  4. PiTInfo
  5. reading garbage from serial port PiTInfo
10 Posts 2 Posters 8.3k Views 2 Watching
    J Offline
    JohnDoe
    I'm trying to get a PiTInfo v1.0 to work on a freshly installed Jessie on my Raspberry PI, but for reasons that escape me, I can only read garbage.
    As far as I can tell, the console on serial port is disabled:
    cat /boot/cmdline.txt
    dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    I've got a link to ttyS0
    sudo ln -s /dev/ttyAMA0 /dev/ttyS0
    I've set the serial port:
    stty 1200 cs7 evenp cstopb -igncr -inlcr -brkint -icrnl -opost -isig -icanon -iexten -F /dev/ttyAMA0
    and yet what I read is not what I'm expecting:
    cat /dev/ttyAMA0
    BPT@3L623@1|
    G]JF8Ic
    @*.5 |
    8j@6M&S
    0LS c
    @rjE@1Va
    @` @c
    @0Ka
    ^C
    Any pointers or help would be greatly appreciated.
      @JohnDoe
      Thing to check in order are :
      • cable wiring and lenght
      • remove any other devices already connected on téléinfo terminal block of ErdF counter
      • did you solder the GPIO connector on the PITinfo board ?
      then if it still doesn't work
      • Change the 3.3K R1 resistor by a 1.2K
        0_1448036267638_upload-55dfef86-3945-426f-b552-fd206a31ce7a
      • remove the 1.2K and do a shunt.
      Let me know these results, the last one should always works 😉
        J Offline
        JohnDoe
        Wonderful. I really am impressed with how much effort you help people trying to follow your foot steps.
        Some answers:
        • I'll check the cable length; I don't like the cable I'm using now or how much slack there is; but I didn't think this might be an issue;
        • there are no other devices - the PiTInfo connected is the only thing on the GPIO, and is directly connected to the EDF meter. There is nothing else;
        • I bought the PiTInfo fully assembled;
        Note that to check I just ordered a fully assembled PiTInfo v1.2 via Tindie from you - so we will see if this is a cable issue, a PiTInfo/hardware issue, or something else.
        Updates to follow.
          @JohnDoe
          Excellent, we'll know if the changes made on 1.2 version solve your problem if it's coming from the output of your device (it should),
          Just let us know, because I don't have a such device, everything always worked first time on my both counters here.
          J 1 Reply Last reply
            @JohnDoe
            J Offline
            J Offline
            JohnDoe
            @Charles New PiTInfo arrived, thanks! Installed and still the same thing happening. I also changed the cable from the PiTInfo to the meter. Output is still:
            pi@raspberry ~ $ cat /dev/ttyAMA0
            GT` @ cPT@3Yn623@1|
            gP0FP8Ic
            @*.5 L |
            $8j@6N
            $8
            0H[
                    1F
            `08
            er
            `rjE@1PVa
            @` ec
            D0Ba
            Next things to try: a different Raspberry, perhaps an A or B+ (I've been using a Raspberry Pi 1 Model A+) then also revert back to Wheezy OS.
              @JohnDoe
              I don't rely too much on cat command
              would you mind try a picocom -b 1200 -d 7 -p e -f n /dev/ttyAMA0 instead ?
              J 2 Replies Last reply
                @JohnDoe
                J Offline
                J Offline
                JohnDoe
                @Charles Sorry for the delay. I had a faulty SD card and couldn't figure out why making my bootable Wheezy SD card kept failing. Booted to Wheezy, adjusted the /boot/cmdline.txt file, /etc/inittab, and rebooted, but the cat command still yields the same results.
                Here's the output of picocom:
                 $8
                 c 0[
                 `08
                    er
                       `rjE@8@a
                               @S@ @c
                "       @0|          P*
                           $Rj
                               &GT u @ cPT@3L623@1|
                                                   gP0FPP8Ic
                                                             d*.5 H |
                j                                                    $8j@6n$
                1F 0[
                  (p08
                      er
                         drjE@8@a
                                 @S@ @c
                "       @0jq           P*
                 c!
                   &GT q @ cPT@3L623@1|
                                       G]JF8Ic!
                                               d*.5 H |
                j                                      $8j@6L$'
                 $8
                   0[   @ c
                           (t08
                               er
                                  @rjE@8P@a
                                           @` ec
                "       @0ja                     P*
                Now I'm testing if it's a locale/codepage issue. What local are you using in your configurations?
                • J JohnDoe
                   $8
                   c 0[
                   `08
                      er
                         `rjE@8@a
                                 @S@ @c
                  "       @0|          P*
                             $Rj
                                                     gP0FPP8Ic
                                                               d*.5 H |
                  j                                                    $8j@6n$
                  1F 0[
                    (p08
                        er
                           drjE@8@a
                                   @S@ @c
                  "       @0jq           P*
                   c!
                                         G]JF8Ic!
                                                 d*.5 H |
                  j                                      $8j@6L$'
                   $8
                     0[   @ c
                             (t08
                                 er
                                    @rjE@8P@a
                                             @` ec
                  "       @0ja                     P*
                  J Offline
                  J Offline
                  JohnDoe
                  playing with code pages yields nothing - still only garbage - don't know where to look anymore
                    @JohnDoe
                    J Offline
                    J Offline
                    JohnDoe
                    @Charles It works! Why, I don't know. stty wants odd parity, picocom no parity. This is beyond me for now.
                    pi@raspberrypi ~ $ stty --file /dev/ttyAMA0 1200 cs7 ixon -parenb
                    pi@raspberrypi ~ $ cat /dev/ttyAMA0
                    ADCO 012345678901 L
                    OPTARIF HC.. <
                    ISOUSC 30 9
                    HCHC 002698197 0
                    HCHP 010687090 2
                    PTEC HP..
                    IINST 003 Z
                    IMAX 038 J
                    PAPP 00680 /
                    HHPHC A ,
                    MOTDETAT 000000 B
                    or with picocom:
                    pi@raspberrypi ~ $ picocom --baud 1200 --flow x --parity n --databits 7 /dev/ttyAMA0
                    picocom v1.7
                    port is        : /dev/ttyAMA0
                    flowcontrol    : xon/xoff
                    baudrate is    : 1200
                    parity is      : none
                    databits are   : 7
                    escape is      : C-a
                    local echo is  : no
                    noinit is      : no
                    noreset is     : no
                    nolock is      : no
                    send_cmd is    : sz -vv
                    receive_cmd is : rz -vv
                    imap is        :
                    omap is        :
                    &4Nc
                        HCHC 002698197 0
                    HCHP 010687195 8
                    PTEC HP..
                    IINST 012 Z
                    IMAX 038 J
                    PAPP 02840 /
                    HHPHC A ,
                    MOTDETAT 000000
                    Thanks for using picocom
                      Good it works, but the 1st time I see two linux programs that need different config to work on the same serial port !!!
                      would be interesting to know what node red want 😉
