  5. Rubriques manquantes
17 Posts 4 Posters 3.3k Views 1 Watching
    @beneva le cable téléphonique c'est parfait, sur 10M je ne sais pas trop comment ça va se comporter en standard car on passe de 1200baud a 9600baud mais normalement ça ne doit pas poser de soucis.
    Concernant l'injection je ne sais pas ce que retourne le Linky (en histo et en standard) mais de mémoire en standard il retourne les données d'injection
    tu pourrais faire une capture de trame (via la console tasmota) quand ça injecte et quand ca n'injecte pas ? Tu as bien un seul compteur Linky qui fait compteur principal de chez toi et gère l'injection ?
    Peut être d'autres personnes utilisant de la production pouraient répondre.
    beneva
    wrote on last edited by beneva
    @Charles Voici les trames :
    12:15:29.301 MQT: tele/tasmota_EB1F34/STATE = {"Time":"2023-04-12T12:15:29","Uptime":"6T05:57:02","UptimeSec":539822,"Heap":161,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":10,"Berry":{"HeapUsed":7,"Objects":109},"POWER1":"OFF","Dimmer":100,"Color":"00FFED","HSBColor":"176,100,100","Channel":[0,100,93],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"xxxxxxx","BSSId":"xxxxxx","Channel":11,"Mode":"11n","RSSI":100,"Signal":-30,"LinkCount":1,"Downtime":"0T00:01:47"}}
    12:15:29.324 MQT: tele/tasmota_EB1F34/SENSOR = {"Time":"2023-04-12T12:15:29","ENERGY":{"TotalStartTime":"2023-03-13T19:26:55","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"Current":2.000,"Load":4},"TIC":{"ADCO":"xxxxxx","ISOUSC":45,"BBRHCJB":7450836,"BBRHPJB":18409182,"BBRHCJW":174214,"BBRHPJW":270655,"BBRHCJR":97931,"BBRHPJR":162452,"PTEC":"HPJB","DEMAIN":"----","IINST":2,"IMAX":90,"PAPP":0,"HHPHC":"A","MOTDETAT":0}}
    12:15:30.611 MQT: tele/tasmota_EB1F34/SENSOR = {"TIC":{"ADCO":"xxxxxx","ISOUSC":45,"BBRHCJB":7450836,"BBRHPJB":18409182,"BBRHCJW":174214,"BBRHPJW":270655,"BBRHCJR":97931,"BBRHPJR":162452,"PTEC":"HPJB","DEMAIN":"----","IINST":2,"IMAX":90,"PAPP":0,"HHPHC":"A","MOTDETAT":0}}
    • Jonathan LacroixJ Jonathan Lacroix
      Hello ! Pour info j'ai exactement le même constat sur mon linky avec depuis le passage à un contrat TEMPO (en mode historique côté linky). Des erreurs en pagaille dans les logs et pas de comptage quotidien.
      Je vais passer en mode standard du coup.
      beneva
      @Jonathan-Lacroix Bonjour, est-ce que le passage en mode standard a amélioré tes problèmes de checksums ?
      Jonathan LacroixJ 1 Reply Last reply
      • B beneva
        Jonathan LacroixJ Offline
        Jonathan Lacroix
        wrote on last edited by Jonathan Lacroix
        @beneva Bonjour,
        Alors le passage en mode standard a été fait ce matin. C'est une intervention d'ENEDIS directement sur le compteur avec coupure électrique, j'aurai pensé qu'ils le feraient à distance mais pas du tout.
        Pour l'instant, j'ai de nouveau problèmes. Après l'intervention, le module en mode historique ne voyait plus rien. Le passage en mode standard via Energyconfig Standard me cause une erreur "grave", le module Tasmota redémarre avec une cause "Exception" et se reset en "Sonoff truc"...
        11:01:08.175 MQT: stat/tasmota_639D05/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":" ","RestartReason":"Exception","Uptime":"0T00:00:06","StartupUTC":"2023-04-14T10:01:02","Sleep":50,"CfgHolder":4617,"BootCount":23,"BCResetTime":"2022-08-06T11:54:03","SaveCount":453,"SaveAddress":"FA000"}}
        11:01:08.230 MQT: stat/tasmota_639D05/STATUS11 = {"StatusSTS":{"Time":"2023-04-14T11:01:08","Uptime":"0T00:00:06","UptimeSec":6,"Vcc":2.993,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Livebox-17E6","BSSId":"50:39:2F:CA:73:D0","Channel":1,"Mode":"11n","RSSI":68,"Signal":-66,"LinkCount":1,"Downtime":"0T00:00:03"}}}
        11:01:08.279 MQT: stat/tasmota_639D05/RESULT = {"Time":"2023-04-14T11:01:08","Uptime":"0T00:00:06","UptimeSec":6,"Vcc":2.989,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Livebox-17E6","BSSId":"50:39:2F:CA:73:D0","Channel":1,"Mode":"11n","RSSI":66,"Signal":-67,"LinkCount":1,"Downtime":"0T00:00:03"}}
        11:01:10.422 QPC: Reset
        @Charles tu as déjà vu un comportement du type ?
        B 1 Reply Last reply
          @beneva Bonjour,
          beneva
          @Jonathan-Lacroix As-tu vérifié que ton module a bien été rebranché sur les bornes I1 et I2 du Linky ?
          • B beneva
            Jonathan Lacroix
            @beneva Tout à fait, c'est vraiment au branchement du module sur le Linky qu'il plante. Si je ne le branche à rien, il reste en mode Wemos Teleinfo. Au moment du branchement --> exception... reboot en "sonoff basic"
            Je suis bloqué 😕 je n'ai aucune idée de la provenance du problème, surtout qu'il a fonctionné niquel en mode historque sur un contrat BASE pendant 6 mois.
              @Jonathan-Lacroix tu as une photo de ton montage et le module ESP que tu as mis dessus ? parfois les clones chinois sont vraiment de piètre qualité. As tu essayé de changer ton alimentation aussi ?
                Jonathan Lacroix
                @Charles Jusqu'à présent, j'utilisais un module ESP8266 D1 mini, de qualité moyenne. Je n'ai pas eu de problèmes majeurs jusqu'à aujourd'hui en mode Historique et sans contrat TEMPO. Quand même bizzarre cette histoire de contrat qui crée des problèmes de checksum en mode historique et qui déconne en mode standard sur ESP8266.
                Mon alimentation est bonne et le passage à un ESP32-S2 règle le problème --> toutes les informations sont affichées. j'ai d'ailleurs BEAUCOUP d'informations, beaucoup plus qu'avec le mode historique. Je suis étonné d'avoir les 3 puissances et même plus !
                La puissance active peut donc être remontée en sortie du Linky, bien que sur l'afficheur on ne puisse pas.
                Je n'aime pas ne pas comprendre l'origine des problèmes mais bon puisque changer le module par un ESP32 résoud le problème je ne vais pas me creuser la tête !
                @beneva si tu utilises un module ESP32 je t'invite à demander à ton fournisseur d'énergie de passer en mode standard 🙂 (ils connaissent pas bien la procédure, mais par exemple si tu es chez EDF il faut insister auprès du service client car c'est eux qui déclenchent l'intervention d'ENEDIS).
                  Jonathan Lacroix
                  EDIT : Je viens de réaliser des mesures. C'est en fait des informations toutes erronées remontées par le module... La puissance appelée puissance active par Tasmota est la puissance apparente en VA (exactement comme en mode historique, comme je l'ai évoqué sur un autre thread).
                  La puissance apparente de Tasmota ne correspond donc à rien de mon point de vue. Il semble que ce soit un calcul réalisé dans le mauvais sens, si la puissance réactive est remontée par la teleinfo.
                  Je vais essayer de me pencher la dedans, mais je ne sais pas si on a accès au code source de ces calculs.
                    @Jonathan-Lacroix tu as tout à fait raison, il faut que je regarde ça de plus prêt. @Nicolas-Bernaerts tu as traité ce mode de puissance dans ta version ? si oui on peu s'en inspirer.
                      @Charles Désolé, je viens de tomber sur ce vieux topic. J'aurais tendance à dire que le calcul devrait être ok sur mon fork. Mais le plus simple serait d'installer la version et de vérifier.
                      @Jonathan-Lacroix pourrais tu essayer ?
