  3. Blog articles comments
driver1.30.96i2ciic
    @Meng-Qi
    the i2c smbus_ is a know problem
    you just need to intall again lm-sensors package (even if correctly installed) then all shoud go fine. Something obvious I’d like to understand, but it seems to work.
    look below how I resolved it.
    root@pi03:~/github/ArduiPi_SSD1306/examples# make
    g++ -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -Wall  -lssd1306 ssd1306_demo.cpp -o ssd1306_demo
    /usr/local/lib/libssd1306.so: undefined reference to `i2c_smbus_write_i2c_block_data'
    /usr/local/lib/libssd1306.so: undefined reference to `i2c_smbus_write_byte_data'
    /usr/local/lib/libssd1306.so: undefined reference to `i2c_smbus_write_word_data'
    collect2: ld returned 1 exit status
    make: *** [ssd1306_demo] Error 1
    root@pi03:~/github/ArduiPi_SSD1306/examples# dpkg --get-selections | grep i2c
    i2c-tools                                       install
    libi2c-dev                                      install
    root@pi03:~/github/ArduiPi_SSD1306/examples#  dpkg --get-selections | grep lm
    lm-sensors                                      install
    root@pi03:~/github/ArduiPi_SSD1306/examples# apt-get install lm-sensors
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    lm-sensors is already the newest version.
    The following packages were automatically installed and are no longer required:
      libblas3gf liblapack3gf
    Use 'apt-get autoremove' to remove them.
    0 upgraded, 0 newly installed, 0 to remove and 14 not upgraded.
    root@pi03:~/github/ArduiPi_SSD1306/examples# make clean
    rm -rf ssd1306_demo teleinfo-oled
    root@pi03:~/github/ArduiPi_SSD1306/examples# cd ..
    root@pi03:~/github/ArduiPi_SSD1306# make clean
    rm -rf *.o libssd1306.* /usr/local/lib/libssd1306.*
    g++ -Wall -fPIC -fno-rtti -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c Adafruit_SSD1306.cpp
    ./ArduiPi_SSD1306.h:51:21: warning: ‘oled_type_str’ defined but not used [-Wunused-variable]
    g++ -Wall -fPIC -fno-rtti -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c Adafruit_GFX.cpp
    gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c bcm2835.c
    g++ -shared -Wl,-soname,libssd1306.so.1 -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s  -o libssd1306.so.1.0 Adafruit_SSD1306.o Adafruit_GFX.o bcm2835.o
    [Install Library]
    [Install Headers]
    root@pi03:~/github/ArduiPi_SSD1306# cd examples/
    g++ -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -Wall  -lssd1306 teleinfo-oled.cpp -o teleinfo-oled
    For the i2cbus detection, nothing to do with my lib, i2cdetect is a tool distribued with your linux distro.
    So to be sure I've just gone on my PI V2 to test
    root@pi01(rw):~/ArduiPi_OLED/examples# i2cdetect -y 1
         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
    00:          -- -- -- -- -- -- -- -- -- -- -- -- --
    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- --
    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    70: -- -- -- -- -- -- -- --
    root@pi01(rw):~/ArduiPi_OLED/examples# ./oled_demo -o 3
    x: 9y: 0dy: 3
    x: 30y: 0dy: 2
    x: 111y: 0dy: 2
    x: 81y: 0dy: 4
    x: 41y: 0dy: 2
    x: 85y: 0dy: 5
    So @Mr_Tom yes it works on Pi V2 (at least in I2C mode) but should be the same for SPI; look below
    • Meng QiM Offline
      Meng QiM Offline
      Meng Qi
      I've got the lm-sensors module in there, and the make on examples worked.
      But only still I can't get my Pi to recognize my oled screen, and I have another device on the i2c bus which works perfectly.
      I just ordered another oled (a seeed 96*96) to see if that would work.
      Thank you for your detailed reply!
        Meng,
        Even if Seeed OLED will be seen, it won't work because it"s another driver in it (SSD1308) and I didn't port this one in the example code, something I wanted to do but never had time do do it.
        By the way Seeed OLED 96x96 is the best OLED I ever saw, excellent display and gray level.
          Meng
          did you tried your non working OLED on an Arduino with I2CScan sketch just to see ?
          • Meng QiM Offline
            Meng QiM Offline
            Meng Qi
            Hi, Charles,
            I've tested my oled with I2CScan, and it wasn't detected... maybe a broken one. And I have another oled screen here which can be detected on Arduino, but not on Pi.
            Here is a library by Seeed themselves : https://github.com/DexterInd/GrovePi/tree/master/Software/Python/grove_oled
            I'll see if that would work once the oled screen arrives. Happy to know that it looks amazing.
              Meng,
              yeah Seeed library works fine on Arduino, but not sure there is a port on Raspberry Pi
              • Meng QiM Offline
                Meng QiM Offline
                Meng Qi
                wrote on last edited by Meng Qi
                This 96*96 oled screen is detected by my Pi and it is working with Seeed's own library, and it would also put out stuff while running your oled_demo.
                Does your library has a manual? It doesn't looks like python when I peek into your library files... Sorry I am quite a beginner. Thank you.
                I use my Pi to generate sound, and if I do oled operations within the same piece of .py file that does sound, any oled writing operations would block the sound. But if I open 2 terminal instances (I am using SSH), and run sound code on one, oled code on another, it wouldn't block the sound. So it is certainly not a CPU speed issue...
                Why does this happen? And if I make my Pi running some python code at boot, how I can make the codes running like within multiple terminals?
                Thank you!
                  gbona
                  I also try to run it on RPi2 with an SPI OLED 128x64 and ran into the same problem. The program freezes in display.begin(). What can be wrong?
                    Hi gbona,
                    Did you checked that your I2C oled is visible with i2cdetect ? If so does his I2C address is 0x3C ?
                      boik
                      Hi Charles. I am trying to use your library to drive a 128x64 SPI OLED display I got from the internet. It is advertised as being SSD1106 (which I assume means SH1106). I have hacked the CS detect line of your code to force it to use SPI instead of the default I2C (this display has no CS pin). I am getting something on the display, but quite garbled.
                      Here is a video of it running your OLED_demo.
                      Are these symptoms familiar to you. Any ideas of what might need tweaking.
                      Many thanks
                      Graham
                        @boik,
                        Strange, first time I see SPI oled without CS line, would you mind post a picture of the back ?
                        You're right I forgot to add SPI option for SH1106 in oled_demo.
                          boik
                          Hi Charles,
                          [IMG]http://i68.tinypic.com/6zwsjl.jpg[/IMG]
                          Heres a pic of it running the circle, square, triangle cross demo. Just displays the bottom 8 lines of the image but at the top of the OLED.
                          [IMG]http://i64.tinypic.com/2mhbn7k.jpg[/IMG]
                          Not sure if this forum accepts IMG tags?
                          Graham
                            Deennoo
                            Hello Charles
                            I got a freebox server out of ordre.
                            There is a ssd1327 screen on it.
                            If i send you the pcb pictures can you help me to find the good pin to plug it to my PI ?
                              @Deennoo
                              you can post the picture on the forum, may be some other will know, because I'm not sure I will.
                              • D Deennoo
                                Hello Charles
                                Matthieu Laborie
                                @Deennoo
                                Hi, did you succeed getting the freebox server Oled Display work with a raspberry or Arduino? Did you find any wiring schema, or source code. I would like to reuse the whole SSD1327 and CAP1066 pad of the freebox.
                                Regards
                                  akdracom
                                  I followed your procedures and up to the part of :
                                  git clone https://github.com/hallard/ArduiPi_OLED
                                  and received the following error message and can't go further :
                                  fatal: could not create work tree dir 'ArduiPi_OLED'.: No space left on device
                                  I am using a 8GB SD card and I think I have enough space - don't I ?
                                  I then issued df -Bm command to check space with following :
                                  Filesystem 1M-blocks Used Available Use% Mounted on
                                  /dev/root 4196M 4087M 0M 100% /
                                  devtmpfs 483M 0M 483M 0% /dev
                                  tmpfs 487M 0M 487M 0% /dev/shm
                                  tmpfs 487M 7M 481M 2% /run
                                  tmpfs 5M 1M 5M 1% /run/lock
                                  tmpfs 487M 0M 487M 0% /sys/fs/cgroup
                                  /dev/mmcblk0p6 63M 20M 44M 31% /boot
                                  tmpfs 98M 0M 98M 0% /run/user/1000
                                  Am I running out of memory or what, please advise - thanks
                                    akdracom
                                    I forget to mention that in my SD card - I also have installed a media player OS (OpenElec) in addition to the Raspian OS
                                      @akdracom
                                      your're missing space on SD card 100% on /dev/root, you're SD seems to be formatted to 4GB
                                      May be trying raspiconfig and select the menu to expand filesystem to use full SD Size (8GB) will help
                                        donde
                                        Screen Never Lights
                                        New to OLED. Waiting for SSH1306 1.3" display like on Adafruit website. Sent for SH1106 display instead. Pinouts are left to right: VDD VSS SCK SDA D/C CS1 FS0 CS2
                                        Using Pi Zero. Went through tutorial OK I think. 2 problems:
                                        root@raspberrypi:~# ls /dev/i2c*
                                        /dev/i2c-0
                                        root@raspberrypi:~# ls /dev/spi*
                                        /dev/spidev0.0 /dev/spidev0.1
                                        The first check returned /dev/i2c-1 instead of /dev/i2c-0
                                        The second response was OK.
                                        Now I wasn't at root when I did commands, but at user.
                                        Other problem I had to supply sudo for
                                        ./oled_demo --verbose --oled 6
                                        I received this:
                                        pi@raspberrypi:~/ArduiPi_OLED/examples $ ./oled_demo --verbose --oled 6
                                        oled_demo v1.1
                                        -- OLED params --
                                        Oled is : SH1106 I2C 128x64
                                        -- Other Stuff --
                                        verbose is : yes
                                        bcm2835_init: Unable to open /dev/mem: Permission denied
                                        pi@raspberrypi:~/ArduiPi_OLED/examples $ sudo ./oled_demo --verbose --oled 6
                                        oled_demo v1.1
                                        -- OLED params --
                                        -- Other Stuff --
                                        verbose is : yes
                                        x: 9y: 0dy: 3
                                        x: 30y: 0dy: 2
                                        x: 111y: 0dy: 2
                                        x: 81y: 0dy: 4
                                        x: 41y: 0dy: 2
                                        x: 85y: 0dy: 5
                                        x: 7y: 0dy: 5
                                        x: 76y: 0dy: 2
                                        x: 72y: 0dy: 3
                                        x: 76y: 0dy: 4
                                        Nothing on screen!
                                        I wired it this way from Pi Zero
                                        Pi 5 volts to Vdd
                                        Pi GND to Display VSS
                                        Pi SCL to Display SCK
                                        Pi SDA to Display SDA
                                        IO25 to Display FSO
                                        No ID on Display, just this description:
                                        Features
                                        Self-luminous display for backlight
                                        High resolution: 128 x 64
                                        Viewing angle: >160 degree
                                        Supports many control chip: Fully compatible with Arduino, 51 Series, MSP430 Series, STM32 / 2, CSR IC, etc.
                                        Ultra-low power consumption: full screen lit 0.08W
                                        Voltage: 3V ~ 5V DC
                                        Working Temperature: -30 oC ~ 70 oC
                                        Module Size: 32.0mm x 35.50mm x 4.1mm
                                        SPI Interface, need 4 IO only.
                                        Driver IC: SH1106
                                        Package Includes
                                        1 x 1.3" SPI Serial 128X64 OLED LCD LED Display Module for Arduino UNO R3
                                        Not sure what try next. What turns on screen to see at least something?
                                        Thanks ... donde
                                          donde
                                          I looked closer at box the display came and it said it is for SPI mode. I tried i2C and didn't light up. Then, tried SPI and still no success. Doesn't seem to be a RST pin. I see no pictures of the same pin arrangement on the Net. Looks to be a special display no one knows about. Guess I'll return it and hopefully the SSH1306 will be available soon, Sorry to take up so much room here is this comments section. Moderator, you can delete all I said on first post. donde
