    14:33:13.536 RTE: Token - Private key missing
    17 Posts 2 Posters 2.2k Views
      thierry51170
      je viens de réinstaller la version de @Nicolas-Bernaerts en relancer mon Denky 4 voilà ce message de la console
      00:00:00.003 HDW: ESP32-PICO-V3-02 v3.0 (PSRAM)
      00:00:00.195 UFS: FlashFS mounted with 4068 kB free
      00:00:00.225 CFG: Loaded from File, Compte 105
      00:00:00.230 I2C: Bus1 using GPIO22(SCL) and GPIO21(SDA)
      00:00:00.382 BRY: Berry initialized, RAM used=3773 bytes
      00:00:00.459 CFG: Energy loaded from file
      00:00:00.460 TIC: Teleinfo driver enabled
      00:00:00.460 NRG: Init driver 15
      00:00:00.465 Projet tasmota - Tasmota Version 13.2.0(tasmota)-2_0_14(2023-12-23T07:18:52)
      00:00:00.588 HLP: ftp_help to get help on FTP Server commands
      00:00:00.711 HLP: tcp_help to get help on TCP Server commands
      00:00:00.711 TIC: Partition mounted
      00:00:00.883 TIC: Using default Global Counter method
      00:00:00.883 HLP: Type EnergyConfig to get help on all Teleinfo commands
      00:00:00.885 TIC: Serial set to 7E1 9600 bauds
      00:00:00.008 HLP: tz_help to get help on Timezone commands
      00:00:00.013 HLP: eco_help to get help on Ecowatt module
      00:00:01.848 WIF: Connexion à l'AP1 MonReseau Channel 1 BSSId 54:C4:5B:3D:12:E0 en mode 11n comme EDF...
      00:00:02.146 WIF: Connecté
      14:28:04.141 HTP: Serveur web actif sur EDF avec l'adresse IP 192.168.1.177
      14:28:04.938 MQT: Tentative de connexion...
      14:28:04.964 MQT: Connecté
      14:28:04.968 MQT: maison/tasmota/tele/EDF_teleinfo/LWT = Online (persistant)
      14:28:04.970 MQT: maison/tasmota/cmnd/EDF_teleinfo/POWER =
      14:28:05.102 MQT: maison/tasmota/tele/EDF_teleinfo/INFO1 = {"Info1":{"Module":"Denky D4 (v1.1)","Version":"13.2.0(tasmota)","FallbackTopic":"cmnd/DVES_F5C098_fb/","GroupTopic":"maison/tasmota/cmnd/tasmotas/"}}
      14:28:05.356 MQT: maison/tasmota/tele/EDF_teleinfo/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"EDF","IPAddress":"192.168.1.177","IP6Global":"2001:861:ca1:7c40:4e75:25ff:fef5:c098","IP6Local":"fe80::4e75:25ff:fef5:c098"}}
      14:28:05.609 MQT: maison/tasmota/tele/EDF_teleinfo/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":52}}
      14:28:05.739 MQT: maison/tasmota/stat/EDF_teleinfo/RESULT = {"POWER":"ON"}
      14:28:05.742 MQT: maison/tasmota/stat/EDF_teleinfo/POWER = ON
      14:28:06.095 MQT: maison/tasmota/stat/EDF_teleinfo/RESULT = {"Time":"2024-01-14T14:28:06","Uptime":"0T00:00:05","UptimeSec":5,"Heap":156,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":149,"MqttCount":1,"Berry":{"HeapUsed":4,"Objects":50},"POWER":"ON","Dimmer":23,"Color":"3B3B3B","HSBColor":"0,0,23","Channel":[23,23,23],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"MonReseau","BSSId":"54:C4:5B:3D:12:E0","Channel":1,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:02"}}
      14:28:06.609 MQT: maison/tasmota/stat/EDF_teleinfo/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"https://raw.githubusercontent.com/tasmota/install/main/firmware/unofficial/tasmota32-teleinfo.bin","RestartReason":"Software reset CPU","Uptime":"0T00:00:05","StartupUTC":"2024-01-14T13:28:01","Sleep":50,"CfgHolder":4617,"BootCount":51,"BCResetTime":"2023-12-04T15:20:58","SaveCount":105}}
      14:28:07.006 MQT: maison/tasmota/stat/EDF_teleinfo/STATUS11 = {"StatusSTS":{"Time":"2024-01-14T14:28:06","Uptime":"0T00:00:05","UptimeSec":5,"Heap":155,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":237,"MqttCount":1,"Berry":{"HeapUsed":4,"Objects":50},"POWER":"ON","Dimmer":23,"Color":"3B3B3B","HSBColor":"0,0,23","Channel":[23,23,23],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"MonReseau","BSSId":"54:C4:5B:3D:12:E0","Channel":1,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":1,"Downtime":"0T00:00:02"}}}
      14:28:07.646 MQT: maison/tasmota/stat/EDF_teleinfo/STATUS10 = {"StatusSNS":{"Time":"2024-01-14T14:28:07","ENERGY":{"TotalStartTime":"2023-12-04T15:24:29","Total":0.000,"Yesterday":12.193,"Today":9.021,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":230,"Current":0.0}}}
      14:28:09.762 MQT: maison/tasmota/tele/EDF_teleinfo/STATE = {"Time":"2024-01-14T14:28:09","Uptime":"0T00:00:08","UptimeSec":8,"Heap":154,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":111,"MqttCount":1,"Berry":{"HeapUsed":4,"Objects":50},"POWER":"ON","Dimmer":23,"Color":"3B3B3B","HSBColor":"0,0,23","Channel":[23,23,23],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"MonReseau","BSSId":"54:C4:5B:3D:12:E0","Channel":1,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":1,"Downtime":"0T00:00:02"}}
      14:28:10.267 MQT: maison/tasmota/tele/EDF_teleinfo/SENSOR = {"Time":"2024-01-14T14:28:10","ENERGY":{"TotalStartTime":"2023-12-04T15:24:29","Total":0.000,"Yesterday":12.193,"Today":9.021,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":230,"Current":0.0}} (persistant)
      ****14:28:12.005 RTE: Token - Private key missing****  ICI LE PROBLEME
      Que dois je faire mon Denky 4 est sous home assitant
      merci pour votre aide
        Nicolas Bernaerts @thierry51170
        @thierry51170 Bonjour,
        Ce n'est pas réellement un problème.
        Si vous n'utilisez pas les calendrier RTE, ignorez le message.
        La prochaine version n'affichera ce warning que lorsqu'un calendrier RTE sera configuré.
          thierry51170 @Nicolas Bernaerts
          @Nicolas-Bernaerts ok merci beaucoup
          mais pourquoi dans cette version je n'ai pas les HC et HP ?
            @thierry51170 Effectivement un bug de détection HP/HC m'avait été remonté. N'yant pas ce type de contrat, je n'avais pu le tester. Le bug a normalement été corrigé depuis. Je vais redéposer une nouvelle version sur Github. Merci de me confirmer que la correction est effective.
              @Nicolas-Bernaerts ok préviens dès que c'est dispo je ferais l'installation et te tiendrais au courant
                @thierry51170 C'est publié en v13.3.1
                  @Nicolas-Bernaerts tu peux me mettre le lien stp
                    @thierry51170 https://github.com/NicolasBernaerts/tasmota/tree/master/teleinfo/binary
                      @Nicolas-Bernaerts ok merci je lance
                      voilà
                      qu'est ce que tu en pense?
                        @thierry51170 Plutôt pas mal 🙂
                        Ton compteur est en mode historique ?
                          @Nicolas-Bernaerts oui en historique (1200 bauds)Capture d'écran 2024-01-14 152608.png
                            thierry51170 @thierry51170
                            @thierry51170 Bonjour Nicolas alors tu en pense quoi?
                              @thierry51170 il y a 0 calcul de cosphi ... Ce n'est pas normal. Est ce que tu pourrais faire une capture de trame de 5mn et me l'envoyer par message ? Il doit y avoir une spécificité côté compteur.
                                je rencontre des problèmes avec ta version il se déconnecte 3 à 4 fois par jours je suis donc obligé de le redémarrer à chaque fois.
                                je fais te faire une capture d'écran dans la journée car là il est encore déconnecté
                                Voilà encore sorti du réseau
                                  @thierry51170 Effectivement il y a un problème de stabilité lorsque Berry est activé dans le build. J'ai vu un case parlant de quelque chose qui ressemble sur le GitHub de tasmota. En attendant je vais publier un build sans Berry (sans doute ce soir).
                                    @thierry51170 Je viens de publier une version 13.3.2 avec Berry désactivé. La stabilité devrait être retrouvée. Je suis en train de rechercher la cause de ces instabilités pour pouvoir réactiver Berry.
                                      @Nicolas-Bernaerts Bonjour Nicolas Ok merci je vois cela
                                      modification faite je te tiens au courant
                                      délai de 5mm
                                      5.7k
