  4. PiTInfo
  5. Reading garbage from serial port, reborn
12 Posts 4 Posters 4.4k Views 2 Watching
    ThomasC
    Re: reading garbage from serial port PiTInfo
    I just got the pitinfo v1.2 throwing garbage at me.
    I have tried different settings for serial port ( baud, parity, flow control), using picocom and https://hallard.me/enable-serial-port-on-raspberry-pi/
    I have check cabling by connecting module directly to EDF appliance
    Any idea (Ie proper serial port settings)
    Thanks in advance
      @ThomasC
      What version of PI and EdF counter do you have RPI 3, Linky, ... ?
      T 1 Reply Last reply
        @ThomasC
        ThomasC
        @Charles It's a RPI 3 and a linky.
          Thomas, there is a problem detected by Linky users, to be able to works a resistor need to be changed.
          • R3 (4.7K) need to be changed by 1K, 1.2K or 1.5K (and may be 2.2K) whatever you have in hand.
          • or put another resistor from 800 Ohm to 1.8K in // of R3 leaving R3 in place.
          If you can't do it, you can send me back the board and I'll do it for you.
          T 2 Replies Last reply
            ThomasC
            @Charles Thanks for the feedback. I am out of office ATM. I'll see what i can do at end of week. But my soldering skills are poor.
            Regards
              ThomasC
              Hello @charles,
              what is the address i should send back the borard ?
              Best regards
              Thomas C
              S 1 Reply Last reply
                @ThomasC
                Je viens d'envoyer un PM sur le Chat avec l'adresse
                • T ThomasC
                  Hello @charles,
                  Best regards
                  Thomas C
                  Strebor
                  @ThomasC
                  Bonne journée à tous.
                  Une autre victime de Linky ici.
                  Avant de changer R3, je ferai un différentiel adaptateur pour mon oscilloscope.
                  Mon installation a une connexion parallèle de la téléinfo bus.
                  Je pense qu'un «récepteur de ligne» à haute impédance est nécessaire?
                  sorry for the baby french, I'm a slow learner.
                  Regards Strebor
                    @Strebor
                    Oui tu peux changer juste R3 et voir si tout fonctionne, après. Sait-on jamais 😉
                      Strebor
                      je pourrais faire ça.Mais je préfère voir ce qui se passe en premier....Strebor
                        Michel
                        je viens d'installer et configurer la PiTinfo sur mon Raspberry et je rencontre le même problème.
                        Lorsque je lance picocom, le début de trame est lisible puis je n'ai que du déchet.
                        Mes compétences de soudage sont très limitées et les composants tout petits...
                        Etes-vous toujours ok pour remplacer la R3 si je vous renvoie la carte?
                          Bonjour Michel,
                          Bien entendu aucun soucis, passez en mode chat pour les adresses de retour
