  5. Messages corrompus, Linky en mode standard
21 Posts 5 Posters 10.5k Views 3 Watching
  • K kenavo
    Bonjour @Charles
    Voici les résultats des commandes ps -aux et top :
    ~ ps -aux
    USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
    root           1  0.0  0.0    424     0 ?        Ss   15:19   0:00 /package/admin/s6/command/s6-svscan -d4 -- /run/service
    root          16  0.0  0.0    208     0 ?        S    15:19   0:00 s6-supervise s6-linux-init-shutdownd
    root          19  0.0  0.0    192     0 ?        Ss   15:19   0:00 /package/admin/s6-linux-init/command/s6-linux-init-shutdownd -d3 -c /run/s6/base
    root          25  0.0  0.0    208     0 ?        S    15:19   0:00 s6-supervise s6rc-fdholder
    root          26  0.0  0.0    208     0 ?        S    15:19   0:00 s6-supervise sshd
    root          27  0.0  0.0    208     0 ?        S    15:19   0:00 s6-supervise ttyd
    root          28  0.0  0.0    208     0 ?        S    15:19   0:00 s6-supervise s6rc-oneshot-runner
    root          36  0.0  0.0    196     0 ?        Ss   15:19   0:00 /package/admin/s6/command/s6-ipcserverd -1 -- /package/admin/s6/command/s6-ipcse
    root         336  0.0  0.1   6796  4864 ?        Ss   15:19   0:00 sshd: /usr/sbin/sshd -D -e [listener] 0 of 10-100 startups
    root         341  0.0  0.0  16256  2816 ?        Ssl  15:19   0:00 ttyd -d1 -i hassio --writable -p 62795 tmux -u new -A -s homeassistant zsh -l
    root         380  0.0  0.0   2528  2048 pts/0    Ss+  15:20   0:00 tmux -u new -A -s homeassistant zsh -l
    root         383  0.0  0.0   3016  2180 ?        S    15:20   0:00 tmux -u new -A -s homeassistant zsh -l
    root         387  0.8  0.1   5540  4272 pts/1    Ss   15:20   0:00 zsh -l
    root         446  0.0  0.0   2748  1792 pts/1    R+   15:21   0:00 ps -aux
    top - 15:23:23 up 4 min,  0 user,  load average: 1.29, 1.00, 0.46
    Tasks:  14 total,   1 running,  13 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 16.7 us, 13.3 sy,  0.0 ni, 70.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3989.8 total,   1812.4 free,    971.0 used,   1269.5 buff/cache
    MiB Swap:   1317.1 total,   1317.1 free,      0.0 used.   3018.8 avail Mem
        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
          1 root      20   0     424      0      0 S   0.0   0.0   0:00.01 s6-svscan
         16 root      20   0     208      0      0 S   0.0   0.0   0:00.00 s6-supervise
         19 root      20   0     192      0      0 S   0.0   0.0   0:00.00 s6-linux-init-s
         25 root      20   0     208      0      0 S   0.0   0.0   0:00.00 s6-supervise
         26 root      20   0     208      0      0 S   0.0   0.0   0:00.00 s6-supervise
         27 root      20   0     208      0      0 S   0.0   0.0   0:00.00 s6-supervise
         28 root      20   0     208      0      0 S   0.0   0.0   0:00.00 s6-supervise
         36 root      20   0     196      0      0 S   0.0   0.0   0:00.00 s6-ipcserverd
        336 root      20   0    6796   4864   4096 S   0.0   0.1   0:00.02 sshd
        341 root      20   0   16256   2816   2432 S   0.0   0.1   0:00.03 ttyd
        380 root      20   0    2528   2048   1664 S   0.0   0.1   0:00.00 tmux: client
        383 root      20   0    3188   2308   1536 S   0.0   0.1   0:00.04 tmux: server
        387 root      20   0    5540   4272   2304 S   0.0   0.1   0:00.59 zsh
        464 root      20   0    4068   2944   1024 R   0.0   0.1   0:00.00 top
    Je ne vois rien d'anormal...
    Par contre, j'ai installé un debian sur une autre carte et j'ai fait des essais avec picocom et cela fonctionne très bien. Ton intuition était bonne !
    Il semblerait donc que ce soit l'intégration dans Home Assistant qui pose problème.
    Il va donc falloir que je regarde cela de plus près, mais ce qui me gêne, c'est que cette intégration est assez simple et que je n'ai pas beaucoup de paramètres sur lesquels je peux jouer.
    Je te remercie de m'avoir mis sur la voie,
    Bonne journée.
    @kenavo ah yes l'intégration HA devait ouvrir le même port (logique ceci dit), mais c'est curieux qu'elle ne fonctionne pas quand elle est toute seule, tu as d'autres USB branchés et/ou configuré dans HA ?
    K 1 Reply Last reply
      K Offline
      K Offline
      kenavo
      Non, rien du tout.
      Je ne vois vraiment pas.
      Je vais sûrement finir par refaire une SD avec home assistant et uniquement le module teleinfo intégré pour tester, mais ça ne me dira pas ce qui ne va pas sur ma configuration.
        devchristof
        wrote on last edited by devchristof
        Bonjour à vous, Kenavo j'ai le même souci que toi, je suis sur HA sous proxmox sans passer par un hub usb, j'ai essayé avec un hub alimenté aussi.
        j'ai utilisé un cable cat5e et cable classique de téléphone, j'ai le mem resultat, le cable fait environ 1M
        10:31:14.909 DEBUG teleinfo2mqtt: Split frame [PJORF+1,00008001 NONTILE NONQILNONUTILE NONTIL NONUTILANOTILE NONTIL NONUTILE NOUTILE NONILE,9
        10:31:14.909  WARN teleinfo2mqtt: Invalid value received for label PJORF+1 [00008001 NONTILE NONQILNONUTILE NONTIL NONUTILANOTILE NONTIL NONUTILE NOUTILE NONILE]
        10:31:14.942 DEBUG teleinfo2mqtt: Raw frame [ASC	021875392346	A]
        10:31:14.942 DEBUG teleinfo2mqtt: Split frame [ASC,021875392346,A]
        10:31:14.942  WARN teleinfo2mqtt: Invalid value received for label ASC [021875392346]
        10:31:14.988 DEBUG teleinfo2mqtt: Raw frame [TI	02	J
        10:31:14.988 DEBUG teleinfo2mqtt: Split frame [TI,02,J
        10:31:14.988  WARN teleinfo2mqtt: Invalid value received for label TI [02]
        10:31:15.036 DEBUG teleinfo2mqtt: Raw frame [DATE	E240825103120		:
        10:31:15.036 DEBUG teleinfo2mqtt: Split frame [DATE,E240825103120,:
        10:31:15.036 DEBUG teleinfo2mqtt: Value for label DATE =
        10:31:15.036 DEBUG teleinfo2mqtt: Frame parsed [[object Object]]
        10:31:15.085 DEBUG teleinfo2mqtt: Raw frame [NGTF     BAE      	8
        10:31:15.085 DEBUG teleinfo2mqtt: Split frame [NGTF     BAE      ,8
        10:31:15.085  WARN teleinfo2mqtt: Corrupted line received [NGTF     BAE      	8
        10:31:15.126 DEBUG teleinfo2mqtt: Raw frame [LTRF	     BASE
        10:31:15.126 DEBUG teleinfo2mqtt: Split frame [LTRF,     BASE     ,
        10:31:15.126  WARN teleinfo2mqtt: Invalid value received for label LTRF [     BASE     ]
        10:31:15.169 DEBUG teleinfo2mqtt: Raw frame [EAST	080905375	8
        10:31:15.169 DEBUG teleinfo2mqtt: Split frame [EAST,080905375,8
        10:31:15.169 DEBUG teleinfo2mqtt: Value for label EAST = 080905375
        10:31:15.169 DEBUG teleinfo2mqtt: Frame parsed [[object Object]]
        10:31:15.212 DEBUG teleinfo2mqtt: Raw frame [EASF01	074831120	<
        10:31:15.212 DEBUG teleinfo2mqtt: Split frame [EASF01,074831120,<
        10:31:15.212 DEBUG teleinfo2mqtt: Value for label EASF01 = 074831120
        10:31:15.212 DEBUG teleinfo2mqtt: Frame parsed [[object Object]]
        10:31:15.255 DEBUG teleinfo2mqtt: Raw frame [ASF02	007073732	@
        10:31:15.255 DEBUG teleinfo2mqtt: Split frame [ASF02,007073732,@
        10:31:15.255  WARN teleinfo2mqtt: Invalid value received for label ASF02 [007073732]
        10:31:15.298 DEBUG teleinfo2mqtt: Raw frame [EAS03	000659339
        10:31:15.298 DEBUG teleinfo2mqtt: Split frame [EAS03,000659339,
        10:31:15.298  WARN teleinfo2mqtt: Invalid value received for label EAS03 [000659339]
        10:31:15.341 DEBUG teleinfo2mqtt: Raw frame [EASF04	002341184	<
        10:31:15.341 DEBUG teleinfo2mqtt: Split frame [EASF04,002341184,<
        10:31:15.341 DEBUG teleinfo2mqtt: Value for label EASF04 = 002341184
        10:31:15.341 DEBUG teleinfo2mqtt: Frame parsed [[object Object]]
        10:31:15.384 DEBUG teleinfo2mqtt: Raw frame [EASF05	000000000	&	]
        10:31:15.384 DEBUG teleinfo2mqtt: Split frame [EASF05,000000000,&,]
        10:31:15.385 DEBUG teleinfo2mqtt: Value for label EASF05 = 000000000
        10:31:15.385 DEBUG teleinfo2mqtt: Frame parsed [[object Object]]
        10:31:15.427 DEBUG teleinfo2mqtt: Raw frame [EASF06	000000000'
        10:31:15.427 DEBUG teleinfo2mqtt: Split frame [EASF06,000000000'
        10:31:15.427  WARN teleinfo2mqtt: Corrupted line received [EASF06	000000000'
        10:31:15.470 DEBUG teleinfo2mqtt: Raw frame [AASF0&	000000000	 ]
        10:31:15.470 DEBUG teleinfo2mqtt: Split frame [AASF0&,000000000, ]
        10:31:15.470  WARN teleinfo2mqtt: Invalid value received for label AASF0& [000000000]
        10:31:15.513 DEBUG teleinfo2mqtt: Raw frame [ESF08	000000000	)
        10:31:15.513 DEBUG teleinfo2mqtt: Split frame [ESF08,000000000,)
        10:31:15.513  WARN teleinfo2mqtt: Invalid value received for label ESF08 [000000000]
        10:31:15.555 DEBUG teleinfo2mqtt: Raw frame [EASF09	000000000	*
        10:31:15.556 DEBUG teleinfo2mqtt: Split frame [EASF09,000000000,*
        10:31:15.556 DEBUG teleinfo2mqtt: Value for label EASF09 = 000000000
        10:31:15.556 DEBUG teleinfo2mqtt: Frame parsed [[object Object]]
        10:31:15.599 DEBUG teleinfo2mqtt: Raw frame [EASF10000000000	"
        10:31:15.599 DEBUG teleinfo2mqtt: Split frame [EASF10000000000,"
        10:31:15.599  WARN teleinfo2mqtt: Corrupted line received [EASF10000000000	"
        10:31:15.643 DEBUG teleinfo2mqtt: Raw frame [EAS01	042091524	C
        10:31:15.643 DEBUG teleinfo2mqtt: Split frame [EAS01,042091524,C
        10:31:15.643  WARN teleinfo2mqtt: Invalid value received for label EAS01 [042091524]
        10:31:15.686 DEBUG teleinfo2mqtt: Raw frame [ASD02	021066349	B]
        10:31:15.686 DEBUG teleinfo2mqtt: Split frame [ASD02,021066349,B]
        10:31:15.686  WARN teleinfo2mqtt: Invalid value received for label ASD02 [021066349]
        10:31:15.730 DEBUG teleinfo2mqtt: Raw frame [EAD03	007046942B
        10:31:15.731 DEBUG teleinfo2mqtt: Split frame [EAD03,007046942B
        10:31:15.731  WARN teleinfo2mqtt: Corrupted line received [EAD03	007046942B
        10:31:15.771 DEBUG teleinfo2mqtt: Raw frame [EAS04	014692540B
        10:31:15.771 DEBUG teleinfo2mqtt: Split frame [EAS04,014692540B
        10:31:15.771  WARN teleinfo2mqtt: Corrupted line received [EAS04	014692540B
        10:31:15.812 DEBUG teleinfo2mqtt: Raw frame [AIT	006867518	/
        10:31:15.812 DEBUG teleinfo2mqtt: Split frame [AIT,006867518,/
        10:31:15.812  WARN teleinfo2mqtt: Invalid value received for label AIT [006867518]
        10:31:15.853 DEBUG teleinfo2mqtt: Raw frame [ER 	005173875	_]
        10:31:15.853 DEBUG teleinfo2mqtt: Split frame [ER ,005173875,_]
        10:31:15.853  WARN teleinfo2mqtt: Invalid value received for label ER  [005173875]
        du cou ça me fait souvent du 0 en soutiré par exemple
        si vous avez des idées car la je seche je vais peut essayer brancher directement sur un raspberry pour voir si c'est pareil
        • D devchristof
          @devchristof avez vous essayé de jouer avec le petit potentiomètre de la carte Teleinfo ?
          G 1 Reply Last reply
            Geoffrey
            @Charles Même problème ici mais en mode historique. Les données sont corrompus. Souvent les dernières lignes sont répétées plusieurs fois. Ou bien elles se chevauchent. Par exemple le numéro de série du linky se retrouvent "bouffé" par le reste. Je n'ai pas pensé à faire de capture sous minicom.
            Au bout d'un moment cela fait planter le Pi. Problème identique sur un Raspberry Pi 3 et un Orange Pi Zero LTS.
            Du coup j'ai acheté deux nouveaux Micro TeleInfo....
            • G Geoffrey
              @Geoffrey je ne suis pas certain que changer de module va solutionner le soucis (sauf peut être si c'était une génération précédente).
              Au bout d'un moment
              c'est assez relatif, genre 1 heure 1 jour 1 mois ?
              Tu peux regarder dans ce repo, pour programmer les chip FTDI (ancienne génération) j'utilisais usb_modeswitch qui faisait comme si tu plug/unplug le dongle physiquement.
              https://github.com/ch2i/ftx_prog/blob/master/flash_replug.sh
              Peut être voir avec ça pour glisser un reset du port USB qui contient le dongle (tt les nuits par exemple) parce que pour planter le PI je vois pas bien comment un USB/Serial à lui tout seul fait ça, sauf si le "lecteur" à des fuites mémoires ou qu'un autre process accède à l'interface.
                Au bout d'un moment
                Geoffrey
                @Charles Ben au début c'était tous les deux jours, puis c'est devenu de plus en plus souvent.... Ca ne tenait plus 1h.... L'ensemble a tourné sans soucis depuis octobre 2024.
                • G Geoffrey
                  @Geoffrey est ce que ce ne serait pas la source du problème ?
                  https://github.com/serialport/node-serialport/issues/1747
                    Geoffrey
                    wrote on last edited by Geoffrey
                    @Nicolas-Bernaerts Ca pourrait si je n'avais que le soucis avec teleinfo-linky mais je l'ai aussi avec Linky Exporter. EDIT Je n'utilise pas le port série du RPi, je suis en USB. Donc pas de console sur le port série.
                    Dans minicom je vois les données corrompus, donc ce n'est pas un soucis du programmes qui lit les données du linky. Au bout d'un moment les lignes
                    HHPHC A ,
                    MOTDETAT 000000 B
                    Se répètent pendant un certain temps plus ou moins aléatoire.
                    Si je débranches le câble venant du linky la LED rouge reste allumée faiblement.
                    Même soucis sur un Orange Pi Zero LTS et sur un Raspberry Pi 3 A+
                      Geoffrey
                      J'ai remis le Teleinfo qui me posait problème, et les messages corrompus sont de retour. Cela se traduit, entre autres, par des numéros de Linky différents dans mes données prométheus.
                      • G Geoffrey
                        Geoffrey
                        @Geoffrey Bon j'en ai trois différents, et ils finissent tous par planter ! Je vais passer sur un PITInfo pour éviter les soucis avec l'USB ....
                          Geoffrey
                          J'ai demandé à faire basculer mon Linky en mode standard, c'est effectif depuis hier.
                          Les données sont toujours et encore corrompues. Quelque soit le module utilisé. Le module le plus ancien est celui qui plante le plus vite.
                          Ce soir j'ai remarqué la chose suivante: Si je débranche le connecteur venant du Linky, la LED rouge continue à clignoter gaiement alors que plus aucune données ne sont censer transiter 😐
                            Geoffrey
                            Je continue mon monologue 😁
                            A force de recherche, je soupçonne de plus en plus un bug dans le driver cdc_acm ou dans le chip CH9102 ou bien dans les deux. J'ai trouvé ce driver et je l'ai installé. Pour le moment, ça tourne depuis hier soir sans corruption des données.
                            • G Geoffrey
                              @Geoffrey c'est mieux avec le nouveau driver ? c'est intéressant comme retour car jusqu'ici personne ne m'a jamais remonté ce type de soucis.
                              nous sommes d'accord sauf si un autre process tente une lecture/ecriture sur le port série en même temps
                              c'est quelle version de l'OS qui tourne sur le PI ?
