  3. Blog articles comments
driver1.30.96i2ciic
    Mr_Tom
    I meant I ignored your OLED pinout. Pins 1-8 on the OLED.
    Example; OLED pin 4, my OLED has CS written on it, but you're calling it DATA.
    My OLED pin 8 has DATA written next to it. You're calling it CS.
    Adafruit says DATA should go to RPi pin 19, which is what you say DATA should go to. But you're calling DATA on the OLED as pin 4.
    What is the REAL/CORRECT wiring for the RPi2?
      Mr_Tom
      https://learn.adafruit.com/ssd1306-oled-displays-with-raspberry-pi-and-beaglebone-black/wiring
        Tom,
        The link you provided (ie this one https://learn.adafruit.com/ssd1306-oled-displays-with-raspberry-pi-and-beaglebone-black/wiring) refers to pin name printed on PCB, mine the pin that I call Pi P1 Header Pin is the pin number of the connector P1, not the number printed on the PCB (which is the GPIO name) take a look on the connector
        As You see Adafruit and mine are most of time the same (I refer to the P1 connector pin numbers in the circle in the previous image link).
        The only change For SPI, is that Adafruit connected RST to GPIO24 (P1 pin 18) and DC to GPIO23 (P1 pin 16) and mine is RST to GPIO25 (P1 pin 22) and DC to GPIO24 (P1 pin 18) so you just need to change these 2 ones in your wiring
        • RST to GPIO25 (P1 pin 22)
        • D/C GPIO24 (P1 pin 18)
        And this should be working fine
        PS : you can also keep Adafruit connection and change these 2 lines in the code
        #define OLED_SPI_RESET RPI_V2_GPIO_P1_22 /* GPIO 25 pin 22  */
        #define OLED_SPI_DC    RPI_V2_GPIO_P1_18 /* GPIO 24 pin 18  */
        by
        #define OLED_SPI_RESET RPI_V2_GPIO_P1_18 /* GPIO 24 pin 18  */
        #define OLED_SPI_DC    RPI_V2_GPIO_P1_16 /* GPIO 23 pin 16  */
        in the file ArduiPi_SSD1306.h
          Mr_Tom
          Ok. I changed the Raspberry Pi wiring back to Adafruit. I can run Adafruit's Python examples okay. I changed those 2 lines in 'ArduiPi_OLED_lib.h'. I 'sudo make' the library files, and 'sudo make' the example. When I run 'sudo ./oled_demo -o 1' nothing happens.
          I put some 'printf' commands in the example for debugging, and it seems to lock up after it calls 'display.begin()'.
          I can't find where the function display.begin() is so I can diagnose/debug it further.
            Mr_Tom
            I downloaded the older ArduiPi_SSD1306 and tried that, but same thing. Freezes after it runs 'display.begin()'. I changed the RESET and DC in the .h file as you mentioned. I don't understand why I can't access the display in C++, but Python works perfectly. I'm using a Raspberry Pi 2 if that makes a difference, and an SSD1306 1.3" 128x64 purchased from Adafruit.
              Mr_Tom
              Update: I setup my OLED in I2C mode and changed the address to 3D, and it worked. But I would still rather use SPI mode.
                That's an interesting point, I did not tried on a PI V2, I have one at home, I need to test just in case, because the driver relies on old BCM2835 library that may be I need to update for PI V2, worth checking.
                Good to know it works with I2C but I understand you prefer SPI, for sure it's so much faster.
                  Mr_Tom
                  Hi, Charles. Any progress with testing the library on a PI v2? Is the BCM2836 extremely different than the BCM2835?
                  • Meng QiM Offline
                    Meng QiM Offline
                    Meng Qi
                    wrote on last edited by Meng Qi
                    Thank you for the detailed blog post. I followed your instructions and got 2 problems :
                    1. there is no libi2c available, the only thing similar I've found is libi2c-dev so I installed that;
                    2. I got error messages while trying to "sudo make" within the example folder, here is a photo showing the result.
                      http://i.imgur.com/MkWvXbC.jpg
                    Btw I am on a Pi B V2. One strange thing is that when I ran "sudo i2cdetect -y 1" there is nothing on the table. But while I tried to use Adafruit_SSD1306 library, the oled would respond (weirdly).
                    Thanks
                      @Meng-Qi
                      the i2c smbus_ is a know problem
                      you just need to intall again lm-sensors package (even if correctly installed) then all shoud go fine. Something obvious I’d like to understand, but it seems to work.
                      look below how I resolved it.
                      root@pi03:~/github/ArduiPi_SSD1306/examples# make
                      g++ -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -Wall  -lssd1306 ssd1306_demo.cpp -o ssd1306_demo
                      /usr/local/lib/libssd1306.so: undefined reference to `i2c_smbus_write_i2c_block_data'
                      /usr/local/lib/libssd1306.so: undefined reference to `i2c_smbus_write_byte_data'
                      /usr/local/lib/libssd1306.so: undefined reference to `i2c_smbus_write_word_data'
                      collect2: ld returned 1 exit status
                      make: *** [ssd1306_demo] Error 1
                      root@pi03:~/github/ArduiPi_SSD1306/examples# dpkg --get-selections | grep i2c
                      i2c-tools                                       install
                      libi2c-dev                                      install
                      root@pi03:~/github/ArduiPi_SSD1306/examples#  dpkg --get-selections | grep lm
                      lm-sensors                                      install
                      root@pi03:~/github/ArduiPi_SSD1306/examples# apt-get install lm-sensors
                      Reading package lists... Done
                      Building dependency tree
                      Reading state information... Done
                      lm-sensors is already the newest version.
                      The following packages were automatically installed and are no longer required:
                        libblas3gf liblapack3gf
                      Use 'apt-get autoremove' to remove them.
                      0 upgraded, 0 newly installed, 0 to remove and 14 not upgraded.
                      root@pi03:~/github/ArduiPi_SSD1306/examples# make clean
                      rm -rf ssd1306_demo teleinfo-oled
                      root@pi03:~/github/ArduiPi_SSD1306/examples# cd ..
                      root@pi03:~/github/ArduiPi_SSD1306# make clean
                      rm -rf *.o libssd1306.* /usr/local/lib/libssd1306.*
                      g++ -Wall -fPIC -fno-rtti -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c Adafruit_SSD1306.cpp
                      ./ArduiPi_SSD1306.h:51:21: warning: ‘oled_type_str’ defined but not used [-Wunused-variable]
                      g++ -Wall -fPIC -fno-rtti -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c Adafruit_GFX.cpp
                      gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c bcm2835.c
                      g++ -shared -Wl,-soname,libssd1306.so.1 -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s  -o libssd1306.so.1.0 Adafruit_SSD1306.o Adafruit_GFX.o bcm2835.o
                      [Install Library]
                      [Install Headers]
                      root@pi03:~/github/ArduiPi_SSD1306# cd examples/
                      g++ -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -Wall  -lssd1306 teleinfo-oled.cpp -o teleinfo-oled
                      For the i2cbus detection, nothing to do with my lib, i2cdetect is a tool distribued with your linux distro.
                      So to be sure I've just gone on my PI V2 to test
                      root@pi01(rw):~/ArduiPi_OLED/examples# i2cdetect -y 1
                           0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
                      00:          -- -- -- -- -- -- -- -- -- -- -- -- --
                      10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                      20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                      30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- --
                      40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                      50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                      60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                      70: -- -- -- -- -- -- -- --
                      root@pi01(rw):~/ArduiPi_OLED/examples# ./oled_demo -o 3
                      x: 9y: 0dy: 3
                      x: 30y: 0dy: 2
                      x: 111y: 0dy: 2
                      x: 81y: 0dy: 4
                      x: 41y: 0dy: 2
                      x: 85y: 0dy: 5
                      So @Mr_Tom yes it works on Pi V2 (at least in I2C mode) but should be the same for SPI; look below
                      • Meng QiM Offline
                        Meng QiM Offline
                        Meng Qi
                        I've got the lm-sensors module in there, and the make on examples worked.
                        But only still I can't get my Pi to recognize my oled screen, and I have another device on the i2c bus which works perfectly.
                        I just ordered another oled (a seeed 96*96) to see if that would work.
                        Thank you for your detailed reply!
                          Meng,
                          Even if Seeed OLED will be seen, it won't work because it"s another driver in it (SSD1308) and I didn't port this one in the example code, something I wanted to do but never had time do do it.
                          By the way Seeed OLED 96x96 is the best OLED I ever saw, excellent display and gray level.
                            Meng
                            did you tried your non working OLED on an Arduino with I2CScan sketch just to see ?
                            • Meng QiM Offline
                              Meng QiM Offline
                              Meng Qi
                              Hi, Charles,
                              I've tested my oled with I2CScan, and it wasn't detected... maybe a broken one. And I have another oled screen here which can be detected on Arduino, but not on Pi.
                              Here is a library by Seeed themselves : https://github.com/DexterInd/GrovePi/tree/master/Software/Python/grove_oled
                              I'll see if that would work once the oled screen arrives. Happy to know that it looks amazing.
                                Meng,
                                yeah Seeed library works fine on Arduino, but not sure there is a port on Raspberry Pi
                                • Meng QiM Offline
                                  Meng QiM Offline
                                  Meng Qi
                                  This 96*96 oled screen is detected by my Pi and it is working with Seeed's own library, and it would also put out stuff while running your oled_demo.
                                  Does your library has a manual? It doesn't looks like python when I peek into your library files... Sorry I am quite a beginner. Thank you.
                                  I use my Pi to generate sound, and if I do oled operations within the same piece of .py file that does sound, any oled writing operations would block the sound. But if I open 2 terminal instances (I am using SSH), and run sound code on one, oled code on another, it wouldn't block the sound. So it is certainly not a CPU speed issue...
                                  Why does this happen? And if I make my Pi running some python code at boot, how I can make the codes running like within multiple terminals?
                                  Thank you!
                                    gbona
                                    I also try to run it on RPi2 with an SPI OLED 128x64 and ran into the same problem. The program freezes in display.begin(). What can be wrong?
                                      Hi gbona,
                                      Did you checked that your I2C oled is visible with i2cdetect ? If so does his I2C address is 0x3C ?
                                        boik
                                        Hi Charles. I am trying to use your library to drive a 128x64 SPI OLED display I got from the internet. It is advertised as being SSD1106 (which I assume means SH1106). I have hacked the CS detect line of your code to force it to use SPI instead of the default I2C (this display has no CS pin). I am getting something on the display, but quite garbled.
                                        Here is a video of it running your OLED_demo.
                                        Are these symptoms familiar to you. Any ideas of what might need tweaking.
                                        Many thanks
                                        Graham
                                          @boik,
                                          Strange, first time I see SPI oled without CS line, would you mind post a picture of the back ?
                                          You're right I forgot to add SPI option for SH1106 in oled_demo.
