  4. Wemos Teleinfo
  5. WeMos Teleinfo Shield with ESPHome on ESP32-S2 mini - no data being received
3 Posts 2 Posters 9.6k Views 1 Watching
  • H Offline
    H Offline
    harg
    wrote on last edited by harg
    Re: Wemos Teleinfo et ESP Home
    I'm trying to get the Teleinfo data working with the Teleinfo shield on an ESP32-S2 mini using ESPHome for HomeAssistant integration. I've used some of the config in the linked topic and adapted it for my hardware.
    My config looks like:
    esphome:
      friendly_name: bosh
    esp32:
      board: lolin_s2_mini
      variant: esp32s2
      framework:
        type: esp-idf
    # Enable logging
    logger:
      level: DEBUG
      hardware_uart: UART1
    # Enable Home Assistant API
    api:
      encryption:
        key: "***"
    ota:
      password: "***"
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      # Enable fallback hotspot (captive portal) in case wifi connection fails
      ap:
        ssid: "Bosh Fallback Hotspot"
        password: "***"
    captive_portal:
    uart:
      rx_pin: GPIO11
      baud_rate: 1200
      parity: EVEN
      data_bits: 7
    teleinfo:
      update_interval: 60s
      historical_mode: true
    sensor:
      - platform: wifi_signal
        name: "WiFi Signal Sensor"
        unit_of_measurement: dB
        accuracy_decimals: 0
        force_update: false
        icon: mdi:wifi
      - platform: teleinfo
        tag_name: "IRMS1"
        unit_of_measurement: "A"
        icon: mdi:current-ac
        teleinfo_id: linky
        tag_name: "URMS1"
        unit_of_measurement: "V"
        teleinfo_id: linky
        tag_name: "SINSTS"
        device_class: power
        unit_of_measurement: "VA"
        icon: mdi:flash
        teleinfo_id: linky
        tag_name: "EASF01"
        name: "Off-peak hour consumption"
        unit_of_measurement: "kWh"
        accuracy_decimals: 3
        device_class: energy
        state_class: "total_increasing"
        icon: mdi:gauge
        teleinfo_id: linky
        filters:
          - multiply: 0.001
        tag_name: "EASF02"
        name: "Peak hour consumption"
        icon: mdi:gauge
        teleinfo_id: linky
        filters:
          - multiply: 0.001
        tag_name: "LTARF"
        icon: mdi:clock-time-nine-outline
    Here is a picture of the board connected to the Linky:
    Everything compiles and installs correctly but it seems like no data is being received from teleinfo:
    I've checked that my meter is set to "Historical mode" and the baud rate is correct.
    I was not sure of which way round to connect the Linky to the Teleinfo shield, but I tried both ways and neither seems to work.
    Logs from ESPHome:
    [13:40:52][I][app:102]: ESPHome version 2024.2.0 compiled on Mar  4 2024, 10:26:21
    [13:40:52][C][wifi:577]: WiFi:
    [13:40:52][C][wifi:409]:   Local MAC: 80:65:99:E3:ED:BC
    [13:40:52][C][wifi:414]:   SSID: [redacted]
    [13:40:52][C][wifi:415]:   IP Address: 10.5.3.34
    [13:40:52][C][wifi:417]:   BSSID: [redacted]
    [13:40:52][C][wifi:418]:   Hostname: 'bosh'
    [13:40:52][C][wifi:420]:   Signal strength: -77 dB ▂▄▆█
    [13:40:52][C][wifi:424]:   Channel: 6
    [13:40:52][C][wifi:425]:   Subnet: 255.255.255.0
    [13:40:52][C][wifi:426]:   Gateway: 10.5.3.1
    [13:40:52][C][wifi:427]:   DNS1: 10.5.3.1
    [13:40:52][C][wifi:428]:   DNS2: 0.0.0.0
    [13:40:52][C][logger:447]: Logger:
    [13:40:52][C][logger:448]:   Level: DEBUG
    [13:40:52][C][logger:449]:   Log Baud Rate: 115200
    [13:40:52][C][logger:451]:   Hardware UART: UART1
    [13:40:52][C][uart.idf:139]: UART Bus 0:
    [13:40:52][C][uart.idf:141]:   RX Pin: GPIO11
    [13:40:52][C][uart.idf:143]:   RX Buffer Size: 256
    [13:40:52][C][uart.idf:145]:   Baud Rate: 1200 baud
    [13:40:52][C][uart.idf:146]:   Data Bits: 7
    [13:40:52][C][uart.idf:147]:   Parity: EVEN
    [13:40:52][C][uart.idf:148]:   Stop bits: 1
    [13:40:52][C][teleinfo:189]: TeleInfo:
    [13:40:52][C][teleinfo_sensor:012]:   Teleinfo Sensor 'Current'
    [13:40:52][C][teleinfo_sensor:012]:     State Class: ''
    [13:40:52][C][teleinfo_sensor:012]:     Unit of Measurement: 'A'
    [13:40:52][C][teleinfo_sensor:012]:     Accuracy Decimals: 0
    [13:40:52][C][teleinfo_sensor:012]:     Icon: 'mdi:current-ac'
    [13:40:52][C][teleinfo_sensor:012]:   Teleinfo Sensor 'Voltage'
    [13:40:52][C][teleinfo_sensor:012]:     Unit of Measurement: 'V'
    [13:40:52][C][teleinfo_sensor:012]:   Teleinfo Sensor 'Power'
    [13:40:52][C][teleinfo_sensor:012]:     Device Class: 'power'
    [13:40:52][C][teleinfo_sensor:012]:     Unit of Measurement: 'VA'
    [13:40:52][C][teleinfo_sensor:012]:     Icon: 'mdi:flash'
    [13:40:52][C][teleinfo_sensor:012]:   Teleinfo Sensor 'Off-peak hour consumption'
    [13:40:52][C][teleinfo_sensor:012]:     Device Class: 'energy'
    [13:40:52][C][teleinfo_sensor:012]:     State Class: 'total_increasing'
    [13:40:52][C][teleinfo_sensor:012]:     Unit of Measurement: 'kWh'
    [13:40:52][C][teleinfo_sensor:012]:     Accuracy Decimals: 3
    [13:40:52][C][teleinfo_sensor:012]:     Icon: 'mdi:gauge'
    [13:40:52][C][teleinfo_sensor:012]:   Teleinfo Sensor 'Peak hour consumption'
    [13:40:52][C][teleinfo_sensor:012]:   Teleinfo Sensor 'Current price'
    [13:40:52][C][teleinfo_sensor:012]:     Unit of Measurement: 'Wh'
    [13:40:52][C][teleinfo_sensor:012]:     Icon: 'mdi:clock-time-nine-outline'
    [13:40:52][C][captive_portal:088]: Captive Portal:
    [13:40:52][C][mdns:115]: mDNS:
    [13:40:52][C][mdns:116]:   Hostname: bosh
    [13:40:52][C][ota:096]: Over-The-Air Updates:
    [13:40:52][C][ota:097]:   Address: bosh.local:3232
    [13:40:52][C][ota:100]:   Using Password.
    [13:40:52][C][ota:103]:   OTA version: 2.
    Any ideas how to debug this? I'm quite new to this kind of thing? @Charles do you have any ideas?
    H 1 Reply Last reply
    • H harg
      esphome:
        friendly_name: bosh
      esp32:
        variant: esp32s2
        framework:
          type: esp-idf
      # Enable logging
      logger:
        level: DEBUG
      api:
        encryption:
          key: "***"
      ota:
        password: "***"
      wifi:
        ap:
          password: "***"
      captive_portal:
      uart:
        rx_pin: GPIO11
        baud_rate: 1200
        parity: EVEN
        data_bits: 7
      teleinfo:
      sensor:
          force_update: false
          icon: mdi:wifi
          tag_name: "IRMS1"
          teleinfo_id: linky
          tag_name: "URMS1"
          teleinfo_id: linky
          tag_name: "SINSTS"
          device_class: power
          icon: mdi:flash
          teleinfo_id: linky
          tag_name: "EASF01"
          icon: mdi:gauge
          teleinfo_id: linky
          filters:
            - multiply: 0.001
          tag_name: "EASF02"
          icon: mdi:gauge
          teleinfo_id: linky
          filters:
            - multiply: 0.001
          tag_name: "LTARF"
      Logs from ESPHome:
      H Offline
      H Offline
      harg
      OK it looks like I had connected the shield to the wrong terminals on the Linky. I reconnected to the I1 and I2 pins and the LED on the shield started blinking.
      However I'm still not getting data in HomeAssistant.
      The logs are now showing lines like the following:
      [14:43:44][E][teleinfo:038]: bad crc: got 40 except 53
      [14:44:44][E][teleinfo:038]: bad crc: got 66 except 89
      [14:45:44][E][teleinfo:038]: bad crc: got 35 except 46
      What does this mean ?
      • H harg
        @harg looks like you're in standard mode, adding 1K resistor in serial with one of the wire (whatever which one) of teleinfo should solve your issue.
