  3. Blog articles comments
  4. Enable SSL for apache server in 5 minutes
apache2cloudlinuxapachecertificate
11 Posts 10 Posters 6.2k Views 2 Watching
    This post describe how to quickly enable SSL for apache web server under linux. This has been done on a clouded virtual machine, the Linux distribution is Ubuntu 12.04 LTS Server, the one provided by Amazon Aws or Microsoft Azure.… Continue Reading
      AfroViking
      Thank you so much!!! I can finally go to bed now 😄
      BTW I would also recommend these lines in the default-ssl or default-ssl.conf (depending on what is in your folder when logged into your server
      /etc/apache2/sites-available/
      under: <Virtual host default:443>
      Find a place to put this three lines
      Header add Strict-Transport-Security "max-age=1576800"
      SSLProtocol all -SSLv2 -SSLv3
      SSLCipherSuite HIGH:!aNULL:!MD5
      </VirtualHost>
      This will give you a better score at https://sslanalyzer.comodoca.com/
        @AfroViking
        thanks for the head up, I will add these line for sure
        • I Offline
          I Offline
          Israel Barragan
          So simple. I had to do a few trick on my apache configuration becabuse I compiled it from source but your post helped a lot. I have setting up my SSL on my Debian and Linux Mint distros.
          • Raju GinneR Offline
            Raju GinneR Offline
            Raju Ginne
            how to enable ssl for only website in server all other are port 80
            if i enabled ssl module then port 80 http traffic refusing
              test123
              You bloody genius.
                R Offline
                rubybenson
                Thanks for this great article. I got many ideas from this blog. You may get some more ideas here http://bit.ly/2Afdi6i
                • Oliver RussellO Offline
                  Oliver Russell
                  Nice guide for integrating <a href="https://www.cloudways.com/blog/add-ssl-certificates-to-custom-php-sites/">PHP with SSL</a>. But this doesn't include how to write redirect rules so your http php site is redirect to https urls. You can write the redirect rules in .htacess.
                    E Offline
                    Ethan Roman
                    Thank you
                    • I Offline
                      I Offline
                      imheretobeuseful
                      AWS amazon, I was able to make this guide working in 2020.
                      anyway, for apache2/php7 you have to change this:
                      000-default-ssl is now default-ssl
                      also pay attention to symlink creation. if red, something bad. if its blue, good 4 you.
                      also, depending on the distribution, to check apache you may apachectl -V
                      cercatore @ github.com
                      or httpdctl -V
                      • Hasibur JoyH Offline
                        Hasibur Joy
                        Hi, This is hasibur joy. I have a site and i also want to enable SSL for my site: here is my site link: Blog With Joy.
