptage au moment où il recommence à émettre. Du fait de cette
                          particularité de fonctionnement, les systèmes qui sont raccordés à cette sortie sont contraints d’être absolument équipés d’un
                          mode de fonctionnement dégradé leur permettant de gérer correctement ces périodes d’absence d’émission (pas de blocage
                          de fonctionnement, ni comportement erratique).
                          Dans ce but, lors d’une telle interruption de l’émission :
                          • le caractère ASCII « End Of Transmission » alias « EOT » de valeur 0x04 est généré avant l’interruption de l’émission,
                          • la reprise de l'émission se fait par un début de trame avec l’émission du caractère ASCII « Start of TeXt » alias « STX » de
                            valeur 0x02.
                              valeur 0x02.
                            Nicolas Fovet
                            @Charles merci pour ta réactivité 😉
                            Je suis dans un lotissement en campagne.
                            Voici ce que j'obtiens :
                            sts Jul 29 2019 12:21:46
                            rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                            configsip: 271414342, SPIWP:0xee
                            clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
                            mode:DIO, clock div:1
                            load:0x3fff0030,len:1184
                            load:0x40078000,storique
                            TIC RX=GPIO8  Mode:Standard
                            <TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><ETX><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><STX><TAB><INTERRUPT><TAB><ETX><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><STX><STX><TAB><INTERRUPT><STX><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><STX><STX><TAB><INTERRUPT><STX><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX>
                            {« _UPTIME »:49}
                            <ETX><TAB>-1<TAB>030121150000<TAB>01740<TAB>J
                            UMOY1<TAB>H230121155000<TAB>024
                            STG<INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><STX><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><ETX>CAIN-1<TAB>H230121150000<TAB>01740<TAB>J
                            UMOY1<TAB>H230120044000025<TAB>,
                            <INTERRUPT><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><ETX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><ETX>CAIN-1<TAB>H230121150000<TAB>01740<TAB>J
                            <INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><STX><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><STX><STX><TAB><TAB><INTERRUPT><STX><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><STX><TAB><TAB><INTERRUPT><STX><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><INTERRUPT><TAB><INTERRUPT><STX><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><ETX><INTERRUPT><STX><TAB><TAB><ETX><TAB>02<TAB>J
                            <INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><INTERRUPT><TAB><ETX><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><INTERRUPT><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><INTERRUPT><TAB><STX><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><ETX><ETX><TAB><TAB><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><ETX><INTERRUPT><STX><TAB><TAB><ETX><TAB>02<TAB>J
                            <INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><STX><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><STX><INTERRUPT><ETX><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><STX><INTERRUPT><TAB><INTERRUPT><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><STX><TAB><INTERRUPT><INTERRUPT><TAB><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><INTERRUPT><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><INTERRUPT><TAB><INTERRUPT><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><TAB><STX><ETX><TAB>-1<TAB>030121150000<TAB>01740<TAB>J
                            UMOY1<TAB>H230121155000<TAB>224
                            STGE<TAB>002�0200<
                            0� <INTERRUPT><TAB>
                              {« _UPTIME »:49}
                              STGE<TAB>002�0200<
                              0� <INTERRUPT><TAB>
                              @Nicolas-Fovet Alors ça c'est curieux, et je reste de plus en plus frustré (comme toi j'imagine) parce que je n'arrive pas à reproduire le problème, c'est peut être lié au hardware mais sans pouvoir regarder et faire des tests en direct à la sortie de ton compteur impossible pour moi d'investiguer plus loin mis à part enfin trouver un des linky près de chez moi qui déconne pareil.
                                Nicolas FovetN Offline
                                Nicolas Fovet
                                @Charles oui c'est frustrant effectivement.
                                Du coup, je reviens à ma proposition initiale. Ne pourrait-il pas y avoir une évolution de la librairie pour empêcher l'affichage et l'envoi sur MQTT de tout caractère non alphanumérique dans les labels et les contenus des données des labels ?
                                Cela ne résoudra pas totalement le problème mais permettra au moins d'avoir un json exploitable dans les trames MQTT.
                                  @Nicolas-Fovet oui c'est une excellente idée, mais en réfléchissant et la je ne comprends pas pourquoi, mais normalement ça devrait déjà être le cas puisque toute ligne avec une mauvaise checksum (donc caractère pourri) n'est pas retenue (donc pas envoyée via MQTT ou autre) Il faut que je vois pourquoi ça fait ça mais dans ton 1er message, les logs de la console tasmota n'indiquent pas d'envoi MQTT avec des mauvais caractères (hormis après le copier/coller) pourtant ou je me trompe ?
                                    FredLo
                                    wrote on last edited by FredLo
                                    Bonjour @Charles,
                                    Tout d'abord, un grand merci pour ton travail. J'utilise un module micro téléinfo V2.0 depuis plus d'an maintenant, et il marche du tonnerre ! J'ai juste eu besoin d'une modif hardware pour lui faire accepter le passage du Linky en mode Standard.
                                    Je viens juste d'acheter un Denky D4 pour pouvoir sortir mon raspberry du garage (à coté du Linky, obviously) et le mettre à l'abris derrière un onduleur dans la maison.
                                    Ma config:
                                    Rasberry Pi 4 avec Jeedom et le plugin JMQTT, entres autres. Le Broker est également sur le Rasp.
                                    J'ai des modules domotiques en Wifi (Shelly) et en Zigbee (SonOff, Xiaomi et même Lidl !)
                                    Le Linky:
                                    Un seul compteur, en mode Standard car production photovoltaïque pour autoconsommation avec revente de surplus, presque comme Nicolas.
                                    Mes constations.
                                    La simplicité de configuration de Tasmota est enthousiasmante, j'ai très vite eu des trames MQTT remontées jusqu'au Broker et visibles dans Jeedom. Mais lors de mon premier vrai test, avec des informations de TIC, j'ai eu également un blocage:
                                    Les premières payloads MQTT TIC étaient bonnes, dans le sens JSON du terme: Jeedom me permettait de les éclater en sous modules pour faciliter la création de nouvelle commandes. Et puis brusquement, les informations ne remontaient plus. La payload TIC était toujours reçue régulièrement mais contenait systématiquement un éléments étrange en bout de chaîne: "EST":8062115. Jeedom ne considérait plus cette payload comme du JSON valide. Il me semble qu'il s'agissait d'un doublon de l'info EAST mais avec un caractère corrompu. La valeur correspondait bien à l'info EAST, mais un peu plus ancienne et non mise à jour.
                                    Le test d'aujourd'hui a été beaucoup plus stable (plus d'une heure), j'ai branché plus sérieusement les fils à la carte Denky D4. Chance ou effet réel ? je ne bascule pas tout de suite sur cette solution car j'attends une potentielle compatibilité MQTT du plugin teleinfo de Jeedom.
                                    Je peux fournir des exemples de payload avec le défaut et des exemples fonctionnels. Et accessoirement, J’habite également dans la Vienne, à coté de Châtellerault 🙂
                                    Bonne soirée
                                      ThiefMasterT Offline
                                      ThiefMaster
                                      FYI after I replaced the cable between the Linky and the D4, everything is fine. So I guess the (very thin) cable I used before simply didn't have a good connection...
                                        @ThiefMaster thank for the follow up, interesting case 🙂
