    Pi 0 W : trames reçues bizarres
    4 Posts 2 Posters 1.0k Views 3 Watching
    • carmelo42C Offline
      carmelo42
      Je teste mon module PiTInfo sur un Pi 0 W fraichement installé (donc en buster)
      Voici ce que j'obtiens comme trames avec picocom :
      pi@raspberrypi:~ $ picocom -b 1200 -d 7 -p e -f n /dev/ttyS0
      picocom v3.1
      port is        : /dev/ttyS0
      flowcontrol    : none
      baudrate is    : 1200
      parity is      : even
      databits are   : 7
      stopbits are   : 1
      escape is      : C-a
      local echo is  : no
      noinit is      : no
      noreset is     : no
      hangup is      : no
      nolock is      : no
      send_cmd is    : sz -vv
      receive_cmd is : rz -vv -E
      imap is        :
      omap is        :
      logfile is     : none
      initstring     : none
      exit_after is  : not set
      exit is        : no
      !! Settings mismatch !! Type [C-a] [C-v] to see actual port settings
      Terminal ready
      z GDD}@ N
               -f&C{ Fb{ FB{0FF0F FF fFfffffFf"&%bk $jb2fJJJJJJJJJJGfb%F&$j$F}$F} nk(&(T(T(T(TbFH4pD0}D}aG*HN
        *FG}0fC{pFb{ FB{0FF0F FF fFffffffFf"&%bk $jb*fJJJJJJJJJJGfb%FGF&"F& F},f#F{(DF",pbBb" DD|DE|D0|J }
                             d4*FG}0fG0fC{ Fb{ FB{nFF0F FF fFfffffff"&%bk $jb*fJJJJJJJJJJGfC|f"$E"$j$F| jR,p<pbFb xbbbD
        DD|D(~F8~D`fQ f0fG0fC{ Fb{ FB{0FF0F FF fFfffffFf"&%bk $jb*fJJJJJJJJ
        JFfcB}f""FjD"F&$Fb,p@b"bb"yBD
                              BD(D~P&`f f0fG0fC{ Fb{ FB{0FF0F FF fFffffffFf"%bk $jb*fJJJ
        Jp
        JpJDfc""bT|$BD"F&$F}(DbbBb"b"""Kr${
        D(`f f0fG0fC{ Fb{ FB{nFF0F FF fFfffffff"&%bk $j*G
        JpJJ0u""*DfB}"f{jD""pDF""bbbb"""DKDD|I
                                   f&&`f f0fG0fC{ Fb{ FB{0FF0> FF fFffffffFf"&%bk |BUb"G+u$LR]"+5Dbc|"|*D#T"D"D"pbDb"bb"""""Dr rEJ
        &&`f f0fG0fC{ Fb{ FB{0FF0F FF fFffffffFf"&%b&1bEkE0Eb*G$LRY"B$lDD"p"|B"DD"p"D""�"""" D@0r(vEEJ
                                              .`f f0fG0fC{ Fb{ FB{0FF0F FF fFffffffFfT&FDk1bEkD&Eb*GD$L"[LIJ0u""DD"p"|"D"D"pbD"""""""$rcD 0F{8v FbJ
        .&`f f0fG0fC{ F2{ FB{0FF0F FF fFf&ffGFC(""pDOkD(EkE0Eb
                      LIB�$HB�$XB�$D|"pt ""p"D"T"T""""DIAD$v!f(v8F(FJ
        &&`f f0fG0f{ Fb{ FB{0FF0F FF f(FN,FN,FNC("$pDDEJDDD
        "HB
        HB
        HB
        |"pp "D�p"D�""$"DH"�D` A$F{@ (f8F8F(FJ
        `f f0fG0fC{ Fb{ FB{0FF0F FF fF-F'-F'ff~CpBD
                             "Td0
                                  HB
                                    HB
                                      HB
                                        Hz
                                          | pp "D"z"D""IDH$F{,v<v@ ,F,F(f8F8F(FJ
        c&&`f f0fG0fC{ F5{ FB{0FF0FG{~FF| fFCG\,FNfF("&D
        "T
        HB
        HB
        HB
        Hz
        | pNp ""z"DP4Fr"(&$F{@ <b,F,F,F(f88F(FJ
        &&&`f f0fG0fC{ Fb{ FB{ FF0FG{(FL+fF{CFND((JLFN#C~"
                                           HB
                                             HB
                                               HB
                                                 Hz
                                                   | pt " 	D"F|cD D}4F{,F,F<F<F,F,F,F(f8F8F(FJ
        &`f f0fG0fC{ Fb{ FBz*FF~
        fGzcFF|+fFzffffb~JDz#0x"
        HB
        HB
        HB
        Hz
        | pt E$JF|,&v 4F,F,F<F<F,F,F,F(f8F8F(FJ
             .&`f f fG0f
                         N~ | Ht&E$JPF!f<F<F,F,F<F<F,F,,F(f8F8F(J
        :`f f fG~
        fFj (bz\FN{\FF{BFfD
        L|BFHBJD x
        HB
        HB
        Jz
        N|$Fp&E&$j$,f'F<F,F,FF<F,F,F,F(f8F8F(FJ
        .&`fN f< fG~
        fFj fF
        ~\FFpXFFt`L
        L|xJDJD
        $HUDJR $R"BE$F"&$j$F&$',f<F<F,F,F<F<F,F,F,F(f8F8F(FJ
                                                 .&.G`fN f<*fG~,F
        fF`XFp#4P#|z~IpJD
        L(x*E*BJ
        J%F&$j$F&$',<F<F,F,F,F(f8F(FJ
        g8`fN~\(N
        *fG~-F
        P,|#$Fp#A@#A@
        L|IpJD
        "E E*E$`
        J`JJJtGfb%F&$j$F&$,f<F<FlF,F<F<F,F,F,F(f8F8F(FJ|
                            CG}9D(\bFtX(F
                                         *fXV}#Mp#$Fp#A@ A@
                                                           L|p
                                                           ( D "E ER*fJpJJJJJJJJGfb%F&$j$F&$,f<F<F,F,F<F<F,F,F,F(f8F8F(F((J|cCzFg{9\D(XfNtH(LF|@(F(cF}#@F@#A
        A@ A@
        L|Ip
        (%@BQD $~E0b*fJJJJJJJJJJGfb%F&$j$F&$,f<F<Fp,F,F<F<F,F,F,F(f8F8F(FD}:||cD&Dgz)D(#B@L, Ip#IH#@F@#A
        #A@ A@
        L|IB
        @AxpDKF $jb*fJJJJJJJJJJGfb%F&fj$F&$,f<F<F,F,F<F<F,F,F,F(f8F8F(F0c0bD{Dz|cPQ~KzD!z#F|#x#Ip Ip@F@ A
        A@ A@
             L|Ip
                  &$-F%(B"&%bk $jb*fJJJJ&JJJJJGfb%F&$j$F&$',f<F<F,F,F<F<F,F,F,F(f8FF(& b c0bD}pHKD~KFz
        z
        z @|#Ip#Ip Ip @F@ A
        A@ A@
        L|
        @$@d&dFf"&%bk $jb*fJJJJJJJJJJGfb%F&$j$F&$',f<F<F,F,F<F<F,F,F,F(f#F{8F~(FzDD0@JDxJp
                                   DKDx
                                       Dp
                                        z#@4z#Ip`Ip Ip @F@ A
                                                             A@ IDOB
        D0|AG|&d}ffffFf"&%bk $jb*fJJJJJJJJJJGfR%F&$j$F&$,f<F<F,F,F<F<F,F Fb,F~(& FbB((~D Bdp(Dp
        D
        Dz
        Dz
        z @| Ip Ip
      Terminating...
      Skipping tty reset...
      Thanks for using picocom
      C'est .... bizarre non ?
        carmelo42
        J'ai réussi à recevoir autre chose, qui ressemble plus à du contenu viable :
        pi@raspberrypi:~ $ cat logteleinfo.log
        picocom v3.1
        port is        : /dev/ttyAMA0
        flowcontrol    : none
        baudrate is    : 9600
        parity is      : even
        databits are   : 7
        stopbits are   : 1
        escape is      : C-a
        local echo is  : no
        noinit is      : no
        noreset is     : no
        hangup is      : no
        nolock is      : no
        imap is        :
        omap is        :
        logfile is     : none
        initstring     : none
        exit is        : no
        Terminal ready
        0	%
        EASF05	000000000	&
        EASF06	000000000	'
        EASF07	000000000	(
        EASF08	000000000	)
        EASF09	000000000	*
        EASF10	0	"
        EASD01	002493203	7
        EASD02	000000000	!
        EASD03	000000000	"
        EASD04	000000000	#
        IRMS1	001	/
        IRMS2	002	1
        IRMS3	000	0
        40MS1	A40	@
        URMS3	239	J
        PREF	09	H
        PCOUP	09	"
        SINSTS	00892	Y
        SINSTS1	00271	A
        SINSTS2	00583	H
        SINSTS3	00038	D
        SMAXSN	E200811115306	03320	.
        SMAXSN1	E200811115306	03050	_
        SMAXSN2	E200811131815	02350	%
        SMAXSN3095922	00130	(
        SMAXSN3-1	E2008	00380	I
        CCASN	E200811150000	00578	>
        CCASN-1	E200811143000	00558	\
        UMOY1	E200811150000	239	+
        UMOY2	E200811150000	240	$
        UMOY3	E0000	238	,
        STGE	003A0001	:
        MSG1	     PAS DE          MESSAGE    	<
        PRM	19858176535209	F
        RELAIS	000	B
        NTARF	01	N
        NJOURF
        NJOURF+1	00	B
        ADSC	J21976885617	I
        DATE	E200811150447		?
        NGTF	      BASE      	<
        LTARF	      BASE      	F
        EAST	002493204	'
        EASF01	002493204	:
        EASF02	000000000	#
        EASF03	000000000	$
        EASF04	000000000	%
        EASF05	000000000	&
        EASF06	000000000	'
        EASF07	000000000	(
        EASF08	000000000	)
        EASF09	000000000	*
        EASF10	000000000	"
        EASD01	40	@
        URMS2	240	A
        URMS3	238	I
        PREF	09	H
        PCOUP	09	"
        SINSTS	00897	^
        SINSTS1	00267	F
        SINSTS2	00591	G
        SINSTS3	00038	D
        SMAXSN3	E200811095922	00130	(
        UMOY3	E200811150000	238	,
        STGE	00
        RELAIS	000	B
        NTARF	01	N
        NJOURF	00	&
        ADSC	021976885617	I
        VTIC	02	J
        DATE	E2449		A
        NGTF	      BASE      	<
        LTARF	      BASE      	F
        EAST	002493204	'
        EASF01	002493204	:
        EASF02	00000000
        EASF03	000000000	$
        EASF04	000000000	%
        EASF05	000000000	&
        EASF06	000000000	'
        EASF07	000000000	(
        EASF08	000000000	)
        EASF09	0	*
        EASF10	000000000	"
        EASD01	002493204	8
        EASD02	000000000	!
        EASD03	000000000	"
        EASD04	000000000	#
        IRMS1	001	/
        IRMS2	0
        IRMS3	000	0
        URMS1	240	@
        URMS2	240	A
        URMS3	238	I
        PREF	09	H
        PCOUP	09	"
        SINSTS	00931	S
        SINSTS1	00269	H
        SINSTS2	00038	D
        SMAXSN-1	E2008104240	T
        CCASN	E200811143000	00558	\
        STGE	003A0001	:
        MSG1	  E          MESSAGE    	<
        RELAIS	000	B
        NTARF	01	N
        NJOURF	00	&
        NJOURF+1	00	B
        PJOURF+1	00008001 NONUTILE NONUTILE NONUTILE NOONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE	9
        ADSC	021976885617	I
        VTIC	02	J
        DATE	E200811150451		:
        NGTF	      BASE      	<
        LTARF	      BASE      	F
        EAST	002493204	'
        EASF01	002493204	:
        EASF02	000000000	#
        EASF03	000000000	$
        EASF04	00000000
        EASF05	000000000	&
        EASF06	000000000	'
        EASF07	000000000	(
        EASF08	000000000	)
        EASF09	000000000	*
        EASF10	000000000	"
        EASD01	002493205	9
        EASD02	000000000	!
        EASD03	000000000	"
        EASD04	000000000	#
        IRMS1	001	/
        IRMS2	002	1
        IRMS3	000	0
        URMS1	2
        URMS2	240	A
        URMS3	239	J
        PREF	09	H
        PCOUP	09	"
        SINSTS	00812	Q
        SINSTS1	00267	F
        SINSTS2	00507	D
        SINSTS3	00038	D
        SMAXSN	15306	03320	.
        UMOY1	E0000	239	+
        STGE	003A0001	:
        MSG1	  E          MESSAGE    	<
        RELAIS	000	B
        NTARF	01	N
        NJOURF	00	&
        NJOURF+1	00	B
        PJOURF+1	00008001 NONUTILE NONUUTILE NONUTILE NONUTILE NONUTILE NONUTIL21976885617	I
        VTIC	02	J
        DATE	E200811150454		=
        NGTF	      BASE      	<
        LTARF	      BASE      	F
        EAST	002493205	(
        EASF01	002493205	;
        EASF02	000000000	#
        EASF03	000000000	$
        EASF04	000000000	%
        EASF05	00000000
        EASF06	000000000	'
        EASF07	000000000	(
        EASF08	000000000	)
        EASF09	000000000	*
        EASF10	000000000	"
        Terminating...
        pi@raspberrypi:~ $
        Afin de sortir ce log j'utilise
        (En effet, en 1200 bauds, c'est que du charabia)
        Est-ce que ces trames semblent correctes ?
          ah ah ah bah oui t'es en mode linky historique c'est du 9600 bauds pas 1200 🙂
          En revanche c'est pas encore codé ce mode dans tasmota, je suis dessus tu pourras tester et me dire si ca fonctionne car tjs pas de linky.
            carmelo42
            ah 🙂
            ça me rassure 🙂
            Ok pour faire les tests, pas de souci 🙂
            D'ailleurs si tu veux que je fasse beta testeur, n'hésite pas !
            Sinon je rappelle mon fournisseur d'électricité pour repasser en mode normal ?
