    ULPNode RF Protocol
    radioprotocolulpnode
    3 Posts 3 Posters 2.5k Views 1 Watching
      ULPNode RF Radio protocol was intended first time to be part of ULPNode library, but as soon as I tried to compile gateway code for other target as ESP8266/Particle/PI and others, some targets env compile all source folder file and as ULPNode library is intended for ATMega328 this was generating errors unless I start playing with #define everywhere.,… Continue Reading
        very smart. it looks promising, I like the way protocol will be managed:)
        • K Offline
          k.j.ongersma
          Charles,
          I ran into th website souliss it seems to be a Arduino library with protocol definitions and interactions between nodes via various radio's. There an API and APP to control. Looks a good solution to integrate te ULP-Node into the world of things. No Central site.
          No Gateway if you want to. All operational (even for ESP unfortunately no SPARK.
          Greeting Koen.
          5.1k
          • EthTinfo/ESPHome/Tasmota GPIO36 non fonctionnel
          • Branchement et configuration Winky
