    Enable SSL for apache server in 5 minutes
    apache2cloudlinuxapachecertificate
    11 Posts 10 Posters 5.9k Views 2 Watching
      This post describe how to quickly enable SSL for apache web server under linux. This has been done on a clouded virtual machine, the Linux distribution is Ubuntu 12.04 LTS Server, the one provided by Amazon Aws or Microsoft Azure.… Continue Reading
        AfroViking
        Thank you so much!!! I can finally go to bed now 😄
        BTW I would also recommend these lines in the default-ssl or default-ssl.conf (depending on what is in your folder when logged into your server
        /etc/apache2/sites-available/
        under: <Virtual host default:443>
        Find a place to put this three lines
        Header add Strict-Transport-Security "max-age=1576800"
        SSLProtocol all -SSLv2 -SSLv3
        SSLCipherSuite HIGH:!aNULL:!MD5
        </VirtualHost>
        This will give you a better score at https://sslanalyzer.comodoca.com/
          @AfroViking
          thanks for the head up, I will add these line for sure
          • I Offline
            Israel Barragan
            So simple. I had to do a few trick on my apache configuration becabuse I compiled it from source but your post helped a lot. I have setting up my SSL on my Debian and Linux Mint distros.
            • Raju GinneR Offline
              Raju Ginne
              how to enable ssl for only website in server all other are port 80
              if i enabled ssl module then port 80 http traffic refusing
                test123
                You bloody genius.
                  rubybenson
                  Thanks for this great article. I got many ideas from this blog. You may get some more ideas here http://bit.ly/2Afdi6i
                  • Oliver RussellO Offline
                    Oliver Russell
                    Nice guide for integrating <a href="https://www.cloudways.com/blog/add-ssl-certificates-to-custom-php-sites/">PHP with SSL</a>. But this doesn't include how to write redirect rules so your http php site is redirect to https urls. You can write the redirect rules in .htacess.
                      Ethan Roman
                      Thank you
                      • I Offline
                        imheretobeuseful
                        AWS amazon, I was able to make this guide working in 2020.
                        anyway, for apache2/php7 you have to change this:
                        000-default-ssl is now default-ssl
                        also pay attention to symlink creation. if red, something bad. if its blue, good 4 you.
                        also, depending on the distribution, to check apache you may apachectl -V
                        cercatore @ github.com
                        or httpdctl -V
                        • Hasibur JoyH Offline
                          Hasibur Joy
                          Hi, This is hasibur joy. I have a site and i also want to enable SSL for my site: here is my site link: Blog With Joy.
