  5. 14:33:13.536 RTE: Token - Private key missing
17 Posts 2 Posters 3.5k Views 1 Watching
    thierry51170
    je viens de réinstaller la version de @Nicolas-Bernaerts en relancer mon Denky 4 voilà ce message de la console
    00:00:00.003 HDW: ESP32-PICO-V3-02 v3.0 (PSRAM)
    00:00:00.195 UFS: FlashFS mounted with 4068 kB free
    00:00:00.225 CFG: Loaded from File, Compte 105
    00:00:00.230 I2C: Bus1 using GPIO22(SCL) and GPIO21(SDA)
    00:00:00.382 BRY: Berry initialized, RAM used=3773 bytes
    00:00:00.459 CFG: Energy loaded from file
    00:00:00.460 TIC: Teleinfo driver enabled
    00:00:00.460 NRG: Init driver 15
    00:00:00.465 Projet tasmota - Tasmota Version 13.2.0(tasmota)-2_0_14(2023-12-23T07:18:52)
    00:00:00.588 HLP: ftp_help to get help on FTP Server commands
    00:00:00.711 HLP: tcp_help to get help on TCP Server commands
    00:00:00.711 TIC: Partition mounted
    00:00:00.883 TIC: Using default Global Counter method
    00:00:00.883 HLP: Type EnergyConfig to get help on all Teleinfo commands
    00:00:00.885 TIC: Serial set to 7E1 9600 bauds
    00:00:00.008 HLP: tz_help to get help on Timezone commands
    00:00:00.013 HLP: eco_help to get help on Ecowatt module
    00:00:01.848 WIF: Connexion à l'AP1 MonReseau Channel 1 BSSId 54:C4:5B:3D:12:E0 en mode 11n comme EDF...
    00:00:02.146 WIF: Connecté
    14:28:04.141 HTP: Serveur web actif sur EDF avec l'adresse IP 192.168.1.177
    14:28:04.938 MQT: Tentative de connexion...
    14:28:04.964 MQT: Connecté
    14:28:04.968 MQT: maison/tasmota/tele/EDF_teleinfo/LWT = Online (persistant)
    14:28:04.970 MQT: maison/tasmota/cmnd/EDF_teleinfo/POWER =
    14:28:05.102 MQT: maison/tasmota/tele/EDF_teleinfo/INFO1 = {"Info1":{"Module":"Denky D4 (v1.1)","Version":"13.2.0(tasmota)","FallbackTopic":"cmnd/DVES_F5C098_fb/","GroupTopic":"maison/tasmota/cmnd/tasmotas/"}}
    14:28:05.356 MQT: maison/tasmota/tele/EDF_teleinfo/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"EDF","IPAddress":"192.168.1.177","IP6Global":"2001:861:ca1:7c40:4e75:25ff:fef5:c098","IP6Local":"fe80::4e75:25ff:fef5:c098"}}
    14:28:05.609 MQT: maison/tasmota/tele/EDF_teleinfo/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":52}}
    14:28:05.739 MQT: maison/tasmota/stat/EDF_teleinfo/RESULT = {"POWER":"ON"}
    14:28:05.742 MQT: maison/tasmota/stat/EDF_teleinfo/POWER = ON
    14:28:06.095 MQT: maison/tasmota/stat/EDF_teleinfo/RESULT = {"Time":"2024-01-14T14:28:06","Uptime":"0T00:00:05","UptimeSec":5,"Heap":156,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":149,"MqttCount":1,"Berry":{"HeapUsed":4,"Objects":50},"POWER":"ON","Dimmer":23,"Color":"3B3B3B","HSBColor":"0,0,23","Channel":[23,23,23],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"MonReseau","BSSId":"54:C4:5B:3D:12:E0","Channel":1,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:02"}}
    14:28:06.609 MQT: maison/tasmota/stat/EDF_teleinfo/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"https://raw.githubusercontent.com/tasmota/install/main/firmware/unofficial/tasmota32-teleinfo.bin","RestartReason":"Software reset CPU","Uptime":"0T00:00:05","StartupUTC":"2024-01-14T13:28:01","Sleep":50,"CfgHolder":4617,"BootCount":51,"BCResetTime":"2023-12-04T15:20:58","SaveCount":105}}
    14:28:07.006 MQT: maison/tasmota/stat/EDF_teleinfo/STATUS11 = {"StatusSTS":{"Time":"2024-01-14T14:28:06","Uptime":"0T00:00:05","UptimeSec":5,"Heap":155,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":237,"MqttCount":1,"Berry":{"HeapUsed":4,"Objects":50},"POWER":"ON","Dimmer":23,"Color":"3B3B3B","HSBColor":"0,0,23","Channel":[23,23,23],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"MonReseau","BSSId":"54:C4:5B:3D:12:E0","Channel":1,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":1,"Downtime":"0T00:00:02"}}}
    14:28:07.646 MQT: maison/tasmota/stat/EDF_teleinfo/STATUS10 = {"StatusSNS":{"Time":"2024-01-14T14:28:07","ENERGY":{"TotalStartTime":"2023-12-04T15:24:29","Total":0.000,"Yesterday":12.193,"Today":9.021,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":230,"Current":0.0}}}
    14:28:09.762 MQT: maison/tasmota/tele/EDF_teleinfo/STATE = {"Time":"2024-01-14T14:28:09","Uptime":"0T00:00:08","UptimeSec":8,"Heap":154,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":111,"MqttCount":1,"Berry":{"HeapUsed":4,"Objects":50},"POWER":"ON","Dimmer":23,"Color":"3B3B3B","HSBColor":"0,0,23","Channel":[23,23,23],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"MonReseau","BSSId":"54:C4:5B:3D:12:E0","Channel":1,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":1,"Downtime":"0T00:00:02"}}
    14:28:10.267 MQT: maison/tasmota/tele/EDF_teleinfo/SENSOR = {"Time":"2024-01-14T14:28:10","ENERGY":{"TotalStartTime":"2023-12-04T15:24:29","Total":0.000,"Yesterday":12.193,"Today":9.021,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":230,"Current":0.0}} (persistant)
    ****14:28:12.005 RTE: Token - Private key missing****  ICI LE PROBLEME
    Que dois je faire mon Denky 4 est sous home assitant
    merci pour votre aide
    • T thierry51170
      @thierry51170 Bonjour,
      Ce n'est pas réellement un problème.
      Si vous n'utilisez pas les calendrier RTE, ignorez le message.
      La prochaine version n'affichera ce warning que lorsqu'un calendrier RTE sera configuré.
      T 1 Reply Last reply
        thierry51170
        @Nicolas-Bernaerts ok merci beaucoup
        mais pourquoi dans cette version je n'ai pas les HC et HP ?
        • T thierry51170
          @thierry51170 Effectivement un bug de détection HP/HC m'avait été remonté. N'yant pas ce type de contrat, je n'avais pu le tester. Le bug a normalement été corrigé depuis. Je vais redéposer une nouvelle version sur Github. Merci de me confirmer que la correction est effective.
            thierry51170
            @Nicolas-Bernaerts ok préviens dès que c'est dispo je ferais l'installation et te tiendrais au courant
            • T thierry51170
              @thierry51170 C'est publié en v13.3.1
                thierry51170
                @Nicolas-Bernaerts tu peux me mettre le lien stp
                • T thierry51170
                  @thierry51170 https://github.com/NicolasBernaerts/tasmota/tree/master/teleinfo/binary
                    thierry51170
                    wrote on last edited by thierry51170
                    @Nicolas-Bernaerts ok merci je lance
                    voilà
                    qu'est ce que tu en pense?
                    • T thierry51170
                      voilà
                      @thierry51170 Plutôt pas mal 🙂
                      Ton compteur est en mode historique ?
                        thierry51170
                        @Nicolas-Bernaerts oui en historique (1200 bauds)Capture d'écran 2024-01-14 152608.png
                        • T thierry51170
                          thierry51170
                          @thierry51170 Bonjour Nicolas alors tu en pense quoi?
                          • T thierry51170
                            @thierry51170 il y a 0 calcul de cosphi ... Ce n'est pas normal. Est ce que tu pourrais faire une capture de trame de 5mn et me l'envoyer par message ? Il doit y avoir une spécificité côté compteur.
                              thierry51170
                              @Nicolas-Bernaerts Bonjour Nicolas,
                              je rencontre des problèmes avec ta version il se déconnecte 3 à 4 fois par jours je suis donc obligé de le redémarrer à chaque fois.
                              je fais te faire une capture d'écran dans la journée car là il est encore déconnecté
                              Voilà encore sorti du réseau
                              Nicolas BernaertsN 2 Replies Last reply
                              • T thierry51170
                                @thierry51170 Effectivement il y a un problème de stabilité lorsque Berry est activé dans le build. J'ai vu un case parlant de quelque chose qui ressemble sur le GitHub de tasmota. En attendant je vais publier un build sans Berry (sans doute ce soir).
                                • T thierry51170
                                  @thierry51170 Je viens de publier une version 13.3.2 avec Berry désactivé. La stabilité devrait être retrouvée. Je suis en train de rechercher la cause de ces instabilités pour pouvoir réactiver Berry.
                                    thierry51170
                                    @Nicolas-Bernaerts Bonjour Nicolas Ok merci je vois cela
                                    modification faite je te tiens au courant
                                    délai de 5mm
