  3. Blog articles comments
  4. Enable SSL for apache server in 5 minutes
apache2cloudlinuxapachecertificate
11 Posts 10 Posters 6.2k Views 2 Watching
    AfroViking
    Thank you so much!!! I can finally go to bed now 😄
    BTW I would also recommend these lines in the default-ssl or default-ssl.conf (depending on what is in your folder when logged into your server
    /etc/apache2/sites-available/
    under: <Virtual host default:443>
    Find a place to put this three lines
    Header add Strict-Transport-Security "max-age=1576800"
    SSLProtocol all -SSLv2 -SSLv3
    SSLCipherSuite HIGH:!aNULL:!MD5
    </VirtualHost>
    This will give you a better score at https://sslanalyzer.comodoca.com/
      @AfroViking
      thanks for the head up, I will add these line for sure
      • I Offline
        I Offline
        Israel Barragan
        So simple. I had to do a few trick on my apache configuration becabuse I compiled it from source but your post helped a lot. I have setting up my SSL on my Debian and Linux Mint distros.
        • Raju GinneR Offline
          Raju GinneR Offline
          Raju Ginne
          how to enable ssl for only website in server all other are port 80
          if i enabled ssl module then port 80 http traffic refusing
            test123
            You bloody genius.
              R Offline
              rubybenson
              Thanks for this great article. I got many ideas from this blog. You may get some more ideas here http://bit.ly/2Afdi6i
              • Oliver RussellO Offline
                Oliver Russell
                Nice guide for integrating <a href="https://www.cloudways.com/blog/add-ssl-certificates-to-custom-php-sites/">PHP with SSL</a>. But this doesn't include how to write redirect rules so your http php site is redirect to https urls. You can write the redirect rules in .htacess.
                  E Offline
                  Ethan Roman
                  Thank you
                  • I Offline
                    I Offline
                    imheretobeuseful
                    AWS amazon, I was able to make this guide working in 2020.
                    anyway, for apache2/php7 you have to change this:
                    000-default-ssl is now default-ssl
                    also pay attention to symlink creation. if red, something bad. if its blue, good 4 you.
                    also, depending on the distribution, to check apache you may apachectl -V
                    cercatore @ github.com
                    or httpdctl -V
                    • Hasibur JoyH Offline
                      Hasibur Joy
                      Hi, This is hasibur joy. I have a site and i also want to enable SSL for my site: here is my site link: Blog With Joy.
