  4. PiTInfo
  5. Pi 0 W : trames reçues bizarres
4 Posts 2 Posters 1.1k Views 3 Watching
  • carmelo42C Offline
    carmelo42C Offline
    carmelo42
    Je teste mon module PiTInfo sur un Pi 0 W fraichement installé (donc en buster)
    Voici ce que j'obtiens comme trames avec picocom :
    pi@raspberrypi:~ $ picocom -b 1200 -d 7 -p e -f n /dev/ttyS0
    picocom v3.1
    port is        : /dev/ttyS0
    flowcontrol    : none
    baudrate is    : 1200
    parity is      : even
    databits are   : 7
    stopbits are   : 1
    escape is      : C-a
    local echo is  : no
    noinit is      : no
    noreset is     : no
    hangup is      : no
    nolock is      : no
    send_cmd is    : sz -vv
    receive_cmd is : rz -vv -E
    imap is        :
    omap is        :
    logfile is     : none
    initstring     : none
    exit_after is  : not set
    exit is        : no
    !! Settings mismatch !! Type [C-a] [C-v] to see actual port settings
    z GDD}@ N
             -f&C{ Fb{ FB{0FF0F FF fFfffffFf"&%bk $jb2fJJJJJJJJJJGfb%F&$j$F}$F} nk(&(T(T(T(TbFH4pD0}D}aG*HN
        *FG}0fC{pFb{ FB{0FF0F FF fFffffffFf"&%bk $jb*fJJJJJJJJJJGfb%FGF&"F& F},f#F{(DF",pbBb" DD|DE|D0|J }
                           d4*FG}0fG0fC{ Fb{ FB{nFF0F FF fFfffffff"&%bk $jb*fJJJJJJJJJJGfC|f"$E"$j$F| jR,p<pbFb xbbbD
        DD|D(~F8~D`fQ f0fG0fC{ Fb{ FB{0FF0F FF fFfffffFf"&%bk $jb*fJJJJJJJJ
        JFfcB}f""FjD"F&$Fb,p@b"bb"yBD
                            BD(D~P&`f f0fG0fC{ Fb{ FB{0FF0F FF fFffffffFf"%bk $jb*fJJJ
        Jp
        JpJDfc""bT|$BD"F&$F}(DbbBb"b"""Kr${
        D(`f f0fG0fC{ Fb{ FB{nFF0F FF fFfffffff"&%bk $j*G
        JpJJ0u""*DfB}"f{jD""pDF""bbbb"""DKDD|I
                                 f&&`f f0fG0fC{ Fb{ FB{0FF0> FF fFffffffFf"&%bk |BUb"G+u$LR]"+5Dbc|"|*D#T"D"D"pbDb"bb"""""Dr rEJ
        &&`f f0fG0fC{ Fb{ FB{0FF0F FF fFffffffFf"&%b&1bEkE0Eb*G$LRY"B$lDD"p"|B"DD"p"D""�"""" D@0r(vEEJ
                                            .`f f0fG0fC{ Fb{ FB{0FF0F FF fFffffffFfT&FDk1bEkD&Eb*GD$L"[LIJ0u""DD"p"|"D"D"pbD"""""""$rcD 0F{8v FbJ
        .&`f f0fG0fC{ F2{ FB{0FF0F FF fFf&ffGFC(""pDOkD(EkE0Eb
                    LIB�$HB�$XB�$D|"pt ""p"D"T"T""""DIAD$v!f(v8F(FJ
        &&`f f0fG0f{ Fb{ FB{0FF0F FF f(FN,FN,FNC("$pDDEJDDD
        "HB
        HB
        HB
        |"pp "D�p"D�""$"DH"�D` A$F{@ (f8F8F(FJ
        `f f0fG0fC{ Fb{ FB{0FF0F FF fF-F'-F'ff~CpBD
                           "Td0
                                HB
                                  HB
                                    HB
                                      Hz
                                        | pp "D"z"D""IDH$F{,v<v@ ,F,F(f8F8F(FJ
        c&&`f f0fG0fC{ F5{ FB{0FF0FG{~FF| fFCG\,FNfF("&D
        "T
        HB
        HB
        HB
        Hz
        | pNp ""z"DP4Fr"(&$F{@ <b,F,F,F(f88F(FJ
        &&&`f f0fG0fC{ Fb{ FB{ FF0FG{(FL+fF{CFND((JLFN#C~"
                                         HB
                                           HB
                                             HB
                                               Hz
                                                 | pt " 	D"F|cD D}4F{,F,F<F<F,F,F,F(f8F8F(FJ
        &`f f0fG0fC{ Fb{ FBz*FF~
        fGzcFF|+fFzffffb~JDz#0x"
        HB
        HB
        HB
        Hz
        | pt E$JF|,&v 4F,F,F<F<F,F,F,F(f8F8F(FJ
           .&`f f fG0f
                       N~ | Ht&E$JPF!f<F<F,F,F<F<F,F,,F(f8F8F(J
                                                               :`f f fG~
        fFj (bz\FN{\FF{BFfD
        L|BFHBJD x
        HB
        HB
        Jz
        N|$Fp&E&$j$,f'F<F,F,FF<F,F,F,F(f8F8F(FJ
        .&`fN f< fG~
        fFj fF
        ~\FFpXFFt`L
        L|xJDJD
        $HUDJR $R"BE$F"&$j$F&$',f<F<F,F,F<F<F,F,F,F(f8F8F(FJ
                                               .&.G`fN f<*fG~,F
        fF`XFp#4P#|z~IpJD
        L(x*E*BJ
        J%F&$j$F&$',<F<F,F,F,F(f8F(FJ
        g8`fN~\(N
        *fG~-F
        P,|#$Fp#A@#A@
        L|IpJD
        "E E*E$`
        J`JJJtGfb%F&$j$F&$,f<F<FlF,F<F<F,F,F,F(f8F8F(FJ|
                          CG}9D(\bFtX(F
                                       *fXV}#Mp#$Fp#A@ A@
                                                         L|p
                                                         ( D "E ER*fJpJJJJJJJJGfb%F&$j$F&$,f<F<F,F,F<F<F,F,F,F(f8F8F(F((J|cCzFg{9\D(XfNtH(LF|@(F(cF}#@F@#A
        A@ A@
        L|Ip
        (%@BQD $~E0b*fJJJJJJJJJJGfb%F&$j$F&$,f<F<Fp,F,F<F<F,F,F,F(f8F8F(FD}:||cD&Dgz)D(#B@L, Ip#IH#@F@#A
        #A@ A@
        L|IB
        @AxpDKF $jb*fJJJJJJJJJJGfb%F&fj$F&$,f<F<F,F,F<F<F,F,F,F(f8F8F(F0c0bD{Dz|cPQ~KzD!z#F|#x#Ip Ip@F@ A
      A@ A@
           L|Ip
                &$-F%(B"&%bk $jb*fJJJJ&JJJJJGfb%F&$j$F&$',f<F<F,F,F<F<F,F,F,F(f8FF(& b c0bD}pHKD~KFz
        z
        z @|#Ip#Ip Ip @F@ A
        A@ A@
        L|
        @$@d&dFf"&%bk $jb*fJJJJJJJJJJGfb%F&$j$F&$',f<F<F,F,F<F<F,F,F,F(f#F{8F~(FzDD0@JDxJp
                                 DKDx
                                     Dp
                                      z#@4z#Ip`Ip Ip @F@ A
                                                           A@ IDOB
        D0|AG|&d}ffffFf"&%bk $jb*fJJJJJJJJJJGfR%F&$j$F&$,f<F<F,F,F<F<F,F Fb,F~(& FbB((~D Bdp(Dp
        D
        Dz
        Dz
        z @| Ip Ip
    Terminating...
    Skipping tty reset...
    Thanks for using picocom
    C'est .... bizarre non ?
      carmelo42C Offline
      carmelo42
      J'ai réussi à recevoir autre chose, qui ressemble plus à du contenu viable :
      pi@raspberrypi:~ $ cat logteleinfo.log
      picocom v3.1
      port is        : /dev/ttyAMA0
      flowcontrol    : none
      baudrate is    : 9600
      parity is      : even
      databits are   : 7
      stopbits are   : 1
      escape is      : C-a
      local echo is  : no
      noinit is      : no
      noreset is     : no
      hangup is      : no
      nolock is      : no
      imap is        :
      omap is        :
      logfile is     : none
      initstring     : none
      exit is        : no
      0	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	0	"
      EASD01	002493203	7
      EASD02	000000000	!
      EASD03	000000000	"
      EASD04	000000000	#
      IRMS1	001	/
      IRMS2	002	1
      IRMS3	000	0
      40MS1	A40	@
      URMS3	239	J
      PREF	09	H
      PCOUP	09	"
      SINSTS	00892	Y
      SINSTS1	00271	A
      SINSTS2	00583	H
      SINSTS3	00038	D
      SMAXSN	E200811115306	03320	.
      SMAXSN1	E200811115306	03050	_
      SMAXSN2	E200811131815	02350	%
      SMAXSN3095922	00130	(
      SMAXSN-1	E200810192506	04240	T
      SMAXSN1-1	E200810192506	03970	N
      SMAXSN2-1	E200810103044	00340	8
      SMAXSN3-1	E2008	00380	I
      CCASN	E200811150000	00578	>
      CCASN-1	E200811143000	00558	\
      UMOY1	E200811150000	239	+
      UMOY2	E200811150000	240	$
      UMOY3	E0000	238	,
      STGE	003A0001	:
      MSG1	     PAS DE          MESSAGE    	<
      PRM	19858176535209	F
      RELAIS	000	B
      NTARF	01	N
      NJOURF
      NJOURF+1	00	B
      PJOURF+1	00008001 NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE	9
      ADSC	J21976885617	I
      DATE	E200811150447		?
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	002493204	'
      EASF01	002493204	:
      EASF02	000000000	#
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      EASD01	40	@
      URMS2	240	A
      URMS3	238	I
      PREF	09	H
      PCOUP	09	"
      SINSTS	00897	^
      SINSTS1	00267	F
      SINSTS2	00591	G
      SINSTS3	00038	D
      SMAXSN3	E200811095922	00130	(
      SMAXSN3-1	E200810085137	00380	I
      UMOY3	E200811150000	238	,
      STGE	00
      RELAIS	000	B
      NTARF	01	N
      NJOURF	00	&
      1JOURF+100008001 NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE	9
      ADSC	021976885617	I
      VTIC	02	J
      DATE	E2449		A
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	002493204	'
      EASF01	002493204	:
      EASF02	00000000
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	0	*
      EASF10	000000000	"
      EASD01	002493204	8
      EASD02	000000000	!
      EASD03	000000000	"
      EASD04	000000000	#
      IRMS1	001	/
      IRMS2	0
      IRMS3	000	0
      URMS1	240	@
      URMS2	240	A
      URMS3	238	I
      PREF	09	H
      PCOUP	09	"
      SINSTS	00931	S
      SINSTS1	00269	H
      SINSTS2	00038	D
      SMAXSN-1	E2008104240	T
      CCASN	E200811143000	00558	\
      STGE	003A0001	:
      MSG1	  E          MESSAGE    	<
      RELAIS	000	B
      NTARF	01	N
      NJOURF	00	&
      NJOURF+1	00	B
      PJOURF+1	00008001 NONUTILE NONUTILE NONUTILE NOONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE	9
      ADSC	021976885617	I
      VTIC	02	J
      DATE	E200811150451		:
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	002493204	'
      EASF01	002493204	:
      EASF02	000000000	#
      EASF03	000000000	$
      EASF04	00000000
      EASF05	000000000	&
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      EASD01	002493205	9
      EASD02	000000000	!
      EASD03	000000000	"
      EASD04	000000000	#
      IRMS1	001	/
      IRMS2	002	1
      IRMS3	000	0
      URMS1	2
      URMS2	240	A
      URMS3	239	J
      PREF	09	H
      PCOUP	09	"
      SINSTS	00812	Q
      SINSTS1	00267	F
      SINSTS2	00507	D
      SINSTS3	00038	D
      SMAXSN	15306	03320	.
      UMOY1	E0000	239	+
      STGE	003A0001	:
      MSG1	  E          MESSAGE    	<
      RELAIS	000	B
      NTARF	01	N
      NJOURF	00	&
      NJOURF+1	00	B
      PJOURF+1	00008001 NONUTILE NONUUTILE NONUTILE NONUTILE NONUTILE NONUTIL21976885617	I
      VTIC	02	J
      DATE	E200811150454		=
      NGTF	      BASE      	<
      LTARF	      BASE      	F
      EAST	002493205	(
      EASF01	002493205	;
      EASF02	000000000	#
      EASF03	000000000	$
      EASF04	000000000	%
      EASF05	00000000
      EASF06	000000000	'
      EASF07	000000000	(
      EASF08	000000000	)
      EASF09	000000000	*
      EASF10	000000000	"
      Terminating...
      pi@raspberrypi:~ $
      Afin de sortir ce log j'utilise
      picocom -b 9600 -d 7 -p e -f n /dev/ttyAMA0
      (En effet, en 1200 bauds, c'est que du charabia)
      Est-ce que ces trames semblent correctes ?
        ah ah ah bah oui t'es en mode linky historique c'est du 9600 bauds pas 1200 🙂
        En revanche c'est pas encore codé ce mode dans tasmota, je suis dessus tu pourras tester et me dire si ca fonctionne car tjs pas de linky.
          carmelo42C Offline
          carmelo42
          ah 🙂
          ça me rassure 🙂
          Ok pour faire les tests, pas de souci 🙂
          D'ailleurs si tu veux que je fasse beta testeur, n'hésite pas !
          Sinon je rappelle mon fournisseur d'électricité pour repasser en mode normal ?
