  4. Wemos Teleinfo
  5. Wemos Teleinfo et ESP Home
4 Posts 3 Posters 2.6k Views 1 Watching
  • Y Offline
    Y Offline
    yannlieb
    Après m'être battu pendant quelque temps avec un D1 mini 8266, le wemos shield et ESPHome, le D1 rebootant de manière aléatoire, voici ma config ESPHome enfin stable.
    Spoiler : j'avais récupéré d'une autre config teleinfo la ligne "tx_pin: GPIO1", une fois commentée, la configuration est stable.
    Disclaimer : Tous les informations disponibles dans le mode standard du Linky ne sont pas reprises dans la config ci-dessous. La config est pour un Linky monophasé.
    esphome:
    esp8266:
      board: nodemcuv2 #d1_mini
    # Enable logging
    logger:
      level: DEBUG
      hardware_uart: UART1
      #baud_rate: 0
    # Enable Home Assistant API
    api:
    ota:
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      # Enable fallback hotspot (captive portal) in case wifi connection fails
      ap:
        ssid: "Esp82-01"
        password: !secret wifi_fallback_password
    captive_portal:
    uart:
      rx_pin: GPIO13
      #tx_pin: GPIO1 # Was crashing when tx_pin was set
      baud_rate: 9600
      parity: EVEN
      data_bits: 7
    teleinfo:
      update_interval: 15s
      historical_mode: false
    sensor:
      - platform: wifi_signal
        name: "WiFi Signal Sensor"
        update_interval: 60s
        unit_of_measurement: dB
        accuracy_decimals: 0
        force_update: false
        icon: mdi:wifi
      - platform: uptime
        unit_of_measurement: s
        force_update: false
        icon: mdi:timer
      - platform: teleinfo
        tag_name: "IRMS1"
        unit_of_measurement: "A"
        icon: mdi:current-ac
        teleinfo_id: myteleinfo
        tag_name: "URMS1"
        unit_of_measurement: "V"
        tag_name: "SINSTS"
        device_class: power
        unit_of_measurement: "VA"
        icon: mdi:flash
        tag_name: "EASF01"
        name: "Index heures creuses"
        unit_of_measurement: "kWh"
        accuracy_decimals: 3
        device_class: energy
        state_class: "total_increasing"
        icon: mdi:gauge
        filters:
          - multiply: 0.001
        tag_name: "EASF02"
        name: "Index heures pleines"
        icon: mdi:gauge
        filters:
          - multiply: 0.001
    text_sensor:
      - platform: template
        update_interval: 30s
        icon: mdi:clock-start
        lambda: |-
          int seconds = (id(uptime_seconds).state);
          int days = seconds / (24 * 3600);
          seconds = seconds % (24 * 3600);
          int hours = seconds / 3600;
          seconds = seconds % 3600;
          int minutes = seconds / 60;
          seconds = seconds % 60;
          if ( days ) {
            return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
          } else if ( hours ) {
            return { (String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
          } else if ( minutes ) {
            return { (String(minutes) +"m "+ String(seconds) +"s").c_str() };
          } else {
            return { (String(seconds) +"s").c_str() };
        tag_name: "LTARF"
        name: "Tarif en cours"
        icon: mdi:clock-time-nine-outline
    • Y yannlieb
      esphome:
      esp8266:
      # Enable logging
      logger:
        level: DEBUG
        #baud_rate: 0
      api:
      ota:
      wifi:
        ap:
          ssid: "Esp82-01"
      captive_portal:
      uart:
        rx_pin: GPIO13
        baud_rate: 9600
        parity: EVEN
        data_bits: 7
      teleinfo:
      sensor:
          force_update: false
          icon: mdi:wifi
        - platform: uptime
          force_update: false
          icon: mdi:timer
          tag_name: "IRMS1"
          tag_name: "URMS1"
          tag_name: "SINSTS"
          device_class: power
          icon: mdi:flash
          tag_name: "EASF01"
          icon: mdi:gauge
          filters:
            - multiply: 0.001
          tag_name: "EASF02"
          icon: mdi:gauge
          filters:
            - multiply: 0.001
      text_sensor:
          lambda: |-
            if ( days ) {
            } else {
          tag_name: "LTARF"
      @yannlieb un grand merci pour ce retour.
      • jerome-labidurieJ Offline
        jerome-labidurie
        Pour ma part, les reboot intempestifs, semblaient plutôt du au logger série. C'est la conf suivante qui a corrigé le problème :
        logger:
          baud_rate: 0
        (HA 2022.12.7, esphome 2022.11.3 en mode mqtt)
        J'ajoute que je suis en mode historique et que tout fonctionne très bien avec une conf dans ce genre :
        uart:
          rx_pin: GPIO13
          # tx_pin: GPIO12 # n'a pas corrigé les reboots
          baud_rate: 1200
          parity: EVEN
          data_bits: 7
        teleinfo:
          historical_mode: true
        sensor:
            tag_name: "HCHC"
            name: "${name} Heures Creuses"
            unit_of_measurement: "Wh"
            icon: mdi:flash
            teleinfo_id: linky
            state_class: total_increasing
            tag_name: "PAPP"
            name: "${name} Puissance Apparente"
            icon: mdi:flash
            teleinfo_id: linky
            device_class: power
        etc... pour les autres tags
        Et en bonus, voici un exemple de conf pour gérer la led:
        light:
          - platform: neopixelbus
            type: GRB
            variant: WS2812
            pin: GPIO14
            num_leds: 1
            effects:
              - pulse:
                 transition_length: 0.5s
                 update_interval: 0.5s
              - pulse:
                 update_interval: 2s
        • jerome-labidurieJ jerome-labidurie
          logger:
            baud_rate: 0
          uart:
            rx_pin: GPIO13
            baud_rate: 1200
            parity: EVEN
            data_bits: 7
          teleinfo:
          sensor:
              tag_name: "HCHC"
              icon: mdi:flash
              teleinfo_id: linky
              tag_name: "PAPP"
              icon: mdi:flash
              teleinfo_id: linky
              device_class: power
          light:
              type: GRB
              variant: WS2812
              pin: GPIO14
              num_leds: 1
              effects:
                - pulse:
                - pulse:
                   update_interval: 2s
          @jerome-labidurie merci pour le retour
          Attention en ESP8266 il n'y a qu'un seul hardware serial (pour ça que je banni au profit de l'ESP32 beaucoup plus souple et performant)
          Donc si t'as un logger série classique sur RX/TX et la téléinfo sur RX (même sur GPIO13 c'est relié a la même uart hard) et bien clairement ça merde. De plus, tu ne peux pas uploader le soft si la téléinfo est branchée car elle fait conflit.
