  5. Tasmota sensor 12.1.1.2 avec linky mode Standard --> Libteleinfo checkline error checksum...
51 Posts 2 Posters 15.5k Views 3 Watching
  • SamquadS Samquad
    OK merci, j'espère que ça va fonctionner du premier coup et ne pas avoir à dessouder des CMS 🔍 😂 🔎
    SamquadS Offline
    SamquadS Offline
    Samquad
    Je viens de recevoir le Pitinfo V1.4 et voici la trame lue avec picocom:
    pi@raspberrypi:~ $ picocom -b 9600 -d 7 -p e -f n /dev/serial0
    picocom v3.1
    port is        : /dev/serial0
    flowcontrol    : none
    baudrate is    : 9600
    parity is      : even
    databits are   : 7
    stopbits are   : 1
    escape is      : C-a
    local echo is  : no
    noinit is      : no
    noreset is     : no
    hangup is      : no
    nolock is      : no
    send_cmd is    : sz -vv
    receive_cmd is : rz -vv -E
    imap is        :
    omap is        :
    logfile is     : none
    initstring     : none
    exit_after is  : not set
    exit is        : no
    Terminal ready
    0%gM      	F
    EAST	073013748	0
    EASF01	036517065	C
    EASF02	036496683	P
    EASF03	000000000	$
    EASF04	000000000	%
    EASF05	000000000	&
    EASF06	000000000	'
    EASF07	000000000	(
    EASF08	000000000	)
    EASF09	000000000	*
    EASF10	000000000	"
    EASD01	028616095	E
    EASD02	044397653	J
    EASD03	000000000	"
    EASD04	000000000	#
    EAIT	006772861	*
    ERQ1	004303674	V
    ERQ2	000117211	I
    ERQ3	000786867	'
    ERQ4	004581944	!
    IRMS1	012	1
    URMS1	237	F
    PREF	12	B
    PCOUP	12	\
    SINSTS	00000	F
    SMAXSN	H221124061347	07063	>
    SMAXSN-1	H221123210546	08067	]
    SINSTI	02949	T
    SMAXIN	H221124115815	03051	-
    SMAXIN-1	H221123150607	01619	P
    CCASN	H221124130000	00496	>
    CCASN-1	H221124123000	00048	W
    CCAIN	H221124130000	01702	+
    CCAIN-1	H221124123000	02272	N
    UMOY1	H221124132000	230	%
    STGE	003A0301	=
    PRM	12432850902420	+
    RELAIS	000	B
    NTARF	01	N
    NJOURF	00	&
    NJOURF+1	00	B
    ADSC	031861721681	9
    VTIC	02	J
    DATE	H221124132804		?
    NGTF	      BASE      	<
    LTARF	      BASE      	F
    EAST	073013748	0
    EASF01	036517065	C
    EASF02	036496683	P
    EASF03	000000000	$
    EASF04	000000000	%
    EASF05	000000000	&
    EASF06	000000000	'
    EASF07	000000000	(
    EASF08	000000000	)
    EASF09	000000000	*
    EASF10	000000000	"
    EASD01	028616095	E
    EASD02	044397653	J
    EASD03	000000000	"
    EASD04	000000000	#
    EAIT	006772862	+
    ERQ1	004303674	V
    ERQ2	000117211	I
    ERQ3	000786867	'
    ERQ4	004581944	!
    IRMS1	012	1
    URMS1	237	F
    PREF	12	B
    PCOUP	12	\
    SINSTS	00000	F
    SINSTI	02933	M
    STGE	003A0301	=
    RELAIS	000	B
    NTARF	01	N
    NJOURF	00	&
    NJOURF+1	00	B
    ADSC	031861721681	9
    VTIC	02	J
    DATE	H221124132806		A
    NGTF	      BASE      	<
    LTARF	      BASE      	F
    EAST	073013748	0
    EASF01	036517065	C
    EASF02	036496683	P
    EASF03	000000000	$
    EASF04	000000000	%
    EASF05	000000000	&
    EASF06	000000000	'
    EASF07	000000000	(
    EASF08	000000000	)
    EASF09	000000000	*
    EASF10	000000000	"
    EASD01	028616095	E
    EASD02	044397653	J
    EASD03	000000000	"
    EASD04	000000000	#
    EAIT	006772864	-
    ERQ1	004303674	V
    ERQ2	000117211	I
    ERQ3	000786867	'
    ERQ4	004581944	!
    IRMS1	012	1
    URMS1	238	G
    PREF	12	B
    PCOUP	12	\
    SINSTS	00000	F
    SINSTI	02895	T
    STGE	003A0301	=
    RELAIS	000	B
    NTARF	01	N
    NJOURF	00	&
    NJOURF+1	00	B
    ADSC	031861721681	9
    VTIC	02	J
    DATE	H221124132807		B
    NGTF	      BASE      	<
    LTARF	      BASE      	F
    EAST	073013748	0
    EASF01	036517065	C
    EASF02	036496683	P
    EASF03	000000000	$
    EASF04	000000000	%
    EASF05	000000000	&
    EASF06	000000000	'
    EASF07	000000000	(
    EASF08	000000000	)
    EASF09	000000000	*
    EASF10	000000000	"
    EASD01	028616095	E
    EASD02	044397653	J
    EASD03	000000000	"
    EASD04	000000000	#
    EAIT	006772864	-
    ERQ1	004303674	V
    ERQ2	000117211	I
    ERQ3	000786867	'
    ERQ4	004581944	!
    IRMS1	012	1
    URMS1	238	G
    PREF	12	B
    PCOUP	12	\
    SINSTS	00000	F
    SINSTI	02877	T
    STGE	003A0301	=
    RELAIS	000	B
    NTARF	01	N
    NJOURF	00	&
    NJOURF+1	00	B
    ADSC	031861721681	9
    VTIC	02	J
    DATE	H221124132808		C
    NGTF	      BASE      	<
    LTARF	      BASE      	F
    EAST	073013748	0
    EASF01	036517065	C
    EASF02	036496683	P
    EASF03	000000000	$
    EASF04	000000000	%
    EASF05	000000000	&
    EASF06	000000000	'
    EASF07	000000000	(
    EASF08	000000000	)
    EASF09	000000000	*
    EASF10	000000000	"
    EASD01	028616095	E
    EASD02	044397653	J
    EASD03	000000000	"
    EASD04	000000000	#
    EAIT	006772865	.
    ERQ1	004303674	V
    ERQ2	000117211	I
    ERQ3	000786867	'
    ERQ4	004581944	!
    IRMS1	012	1
    URMS1	238	G
    PREF	12	B
    PCOUP	12	\
    SINSTS	00000	F
    SINSTI	02837	P
    STGE	003A0301	=
    RELAIS	000	B
    NTARF	01	N
    NJOURF	00	&
    NJOURF+1	00	B
    ADSC	031861721681	9
    VTIC	02	J
    DATE	H221124132809		D
    NGTF	      BASE      	<
    LTARF	      BASE      	F
    EAST	073013748	0
    EASF01	036517065	C
    EASF02	036496683	P
    EASF03	000000000	$
    EASF04	000000000	%
    EASF05	000000000	&
    EASF06	000000000	'
    EASF07	000000000	(
    EASF08	000000000	)
    EASF09	000000000	*
    EASF10	000000000	"
    EASD01	028616095	E
    EASD02	044397653	J
    EASD03	000000000	"
    EASD04	000000000	#
    EAIT	006772866	/
    ERQ1	004303674	V
    ERQ2	000117211	I
    ERQ3	000786867	'
    ERQ4	004581944	!
    IRMS1	012	1
    URMS1	238	G
    PREF	12	B
    PCOUP	12	\
    SINSTS	00000	F
    SINSTI	02774	P
    STGE	003A0301	=
    RELAIS	000	B
    NTARF	01	N
    NJOURF	00	&
    NJOURF+1	00	B
    ADSC	031861721681	9
    VTIC	02	J
    DATE	H221124132810		<
    NGTF	      BASE      	<
    LTARF	      BASE      	F
    EAST	073013748	0
    EASF01	036517065	C
    EASF02	036496683	P
    EASF03	000000000	$
    EASF04	000000000	%
    EASF05	000000000	&
    EASF06	000000000	'
    EASF07	000000000	(
    EASF08	000000000	)
    EASF09	000000000	*
    EASF10	000000000	"
    EASD01	028616095	E
    EASD02	044397653	J
    EASD03	000000000	"
    EASD04	000000000	#
    EAIT	006772866	/
    ERQ1	004303674	V
    ERQ2	000117211	I
    ERQ3	000786867	'
    ERQ4	004581944	!
    IRMS1	011	0
    URMS1	238	G
    PREF	12	B
    PCOUP	12	\
    SINSTS	00000	F
    SINSTI	02702	G
    STGE	003A0301	=
    RELAIS	000	B
    NTARF	01	N
    NJOURF	00	&
    NJOURF+1	00	B
    ADSC	031861721681	9
    VTIC	02	J
    DATE	H221124132811		=
    NGTF	      BASE      	<
    LTARF	      BASE      	F
    EAST	073013748	0
    EASF01	036517065	C
    EASF02	036496683	P
    EASF03	000000000	$
    EASF04	000000000	%
    EASF05	000000000	&
    EASF06	000000000	'
    EASF07	000000000	(
    EASF08	000000000	)
    EASF09	000000000	*
    EASF10	000000000	"
    EASD01	028616095	E
    EASD02	044397653	J
    EASD03	000000000	"
    EASD04	000000000	#
    EAIT	006772867	0
    ERQ1	004303674	V
    ERQ2	000117211	I
    ERQ3	000786867	'
    ERQ4	004581944	!
    IRMS1	011	0
    URMS1	237	F
    PREF	12	B
    PCOUP	12	\
    SINSTS	00000	F
    SINSTI	02613	H
    Terminating...
    Skipping tty reset...
    Thanks for using picocom
    J'ai l'impression que ça fonctionne mieux mais il reste une ligne PJOURF+1 qui semble me mettre le bazar.
    J'ai testé sur tasmota et ça me met toujours des erreurs de checksum
    C'est quoi PJOURF+1?
    • SamquadS Samquad
      picocom v3.1
      flowcontrol    : none
      baudrate is    : 9600
      parity is      : even
      databits are   : 7
      stopbits are   : 1
      escape is      : C-a
      local echo is  : no
      noinit is      : no
      noreset is     : no
      hangup is      : no
      nolock is      : no
      imap is        :
      omap is        :
      logfile is     : none
      initstring     : none
      exit is        : no
      Terminal ready
      0%gM      	F
      EAST	073013748	0
      EASF01	036517065	C
      EASF02	036496683	P
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      EASD01	028616095	E
      EASD02	044397653	J
      EASD03	000000000	"
      EASD04	000000000	#
      EAIT	006772861	*
      ERQ1	004303674	V
      ERQ2	000117211	I
      ERQ3	000786867	'
      ERQ4	004581944	!
      IRMS1	012	1
      URMS1	237	F
      PREF	12	B
      PCOUP	12	\
      SINSTS	00000	F
      SINSTI	02949	T
      STGE	003A0301	=
      RELAIS	000	B
      NTARF	01	N
      NJOURF	00	&
      NJOURF+1	00	B
      ADSC	031861721681	9
      VTIC	02	J
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	073013748	0
      EASF01	036517065	C
      EASF02	036496683	P
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      EASD01	028616095	E
      EASD02	044397653	J
      EASD03	000000000	"
      EASD04	000000000	#
      EAIT	006772862	+
      ERQ1	004303674	V
      ERQ2	000117211	I
      ERQ3	000786867	'
      ERQ4	004581944	!
      IRMS1	012	1
      URMS1	237	F
      PREF	12	B
      PCOUP	12	\
      SINSTS	00000	F
      SINSTI	02933	M
      STGE	003A0301	=
      RELAIS	000	B
      NTARF	01	N
      NJOURF	00	&
      NJOURF+1	00	B
      ADSC	031861721681	9
      VTIC	02	J
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	073013748	0
      EASF01	036517065	C
      EASF02	036496683	P
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      EASD01	028616095	E
      EASD02	044397653	J
      EASD03	000000000	"
      EASD04	000000000	#
      EAIT	006772864	-
      ERQ1	004303674	V
      ERQ2	000117211	I
      ERQ3	000786867	'
      ERQ4	004581944	!
      IRMS1	012	1
      URMS1	238	G
      PREF	12	B
      PCOUP	12	\
      SINSTS	00000	F
      SINSTI	02895	T
      STGE	003A0301	=
      RELAIS	000	B
      NTARF	01	N
      NJOURF	00	&
      NJOURF+1	00	B
      ADSC	031861721681	9
      VTIC	02	J
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	073013748	0
      EASF01	036517065	C
      EASF02	036496683	P
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      EASD01	028616095	E
      EASD02	044397653	J
      EASD03	000000000	"
      EASD04	000000000	#
      EAIT	006772864	-
      ERQ1	004303674	V
      ERQ2	000117211	I
      ERQ3	000786867	'
      ERQ4	004581944	!
      IRMS1	012	1
      URMS1	238	G
      PREF	12	B
      PCOUP	12	\
      SINSTS	00000	F
      SINSTI	02877	T
      STGE	003A0301	=
      RELAIS	000	B
      NTARF	01	N
      NJOURF	00	&
      NJOURF+1	00	B
      ADSC	031861721681	9
      VTIC	02	J
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	073013748	0
      EASF01	036517065	C
      EASF02	036496683	P
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      EASD01	028616095	E
      EASD02	044397653	J
      EASD03	000000000	"
      EASD04	000000000	#
      EAIT	006772865	.
      ERQ1	004303674	V
      ERQ2	000117211	I
      ERQ3	000786867	'
      ERQ4	004581944	!
      IRMS1	012	1
      URMS1	238	G
      PREF	12	B
      PCOUP	12	\
      SINSTS	00000	F
      SINSTI	02837	P
      STGE	003A0301	=
      RELAIS	000	B
      NTARF	01	N
      NJOURF	00	&
      NJOURF+1	00	B
      ADSC	031861721681	9
      VTIC	02	J
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	073013748	0
      EASF01	036517065	C
      EASF02	036496683	P
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      EASD01	028616095	E
      EASD02	044397653	J
      EASD03	000000000	"
      EASD04	000000000	#
      EAIT	006772866	/
      ERQ1	004303674	V
      ERQ2	000117211	I
      ERQ3	000786867	'
      ERQ4	004581944	!
      IRMS1	012	1
      URMS1	238	G
      PREF	12	B
      PCOUP	12	\
      SINSTS	00000	F
      SINSTI	02774	P
      STGE	003A0301	=
      RELAIS	000	B
      NTARF	01	N
      NJOURF	00	&
      NJOURF+1	00	B
      ADSC	031861721681	9
      VTIC	02	J
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	073013748	0
      EASF01	036517065	C
      EASF02	036496683	P
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      EASD01	028616095	E
      EASD02	044397653	J
      EASD03	000000000	"
      EASD04	000000000	#
      EAIT	006772866	/
      ERQ1	004303674	V
      ERQ2	000117211	I
      ERQ3	000786867	'
      ERQ4	004581944	!
      IRMS1	011	0
      URMS1	238	G
      PREF	12	B
      PCOUP	12	\
      SINSTS	00000	F
      SINSTI	02702	G
      STGE	003A0301	=
      RELAIS	000	B
      NTARF	01	N
      NJOURF	00	&
      NJOURF+1	00	B
      ADSC	031861721681	9
      VTIC	02	J
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	073013748	0
      EASF01	036517065	C
      EASF02	036496683	P
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      EASD01	028616095	E
      EASD02	044397653	J
      EASD03	000000000	"
      EASD04	000000000	#
      EAIT	006772867	0
      ERQ1	004303674	V
      ERQ2	000117211	I
      ERQ3	000786867	'
      ERQ4	004581944	!
      IRMS1	011	0
      URMS1	237	F
      PREF	12	B
      PCOUP	12	\
      SINSTS	00000	F
      SINSTI	02613	H
      Terminating...
      @Samquad
      Ah c'est mieux, pourquoi tu dis que PJOURF+1 semble mettre le bazar ? pour moi ce champs et correct (j'ai le même d'ailleurs). Pas certains de savoir à quoi il correspond, mais la définition des étiquettes et valeurs est dans la spécification d'enedis
      ça ne fonctionne pas du tout dans tasmota ? curieux car la tout à l'air parfaitement correct.
      SamquadS 1 Reply Last reply
        @Samquad
        SamquadS Offline
        SamquadS Offline
        Samquad
        J'ai rebranché le Pitinfo V1.4 sur mon Wemos mini d1
        l'affichage des valeurs est correct:
        Par contre voici les logs dans la console:
        07:24:11.514 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASD02":44429781,"EASD03":0,"EASD04":0,"ERQ3":787284,"ERQ4":4585195,"IRMS1":8,"URMS1":235,"PREF":12,"PCOUP":12,"SINSTS":1752,"SMAXSN-1":9520,"SINSTI":0,"CCAIN":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73058485,"EASF04":0,"EASF05":0,"EASF10":0,"EAIT":6775320,"ERQ1":4303683,"ERQ2":117211,"SMAXSN":4958,"SMAXIN":0,"CCAIN-1":0,"CCASN":3830,"CCASN-1":3794,"SMAXIN-1":3051,"EASD01":28628704,"EASF06":0,"EASF01":36561801,"UMOY1":231}}
        07:24:11.754 LibTeleinfo::checkLine Err checksum 0x35 != 0x26
        07:24:11.762 LibTeleinfo::checkLine Err checksum 0x33 != 0x22
        07:24:11.763 LibTeleinfo::checkLine Err checksum 0x44 != 0x45
        07:24:12.011 LibTeleinfo::checkLine Err checksum 0x20 != 0x58
        07:24:12.256 LibTeleinfo::checkLine Err checksum 0x5B != 0x51
        07:24:12.260 LibTeleinfo::checkLine Err checksum 0x2E != 0x4B
        07:24:12.264 LibTeleinfo::checkLine Err checksum 0x21 != 0x26
        07:24:12.266 LibTeleinfo::checkLine Err checksum 0x21 != 0x25
        07:24:12.267 LibTeleinfo::checkLine Err checksum 0x3A != 0x2A
        07:24:14.269 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
        07:24:14.503 LibTeleinfo::checkLine Err checksum 0x55 != 0x51
        07:24:14.507 LibTeleinfo::checkLine Err checksum 0x2F != 0x4B
        07:24:14.511 LibTeleinfo::checkLine Err checksum 0x21 != 0x26
        07:24:14.751 LibTeleinfo::checkLine Err checksum 0x20 != 0x25
        07:24:14.753 LibTeleinfo::checkLine Err checksum 0x45 != 0x2A
        07:24:14.755 LibTeleinfo::checkLine Err checksum 0x3A != 0x3B
        07:24:14.757 LibTeleinfo::checkLine Err checksum 0x41 != 0x42
        07:24:15.002 LibTeleinfo::checkLine Err checksum 0x38 != 0x39
        07:24:15.256 LibTeleinfo::checkLine Err checksum 0x34 != 0x25
        07:24:15.258 LibTeleinfo::checkLine Err checksum 0x25 != 0x26
        07:24:15.264 LibTeleinfo::checkLine Err checksum 0x43 != 0x2A
        07:24:15.266 LibTeleinfo::checkLine Err checksum 0x20 != 0x22
        07:24:15.502 LibTeleinfo::checkLine Err checksum 0x20 != 0x23
        07:24:15.510 LibTeleinfo::checkLine Err checksum 0x28 != 0x30
        07:24:15.512 LibTeleinfo::checkLine Err checksum 0x43 != 0x45
        07:24:15.752 LibTeleinfo::checkLine Err checksum 0x43 != 0x3C
        07:24:15.754 LibTeleinfo::checkLine Err checksum 0x4C != 0x50
        07:24:15.756 LibTeleinfo::checkLine Err checksum 0x50 != 0x3D
        07:24:15.760 LibTeleinfo::checkLine Err checksum 0x5E != 0x45
        07:24:16.006 LibTeleinfo: _recv_idx = 128/128 buffer overflow
        07:24:16.257 LibTeleinfo::checkLine Err checksum 0x4E != 0x43
        07:24:16.259 LibTeleinfo::checkLine Err checksum 0x4F != 0x50
        07:24:16.502 LibTeleinfo::checkLine Err checksum 0x3D != 0x27
        07:24:16.504 LibTeleinfo::checkLine Err checksum 0x25 != 0x28
        07:24:16.510 LibTeleinfo::checkLine Err checksum 0x45 != 0x48
        07:24:16.518 LibTeleinfo::checkLine Err checksum 0x58 != 0x49
        07:24:16.519 LibTeleinfo::checkLine Err checksum 0x5F != 0x21
        07:24:16.758 LibTeleinfo::checkLine Err checksum 0x40 != 0x45
        07:24:16.760 LibTeleinfo::checkLine Err checksum 0x4E != 0x51
        07:24:16.764 LibTeleinfo::checkLine Err checksum 0x25 != 0x4B
        07:24:17.004 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
        07:24:17.008 LibTeleinfo::checkLine Err checksum 0x56 != 0x2A
        07:24:17.272 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASD02":44429781,"EASD03":0,"EASD04":0,"ERQ3":787284,"ERQ4":4585196,"IRMS1":7,"URMS1":234,"PREF":12,"PCOUP":12,"SINSTS":1753,"SMAXSN-1":9520,"SINSTI":0,"CCAIN":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73058487,"EASF04":0,"EASF05":0,"EASF10":0,"EAIT":6775320,"ERQ1":4303683,"ERQ2":117211,"SMAXSN":4958,"SMAXIN":0,"CCAIN-1":0,"CCASN":3830,"CCASN-1":3794,"SMAXIN-1":3051,"EASD01":28628706,"EASF06":0,"EASF01":36561804,"UMOY1":231}}
        07:24:17.502 LibTeleinfo::checkLine Err checksum 0x45 != 0x46
        07:24:17.505 LibTeleinfo::checkLine Err checksum 0x2C != 0x24
        07:24:17.507 LibTeleinfo::checkLine Err checksum 0x22 != 0x25
        07:24:17.512 LibTeleinfo::checkLine Err checksum 0x43 != 0x29
        07:24:17.514 LibTeleinfo::checkLine Err checksum 0x27 != 0x2A
        07:24:17.754 LibTeleinfo::checkLine Err checksum 0x5D != 0x22
        07:24:18.002 LibTeleinfo::checkLine Err checksum 0x41 != 0x45
        07:24:18.004 LibTeleinfo::checkLine Err checksum 0x48 != 0x30
        07:24:18.006 LibTeleinfo::checkLine Err checksum 0x4B != 0x50
        07:24:18.007 LibTeleinfo::checkLine Err checksum 0x4B != 0x3D
        07:24:18.256 LibTeleinfo::checkLine Err checksum 0x3A != 0x45
        07:24:18.502 LibTeleinfo: _recv_idx = 128/128 buffer overflow
        07:24:18.504 LibTeleinfo::checkLine Err checksum 0x40 != 0x44
        07:24:18.754 LibTeleinfo::checkLine Err checksum 0x23 != 0x30
        07:24:18.761 LibTeleinfo::checkLine Err checksum 0x47 != 0x48
        07:24:19.010 LibTeleinfo::checkLine Err checksum 0x5B != 0x51
        07:24:19.257 LibTeleinfo::checkLine Err checksum 0x2E != 0x4B
        07:24:19.261 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
        07:24:19.263 LibTeleinfo::checkLine Err checksum 0x21 != 0x25
        07:24:19.265 LibTeleinfo::checkLine Err checksum 0x3A != 0x2A
        07:24:19.755 LibTeleinfo::checkLine Err checksum 0x20 != 0x30
        07:24:20.002 LibTeleinfo::checkLine Err checksum 0x40 != 0x29
        07:24:20.010 LibTeleinfo::checkLine Err checksum 0x57 != 0x22
        07:24:20.011 LibTeleinfo::checkLine Err checksum 0x20 != 0x23
        07:24:20.256 LibTeleinfo::checkLine Err checksum 0x32 != 0x36
        07:24:20.258 LibTeleinfo::checkLine Err checksum 0x43 != 0x44
        07:24:20.265 LibTeleinfo::checkLine Err checksum 0x4D != 0x51
        07:24:20.271 LibTeleinfo::checkLine Err checksum 0x44 != 0x4B
        07:24:20.273 LibTeleinfo::checkLine Err checksum 0x39 != 0x3D
        07:24:20.502 LibTeleinfo::checkLine Err checksum 0x3E != 0x25
        07:24:20.506 LibTeleinfo::checkLine Err checksum 0x47 != 0x3B
        07:24:20.508 LibTeleinfo::checkLine Err checksum 0x39 != 0x3C
        07:24:20.510 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
        07:24:20.752 LibTeleinfo::checkLine Err checksum 0x41 != 0x42
        07:24:21.002 LibTeleinfo::checkLine Err checksum 0x34 != 0x25
        07:24:21.010 LibTeleinfo::checkLine Err checksum 0x42 != 0x2A
        07:24:21.012 LibTeleinfo::checkLine Err checksum 0x21 != 0x22
        07:24:21.260 LibTeleinfo::checkLine Err checksum 0x20 != 0x23
        07:24:21.502 LibTeleinfo::checkLine Err checksum 0x44 != 0x45
        07:24:21.504 LibTeleinfo::checkLine Err checksum 0x40 != 0x3C
        07:24:21.506 LibTeleinfo::checkLine Err checksum 0x4C != 0x50
        07:24:21.508 LibTeleinfo::checkLine Err checksum 0x30 != 0x3D
        07:24:21.512 LibTeleinfo::checkLine Err checksum 0x24 != 0x25
        07:24:21.752 LibTeleinfo::checkLine Err checksum 0x5F != 0x45
        07:24:22.002 LibTeleinfo: _recv_idx = 128/128 buffer overflow
        07:24:22.004 LibTeleinfo::checkLine Err checksum 0x44 != 0x46
        07:24:22.260 LibTeleinfo::checkLine Err checksum 0x3A != 0x27
        07:24:22.262 LibTeleinfo::checkLine Err checksum 0x27 != 0x28
        07:24:22.268 LibTeleinfo::checkLine Err checksum 0x45 != 0x48
        07:24:22.502 LibTeleinfo::checkLine Err checksum 0x25 != 0x49
        07:24:22.504 LibTeleinfo::checkLine Err checksum 0x20 != 0x21
        07:24:22.513 LibTeleinfo::checkLine Err checksum 0x40 != 0x45
        07:24:22.514 LibTeleinfo::checkLine Err checksum 0x4E != 0x51
        07:24:22.752 LibTeleinfo::checkLine Err checksum 0x4F != 0x50
        07:24:22.754 LibTeleinfo::checkLine Err checksum 0x47 != 0x4B
        07:24:22.755 LibTeleinfo::checkLine Err checksum 0x3D != 0x26
        07:24:22.759 LibTeleinfo::checkLine Err checksum 0x24 != 0x2A
        07:24:23.260 LibTeleinfo::checkLine Err checksum 0x41 != 0x50
        07:24:23.262 LibTeleinfo::checkLine Err checksum 0x23 != 0x24
        07:24:23.267 LibTeleinfo::checkLine Err checksum 0x3D != 0x28
        07:24:23.502 LibTeleinfo::checkLine Err checksum 0x26 != 0x29
        07:24:23.508 LibTeleinfo::checkLine Err checksum 0x33 != 0x48
        07:24:23.510 LibTeleinfo::checkLine Err checksum 0x5F != 0x22
        07:24:23.517 LibTeleinfo::checkLine Err checksum 0x55 != 0x21
        07:24:23.753 LibTeleinfo::checkLine Err checksum 0x40 != 0x43
        07:24:23.760 LibTeleinfo::checkLine Err checksum 0x4E != 0x51
        07:24:23.762 LibTeleinfo::checkLine Err checksum 0x3A != 0x3C
        07:24:23.766 LibTeleinfo::checkLine Err checksum 0x43 != 0x4B
        07:24:23.767 LibTeleinfo::checkLine Err checksum 0x38 != 0x3D
        07:24:24.002 LibTeleinfo::checkLine Err checksum 0x26 != 0x25
        07:24:24.006 LibTeleinfo::checkLine Err checksum 0x47 != 0x3B
        07:24:24.256 LibTeleinfo::checkLine Err checksum 0x40 != 0x42
        07:24:24.272 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASD02":44429781,"EASD03":0,"EASD04":0,"ERQ3":787284,"ERQ4":4585196,"IRMS1":10,"URMS1":234,"PREF":12,"PCOUP":12,"SINSTS":2218,"SMAXSN-1":9520,"SINSTI":0,"CCAIN":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73058491,"EASF04":0,"EASF05":0,"EASF10":0,"EAIT":6775320,"ERQ1":4303683,"ERQ2":117211,"SMAXSN":4958,"SMAXIN":0,"CCAIN-1":0,"CCASN":3830,"CCASN-1":3794,"SMAXIN-1":3051,"EASD01":28628708,"EASF06":0,"EASF01":36561806,"UMOY1":231}}
        07:24:24.276 LibTeleinfo::checkLine Err checksum 0x38 != 0x39
        07:24:24.503 LibTeleinfo::checkLine Err checksum 0x36 != 0x25
        07:24:24.505 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
        07:24:24.510 LibTeleinfo::checkLine Err checksum 0x44 != 0x2A
        07:24:24.512 LibTeleinfo::checkLine Err checksum 0x5F != 0x22
        07:24:24.760 LibTeleinfo::checkLine Err checksum 0x49 != 0x37
        07:24:25.002 LibTeleinfo::checkLine Err checksum 0x57 != 0x51
        07:24:25.008 LibTeleinfo::checkLine Err checksum 0x45 != 0x4B
        07:24:25.010 LibTeleinfo::checkLine Err checksum 0x38 != 0x3D
        07:24:25.012 LibTeleinfo::checkLine Err checksum 0x26 != 0x25
        07:24:25.256 LibTeleinfo::checkLine Err checksum 0x47 != 0x3B
        07:24:25.258 LibTeleinfo::checkLine Err checksum 0x29 != 0x26
        07:24:25.260 LibTeleinfo::checkLine Err checksum 0x40 != 0x42
        07:24:25.503 LibTeleinfo::checkLine Err checksum 0x56 != 0x48
        07:24:25.505 LibTeleinfo::checkLine Err checksum 0x4E != 0x50
        07:24:25.754 LibTeleinfo::checkLine Err checksum 0x3D != 0x27
        07:24:25.756 LibTeleinfo::checkLine Err checksum 0x25 != 0x28
        07:24:25.761 LibTeleinfo::checkLine Err checksum 0x45 != 0x48
        07:24:26.002 LibTeleinfo::checkLine Err checksum 0x59 != 0x49
        07:24:26.004 LibTeleinfo::checkLine Err checksum 0x5E != 0x21
        07:24:26.012 LibTeleinfo::checkLine Err checksum 0x3F != 0x45
        07:24:26.014 LibTeleinfo::checkLine Err checksum 0x4D != 0x51
        07:24:26.256 LibTeleinfo::checkLine Err checksum 0x2E != 0x4B
        07:24:26.261 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
        07:24:26.264 LibTeleinfo::checkLine Err checksum 0x38 != 0x2A
        07:24:26.753 LibTeleinfo::checkLine Err checksum 0x37 != 0x30
        07:24:27.002 LibTeleinfo::checkLine Err checksum 0x41 != 0x2A
        07:24:27.004 LibTeleinfo::checkLine Err checksum 0x21 != 0x22
        07:24:27.009 LibTeleinfo::checkLine Err checksum 0x20 != 0x23
        07:24:27.256 LibTeleinfo::checkLine Err checksum 0x48 != 0x4C
        07:24:27.260 LibTeleinfo::checkLine Err checksum 0x40 != 0x3C
        07:24:27.262 LibTeleinfo::checkLine Err checksum 0x4D != 0x50
        07:24:27.264 LibTeleinfo::checkLine Err checksum 0x2F != 0x3D
        07:24:27.502 LibTeleinfo::checkLine Err checksum 0x24 != 0x25
        07:24:27.504 LibTeleinfo::checkLine Err checksum 0x40 != 0x45
        07:24:27.510 LibTeleinfo::checkLine Err checksum 0x54 != 0x30
        07:24:28.004 LibTeleinfo::checkLine Err checksum 0x35 != 0x50
        07:24:28.006 LibTeleinfo::checkLine Err checksum 0x23 != 0x24
        07:24:28.011 LibTeleinfo::checkLine Err checksum 0x3E != 0x28
        07:24:28.013 LibTeleinfo::checkLine Err checksum 0x26 != 0x29
        07:24:28.019 LibTeleinfo::checkLine Err checksum 0x38 != 0x48
        07:24:28.257 LibTeleinfo::checkLine Err checksum 0x5F != 0x22
        07:24:28.265 LibTeleinfo::checkLine Err checksum 0x57 != 0x21
        07:24:28.503 LibTeleinfo::checkLine Err checksum 0x56 != 0x51
        07:24:28.507 LibTeleinfo::checkLine Err checksum 0x50 != 0x4B
        07:24:28.511 LibTeleinfo::checkLine Err checksum 0x20 != 0x25
        07:24:28.515 LibTeleinfo::checkLine Err checksum 0x26 != 0x2A
        07:24:28.753 LibTeleinfo::checkLine Err checksum 0x39 != 0x3B
        07:24:28.755 LibTeleinfo::checkLine Err checksum 0x4B != 0x2B
        07:24:28.757 LibTeleinfo::checkLine Err checksum 0x3F != 0x42
        07:24:29.003 LibTeleinfo::checkLine Err checksum 0x38 != 0x39
        07:24:29.007 LibTeleinfo::checkLine Err checksum 0x35 != 0x25
        07:24:29.256 LibTeleinfo::checkLine Err checksum 0x25 != 0x26
        07:24:29.262 LibTeleinfo::checkLine Err checksum 0x44 != 0x2A
        07:24:29.264 LibTeleinfo::checkLine Err checksum 0x5F != 0x22
        07:24:36.512 LibTeleinfo::checkLine Err checksum 0x4F != 0x4B
        07:24:36.754 LibTeleinfo::checkLine Err checksum 0x21 != 0x26
        07:24:36.756 LibTeleinfo::checkLine Err checksum 0x20 != 0x25
        07:24:36.757 LibTeleinfo::checkLine Err checksum 0x45 != 0x2A
        07:24:36.759 LibTeleinfo::checkLine Err checksum 0x3A != 0x3B
        07:24:36.760 LibTeleinfo::checkLine Err checksum 0x41 != 0x42
        07:24:37.018 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASD02":44429781,"EASD03":0,"EASD04":0,"ERQ3":787284,"ERQ4":4585197,"IRMS1":10,"URMS1":234,"PREF":12,"PCOUP":12,"SINSTS":2234,"SMAXSN-1":9520,"SINSTI":0,"CCAIN":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73058497,"EASF04":0,"EASF05":0,"EASF10":0,"EAIT":6775320,"ERQ1":4303683,"ERQ2":117211,"SMAXSN":4958,"SMAXIN":0,"CCAIN-1":0,"CCASN":3830,"CCASN-1":3794,"SMAXIN-1":3051,"EASD01":28628715,"EASF06":0,"EASF01":36561813,"UMOY1":231}}
        07:24:37.022 LibTeleinfo::checkLine Err checksum 0x38 != 0x39
        07:24:37.257 LibTeleinfo::checkLine Err checksum 0x35 != 0x25
        07:24:37.259 LibTeleinfo::checkLine Err checksum 0x25 != 0x26
        07:24:37.265 LibTeleinfo::checkLine Err checksum 0x44 != 0x2A
        07:24:37.267 LibTeleinfo::checkLine Err checksum 0x5F != 0x22
        07:24:37.512 LibTeleinfo::checkLine Err checksum 0x2A != 0x50
        07:24:37.752 LibTeleinfo::checkLine Err checksum 0x42 != 0x45
        07:24:37.754 LibTeleinfo::checkLine Err checksum 0x48 != 0x30
        07:24:37.756 LibTeleinfo::checkLine Err checksum 0x4B != 0x50
        07:24:37.757 LibTeleinfo::checkLine Err checksum 0x51 != 0x3D
        07:24:38.002 LibTeleinfo::checkLine Err checksum 0x31 != 0x45
        07:24:38.256 LibTeleinfo: _recv_idx = 128/128 buffer overflow
        07:24:38.259 LibTeleinfo::checkLine Err checksum 0x5D != 0x45
        07:24:38.261 LibTeleinfo::checkLine Err checksum 0x4F != 0x50
        07:24:38.506 LibTeleinfo::checkLine Err checksum 0x3D != 0x27
        07:24:38.508 LibTeleinfo::checkLine Err checksum 0x25 != 0x28
        07:24:38.513 LibTeleinfo::checkLine Err checksum 0x45 != 0x48
        07:24:38.754 LibTeleinfo::checkLine Err checksum 0x59 != 0x49
        07:24:38.756 LibTeleinfo::checkLine Err checksum 0x5F != 0x21
        07:24:38.764 LibTeleinfo::checkLine Err checksum 0x3F != 0x45
        07:24:38.766 LibTeleinfo::checkLine Err checksum 0x4D != 0x51
        07:24:39.002 LibTeleinfo::checkLine Err checksum 0x24 != 0x4B
        07:24:39.006 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
        07:24:39.010 LibTeleinfo::checkLine Err checksum 0x57 != 0x2A
        07:24:39.504 LibTeleinfo::checkLine Err checksum 0x3A != 0x3C
        07:24:39.507 LibTeleinfo::checkLine Err checksum 0x37 != 0x25
        07:24:39.508 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
        07:24:39.754 LibTeleinfo::checkLine Err checksum 0x4E != 0x30
        07:24:39.762 LibTeleinfo::checkLine Err checksum 0x55 != 0x56
        07:24:40.003 LibTeleinfo::checkLine Err checksum 0x49 != 0x31
        07:24:40.005 LibTeleinfo::checkLine Err checksum 0x2B != 0x51
        07:24:40.008 LibTeleinfo::checkLine Err checksum 0x2F != 0x4B
        07:24:40.256 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
        07:24:40.258 LibTeleinfo::checkLine Err checksum 0x24 != 0x25
        07:24:40.260 LibTeleinfo::checkLine Err checksum 0x39 != 0x2A
        07:24:40.505 LibTeleinfo::checkLine Err checksum 0x34 != 0x39
        07:24:40.507 LibTeleinfo::checkLine Err checksum 0x38 != 0x09
        07:24:40.509 LibTeleinfo::checkLine Err checksum 0x3B != 0x3C
        07:24:40.753 LibTeleinfo::checkLine Err checksum 0x44 != 0x50
        07:24:40.754 LibTeleinfo::checkLine Err checksum 0x20 != 0x24
        07:24:40.760 LibTeleinfo::checkLine Err checksum 0x29 != 0x30
        07:24:41.003 LibTeleinfo::checkLine Err checksum 0x55 != 0x22
        07:24:41.011 LibTeleinfo::checkLine Err checksum 0x36 != 0x37
        07:24:41.258 LibTeleinfo::checkLine Err checksum 0x2B != 0x51
        07:24:41.261 LibTeleinfo::checkLine Err checksum 0x22 != 0x3D
        07:24:41.265 LibTeleinfo::checkLine Err checksum 0x22 != 0x25
        07:24:41.267 LibTeleinfo::checkLine Err checksum 0x42 != 0x45
        07:24:42.504 LibTeleinfo::checkLine Err checksum 0x3A != 0x3D
        07:24:42.505 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
        07:24:42.507 LibTeleinfo::checkLine Err checksum 0x3A != 0x45
        07:24:43.256 LibTeleinfo::checkLine Err checksum 0x2C != 0x2A
        07:24:43.266 LibTeleinfo::checkLine Err checksum 0x54 != 0x56
        07:24:43.502 LibTeleinfo::checkLine Err checksum 0x47 != 0x45
        07:24:43.504 LibTeleinfo::checkLine Err checksum 0x51 != 0x50
        07:24:43.508 LibTeleinfo::checkLine Err checksum 0x39 != 0x3D
        07:24:43.752 LibTeleinfo::checkLine Err checksum 0x23 != 0x26
        07:24:43.754 LibTeleinfo::checkLine Err checksum 0x3A != 0x45
        07:24:44.002 LibTeleinfo::checkLine Err checksum 0x22 != 0x09
        07:24:44.004 LibTeleinfo::checkLine Err checksum 0x3B != 0x3C
        07:24:44.256 LibTeleinfo::checkLine Err checksum 0x24 != 0x48
        07:24:44.258 LibTeleinfo::checkLine Err checksum 0x4D != 0x50
        07:24:44.264 LibTeleinfo::checkLine Err checksum 0x46 != 0x30
        07:24:44.502 LibTeleinfo::checkLine Err checksum 0x33 != 0x48
        07:24:44.510 LibTeleinfo::checkLine Err checksum 0x59 != 0x30
        07:24:44.752 LibTeleinfo::checkLine Err checksum 0x5A != 0x51
        07:24:44.756 LibTeleinfo::checkLine Err checksum 0x2E != 0x4B
        07:24:44.760 LibTeleinfo::checkLine Err checksum 0x23 != 0x26
        07:24:44.762 LibTeleinfo::checkLine Err checksum 0x23 != 0x25
        07:24:45.002 LibTeleinfo::checkLine Err checksum 0x3A != 0x2A
        07:24:45.268 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASD02":44429781,"EASD03":0,"EASD04":0,"ERQ3":787284,"ERQ4":4585198,"IRMS1":9,"URMS1":234,"PREF":12,"PCOUP":12,"SINSTS":2220,"SMAXSN-1":9520,"SINSTI":0,"CCAIN":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73058501,"EASF04":0,"EASF05":0,"EASF10":0,"EAIT":6775320,"ERQ1":4303683,"ERQ2":117211,"SMAXSN":4958,"SMAXIN":0,"CCAIN-1":0,"CCASN":3830,"CCASN-1":3794,"SMAXIN-1":3051,"EASD01":28628720,"EASF06":0,"EASF01":36561818,"UMOY1":231}}
        07:24:45.275 LibTeleinfo::checkLine Err checksum 0x37 != 0x30
        07:24:45.508 LibTeleinfo::checkLine Err checksum 0x41 != 0x2A
        07:24:45.516 LibTeleinfo::checkLine Err checksum 0x22 != 0x23
        07:24:45.756 LibTeleinfo::checkLine Err checksum 0x4D != 0x50
        07:24:45.760 LibTeleinfo::checkLine Err checksum 0x4D != 0x50
        07:24:46.004 LibTeleinfo::checkLine Err checksum 0x39 != 0x3D
        07:24:46.006 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
        07:24:46.008 LibTeleinfo::checkLine Err checksum 0x3A != 0x45
        07:24:46.503 LibTeleinfo::checkLine Err checksum 0x3A != 0x50
        07:24:46.505 LibTeleinfo::checkLine Err checksum 0x34 != 0x25
        07:24:46.752 LibTeleinfo::checkLine Err checksum 0x42 != 0x2A
        07:24:46.754 LibTeleinfo::checkLine Err checksum 0x21 != 0x22
        07:24:46.760 LibTeleinfo::checkLine Err checksum 0x20 != 0x23
        07:24:47.002 LibTeleinfo::checkLine Err checksum 0x2C != 0x30
        07:24:47.004 LibTeleinfo::checkLine Err checksum 0x43 != 0x45
        07:24:47.006 LibTeleinfo::checkLine Err checksum 0x42 != 0x3C
        07:24:47.008 LibTeleinfo::checkLine Err checksum 0x4C != 0x50
        07:24:47.010 LibTeleinfo::checkLine Err checksum 0x2F != 0x3D
        07:24:47.256 LibTeleinfo::checkLine Err checksum 0x5F != 0x45
        07:24:47.502 LibTeleinfo: _recv_idx = 128/128 buffer overflow
        07:24:47.752 LibTeleinfo::checkLine Err checksum 0x28 != 0x24
        07:24:47.762 LibTeleinfo::checkLine Err checksum 0x43 != 0x2A
        07:24:47.763 LibTeleinfo::checkLine Err checksum 0x5F != 0x22
        07:24:48.003 LibTeleinfo::checkLine Err checksum 0x20 != 0x23
        07:24:48.011 LibTeleinfo::checkLine Err checksum 0x2C != 0x30
        07:24:48.013 LibTeleinfo::checkLine Err checksum 0x43 != 0x45
        07:24:48.257 LibTeleinfo::checkLine Err checksum 0x43 != 0x3C
        07:24:48.259 LibTeleinfo::checkLine Err checksum 0x4C != 0x50
        07:24:48.261 LibTeleinfo::checkLine Err checksum 0x30 != 0x3D
        07:24:48.266 LibTeleinfo::checkLine Err checksum 0x5E != 0x45
        07:24:48.507 LibTeleinfo: _recv_idx = 128/128 buffer overflow
        07:24:49.002 LibTeleinfo::checkLine Err checksum 0x37 != 0x26
        07:24:49.004 LibTeleinfo::checkLine Err checksum 0x25 != 0x27
        07:24:49.009 LibTeleinfo::checkLine Err checksum 0x35 != 0x22
        07:24:49.011 LibTeleinfo::checkLine Err checksum 0x43 != 0x46
        07:24:49.266 LibTeleinfo::checkLine Err checksum 0x40 != 0x45
        07:24:49.270 LibTeleinfo::checkLine Err checksum 0x5D != 0x50
        07:24:49.502 LibTeleinfo::checkLine Err checksum 0x3F != 0x26
        07:24:49.506 LibTeleinfo::checkLine Err checksum 0x41 != 0x45
        07:24:50.003 LibTeleinfo::checkLine Err checksum 0x39 != 0x50
        07:24:50.005 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
        07:24:50.011 LibTeleinfo::checkLine Err checksum 0x3E != 0x28
        07:24:50.012 LibTeleinfo::checkLine Err checksum 0x26 != 0x29
        07:24:50.260 LibTeleinfo::checkLine Err checksum 0x3A != 0x48
        07:24:50.262 LibTeleinfo::checkLine Err checksum 0x5E != 0x22
        07:24:50.269 LibTeleinfo::checkLine Err checksum 0x58 != 0x21
        07:24:50.503 LibTeleinfo::checkLine Err checksum 0x57 != 0x51
        07:24:50.509 LibTeleinfo::checkLine Err checksum 0x46 != 0x4B
        07:24:50.752 LibTeleinfo::checkLine Err checksum 0x33 != 0x25
        07:24:50.756 LibTeleinfo::checkLine Err checksum 0x26 != 0x2A
        07:24:50.758 LibTeleinfo::checkLine Err checksum 0x39 != 0x3B
        07:24:50.760 LibTeleinfo::checkLine Err checksum 0x3C != 0x2B
        07:24:50.761 LibTeleinfo::checkLine Err checksum 0x3F != 0x42
        07:24:51.005 LibTeleinfo::checkLine Err checksum 0x45 != 0x46
        07:24:51.258 LibTeleinfo::checkLine Err checksum 0x2C != 0x24
        07:24:51.260 LibTeleinfo::checkLine Err checksum 0x22 != 0x25
        07:24:51.265 LibTeleinfo::checkLine Err checksum 0x43 != 0x29
        07:24:51.266 LibTeleinfo::checkLine Err checksum 0x27 != 0x2A
        07:24:51.272 LibTeleinfo::checkLine Err checksum 0x25 != 0x30
        07:24:51.509 LibTeleinfo::checkLine Err checksum 0x41 != 0x42
        07:24:51.511 LibTeleinfo::checkLine Err checksum 0x5A != 0x5C
        07:24:51.512 LibTeleinfo::checkLine Err checksum 0x4F != 0x50
        07:24:51.516 LibTeleinfo::checkLine Err checksum 0x4C != 0x51
        07:24:51.753 LibTeleinfo::checkLine Err checksum 0x39 != 0x3C
        07:24:51.757 LibTeleinfo::checkLine Err checksum 0x38 != 0x3D
        07:24:51.761 LibTeleinfo::checkLine Err checksum 0x21 != 0x25
        07:24:51.763 LibTeleinfo::checkLine Err checksum 0x44 != 0x45
        07:24:51.764 LibTeleinfo::checkLine Err checksum 0x4B != 0x32
        07:24:52.003 LibTeleinfo::checkLine Err checksum 0x54 != 0x42
        07:24:52.257 LibTeleinfo::checkLine Err checksum 0x34 != 0x39
        07:24:52.259 LibTeleinfo::checkLine Err checksum 0x48 != 0x4A
        07:24:52.261 LibTeleinfo::checkLine Err checksum 0x41 != 0x44
        07:24:52.265 LibTeleinfo::checkLine Err checksum 0x38 != 0x26
        07:24:52.503 LibTeleinfo::checkLine Err checksum 0x24 != 0x27
        07:24:52.509 LibTeleinfo::checkLine Err checksum 0x3F != 0x30
        07:24:52.516 LibTeleinfo::checkLine Err checksum 0x47 != 0x49
        07:24:52.761 LibTeleinfo::checkLine Err checksum 0x46 != 0x45
        07:24:52.767 LibTeleinfo::checkLine Err checksum 0x4C != 0x50
        07:24:52.769 LibTeleinfo::checkLine Err checksum 0x4A != 0x4B
        07:24:53.002 LibTeleinfo::checkLine Err checksum 0x52 != 0x26
        07:24:53.006 LibTeleinfo::checkLine Err checksum 0x41 != 0x45
        07:24:53.008 LibTeleinfo::checkLine Err checksum 0x28 != 0x2A
        07:24:53.272 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASD02":44429781,"EASD03":0,"EASD04":0,"ERQ3":787284,"ERQ4":4585198,"IRMS1":10,"URMS1":230,"PREF":12,"PCOUP":12,"SINSTS":2203,"SMAXSN-1":9520,"SINSTI":0,"CCAIN":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73058505,"EASF04":0,"EASF05":0,"EASF10":0,"EAIT":6775320,"ERQ1":4303683,"ERQ2":117211,"SMAXSN":4958,"SMAXIN":0,"CCAIN-1":0,"CCASN":3830,"CCASN-1":3794,"SMAXIN-1":3051,"EASD01":28628724,"EASF06":0,"EASF01":36561822,"UMOY1":231}}
        La trame MQT: tele/TeleInfo/SENSOR me semble complète mais libTeleinfo indique toujours des erreurs de type
        Est-ce que tu sais de quoi ça peut provenir?
        • SamquadS Samquad
          SamquadS Offline
          SamquadS Offline
          Samquad
          Autre question pour décoder la trame MQT en mode historique, j'avais créé un flow nodred pour décoder la trame.
          Depuis le passage en mode standard je n'arrive plus à décoder la trame car elle semble incomplète ou non reconnue comme un objet json
          Est que quelqu'un saurait m'aider à modifier ce flow ou à créer un Rule dans Tamsota pour récupérer directement des les valeurs qui m'intéressent?
          Pour le Rule dans un wemos j'ai l'exemple ci dessous qui me permet d'envoyer des sondes de températures à Domoticz
          Rule1
          on tele-DS18B20-1#Temperature do publish domoticz/in {"idx":105,"svalue":"%value%"} endon
          on tele-DS18B20-2#Temperature do publish domoticz/in {"idx":110,"svalue":"%value%"} endon
          on tele-DS18B20-3#Temperature do publish domoticz/in {"idx":111,"svalue":"%value%"} endon
          Est-ce que quelqu'un a un exemple de Rule pour envoyer le courant , la charge , l'index du compteur?
          • SamquadS Samquad
            Rule1
            #35
            @Samquad sans voir la config de tes noeuds c'est compliqué, au moins le json et le code d'une des fonctions entrantes à minima
            Si tu as du node red fait tout dans node red et évite les rules dans tasmota c'est un peu galère (ou passe via script berry)
              SamquadS Offline
              SamquadS Offline
              Samquad
              Moi aussi je préfèrerai continuer avec nodered.
              Voici mon code node red qui fonctionnait quand le linky était en mode historique avec tasmota V9x et téléinfo.
              J'avais réussi à bricoler ce flow pour envoyer les données dans domoticz
              [{"id":"34f140f8.a2bfa","type":"tab","label":"TeleInfo","disabled":false,"info":""},{"id":"e777bc5.9f4d44","type":"comment","z":"34f140f8.a2bfa","name":"Instructions de paramétrage pour domoticz dans l'ESP Tasmota-sensor-Teleinfo il faut activer \"SetOption108 1\"","info":"Dans domoticz:\nCréer le matériel téléinfo en USB pour créer automatiquement les capteurs de mesure\n\nModifier le matériel en dummy pour rendre les capteurs virtuels\nRelever l'IDX de chaque capteur virtuel dans domoticz\n\nDans L'ESP Tasmota:\n\nParamétrer tasmota sensor avec telefinfo et vérifier que les données du compteur sont affichées sur la page web de l'ESP\nConfiguration MQTT: Renseigner Topic= TeleInfo\n\ndans le menu Console:\n\nSaisir la commande setOption108 1\n\n_______________________________\npour info:\n0 = Teleinfo telemetry into Energy MQTT JSON (default)\n1 = Teleinfo raw data only\n_______________________________\n\nVérifier la présence de trames qui commencent par:--> MQT: tele/TeleInfo/RESULT = {...\n\nDans Node-Red:\n\nDans chaque bloc fonction \"Décode Trame...\"\"\nRenseignger l'IDX Domoticz de chaque capteur virtuel associé\nAdapter les infos et les seuils au contrat\n\nDans chaque bloc \"tele/TeleInfo\" et \"mqtt/in\"\nAdapter les paramètres au serveur domtoticz\nDéployer le Flow\n\nDans Domoticz:\n\nVérifier dans les log si les messages MQTT sont bien réceptionnés\nVérifier si les capteurs affichent les données\n","x":410,"y":40,"wires":[]},{"id":"1b669ddb.c2c732","type":"json","z":"34f140f8.a2bfa","name":"","property":"payload","action":"","pretty":false,"x":230,"y":340,"wires":[["b13a5fad.22bef","ea2010a9.53948","91aaccbd.44a7","3906e2c8.df91ce","c7d7f48.21e2a08","d994fe9.eb362","4928abc7.9f50b4"]]},{"id":"b13a5fad.22bef","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":470,"y":220,"wires":[]},{"id":"4928abc7.9f50b4","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Total","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\nXValue= \"\"+ msg.payload.TIC.BASE + \";0;0;0;\" + msg.payload.TIC.PAPP + \";0\";\n\nmsg.payload = {};\nmsg.payload.idx = 69;\nmsg.payload.svalue = XValue;\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":280,"wires":[["566c815d.a5a5d","4e116d.9133ce94"]]},{"id":"566c815d.a5a5d","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":260,"wires":[]},{"id":"4e116d.9133ce94","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":280,"wires":[]},{"id":"a93412bc.bf78d","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":520,"wires":[]},{"id":"ea2010a9.53948","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Charge","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\n//XValue= \"\"+ Math.round((msg.payload.IINST/msg.payload.ISOUSC)*100);\n\nif (msg.payload.TIC.PAPP>0) {\n    XValue= \"\"+ Math.round((msg.payload.TIC.IINST/msg.payload.TIC.ISOUSC)*100);\n}\nelse XValue= \"0\";\n\nmsg.payload = {};\nmsg.payload.idx = 71;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":440,"wires":[["3b94d44c.87a34c","f45557f4.05a298"]]},{"id":"f45557f4.05a298","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":440,"wires":[]},{"id":"3b94d44c.87a34c","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":420,"wires":[]},{"id":"91aaccbd.44a7","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Current","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\n\n//XValue= msg.payload.IINST+\";0;0\";\n\nif (msg.payload.TIC.PAPP>0) {\n    XValue= msg.payload.TIC.IINST+\";0;0\";\n}\nelse XValue= \"0;0;0\";\n\nmsg.payload = {};\nmsg.payload.idx = 99;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":520,"wires":[["72ded3b2.4e5e1c","a93412bc.bf78d"]]},{"id":"72ded3b2.4e5e1c","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":500,"wires":[]},{"id":"b4e3e8af.7a2818","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":600,"wires":[]},{"id":"c9b9361f.3f2328","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame PTEC","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\nif (msg.payload.TIC.PTEC==\"HP..\") {\n    XValue= \"(2) Heures Pleines\";\n}\nelse XValue= \"(1) Heures Creuses\";\n\nmsg.payload = {};\nmsg.payload.idx = 72;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":600,"wires":[["f762a514.7927c8","b4e3e8af.7a2818"]]},{"id":"f762a514.7927c8","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":580,"wires":[]},{"id":"aa682529.bceab8","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":680,"wires":[]},{"id":"3906e2c8.df91ce","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Gestion alerte courant","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\nif ((msg.payload.TIC.IINST<48 && msg.payload.PAPP>0) || msg.payload.TIC.PAPP<=0) {\n    XValue= \"(1) < 80% de 60A souscrits\";\n}\nelse if (msg.payload.TIC.IINST>=48 && msg.payload.IINST<52 && msg.payload.TIC.PAPP>0) {\n    XValue= \"(2) >80% et <90% de 60A souscrits\";\n}\nelse XValue= \"(3) >90% de 60A souscrits\";\n\nmsg.payload = {};\nmsg.payload.idx = 73;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":550,"y":680,"wires":[["899a138.e5c52f","aa682529.bceab8"]]},{"id":"899a138.e5c52f","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":660,"wires":[]},{"id":"d6e1107c.8379","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":760,"wires":[]},{"id":"c7d7f48.21e2a08","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Current en Surplus","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\n\n//XValue= msg.payload.IINST+\";0;0\";\n\nif (msg.payload.TIC.PAPP===0) {\n    XValue= msg.payload.TIC.IINST+\";0;0\";\n}\nelse XValue= \"0;0;0\";\n\nmsg.payload = {};\nmsg.payload.idx = 96;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":540,"y":760,"wires":[["54692d1e.95f5a4","d6e1107c.8379"]]},{"id":"54692d1e.95f5a4","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":740,"wires":[]},{"id":"d994fe9.eb362","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame KWh","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\nXValue= msg.payload.TIC.PAPP +\";\"+ msg.payload.TIC.BASE;\n\nmsg.payload = {};\nmsg.payload.idx = 68;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":360,"wires":[["5743d5d0.f6320c","b2fc7f56.9ab89"]]},{"id":"b2fc7f56.9ab89","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":360,"wires":[]},{"id":"5743d5d0.f6320c","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":340,"wires":[]},{"id":"386fc3a5.7e04fc","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":450,"y":100,"wires":[]},{"id":"a80552d8.42856","type":"mqtt in","z":"34f140f8.a2bfa","name":"","topic":"tele/TeleInfo/SENSOR/#","qos":"2","datatype":"auto","broker":"ead0b0c3.e5e6d","x":120,"y":100,"wires":[["386fc3a5.7e04fc","1b669ddb.c2c732"]]},{"id":"9a37d1dd.66c5a","type":"mqtt-broker","z":"","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"15","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"{\"hwid\":\"19\",\"idx\":56,\"nvalue\":0,\"svalue\":\"959\"}","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"ead0b0c3.e5e6d","type":"mqtt-broker","z":"","name":"","broker":"192.168.1.200","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
              Depuis le passage du linky en mode standard et tasmota en V12x mon Flow ne fonctionne plus et je ne comprend pas pourquoi.
              J'ai l'impression que le noeud JSON "convert beetween string et object ne fonctionne plus.
              Si quelqu'un peut m'aider à le faire fonctionner ou m'indiquer comment extraire autrement.
              Il ne me manque plus que ça pour pouvoir récupérer les info du compteur Linky dans domoticz🤞
              • SamquadS Samquad
                #37
                @Samquad t'as essayé de changer le mode du noeud json en always convert to javascript object car derrière tu attends un objet JS
                Sinon je viens de tester chez moi ça marche nickel en plus simple (c'est en standard mais même principe)
                Juste le noeud de MQTT mettre auto detect (parsed json, string or buffer)
                  SamquadS Offline
                  SamquadS Offline
                  Samquad
                  Je n'arrive pas à reproduire ton flow et obtenir les infos en debug.
                  Peux-tu m'envoyer le code de ton flow à coller dans Node red pour pouvoir tester?
                  • SamquadS Samquad
                    SamquadS Offline
                    SamquadS Offline
                    Samquad
                    La trame MQT émise par le Wemos Tasmota est complète
                    Je visualise sa valeur avec MQTT explorer (837 caractères)
                    {"TIC":{"EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"PREF":12,"CCAIN":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","EASF04":0,"EASF05":0,"EASF10":0,"SMAXIN":0,"EASD04":"#EAIT","ERQ2":117250,"SMAXSN-1":5555,"SINSTI":0,"EASD01":"028634536FEASD02044464066","ERQ3":787775,"EAST":73129067,"SINSTR02042NRL@XRNH221125202319":5555,"SMAXSN":6553,"CCASN":1710,"SINSTR02006NRL@XRNH221126025342":4970,"SINSTS":2555,"PCOUP":12,"SMAXIN-1":2583,"DATE":"<NGTF","NGTF":"      BASE      ","EASD02":44477233,"CCAIN-1":0,"EAIT":6777077,"EASF01":"036626228HE@RF02026496683","CCASN-1":3686,"VTIC":2,"ERQ1":4304705,"IRMS1":11,"UMOY1":226,"URMS1":224,"ERQ4":4591690,"EASF01":36632382,"LTARF":"      BASE      ","EASF06":0,"EASD01":28651834}}
                    Par contre la trame reçue dans le noeud MQTT node red est incomplète:
                    elle n'affiche que les 501 premiers caractères et il manque les 337 caractères
                    {"TIC":{"EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"PREF":12,"CCAIN":0,"STGE":"003A0101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","EASF04":0,"EASF05":0,"EASF10":0,"SMAXIN":0,"EASD04":"#EAIT","ERQ2":117250,"SMAXSN-1":5555,"SINSTI":0,"EASD01":"028634536FEASD02044464066","ERQ3":787775,"EAST":73128826,"SINSTR02042NRL@XRNH221125202319":5555,"SMAXSN":6553,"CCASN":1710,"SINSTR02006NRL@XRNH221126025342":497
                    C'est pour ça que je n'arrive pas à récupérer mes infos.
                    La trame lue par Node red est incomplète et je ne comprend pas pourquoi😢
                    • SamquadS Samquad
                      SamquadS Offline
                      SamquadS Offline
                      Samquad
                      Dans tasmota sur la page https://tasmota.github.io/docs/Teleinfo/#configuring-teleinfo
                      j'ai vu une option non documentée EnergyConfig Limit
                      Je cherche à réduire la trame mqt envoyée par tasmota pour pouvoir la lire dans Node Red et traiter les infos qui m'intéressent.
                      Peux-tu m'indiquer le paramètre pour limiter les infos émises par tasmota à
                      SINSTS puissance apparante soutirée
                      EASF01 index comptage soutiré
                      IRMS1 courant instantané
                      EAIT index compteur production
                      SINSTI puissance apparente injectée
                      • SamquadS Samquad
                        @Samquad le paramètre limit n'existe plus il a été remplacé par skip mais ça ne change pas la taille de la trame, ça évite juste d'envoyer une trame toutes les secondes par exemple.
                        Pour n'envoyer que les paramètres qui ont changés (donc trame plus courte) la commande c'est energyconfig changed
                        Pour le flow node red c'est peut être l'affichage de la trame en debug dans node red qui tronque parce qu'il n'y a rien dans le flow juste une noeud MQTT et un noeud de fonction que j'ai décrit plus haut.
                          SamquadS Offline
                          SamquadS Offline
                          Samquad
                          le Noeud MQTT in de node red reçoit bien la trame en entier quand l'option energyconfig changed est activée.
                          trame reçue avec option changed
                          Quand energyconfig full est activé la trame est tronquée par le noeud MQTT in😠
                          --> La limitation semble provenir du noeud MQTT in dans Node red.
                          Si je colle la trame full dans le noeud inject je la visualise en entier dans un noeud debug msg.payload
                          Pour compiler mes données pour domoticz j'ai besoin de recevoir les données qui changent mais aussi les autres sur lesquels j'ai des conditions.
                          Est-ce que tu peux m'aider à créer un Rule dans tamsota pour envoyer une trame mqt: tele/Teleinfo/SENSORperso limitée à ces données:
                          Je ne sais pas comment écrire cette rule mais je pense que c'est peut-etre possible et que ça pourrait servir à beaucoup d'entre nous😉
                          • SamquadS Samquad
                            @Samquad comme déjà indiqué les rules c'est galère je n'utilise plus les règles
                            Regarde l'exemple en Berry dans la doc du Wemos Tic qui poste sur Emoncms, tu peux utiliser exactement le même principe a peut prêt.
                            PS : ta trame me parait bien corrompue, tu utilises bien la version 12 de Tasmota?
                              SamquadS Offline
                              SamquadS Offline
                              Samquad
                              OK, j'abandonne l'idée des rules, je vais regarder la doc en Berry mais j'ai peur que ça dépasse mes compétences techniques.
                              Je pense que l'utilisation de node red c'est théoriquement plus simple.
                              Problème : il ne fonctionne pas à cause (je pense) d'un problème de la trame émise MQT --> Est-ce qu'on pourrait s'assurer que Tasmota fonctionne correctement?
                              J'utilise Tasmota V12.2.0.2 et j'ai des erreurs dans la console en permanence.
                              Pour reprendre depuis le début:
                              Mon compteur est configuré en mode standard, le Pitinfo V1.4 est tout neuf
                              • Connecté sur un RPI3 : le test picocom reçoit les trames TIC. elles semblent être conformes (voir les trames un peu plus haut dans le post)
                              • Connecté sur wemos mini d1 tasmota , les données s'affichent
                              La trame MQT est envoyée mais est-ce qu'elle est conforme?
                              Entre chaque trame MQT je constate beaucoup d'erreurs dans la console
                              --> est-ce que c'est normale toutes ces erreurs?
                              19:47:01.520 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASD02":44620995,"EASD03":0,"EASD04":0,"ERQ3":787836,"ERQ4":4606767,"IRMS1":10,"URMS1":233,"PREF":12,"PCOUP":12,"SMAXSN-1":6036,"SINSTI":0,"CCASN":5502,"CCAIN":0,"STGE":"003A4101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73341244,"EASF04":0,"EASF05":0,"EASF09":0,"EASF10":0,"EASD01":28720250,"EAIT":6778086,"ERQ1":4306558,"SINSTS":2387,"SMAXSN":7581,"SMAXIN":2405,"CCAIN-1":0,"EASF01":36844561,"EASF06":0,"ERQ2":117434,"CCASN-1":4176,"SMAXIN-1":1209,"UMOY1":233}}
                              19:47:01.752 LibTeleinfo::checkLine Err checksum 0x45 != 0x46
                              19:47:01.754 LibTeleinfo::checkLine Err checksum 0x2C != 0x24
                              19:47:01.756 LibTeleinfo::checkLine Err checksum 0x22 != 0x25
                              19:47:01.762 LibTeleinfo::checkLine Err checksum 0x43 != 0x29
                              19:47:02.003 LibTeleinfo::checkLine Err checksum 0x27 != 0x2A
                              19:47:02.009 LibTeleinfo::checkLine Err checksum 0x26 != 0x30
                              19:47:02.016 LibTeleinfo::checkLine Err checksum 0x41 != 0x42
                              19:47:02.258 LibTeleinfo::checkLine Err checksum 0x5A != 0x5C
                              19:47:02.260 LibTeleinfo::checkLine Err checksum 0x54 != 0x55
                              19:47:02.264 LibTeleinfo::checkLine Err checksum 0x57 != 0x58
                              19:47:02.265 LibTeleinfo::checkLine Err checksum 0x39 != 0x3C
                              19:47:02.269 LibTeleinfo::checkLine Err checksum 0x40 != 0x45
                              19:47:02.503 LibTeleinfo::checkLine Err checksum 0x29 != 0x2F
                              19:47:02.505 LibTeleinfo::checkLine Err checksum 0x49 != 0x4A
                              19:47:02.506 LibTeleinfo::checkLine Err checksum 0x54 != 0x32
                              19:47:02.508 LibTeleinfo::checkLine Err checksum 0x52 != 0x4E
                              19:47:02.753 LibTeleinfo: _recv_idx = 128/128 buffer overflow
                              19:47:02.755 LibTeleinfo::checkLine Err checksum 0x34 != 0x39
                              19:47:02.757 LibTeleinfo::checkLine Err checksum 0x48 != 0x4A
                              19:47:03.003 LibTeleinfo::checkLine Err checksum 0x47 != 0x4A
                              19:47:03.007 LibTeleinfo::checkLine Err checksum 0x38 != 0x26
                              19:47:03.008 LibTeleinfo::checkLine Err checksum 0x24 != 0x27
                              19:47:03.014 LibTeleinfo::checkLine Err checksum 0x3E != 0x30
                              19:47:03.260 LibTeleinfo::checkLine Err checksum 0x3E != 0x50
                              19:47:03.503 LibTeleinfo::checkLine Err checksum 0x53 != 0x58
                              19:47:03.506 LibTeleinfo::checkLine Err checksum 0x34 != 0x4E
                              19:47:03.510 LibTeleinfo::checkLine Err checksum 0x3D != 0x2F
                              19:47:03.514 LibTeleinfo::checkLine Err checksum 0x30 != 0x35
                              19:47:03.753 LibTeleinfo::checkLine Err checksum 0x3C != 0x31
                              19:47:03.755 LibTeleinfo::checkLine Err checksum 0x4D != 0x4E
                              19:47:04.006 LibTeleinfo::checkLine Err checksum 0x4C != 0x50
                              19:47:04.008 LibTeleinfo::checkLine Err checksum 0x21 != 0x24
                              19:47:04.505 LibTeleinfo::checkLine Err checksum 0x59 != 0x5C
                              19:47:04.507 LibTeleinfo::checkLine Err checksum 0x59 != 0x5B
                              19:47:04.515 LibTeleinfo::checkLine Err checksum 0x2A != 0x32
                              19:47:04.517 LibTeleinfo::checkLine Err checksum 0x4D != 0x4E
                              19:47:04.757 LibTeleinfo::checkLine Err checksum 0x46 != 0x4A
                              19:47:04.759 LibTeleinfo::checkLine Err checksum 0x33 != 0x35
                              19:47:05.019 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASD02":44620997,"EASD03":0,"EASD04":0,"ERQ3":787836,"ERQ4":4606767,"IRMS1":10,"URMS1":233,"PREF":12,"PCOUP":12,"SMAXSN-1":6036,"SINSTI":0,"CCAIN":0,"STGE":"003A4101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73341247,"EASF04":0,"EASF05":0,"EASF09":0,"EASF10":0,"EASD01":28720250,"EAIT":6778086,"ERQ1":4306558,"SINSTS":2379,"SMAXSN":7581,"SMAXIN":2405,"CCAIN-1":0,"EASF01":36844563,"EASF06":0,"ERQ2":117434,"CCASN-1":4176,"SMAXIN-1":1209,"UMOY1":233,"CCASN":"04402DCB@RN0H220129190000"}}
                              19:47:05.258 LibTeleinfo::checkLine Err checksum 0x2D != 0x2F
                              19:47:05.260 LibTeleinfo::checkLine Err checksum 0x37 != 0x25
                              19:47:05.266 LibTeleinfo::checkLine Err checksum 0x2F != 0x30
                              19:47:05.509 LibTeleinfo::checkLine Err checksum 0x58 != 0x5A
                              19:47:05.752 LibTeleinfo::checkLine Err checksum 0x4F != 0x30
                              19:47:05.754 LibTeleinfo::checkLine Err checksum 0x48 != 0x4D
                              19:47:05.756 LibTeleinfo::checkLine Err checksum 0x58 != 0x32
                              19:47:05.760 LibTeleinfo::checkLine Err checksum 0x3F != 0x45
                              19:47:05.761 LibTeleinfo::checkLine Err checksum 0x23 != 0x26
                              19:47:06.003 LibTeleinfo::checkLine Err checksum 0x54 != 0x4A
                              19:47:06.257 LibTeleinfo::checkLine Err checksum 0x3C != 0x09
                              19:47:06.259 LibTeleinfo::checkLine Err checksum 0x3B != 0x3C
                              19:47:06.261 LibTeleinfo::checkLine Err checksum 0x2F != 0x4B
                              19:47:06.503 LibTeleinfo::checkLine Err checksum 0x4D != 0x50
                              19:47:06.508 LibTeleinfo::checkLine Err checksum 0x26 != 0x30
                              19:47:06.516 LibTeleinfo::checkLine Err checksum 0x24 != 0x4B
                              19:47:06.518 LibTeleinfo::checkLine Err checksum 0x21 != 0x22
                              19:47:06.757 LibTeleinfo::checkLine Err checksum 0x22 != 0x30
                              19:47:06.759 LibTeleinfo::checkLine Err checksum 0x21 != 0x22
                              19:47:06.765 LibTeleinfo::checkLine Err checksum 0x31 != 0x58
                              19:47:07.005 LibTeleinfo::checkLine Err checksum 0x32 != 0x4E
                              19:47:07.009 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
                              19:47:07.010 LibTeleinfo::checkLine Err checksum 0x2C != 0x2F
                              19:47:07.012 LibTeleinfo::checkLine Err checksum 0x4D != 0x35
                              19:47:07.506 LibTeleinfo::checkLine Err checksum 0x20 != 0x30
                              19:47:07.759 LibTeleinfo::checkLine Err checksum 0x32 != 0x22
                              19:47:07.761 LibTeleinfo::checkLine Err checksum 0x39 != 0x3A
                              19:47:08.006 LibTeleinfo::checkLine Err checksum 0x20 != 0x5C
                              19:47:08.009 LibTeleinfo::checkLine Err checksum 0x46 != 0x4D
                              19:47:08.011 LibTeleinfo::checkLine Err checksum 0x57 != 0x58
                              19:47:08.014 LibTeleinfo::checkLine Err checksum 0x2C != 0x32
                              19:47:08.016 LibTeleinfo::checkLine Err checksum 0x4B != 0x4E
                              19:47:08.258 LibTeleinfo::checkLine Err checksum 0x29 != 0x26
                              19:47:08.260 LibTeleinfo::checkLine Err checksum 0x2A != 0x2F
                              19:47:08.264 LibTeleinfo::checkLine Err checksum 0x4A != 0x3F
                              19:47:08.266 LibTeleinfo::checkLine Err checksum 0x3A != 0x3C
                              19:47:08.503 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
                              19:47:08.519 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASD02":44620998,"EASD03":0,"EASD04":0,"ERQ3":787836,"ERQ4":4606767,"IRMS1":8,"URMS1":234,"PREF":12,"PCOUP":12,"SMAXSN-1":6036,"SINSTI":0,"CCAIN":0,"STGE":"003A4101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73341247,"EASF04":0,"EASF05":0,"EASF09":0,"EASF10":0,"EASD01":28720250,"EAIT":6778086,"ERQ1":4306558,"SINSTS":1929,"SMAXSN":7581,"SMAXIN":2405,"CCAIN-1":0,"EASF01":36844565,"EASF06":0,"ERQ2":117434,"CCASN-1":4176,"SMAXIN-1":1209,"UMOY1":233,"CCASN":5502}}
                              19:47:08.755 LibTeleinfo::checkLine Err checksum 0x35 != 0x26
                              19:47:09.002 LibTeleinfo::checkLine Err checksum 0x4A != 0x4C
                              19:47:09.008 LibTeleinfo::checkLine Err checksum 0x2A != 0x30
                              19:47:09.010 LibTeleinfo::checkLine Err checksum 0x25 != 0x24
                              19:47:09.012 LibTeleinfo::checkLine Err checksum 0x20 != 0x22
                              19:47:09.258 LibTeleinfo::checkLine Err checksum 0x2C != 0x58
                              19:47:09.262 LibTeleinfo::checkLine Err checksum 0x32 != 0x4E
                              19:47:09.266 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
                              19:47:09.267 LibTeleinfo::checkLine Err checksum 0x2B != 0x2F
                              19:47:09.503 LibTeleinfo::checkLine Err checksum 0x4A != 0x35
                              19:47:09.507 LibTeleinfo::checkLine Err checksum 0x41 != 0x42
                              19:47:09.756 LibTeleinfo::checkLine Err checksum 0x47 != 0x4E
                              19:47:10.002 LibTeleinfo::checkLine Err checksum 0x4D != 0x50
                              19:47:10.009 LibTeleinfo::checkLine Err checksum 0x3C != 0x28
                              19:47:10.011 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
                              19:47:10.016 LibTeleinfo::checkLine Err checksum 0x4E != 0x32
                              19:47:10.018 LibTeleinfo::checkLine Err checksum 0x5F != 0x22
                              19:47:14.515 LibTeleinfo::checkLine Err checksum 0x24 != 0x28
                              19:47:14.762 LibTeleinfo::checkLine Err checksum 0x28 != 0x50
                              19:47:15.005 LibTeleinfo::checkLine Err checksum 0x32 != 0x58
                              19:47:15.009 LibTeleinfo::checkLine Err checksum 0x31 != 0x4E
                              19:47:15.256 LibTeleinfo::checkLine Err checksum 0x21 != 0x26
                              19:47:15.258 LibTeleinfo::checkLine Err checksum 0x2E != 0x2F
                              19:47:15.260 LibTeleinfo::checkLine Err checksum 0x4D != 0x35
                              19:47:15.514 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASD02":44620998,"EASD03":0,"EASD04":0,"ERQ3":787836,"ERQ4":4606768,"IRMS1":8,"URMS1":236,"PREF":12,"PCOUP":12,"SMAXSN-1":6036,"SINSTI":0,"CCAIN":0,"STGE":"003A4101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73341250,"EASF04":0,"EASF05":0,"EASF09":0,"EASF10":0,"EASD01":28720250,"EAIT":6778086,"ERQ1":4306558,"SINSTS":1937,"SMAXSN":7581,"SMAXIN":2405,"CCAIN-1":0,"EASF01":36844566,"EASF06":0,"ERQ2":117434,"CCASN-1":4176,"SMAXIN-1":1209,"UMOY1":233,"CCASN":5502}}
                              19:47:15.753 LibTeleinfo::checkLine Err checksum 0x2C != 0x24
                              19:47:15.755 LibTeleinfo::checkLine Err checksum 0x22 != 0x25
                              19:47:15.760 LibTeleinfo::checkLine Err checksum 0x4C != 0x30
                              19:47:16.011 LibTeleinfo::checkLine Err checksum 0x59 != 0x5C
                              19:47:16.013 LibTeleinfo::checkLine Err checksum 0x53 != 0x56
                              19:47:16.257 LibTeleinfo::checkLine Err checksum 0x31 != 0x32
                              19:47:16.259 LibTeleinfo::checkLine Err checksum 0x3F != 0x45
                              19:47:16.263 LibTeleinfo::checkLine Err checksum 0x2A != 0x2F
                              19:47:16.265 LibTeleinfo::checkLine Err checksum 0x47 != 0x4A
                              19:47:16.504 LibTeleinfo::checkLine Err checksum 0x5C != 0x42
                              19:47:16.753 LibTeleinfo::checkLine Err checksum 0x4B != 0x4F
                              19:47:17.001 LibTeleinfo::checkLine Err checksum 0x42 != 0x30
                              19:47:17.256 LibTeleinfo::checkLine Err checksum 0x3D != 0x5A
                              19:47:17.267 LibTeleinfo::checkLine Err checksum 0x46 != 0x4D
                              19:47:17.272 LibTeleinfo::checkLine Err checksum 0x2B != 0x32
                              19:47:17.502 LibTeleinfo::checkLine Err checksum 0x4B != 0x4E
                              19:47:17.504 LibTeleinfo::checkLine Err checksum 0x29 != 0x26
                              19:47:17.508 LibTeleinfo::checkLine Err checksum 0x47 != 0x4A
                              19:47:17.510 LibTeleinfo::checkLine Err checksum 0x31 != 0x35
                              19:47:17.772 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASD02":44621002,"EASD03":0,"EASD04":0,"ERQ3":787836,"ERQ4":4606768,"IRMS1":8,"URMS1":235,"PREF":12,"PCOUP":12,"SMAXSN-1":6036,"SINSTI":0,"CCAIN":0,"STGE":"003A4101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73341252,"EASF04":0,"EASF05":0,"EASF09":0,"EASF10":0,"EASD01":28720250,"EAIT":6778086,"ERQ1":4306558,"SINSTS":1921,"SMAXSN":7581,"SMAXIN":2405,"CCAIN-1":0,"EASF01":36844569,"EASF06":0,"ERQ2":117434,"CCASN-1":4176,"SMAXIN-1":1209,"UMOY1":233,"CCASN":5502}}
                              19:47:18.004 LibTeleinfo::checkLine Err checksum 0x23 != 0x30
                              19:47:18.257 LibTeleinfo::checkLine Err checksum 0x40 != 0x29
                              19:47:18.265 LibTeleinfo::checkLine Err checksum 0x30 != 0x22
                              19:47:18.267 LibTeleinfo::checkLine Err checksum 0x21 != 0x23
                              19:47:18.274 LibTeleinfo::checkLine Err checksum 0x31 != 0x23
                              19:47:18.276 LibTeleinfo::checkLine Err checksum 0x33 != 0x36
                              19:47:18.278 LibTeleinfo::checkLine Err checksum 0x43 != 0x44
                              19:47:18.508 LibTeleinfo::checkLine Err checksum 0x56 != 0x58
                              19:47:18.514 LibTeleinfo::checkLine Err checksum 0x47 != 0x4E
                              19:47:18.515 LibTeleinfo::checkLine Err checksum 0x3F != 0x45
                              19:47:18.517 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
                              19:47:18.753 LibTeleinfo::checkLine Err checksum 0x52 != 0x4A
                              19:47:19.260 LibTeleinfo::checkLine Err checksum 0x35 != 0x26
                              19:47:19.267 LibTeleinfo::checkLine Err checksum 0x33 != 0x22
                              19:47:19.269 LibTeleinfo::checkLine Err checksum 0x38 != 0x3A
                              19:47:19.513 LibTeleinfo::checkLine Err checksum 0x36 != 0x4D
                              19:47:24.769 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASD02":44621005,"EASD03":0,"EASD04":0,"ERQ3":787836,"ERQ4":4606768,"IRMS1":10,"URMS1":233,"PREF":12,"PCOUP":12,"SMAXSN-1":6036,"SINSTI":0,"CCAIN":0,"STGE":"003A4101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73341255,"EASF04":0,"EASF05":0,"EASF09":0,"EASF10":0,"EASD01":28720250,"EAIT":6778086,"ERQ1":4306558,"SINSTS":2383,"SMAXSN":7581,"SMAXIN":2405,"CCAIN-1":0,"EASF01":36844572,"EASF06":0,"ERQ2":117434,"CCASN-1":4176,"SMAXIN-1":1209,"UMOY1":233,"CCASN":5502}}
                              19:47:24.773 LibTeleinfo::checkLine Err checksum 0x36 != 0x39
                              19:47:25.004 LibTeleinfo::checkLine Err checksum 0x37 != 0x25
                              19:47:25.005 LibTeleinfo::checkLine Err checksum 0x23 != 0x26
                              19:47:25.011 LibTeleinfo::checkLine Err checksum 0x45 != 0x2A
                              19:47:25.257 LibTeleinfo::checkLine Err checksum 0x5E != 0x22
                              19:47:25.503 LibTeleinfo::checkLine Err checksum 0x4A != 0x59
                              19:47:25.504 LibTeleinfo::checkLine Err checksum 0x49 != 0x4D
                              19:47:25.506 LibTeleinfo::checkLine Err checksum 0x25 != 0x32
                              19:47:25.510 LibTeleinfo::checkLine Err checksum 0x3F != 0x45
                              19:47:25.753 LibTeleinfo::checkLine Err checksum 0x52 != 0x4A
                              19:47:26.003 LibTeleinfo: _recv_idx = 128/128 buffer overflow
                              19:47:26.004 LibTeleinfo::checkLine Err checksum 0x57 != 0x09
                              19:47:26.007 LibTeleinfo::checkLine Err checksum 0x2C != 0x4A
                              19:47:26.257 LibTeleinfo::checkLine Err checksum 0x4D != 0x50
                              19:47:26.263 LibTeleinfo::checkLine Err checksum 0x3D != 0x27
                              19:47:26.264 LibTeleinfo::checkLine Err checksum 0x24 != 0x28
                              19:47:26.270 LibTeleinfo::checkLine Err checksum 0x57 != 0x30
                              19:47:26.505 LibTeleinfo::checkLine Err checksum 0x29 != 0x50
                              19:47:26.513 LibTeleinfo::checkLine Err checksum 0x33 != 0x58
                              19:47:26.755 LibTeleinfo::checkLine Err checksum 0x31 != 0x4E
                              19:47:26.759 LibTeleinfo::checkLine Err checksum 0x21 != 0x26
                              19:47:26.761 LibTeleinfo::checkLine Err checksum 0x2E != 0x2F
                              19:47:26.763 LibTeleinfo::checkLine Err checksum 0x4C != 0x35
                              19:47:27.259 LibTeleinfo::checkLine Err checksum 0x2D != 0x24
                              19:47:27.260 LibTeleinfo::checkLine Err checksum 0x22 != 0x25
                              19:47:27.504 LibTeleinfo::checkLine Err checksum 0x4C != 0x30
                              19:47:27.752 LibTeleinfo::checkLine Err checksum 0x2F != 0x42
                              19:47:27.753 LibTeleinfo::checkLine Err checksum 0x59 != 0x5C
                              19:47:27.755 LibTeleinfo::checkLine Err checksum 0x57 != 0x5A
                              19:47:27.759 LibTeleinfo::checkLine Err checksum 0x31 != 0x32
                              19:47:28.002 LibTeleinfo::checkLine Err checksum 0x3F != 0x45
                              19:47:28.006 LibTeleinfo::checkLine Err checksum 0x2A != 0x2F
                              19:47:28.008 LibTeleinfo::checkLine Err checksum 0x46 != 0x4A
                              19:47:28.256 LibTeleinfo::checkLine Err checksum 0x5C != 0x42
                              19:47:28.270 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASD02":44621007,"EASD03":0,"EASD04":0,"ERQ3":787836,"ERQ4":4606769,"IRMS1":10,"URMS1":233,"PREF":12,"PCOUP":12,"SMAXSN-1":6036,"SINSTI":0,"CCAIN":0,"STGE":"003A4101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73341257,"EASF04":0,"EASF05":0,"EASF09":0,"EASF10":0,"EASD01":28720250,"EAIT":6778086,"ERQ1":4306558,"SINSTS":2377,"SMAXSN":7581,"SMAXIN":2405,"CCAIN-1":0,"EASF01":36844574,"EASF06":0,"ERQ2":117434,"CCASN-1":4176,"SMAXIN-1":1209,"UMOY1":233,"CCASN":5502}}
                              19:47:28.502 LibTeleinfo::checkLine Err checksum 0x2D != 0x30
                              19:47:28.504 LibTeleinfo::checkLine Err checksum 0x40 != 0x30
                              19:47:28.512 LibTeleinfo::checkLine Err checksum 0x32 != 0x22
                              19:47:28.757 LibTeleinfo::checkLine Err checksum 0x58 != 0x5A
                              19:47:29.003 LibTeleinfo::checkLine Err checksum 0x46 != 0x4D
                              19:47:29.005 LibTeleinfo::checkLine Err checksum 0x58 != 0x32
                              19:47:29.009 LibTeleinfo::checkLine Err checksum 0x3F != 0x45
                              19:47:29.010 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
                              19:47:29.257 LibTeleinfo::checkLine Err checksum 0x53 != 0x4A
                              19:47:29.753 LibTeleinfo::checkLine Err checksum 0x21 != 0x24
                              19:47:29.759 LibTeleinfo::checkLine Err checksum 0x3F != 0x28
                              19:47:29.764 LibTeleinfo::checkLine Err checksum 0x48 != 0x30
                              19:47:30.005 LibTeleinfo::checkLine Err checksum 0x3C != 0x24
                              19:47:30.007 LibTeleinfo::checkLine Err checksum 0x2F != 0x30
                              19:47:30.012 LibTeleinfo::checkLine Err checksum 0x4D != 0x58
                              19:47:30.258 LibTeleinfo::checkLine Err checksum 0x47 != 0x4E
                              19:47:30.262 LibTeleinfo::checkLine Err checksum 0x45 != 0x2F
                              19:47:30.266 LibTeleinfo::checkLine Err checksum 0x30 != 0x35
                              19:47:30.504 LibTeleinfo::checkLine Err checksum 0x4D != 0x4E
                              19:47:30.754 LibTeleinfo::checkLine Err checksum 0x2F != 0x31
                              19:47:30.756 LibTeleinfo::checkLine Err checksum 0x37 != 0x25
                              19:47:30.758 LibTeleinfo::checkLine Err checksum 0x22 != 0x26
                              19:47:31.004 LibTeleinfo::checkLine Err checksum 0x2F != 0x30
                              19:47:31.011 LibTeleinfo::checkLine Err checksum 0x58 != 0x5A
                              19:47:31.260 LibTeleinfo::checkLine Err checksum 0x5F != 0x4D
                              19:47:31.266 LibTeleinfo::checkLine Err checksum 0x2B != 0x32
                              19:47:31.268 LibTeleinfo::checkLine Err checksum 0x47 != 0x4E
                              19:47:31.270 LibTeleinfo::checkLine Err checksum 0x44 != 0x45
                              19:47:31.502 LibTeleinfo::checkLine Err checksum 0x46 != 0x2F
                              19:47:31.508 LibTeleinfo::checkLine Err checksum 0x4D != 0x4E
                              19:47:31.510 LibTeleinfo::checkLine Err checksum 0x25 != 0x26
                              19:47:31.766 MQT: tele/TeleInfo/SENSOR = {"TIC":{"NGTF":"      BASE      ","EASF02":36496683,"EASF03":0,"EASF07":0,"EASF08":0,"EASD02":44621009,"EASD03":0,"EASD04":0,"ERQ3":787836,"ERQ4":4606769,"IRMS1":11,"URMS1":233,"PREF":12,"PCOUP":12,"SMAXSN-1":6036,"SINSTI":0,"CCAIN":0,"STGE":"003A4101","PRM":2147483647,"RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"ADSC":"031861721681","VTIC":2,"LTARF":"      BASE      ","EAST":73341259,"EASF04":0,"EASF05":0,"EASF09":0,"EASF10":0,"EASD01":28720250,"EAIT":6778086,"ERQ1":4306558,"SINSTS":2538,"SMAXSN":7581,"SMAXIN":2405,"CCAIN-1":0,"EASF06":0,"ERQ2":117434,"CCASN-1":4176,"SMAXIN-1":1209,"UMOY1":233,"CCASN":5502,"EASF01":36844576}}
                              19:47:31.770 LibTeleinfo::checkLine Err checksum 0x3C != 0x09
                              19:47:31.772 LibTeleinfo::checkLine Err checksum 0x3B != 0x3C
                              19:47:32.003 LibTeleinfo::checkLine Err checksum 0x25 != 0x4E
                              19:47:32.005 LibTeleinfo::checkLine Err checksum 0x4D != 0x50
                              19:47:32.011 LibTeleinfo::checkLine Err checksum 0x26 != 0x30
                              19:47:32.257 LibTeleinfo::checkLine Err checksum 0x4C != 0x33
                              19:47:32.265 LibTeleinfo::checkLine Err checksum 0x22 != 0x30
                              19:47:32.267 LibTeleinfo::checkLine Err checksum 0x23 != 0x24
                              19:47:32.503 LibTeleinfo::checkLine Err checksum 0x31 != 0x58
                              19:47:32.504 LibTeleinfo::checkLine Err checksum 0x38 != 0x3C
                              19:47:32.506 LibTeleinfo::checkLine Err checksum 0x31 != 0x32
                              19:47:32.508 LibTeleinfo::checkLine Err checksum 0x43 != 0x45
                              19:47:32.512 LibTeleinfo::checkLine Err checksum 0x2A != 0x2F
                              19:47:32.753 LibTeleinfo::checkLine Err checksum 0x47 != 0x4A
                              19:47:32.754 LibTeleinfo::checkLine Err checksum 0x2B != 0x26
                              19:47:33.005 LibTeleinfo::checkLine Err checksum 0x54 != 0x50
                              19:47:33.257 LibTeleinfo::checkLine Err checksum 0x20 != 0x24
                              19:47:33.263 LibTeleinfo::checkLine Err checksum 0x48 != 0x30
                              19:47:33.270 LibTeleinfo::checkLine Err checksum 0x2D != 0x22
                              19:47:33.505 LibTeleinfo::checkLine Err checksum 0x50 != 0x24
                              19:47:33.506 LibTeleinfo::checkLine Err checksum 0x2F != 0x30
                              19:47:33.514 LibTeleinfo::checkLine Err checksum 0x56 != 0x58
                              19:47:33.755 LibTeleinfo::checkLine Err checksum 0x47 != 0x4E
                              19:47:33.757 LibTeleinfo::checkLine Err checksum 0x44 != 0x45
                              19:47:33.759 LibTeleinfo::checkLine Err checksum 0x45 != 0x2F
                              J'espère que ces infos peuvent t'aider à cibler le problème.
                              Est-ce que c'est le contenu des données TIC qui provoque ces erreurs?
                              Mon compteur est mono / tarif base/ avec revente de surplus solaire (injection)
                              • SamquadS Samquad
                                @Samquad compliqué puisque le module semble fonctionner, mais sous tasmota tu as trop d'erreurs.
                                Tu ne veux pas essayer juste la base :
                                • juste le PI Tinfo, Ton ESP32 et le programme passthru check que les trames sont correctes à l'oeil
                                • Ensuite si ça marche, même montage mais avec Tasmota dernière version
                                Déjà avec la dernière version les étiquettes LTARF et NGTF sont trimmées ce qui doit réduire la taille
                                PS : question con pourquoi tu n'as pas pris un shield téléinfo Wemos, ça solutionne déjà tout problème potentiel de connectique entre le WeMos et le PITinfo ?
                                SamquadS 1 Reply Last reply
                                  SamquadS Offline
                                  SamquadS Offline
                                  Samquad
                                  J'ai fait les essais.
                                  ESP32 avec pitinfo et passthru check voici les captures d'écrans
                                  je ne sais pas si c'est normal mais c'est impossible de copier coller les trames dans un bloc note.
                                  Même montage avec Tasmota dernière version (toujours sur ESP32)
                                  Les valeurs s'affichent sur la page principale, mais j'ai des erreurs checksum et buffer overflow comme sur le wemos tasmota
                                  19:17:33.182 RSL: SENSOR = {"TIC":{"EAST":73562674,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625402,"IRMS1":18,"URMS1":232,"PREF":12,"PCOUP":12,"SINSTS":4235,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768300,"EASF06":0,"EASF01":37065991,"CCASN":3496}}
                                  19:17:33.400 LibTeleinfo::checkLine Err checksum 0x37 != 0x30
                                  19:17:33.405 LibTeleinfo::checkLine Err checksum 0x41 != 0x2A
                                  19:17:33.656 LibTeleinfo::checkLine Err checksum 0x25 != 0x26
                                  19:17:33.900 LibTeleinfo::checkLine Err checksum 0x53 != 0x56
                                  19:17:33.904 LibTeleinfo::checkLine Err checksum 0x4A != 0x4C
                                  19:17:33.906 LibTeleinfo::checkLine Err checksum 0x4D != 0x44
                                  19:17:33.909 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
                                  19:17:34.149 LibTeleinfo::checkLine Err checksum 0x40 != 0x44
                                  19:17:34.154 LibTeleinfo::checkLine Err checksum 0x53 != 0x30
                                  19:17:34.409 RSL: SENSOR = {"TIC":{"EAST":73562679,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625402,"IRMS1":18,"URMS1":232,"PREF":12,"PCOUP":12,"SINSTS":4235,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768306,"EASF06":0,"EASF01":37065996,"CCASN":3496}}
                                  19:17:34.679 LibTeleinfo::checkLine Err checksum 0x23 != 0x26
                                  19:17:34.680 LibTeleinfo::checkLine Err checksum 0x3B != 0x28
                                  19:17:34.687 LibTeleinfo::checkLine Err checksum 0x40 != 0x48
                                  19:17:34.689 LibTeleinfo::checkLine Err checksum 0x21 != 0x22
                                  19:17:34.929 LibTeleinfo::checkLine Err checksum 0x4C != 0x23
                                  19:17:34.930 LibTeleinfo::checkLine Err checksum 0x55 != 0x56
                                  19:17:34.937 LibTeleinfo::checkLine Err checksum 0x21 != 0x5B
                                  19:17:35.178 LibTeleinfo::checkLine Err checksum 0x4E != 0x29
                                  19:17:35.182 LibTeleinfo::checkLine Err checksum 0x5F != 0x23
                                  19:17:35.184 LibTeleinfo::checkLine Err checksum 0x20 != 0x24
                                  19:17:35.186 LibTeleinfo::checkLine Err checksum 0x37 != 0x2A
                                  19:17:35.707 RSL: SENSOR = {"TIC":{"EAST":73562679,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625402,"IRMS1":18,"URMS1":231,"PREF":12,"PCOUP":12,"SINSTS":4226,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768306,"EASF06":0,"EASF01":37065996,"CCASN":3496}}
                                  19:17:35.771 LibTeleinfo::checkLine Err checksum 0x38 != 0x24
                                  19:17:35.775 LibTeleinfo::checkLine Err checksum 0x40 != 0x29
                                  19:17:35.777 LibTeleinfo::checkLine Err checksum 0x29 != 0x2A
                                  19:17:35.889 LibTeleinfo::checkLine Err checksum 0x5B != 0x22
                                  19:17:35.891 LibTeleinfo::checkLine Err checksum 0x20 != 0x23
                                  19:17:35.892 LibTeleinfo::checkLine Err checksum 0x23 != 0x26
                                  19:17:36.139 LibTeleinfo::checkLine Err checksum 0x42 != 0x43
                                  19:17:36.141 LibTeleinfo::checkLine Err checksum 0x55 != 0x3C
                                  19:17:36.143 LibTeleinfo::checkLine Err checksum 0x48 != 0x4C
                                  19:17:36.388 LibTeleinfo::checkLine Err checksum 0x4E != 0x44
                                  19:17:36.392 LibTeleinfo::checkLine Err checksum 0x5E != 0x44
                                  19:17:36.395 LibTeleinfo::checkLine Err checksum 0x5F != 0x3C
                                  19:17:36.638 LibTeleinfo::checkLine Err checksum 0x24 != 0x26
                                  19:17:36.641 LibTeleinfo::checkLine Err checksum 0x41 != 0x42
                                  19:17:36.652 RSL: SENSOR = {"TIC":{"EAST":73562681,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625402,"IRMS1":18,"URMS1":231,"PREF":12,"PCOUP":12,"SINSTS":4226,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768306,"EASF06":0,"EASF01":37065996,"CCASN":3496}}
                                  19:17:36.715 LibTeleinfo::checkLine Err checksum 0x33 != 0x36
                                  19:17:36.925 LibTeleinfo::checkLine Err checksum 0x40 != 0x30
                                  19:17:36.931 LibTeleinfo::checkLine Err checksum 0x32 != 0x22
                                  19:17:37.175 LibTeleinfo::checkLine Err checksum 0x4C != 0x4F
                                  19:17:37.183 LibTeleinfo::checkLine Err checksum 0x42 != 0x43
                                  19:17:37.427 LibTeleinfo::checkLine Err checksum 0x4B != 0x4C
                                  19:17:37.429 LibTeleinfo::checkLine Err checksum 0x26 != 0x29
                                  19:17:37.434 LibTeleinfo::checkLine Err checksum 0x42 != 0x44
                                  19:17:37.666 LibTeleinfo::checkLine Err checksum 0x25 != 0x2A
                                  19:17:37.988 RSL: SENSOR = {"TIC":{"EAST":73562681,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625403,"IRMS1":18,"URMS1":231,"PREF":12,"PCOUP":12,"SINSTS":4226,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768309,"EASF06":0,"EASF01":37065999,"CCASN":"03486DCCASN0H220202183000"}}
                                  19:17:38.051 LibTeleinfo::checkLine Err checksum 0x45 != 0x46
                                  19:17:38.054 LibTeleinfo::checkLine Err checksum 0x28 != 0x24
                                  19:17:38.058 LibTeleinfo::checkLine Err checksum 0x42 != 0x29
                                  19:17:38.060 LibTeleinfo::checkLine Err checksum 0x28 != 0x2A
                                  19:17:38.071 LibTeleinfo::checkLine Err checksum 0x5F != 0x22
                                  19:17:38.441 LibTeleinfo::checkLine Err checksum 0x31 != 0x43
                                  19:17:38.444 LibTeleinfo::checkLine Err checksum 0x2D != 0x4C
                                  19:17:38.682 LibTeleinfo::checkLine Err checksum 0x44 != 0x29
                                  19:17:38.686 LibTeleinfo::checkLine Err checksum 0x20 != 0x23
                                  19:17:38.687 LibTeleinfo::checkLine Err checksum 0x5F != 0x24
                                  19:17:38.689 LibTeleinfo::checkLine Err checksum 0x44 != 0x2A
                                  19:17:38.701 LibTeleinfo::checkLine Err checksum 0x3E != 0x3F
                                  19:17:38.934 LibTeleinfo::checkLine Err checksum 0x41 != 0x42
                                  19:17:38.949 RSL: SENSOR = {"TIC":{"EAST":73562683,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625403,"IRMS1":18,"URMS1":231,"PREF":12,"PCOUP":12,"SINSTS":4226,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768310,"EASF06":0,"EASF01":37066000,"CCASN":3496}}
                                  19:17:39.168 LibTeleinfo::checkLine Err checksum 0x37 != 0x26
                                  19:17:39.170 LibTeleinfo::checkLine Err checksum 0x25 != 0x27
                                  19:17:39.421 LibTeleinfo::checkLine Err checksum 0x35 != 0x22
                                  19:17:39.422 LibTeleinfo::checkLine Err checksum 0x48 != 0x4B
                                  19:17:39.427 LibTeleinfo::checkLine Err checksum 0x4F != 0x50
                                  19:17:39.670 LibTeleinfo::checkLine Err checksum 0x5C != 0x43
                                  19:17:39.674 LibTeleinfo::checkLine Err checksum 0x5D != 0x4C
                                  19:17:39.920 LibTeleinfo::checkLine Err checksum 0x3C != 0x23
                                  19:17:39.924 LibTeleinfo::checkLine Err checksum 0x41 != 0x44
                                  19:17:40.176 RSL: SENSOR = {"TIC":{"EAST":73562683,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625403,"IRMS1":18,"URMS1":232,"PREF":12,"PCOUP":12,"SINSTS":4226,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768311,"EASF06":0,"EASF01":37066001,"CCASN":3496}}
                                  19:17:40.241 LibTeleinfo::checkLine Err checksum 0x2F != 0x50
                                  19:17:40.401 LibTeleinfo::checkLine Err checksum 0x22 != 0x24
                                  19:17:40.404 LibTeleinfo::checkLine Err checksum 0x43 != 0x29
                                  19:17:40.405 LibTeleinfo::checkLine Err checksum 0x27 != 0x2A
                                  19:17:40.649 LibTeleinfo::checkLine Err checksum 0x58 != 0x22
                                  19:17:40.656 LibTeleinfo::checkLine Err checksum 0x54 != 0x37
                                  19:17:40.657 LibTeleinfo::checkLine Err checksum 0x41 != 0x42
                                  19:17:40.659 LibTeleinfo::checkLine Err checksum 0x5B != 0x5C
                                  19:17:40.902 LibTeleinfo::checkLine Err checksum 0x57 != 0x5B
                                  19:17:40.904 LibTeleinfo::checkLine Err checksum 0x39 != 0x3C
                                  19:17:40.908 LibTeleinfo::checkLine Err checksum 0x3F != 0x44
                                  19:17:40.912 LibTeleinfo::checkLine Err checksum 0x21 != 0x24
                                  19:17:41.149 LibTeleinfo::checkLine Err checksum 0x49 != 0x32
                                  19:17:41.152 LibTeleinfo::checkLine Err checksum 0x55 != 0x42
                                  19:17:41.409 RSL: SENSOR = {"TIC":{"EAST":73562687,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625403,"IRMS1":18,"URMS1":232,"PREF":12,"PCOUP":12,"SINSTS":4228,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768311,"EASF06":0,"EASF01":37066001,"CCASN":3496}}
                                  19:17:41.474 LibTeleinfo::checkLine Err checksum 0x2C != 0x24
                                  19:17:41.476 LibTeleinfo::checkLine Err checksum 0x23 != 0x26
                                  19:17:41.686 LibTeleinfo::checkLine Err checksum 0x45 != 0x2A
                                  19:17:41.688 LibTeleinfo::checkLine Err checksum 0x5E != 0x22
                                  19:17:41.693 LibTeleinfo::checkLine Err checksum 0x5A != 0x30
                                  19:17:41.939 LibTeleinfo::checkLine Err checksum 0x3A != 0x57
                                  19:17:41.940 LibTeleinfo::checkLine Err checksum 0x3F != 0x43
                                  19:17:41.942 LibTeleinfo::checkLine Err checksum 0x4E != 0x4C
                                  19:17:42.184 LibTeleinfo::checkLine Err checksum 0x41 != 0x44
                                  19:17:42.188 LibTeleinfo::checkLine Err checksum 0x38 != 0x44
                                  19:17:42.436 LibTeleinfo: _recv_idx = 128/128 buffer overflow
                                  19:17:42.439 LibTeleinfo::checkLine Err checksum 0x34 != 0x39
                                  19:17:42.685 LibTeleinfo::checkLine Err checksum 0x21 != 0x24
                                  19:17:42.689 LibTeleinfo::checkLine Err checksum 0x3F != 0x28
                                  19:17:42.691 LibTeleinfo::checkLine Err checksum 0x26 != 0x29
                                  19:17:43.075 LibTeleinfo::checkLine Err checksum 0x2A != 0x30
                                  19:17:43.083 LibTeleinfo::checkLine Err checksum 0x4F != 0x30
                                  19:17:43.086 LibTeleinfo::checkLine Err checksum 0x59 != 0x5C
                                  19:17:43.088 LibTeleinfo::checkLine Err checksum 0x4B != 0x4D
                                  19:17:43.092 LibTeleinfo::checkLine Err checksum 0x57 != 0x5B
                                  19:17:43.104 LibTeleinfo::checkLine Err checksum 0x38 != 0x3C
                                  19:17:43.166 LibTeleinfo::checkLine Err checksum 0x59 != 0x44
                                  19:17:43.418 LibTeleinfo::checkLine Err checksum 0x21 != 0x24
                                  19:17:43.419 LibTeleinfo::checkLine Err checksum 0x42 != 0x44
                                  19:17:43.422 LibTeleinfo::checkLine Err checksum 0x40 != 0x42
                                  19:17:43.675 RSL: SENSOR = {"TIC":{"EAST":73562688,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625404,"IRMS1":18,"URMS1":232,"PREF":12,"PCOUP":12,"SINSTS":4228,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768315,"EASF06":0,"EASF01":37066005,"CCASN":3496}}
                                  19:17:43.736 LibTeleinfo::checkLine Err checksum 0x2C != 0x24
                                  19:17:43.897 LibTeleinfo::checkLine Err checksum 0x22 != 0x25
                                  19:17:43.901 LibTeleinfo::checkLine Err checksum 0x4C != 0x30
                                  19:17:44.153 LibTeleinfo::checkLine Err checksum 0x25 != 0x41
                                  19:17:44.155 LibTeleinfo::checkLine Err checksum 0x59 != 0x5C
                                  19:17:44.157 LibTeleinfo::checkLine Err checksum 0x4E != 0x51
                                  19:17:44.396 LibTeleinfo::checkLine Err checksum 0x4B != 0x4C
                                  19:17:44.399 LibTeleinfo::checkLine Err checksum 0x4C != 0x44
                                  19:17:44.403 LibTeleinfo::checkLine Err checksum 0x21 != 0x24
                                  19:17:44.404 LibTeleinfo::checkLine Err checksum 0x40 != 0x44
                                  19:17:44.646 LibTeleinfo::checkLine Err checksum 0x5C != 0x42
                                  19:17:44.906 RSL: SENSOR = {"TIC":{"EAST":73562690,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625404,"IRMS1":18,"URMS1":232,"PREF":12,"PCOUP":12,"SINSTS":4228,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768317,"EASF06":0,"EASF01":37066007,"CCASN":3496}}
                                  19:17:44.965 LibTeleinfo::checkLine Err checksum 0x33 != 0x36
                                  19:17:44.968 LibTeleinfo::checkLine Err checksum 0x40 != 0x30
                                  19:17:45.184 LibTeleinfo::checkLine Err checksum 0x32 != 0x22
                                  19:17:45.191 LibTeleinfo::checkLine Err checksum 0x4C != 0x4F
                                  19:17:45.434 LibTeleinfo::checkLine Err checksum 0x3F != 0x43
                                  19:17:45.437 LibTeleinfo::checkLine Err checksum 0x5B != 0x4C
                                  19:17:45.795 LibTeleinfo::checkLine Err checksum 0x40 != 0x44
                                  19:17:45.796 LibTeleinfo::checkLine Err checksum 0x5F != 0x23
                                  19:17:45.798 LibTeleinfo::checkLine Err checksum 0x3A != 0x44
                                  19:17:45.938 RSL: SENSOR = {"TIC":{"EAST":73562690,"EASF05":0,"EASF07":0,"EASF10":0,"EASD01":28794373,"ERQ1":4307600,"ERQ2":117434,"ERQ3":787844,"SMAXSN":7504,"CCASN-1":3666,"UMOY1":224,"PRM":2147483647,"ADSC":"031861721681","VTIC":2,"EASF02":36496683,"CCAIN":0,"STGE":"003A4101","RELAIS":0,"NTARF":1,"NJOURF":0,"NJOURF+1":0,"NGTF":"BASE","EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD03":0,"EASD04":0,"ERQ4":4625405,"IRMS1":18,"URMS1":232,"PREF":12,"PCOUP":12,"SINSTS":4228,"SINSTI":0,"LTARF":"BASE","EAIT":6778140,"SMAXIN":0,"CCAIN-1":0,"SMAXSN-1":8661,"SMAXIN-1":0,"EASD02":44768318,"EASF06":0,"EASF01":37066008,"CCASN":3496}}
                                  19:17:46.154 LibTeleinfo::checkLine Err checksum 0x37 != 0x50
                                  19:17:46.156 LibTeleinfo::checkLine Err checksum 0x20 != 0x24
                                  19:17:46.160 LibTeleinfo::checkLine Err checksum 0x48 != 0x30
                                  19:17:46.411 LibTeleinfo::checkLine Err checksum 0x59 != 0x22
                                  19:17:46.419 LibTeleinfo::checkLine Err checksum 0x36 != 0x37
                                  19:17:46.658 LibTeleinfo::checkLine Err checksum 0x57 != 0x5B
                                  19:17:46.664 LibTeleinfo::checkLine Err checksum 0x27 != 0x29
                                  J'espère que les captures vont te permettre d'identifier le problème
                                  • SamquadS Samquad
                                    SamquadS Offline
                                    SamquadS Offline
                                    Samquad
                                    Le format Shield n'existait pas quand j'ai acheté mon premier module téléinfo.
                                    Je n'ai pas pris un shield téléinfo Wemos car j'ai créé ma propre carte sur le standard du modèle pour RPI. et finalement ça m'est utile pour tester facilement avec un RPI et picocom.
                                    Je ne pense pas que mon cablage soit en cause.
                                    Depuis que j'ai reçu le Pitinfo V1.4, j'ai l'impression que les trames sont complètes?
                                    • SamquadS Samquad
                                      SamquadS Offline
                                      SamquadS Offline
                                      Samquad
                                      La trame MQT émise par tasmota téléinfo dépasse la capacité max des messages dans NodeRed qui est limitée par défaut à 1000
                                      On m'a aidé pour augmenter cette valeur dans la configuration de NodeRed:
                                      Editer le fichier settings.js:
                                      sudo nano /home/pi/.node-red/settings.js
                                      augmenter le paramètre:
                                      "debugMaxLength: 2000"
                                      Sauvegarder et relancer NodeRed
                                      La trame affichée en débug s'affiche sous cette forme:
                                      Object:
                                      Topic: "tele/TeleInfo/SENSOR"
                                      Payload: buffer[1454] String
                                      {"TIC":{"EASF03":0,"EASF04":0,"EASF08":0,"EASF09":0,"EASD04":0,"NJOURF":0,"NJOURF+1":0,"EASF02":36496683,"PRM":2147483647,"RELAIS":0,"NTARF":1,"EASF05":0,"SINSTR06020NRL@XRNH221204190514":9991,"PBNTP02\SINSTS":8512,"DATE":"	<NGTF","EASF10":0,"ADSC":"031861721681","SINSTR02042NRL@XRNH221207100410":7417,"EASF01":"037424628HD@RF02026496683","EASD03":0,"SINSTS00620NRL@XRNH220208194823":10315,"SINSTR04202NRL@XRNH221208195016":10387,"EASD01":"029125668FEASD02044446480","SINSTI":534,"SINSTR00800NRL@XRNH221209123344":7944,"SINSTR04220NRL@XRNH221209123344":7944,"SINSTS06002NRL@XRNH220209194457":8468,"SINSTR04200PRL@XRNH221210104936":13237,"EAIT":"004300868\ERQ2","SINSTS02222NRL@XRNH220210104936":13237,"SINSTR02222NRL@XRNH221211000811":8456,"EASF07":0,"CCAIN":"00000CB@HN0H221212083000","IRMS1":"0100URMS1220>PRDF02BPBNTP02\RHNRTR02284","SMAXIN":0,"PREF":12,"ERQ2":117445,"ERQ3":788456,"ERQ1":"004202002HDRP2000017445","SINSTI":0,"SMAXSN-1":11541,"EAIT":6780905,"ERQ4":"0344URMS1","STGE":"003A0101","EASD04":"#EAIT","CCAIN":0,"PCOUP":12,"EASD02":45505640,"SINSTS":7339,"EAST":74658330,"SMAXIN-1":2623,"CCASN":8484,"CCAIN-1":0,"SMAXSN":11918,"CCASN-1":5768,"UMOY1":211,"VTIC":2,"URMS1":210,"ERQ4":4714036,"LTARF":"      BASE      ","EASD01":29152690,"ERQ1":4312022,"EASF01":38161647,"NGTF":"      BASE      ","EASF06":0,"IRMS1":"200<PREF02BPCNTP02\SHNRTR06233"}}
                                      Par contre elle n'est pas reconnue comme Json object donc les champs ne peuvent pas être récupérés avec une fonction de ce type:
                                      var xvalue = {};
                                      xvalue = msg.payload.TIC.SINSTS;
                                      msg.payload = xvalue
                                      return msg;
                                      Le problème semble venir de l'impossibilité d'interpréter les charactères représentés par des  dans plusieurs noms de données comme par exemple:
                                      Ces trames apparaissent dans les log que j'ai fait avec le RPI et picocom donc on ne peut pas remettre en cause le cablage du module sur le RPI
                                      Qu'est ce qu'on peut faire?
                                      • SamquadS Samquad
                                        Object:
                                        var xvalue = {};
                                        return msg;
                                        SamquadS Offline
                                        SamquadS Offline
                                        Samquad
                                        J'ai galéré mais j'ai finalement réussi à créer un flow node Red pour interpréter la trame MQT émise par tasmota téléinfo en mode standard pour envoyer les infos dans Domoticz.
                                        La trame MQT que je reçois n'est pas exploitable json objet: le noeux json indique des erreurs contenues dans la trame.
                                        J'ai été obligé de cleaner la trame MQT string pour supprimer tous les charactères non supportés avec un msg.payload.replace()
                                        Voici le code de mon flow:
                                        [{"id":"34f140f8.a2bfa","type":"tab","label":"TeleInfo","disabled":false,"info":""},{"id":"e777bc5.9f4d44","type":"comment","z":"34f140f8.a2bfa","name":"Instructions de paramétrage pour domoticz dans l'ESP Tasmota-sensor-Teleinfo il faut activer \"SetOption108 1\"","info":"Dans domoticz:\nCréer le matériel téléinfo en USB pour créer automatiquement les capteurs de mesure\n\nModifier le matériel en dummy pour rendre les capteurs virtuels\nRelever l'IDX de chaque capteur virtuel dans domoticz\n\nDans L'ESP Tasmota:\n\nParamétrer tasmota sensor avec telefinfo et vérifier que les données du compteur sont affichées sur la page web de l'ESP\nConfiguration MQTT: Renseigner Topic= TeleInfo\n\ndans le menu Console:\n\nSaisir la commande setOption108 1\n\n_______________________________\npour info:\n0 = Teleinfo telemetry into Energy MQTT JSON (default)\n1 = Teleinfo raw data only\n_______________________________\n\nVérifier la présence de trames qui commencent par:--> MQT: tele/TeleInfo/RESULT = {...\n\nDans Node-Red:\n\nDans chaque bloc fonction \"Décode Trame...\"\"\nRenseignger l'IDX Domoticz de chaque capteur virtuel associé\nAdapter les infos et les seuils au contrat\n\nDans chaque bloc \"tele/TeleInfo\" et \"mqtt/in\"\nAdapter les paramètres au serveur domtoticz\nDéployer le Flow\n\nDans Domoticz:\n\nVérifier dans les log si les messages MQTT sont bien réceptionnés\nVérifier si les capteurs affichent les données\n","x":410,"y":40,"wires":[]},{"id":"4928abc7.9f50b4","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Total","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\nXValue = \"\" + msg.payload.TIC.EASF01 + \";0;0;0;\" + msg.payload.TIC.SINSTS + \";0\";\n\nmsg.payload = {};\nmsg.payload.idx = 69;\nmsg.payload.svalue = XValue;\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":140,"wires":[["566c815d.a5a5d","4e116d.9133ce94"]]},{"id":"566c815d.a5a5d","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":100,"wires":[]},{"id":"4e116d.9133ce94","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":140,"wires":[]},{"id":"a93412bc.bf78d","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":380,"wires":[]},{"id":"ea2010a9.53948","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Charge","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\n//XValue= \"\"+ Math.round((msg.payload.IINST/msg.payload.ISOUSC)*100);\n\nif (msg.payload.TIC.SINSTS>0) {\n    XValue= \"\"+ Math.round((msg.payload.TIC.IRMS1/60)*100);\n}\nelse XValue= \"0\";\n\nmsg.payload = {};\nmsg.payload.idx = 71;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":300,"wires":[["3b94d44c.87a34c","f45557f4.05a298"]]},{"id":"f45557f4.05a298","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":300,"wires":[]},{"id":"3b94d44c.87a34c","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":280,"wires":[]},{"id":"91aaccbd.44a7","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Current","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\n\n//XValue= msg.payload.IINST+\";0;0\";\n\nif (msg.payload.TIC.SINSTS>0) {\n    XValue= msg.payload.TIC.IRMS1+\";0;0\";\n}\nelse XValue= \"0;0;0\";\n\nmsg.payload = {};\nmsg.payload.idx = 99;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":380,"wires":[["72ded3b2.4e5e1c","a93412bc.bf78d"]]},{"id":"72ded3b2.4e5e1c","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":360,"wires":[]},{"id":"aa682529.bceab8","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":460,"wires":[]},{"id":"3906e2c8.df91ce","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Gestion alerte courant","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\nif ((msg.payload.TIC.IRMS1<48 && msg.payload.TIC.SINSTS>0) || msg.payload.TIC.SINSTS<=0) {\n    XValue= \"(1) < 80% de 60A souscrits\";\n}\nelse if (msg.payload.TIC.IRMS1 >= 48 && msg.payload.TIC.IRMS1 < 52 && msg.payload.TIC.SINSTS>0) {\n    XValue= \"(2) >80% et <90% de 60A souscrits\";\n}\nelse XValue= \"(3) >90% de 60A souscrits\";\n\nmsg.payload = {};\nmsg.payload.idx = 73;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":460,"wires":[["899a138.e5c52f","aa682529.bceab8"]]},{"id":"899a138.e5c52f","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":440,"wires":[]},{"id":"d6e1107c.8379","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":540,"wires":[]},{"id":"c7d7f48.21e2a08","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Current en Surplus","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\n\n//XValue= msg.payload.IINST+\";0;0\";\n\nif (msg.payload.TIC.SINSTS===0) {\n    XValue= msg.payload.TIC.IRMS1+\";0;0\";\n}\nelse XValue= \"0;0;0\";\n\nmsg.payload = {};\nmsg.payload.idx = 96;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":540,"wires":[["54692d1e.95f5a4","d6e1107c.8379"]]},{"id":"54692d1e.95f5a4","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":520,"wires":[]},{"id":"d994fe9.eb362","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame KWh","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\nXValue= msg.payload.TIC.SINSTS +\";\"+ msg.payload.TIC.EASF01;\n\nmsg.payload = {};\nmsg.payload.idx = 68;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":220,"wires":[["5743d5d0.f6320c","b2fc7f56.9ab89"]]},{"id":"b2fc7f56.9ab89","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":220,"wires":[]},{"id":"5743d5d0.f6320c","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":200,"wires":[]},{"id":"a80552d8.42856","type":"mqtt in","z":"34f140f8.a2bfa","name":"","topic":"tele/TeleInfo/SENSOR/#","qos":"2","datatype":"utf8","broker":"ead0b0c3.e5e6d","nl":false,"rap":false,"inputs":0,"x":140,"y":100,"wires":[["5367159b1760b8b2"]]},{"id":"5e0c7c675c1407c8","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":450,"y":100,"wires":[]},{"id":"5367159b1760b8b2","type":"function","z":"34f140f8.a2bfa","name":"Cleaning Trame","func":"// Récupération des données MQT\n//Cleaning de la trame pour pouvoir la passer dans le noeud json\nvar xvalue = {};\nxvalue = msg.payload;\nmsg.payload = xvalue.replace(/\b|\u0004|@|\f|\t|\\\\|\\n/g, '')\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":140,"y":180,"wires":[["e1a1acc9fbf67ad3"]]},{"id":"e1a1acc9fbf67ad3","type":"json","z":"34f140f8.a2bfa","name":"","property":"payload","action":"","pretty":false,"x":130,"y":280,"wires":[["5e0c7c675c1407c8","4928abc7.9f50b4","d994fe9.eb362","ea2010a9.53948","91aaccbd.44a7","3906e2c8.df91ce","c7d7f48.21e2a08","c221536d537bfda3","26b7916af05ef065"]]},{"id":"26b7916af05ef065","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Total","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\nXValue = \"\" + msg.payload.TIC.EAIT + \";0;0;0;\" + msg.payload.TIC.SINSTI + \";0\";\n\nmsg.payload = {};\nmsg.payload.idx = 114;\nmsg.payload.svalue = XValue;\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":620,"wires":[["576532848921fb85","1ad502b556f2e870"]]},{"id":"c221536d537bfda3","type":"function","z":"34f140f8.a2bfa","name":"Decode Trame Prod KWh","func":"// Récupération des données\n//Préparation requête pour Domoticz\nvar XValue\nXValue= msg.payload.TIC.SINSTI +\";\"+ msg.payload.TIC.EAIT;\n\nmsg.payload = {};\nmsg.payload.idx = 113;\nmsg.payload.svalue = XValue;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":700,"wires":[["97927f558ccb20a5","a34ae61157ac9378"]]},{"id":"576532848921fb85","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":600,"wires":[]},{"id":"97927f558ccb20a5","type":"debug","z":"34f140f8.a2bfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":680,"wires":[]},{"id":"1ad502b556f2e870","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":620,"wires":[]},{"id":"a34ae61157ac9378","type":"mqtt out","z":"34f140f8.a2bfa","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"9a37d1dd.66c5a","x":1090,"y":700,"wires":[]},{"id":"9a37d1dd.66c5a","type":"mqtt-broker","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"15","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"{\"hwid\":\"19\",\"idx\":56,\"nvalue\":0,\"svalue\":\"959\"}","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"ead0b0c3.e5e6d","type":"mqtt-broker","name":"","broker":"192.168.1.200","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
                                        Conclusion:
                                        Soit le problème vient d'erreur dans les échanges entre le linky et le module téléinfo (voir les log plus haut réalisés avec picocom)
                                        Soit le problème vient du code dans tasmota qui envoi des trames MQT avec des charactères incompatibles avec json object (voir aussi plus haut les trames MQT).
                                        Pour le moment ça fonctionne dans l'état mais il y a un problème quelque part...
                                        Je suis dispo four poursuivre des test si besoin pour faire faire progresser le système👍
                                        A suivre...
                                        • SamquadS Samquad
                                          Conclusion:
                                          A suivre...
                                          @Samquad je suis désolé, pour moi la trame est polluée à la base, je ne sais dire si ça vient du compteur ou non, sachant que nous avons a peut prêt tout essayé coté carte électronique et c'est la 1ere fois que je vois ça non resolvable.
