  • rgrunblaR rgrunbla
    Merci ! Ça fonctionne globalement, mais… J'ai encore un petit problème: j'ai parfois des caractères non-ascii / utf8 dans la sortie, par exemple:
    {"Time":"2020-08-23T12:05:47","ENERGY":{"TotalStartTime":"2020-08-22T13:20:46","Total":2.594,"Yesterday":2.106,"Today":0.488,"Period":0,"Power":240,"Current":1.000,"Load":2,"ADCO":"811775074547","ISOUSC":45,"HHPHC":"A","IMAX":90,"BASE":7822520,"PTEC":"TH..","IINST":1,"PAPP":240,"MOTDETAT":0,"OPTARIF":"BASE","TEC":"TH.."}}
    se termine en fait par:
     'OPTARIF":"BASE","\x10TEC":"TH.."}}'
    Ça ne semble pas arriver tout le temps, je peux probablement traiter le \x10 à la sortie de MQTT mais c'est peut être le syndrome d'un autre problème.
    Rémy
    rgrunblaR Offline
    rgrunblaR Offline
    rgrunbla
    wrote on last edited by rgrunbla
    #74
    En fait, il semblerait qu'il y ait des corruptions dans la sortie TIC, qui se traduisent par des corruptions dans les messages MQTT:
    12:10:39 CFG: Saved to flash at FB, Count 58, Bytes 4096
    12:10:39 MQT: tele/tasmota_19FDA8/STATE = {"Time":"2020-08-23T12:10:39","Uptime":"0T00:00:11","UptimeSec":11,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Wifi":{"AP":1,"SSId":"Livebox-FE98","BSSId":"70:FC:8F:49:25:7F","Channel":6,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:05"}}
    12:10:39 MQT: tele/tasmota_19FDA8/SENSOR = {"Time":"2020-08-23T12:10:39","ENERGY":{"TotalStartTime":"2020-08-22T13:20:46","Total":2.611,"Yesterday":2.106,"Today":0.505,"Period":1,"Power":230,"Current":1.000,"Load":2,"ADCO":"811775074547","OPTARIF":"BASE","ISOUSC":45,"BASE":7822537,"PTEC":"TH..","IINST":1,"HHPHC":"A","MOTDETAT":0,"IMAX":90,"PAPP":230}}
    12:10:42 TIC: [26]# rj^5jxGW^FwVASE=007822537
    12:10:49 MQT: tele/tasmota_19FDA8/STATE = {"Time":"2020-08-23T12:10:49","Uptime":"0T00:00:21","UptimeSec":21,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Wifi":{"AP":1,"SSId":"Livebox-FE98","BSSId":"70:FC:8F:49:25:7F","Channel":6,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:05"}}
    12:10:49 MQT: tele/tasmota_19FDA8/SENSOR = {"Time":"2020-08-23T12:10:49","ENERGY":{"TotalStartTime":"2020-08-22T13:20:46","Total":2.611,"Yesterday":2.106,"Today":0.505,"Period":0,"Power":230,"Current":1.000,"Load":2,"ADCO":"811775074547","OPTARIF":"BASE","ISOUSC":45,"BASE":7822537,"PTEC":"TH..","IINST":1,"HHPHC":"A","MOTDETAT":0,"IMAX":90,"PAPP":230,"rj^5jxGW^FwVASE":7822537}}
    Est-ce ma faute, est-ce que quelqu'un a déjà vu ça?
    Une fois que la sortie TIC s'est plantée, on dirait que les données restent dans les messages MQTT suivants (même si la sortie TIC semble être "rétablie").
    Rémy
      @Seb-H
      Cool, le package prêt à compiler est déjà mergé dans la branche development de l'officiel tasmota 🙂
      SebHS Offline
      SebHS Offline
      SebH
      Désolé pour le retard, je rentre de déplacement et j'ai enfin 5 minutes. Donc j'ai tester la dernière version en mode standard. Donc, le système ne voit rien du tout (aucune remonté de l'intensité et de la puissance apparente et des index ) et pourtant les données arrivent bien (j'ai pu refaire un log des données qui arrive sur la pin Rx)...
      • SebHS Offline
        SebHS Offline
        SebH
        Par rapport à mon précédent post, je reformule une question déjà posé et qui est resté sans réponse à ce jour. Pourra t on définir une autre pin que celle imposé pour la réception des données ?
          @Seb-H
          Si c'est un ESP8266, non c'est soit GPIO3 soit GPIO13 (de mémoire), c'est les seules pins possibles pour la hardware Serial, sur un ESP32 tu dois normalement avec le template pouvoir changer de pin à ta guise.
          SebHS 1 Reply Last reply
            Rémy
            @rgrunbla ça me rapelle de vieux souvenirs, oui une fois une mauvaise etiquette détectée elle reste jusqu'au reset mais normalement la checksum est controlée avant stockage donc c'est une corruption de mémoire.
            ton tasmota fait beaucoup de chose en même temps ?
              @Seb-H
              SebHS Offline
              SebHS Offline
              SebH
              @Charles Ok, donc chez moi en mode standard, mon tasmota ne voit rien du tout ! Quelqu'un à déjà tester sur un linky en standard ?? Y a t il une opération à faire de particulière dans la fenêtre de log ??
              • Nicolas DeraedtN Nicolas Deraedt
                @Patrice said in Ré-écriture de Wifinfo pour traiter le mode standard du Linky:
                Je suis avec grand intérêt ce post.
                Est il possible d'ajouter la prise en charge des implusions du compteur gaz (Gazpar) qui est situé juste à côté du compteur electrique ?
                je me posais la meme question ?
                tu en penses quoi charles ?
                flouckF Offline
                flouckF Offline
                flouck
                @Nicolas-Deraedt
                Hello 🙂 Des nouvelles ? Ça serait top !
                • P Patrice
                  flouckF Offline
                  flouckF Offline
                  flouck
                  @Patrice Hello, tu as pu avancer dans ta recherche ?
                  • SamquadS Offline
                    SamquadS Offline
                    Samquad
                    Bonjour, j'ai acheté un module PiTinfo pour interfacer mon compteur linky avec Domoticz. J'ai déjà essayé avec espeasy mais j'avais trop d'erreurs de communication. Je viens de découvrir ce billet intéressant car tasmota peut envoyer des données domoticz via mqtt.
                    Pour le moment j'ai flashé mon esp avec tasmota sensor compilé pour activer teleinfo (wifinfo).
                    J'ai bien les données du compteur qui s'affichent sur la page web de mon esp. Je ne sais pas comment finaliser le paramétrage pour renvoyer les données à domoticz via MQTT. Mes capteurs virtuels n'attendent plus que vos conseils pour être fonctionnels... Merci
                    Nicolas DeraedtN 1 Reply Last reply
                    • SamquadS Samquad
                      Nicolas DeraedtN Offline
                      Nicolas Deraedt
                      @Samquad said in Ré-écriture de Wifinfo pour traiter le mode standard du Linky:
                      essaye dans la console setoption19 1
                      • doddyfabD Offline
                        doddyfabD Offline
                        doddyfab
                        J'ai commandé et reçu mon PiTinfo.
                        Je souhaite le faire marcher avec un wemos D1 mini pro et Tasmota.
                        Je suis en linky TIC Standard.
                        J'ai réussi à flasher le wemos avec Tasmota et activer le module téléinfo via les modules Energy.
                        J'ai bien mis au flash :
                        #define USE_TELEINFO_STANDARD
                        et j'ai bien lancer dans la console
                        SetOption102 1 //active teleinfo
                        Sur la page d'accueil, mes valeurs restent à zéro.
                        Mon cablage est Wemos / Module :
                        RX - TX
                        5V - VCC
                        GND - GND
                        J'ai l'impression que je ne suis pas loin mais quelque chose bloque.
                        Savez vous si c'est un problème de cablage ou de paramétrage de RX (GPIO3) ?
                        Merci pour votre aide
                        Fabien
                          Bonjour et félicitations tu y es presque mais d'abord ton WeMos est en 3.3V donc sur le PiTinfo VCC doit être 3V3 pas 5V ce qui peut ruiner ton entrée RX
                          Le 2eme point c'est que le mode standard du linky n'est pas traité dans tasmota (ou a minima) mais comme j'ai pas de linky, impossible de tester chez moi.
                          doddyfabD 1 Reply Last reply
                            doddyfabD Offline
                            doddyfabD Offline
                            doddyfab
                            @Charles merci je vais corriger l’alim. J’ai eu un doute et vu que le wemos propose les 2 en sortie j’ai hésité.
                            Merci pour le retour je vais voir si j’arrive à quelque chose, sinon je passerais par une méthode differente.
                            Est-ce que le wifiInfo gere le linky standard ?
                            Merci et encore bravo pour tout ce que vous faites.
                            Bonne journée.
                            Fabien
                            Seb HS 1 Reply Last reply
                            • doddyfabD doddyfab
                              Bonne journée.
                              Fabien
                              Seb HS Offline
                              Seb HS Offline
                              Seb H
                              wrote on last edited by Seb H
                              #87
                              @doddyfab
                              Si tu remontes le fil du post, je l'ai signalé plusieurs fois . J'ai un linky en mode standard avec la dernière version de Tasmota, le mode standard ne fonctionne pas ! La communication arrive bien sur la pin d'entrée du wemos mais aucune remonté des infos par le soft. J'avais proposé pour être le beta testeur, mais pas de nouvelle version depuis . On sera deux maintenant !
                              • Seb HS Seb H
                                @doddyfab
                                doddyfabD Offline
                                doddyfabD Offline
                                doddyfab
                                @Seb-H merci pour ta reponse, il me semblait que ca ne marchait pas mais je n’etais pas sur.
                                As tu trouvé un autre moyen en attendant pour faire remonter la teleinfo en mode standard ?
                                Merci !
                                  Merci !
                                  Seb HS Offline
                                  Seb HS Offline
                                  Seb H
                                  @doddyfab Oui j'ai depuis 10 mois une version de wifinfo que j'ai trouvé sur le web qui fonctionne bien. Il suffit d'activer une option pour activer le mode standard. Le seul defaut que je lui trouve, c'est après une perte secteur, il se peut qu'il à du mal à se connecter au wifi, il ne se plante et ne se réinitialise pas tout seul...
                                  • Seb HS Seb H
                                    doddyfabD Offline
                                    doddyfabD Offline
                                    doddyfab
                                    @Seb-H si tu as un lien de l’image je suis preneur.
                                    Merci pour ton retour
                                      J Offline
                                      JG
                                      attention à l'entrée série sur les cartes WEMOS D1 mini : Suivant les versions, si on se sert des pins RX et TX, il faut couper la piste qui relie la pin 2 du convertisseur USB/Série CH340C au Rx. En effet ce composant impose un niveau haut sur la pin 2 (TxD ) s'il n'y a rien sur l'entrée USB.
                                      Il faut bien sûr reconnecter la liaison pour flasher en USB. Personnellement, je flashe en usb, je coupe la piste, et je fais les flashs suivant en OTA.
                                      C'est le seul défaut de cette carte, et pas sur toutes les versions : il faut vérifier sur le schéma électrique de la carte.
                                      Pierre
                                      • PapyMoP Offline
                                        PapyMoP Offline
                                        PapyMo
                                        Quelqu'un à des informations concernant l'étiquette ISOUSP du LINKY en mode historique ? Ci-dessous une capture partielle d'une page Wifinfo :
                                        Maurice
                                          J Offline
                                          JG
                                          d'après la doc, le libellé exact de l'étiquette semble être "ISOUSC" et ses données ne comportent que 2 caractères , en Ampères, avec la formule suivante : PREF(en VA)/200V.
                                          Si le libellé est faux, c'est probablement une erreur de synchro en réception des infos du compteur.
