  4. Wemos Teleinfo
  5. Carte WeMos Teleinfo
wemosteleinfotasmota
  • TontonGilouT TontonGilou
    Pour la téléinfo, pas de problème, je la récupère dans jeedom par MQTT.
    Autrement voici pour la console après un restart.
    00:00.002 HDW: ESP32-D0WD-V3 v3.1
    00:00:00.073 UFS: FlashFS mounted with 300 kB free
    00:00:00.104 CFG: Loaded from File, Count 65
    00:00:00.114 QPC: Count 1
    00:00:00.120 I2C: Bus1 using GPIO22(SCL) and GPIO21(SDA)
    00:00:00.225 BRY: Berry initialized, RAM used 3934 bytes
    00:00:00.330 CFG: Energy loaded from file
    00:00:00.330 NRG: Init driver 15
    00:00:00.340 Project tasmota - Tasmota Version 13.3.0.1(teleinfo)-2_0_14(2023-12-19T14:59:56)
    00:00:00.342 TIC: RX on GPIO23, baudrate 1200
    00:00:01.227 WIF: Connecting to AP1 Freebox-XXXXXX Channel 6 BSSId XX:XX:XX:FD:E4:D0 in mode 11n as Teleinfo-Linky-0344...
    00:00:04.333 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=1)
    00:00:04.343 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=2)
    00:00:05.443 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=3)
    00:00:05.943 WIF: Connected
    00:00:06.202 HTP: Web server active on Teleinfo-Linky-0344 with IP address 192.168.0.62
    00:00:06.896 QPC: Reset
    13:21:03.181 MQT: Attempting connection...
    13:21:03.231 MQT: Connected
    13:21:03.235 MQT: tele/Teleinfo_Linky/LWT = Online (retained)
    13:21:03.238 MQT: cmnd/Teleinfo_Linky/POWER =
    13:21:03.247 MQT: tele/Teleinfo_Linky/INFO1 = {"Info1":{"Module":"Wemos Teleinfo Linky","Version":"13.3.0.1(teleinfo)","FallbackTopic":"cmnd/DVES_0C4158_fb/","GroupTopic":"cmnd/tasmotas/"}}
    13:21:03.264 MQT: tele/Teleinfo_Linky/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"Teleinfo-Linky-0344","IPAddress":"192.168.0.62","IP6Global":"2a01:e0a:6a:8390:e665:b8ff:fe0c:4158","IP6Local":"fe80::e665:b8ff:fe0c:4158%st1"}}
    13:21:03.278 MQT: tele/Teleinfo_Linky/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":44}}
    13:21:03.293 MQT: stat/Teleinfo_Linky/RESULT = {"POWER":"OFF"}
    13:21:03.296 MQT: stat/Teleinfo_Linky/POWER = OFF
    13:21:03.666 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=4)
    13:21:06.146 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=5)
    13:21:07.883 MQT: tele/Teleinfo_Linky/STATE = {"Time":"2024-01-24T13:21:07","Uptime":"0T00:00:12","UptimeSec":12,"Heap":159,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":35,"MqttCount":1,"Berry":{"HeapUsed":3,"Objects":39},"POWER":"OFF","Dimmer":62,"Color":"9E9E9E","HSBColor":"0,0,62","Channel":[62,62,62],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"22:66:CF:FD:E4:D0","Channel":6,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":1,"Downtime":"0T00:00:07"}}
    13:21:07.938 MQT: tele/Teleinfo_Linky/SENSOR = {"Time":"2024-01-24T13:21:07","ENERGY":{"TotalStartTime":"2023-12-24T14:42:15","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":1440,"Current":6.000,"Load":10},"TIC":{"ADCO":"031864074148","ISOUSC":60,"BBRHCJB":21603399,"BBRHPJB":20499644,"BBRHCJW":5465122,"BBRHPJW":5397423,"BBRHCJR":903746,"BBRHPJR":911531,"PTEC":"HPJB","DEMAIN":"----","IINST":6,"IMAX":90,"PAPP":1440,"HHPHC":"A","MOTDETAT":0}}
    13:21:08.430 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=6)
    13:21:10.683 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=7)
    13:21:12.954 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=8)
    13:21:15.404 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=9)
    13:21:17.683 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=10)
    13:21:19.934 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=11)
    13:21:22.432 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=12)
    13:21:24.683 LibTeleinfo::checkLine Err checksum 0x00 != 0x53 (total errors=13)
    Config utilisée carte wemos avec ESP32 MH & Live avec Tasmota
    Program Version 13.3.0.1(teleinfo)
    Build Date & Time 2023-12-19T14:59:56
    Core/SDK Version 2_0_14/4.4.6.231122
    Uptime 0T00:06:58
    Flash Write Count 66
    Boot Count 44
    Friendly Name 1 Tasmota
    Avec mes amitiés.
    Gilles
    TontonGilouT Offline
    TontonGilou
    Tarif Tempo EDF
    2 cartes ESP32 MH & LIVE
      TontonGilou
      #27
      Peut-être ceci aussi:
      20:21:50.119 CMD: EnergyConfig
      20:21:50.123 TIC: Settings Mode:historique, RX:GPIO23, EN:None, Raw:noraw, Skip:0, Limit:0, Stats:0
      20:21:50.128 MQT: stat/Teleinfo_PAC/RESULT = {"EnergyConfig":"Done"}
      Gilles.
      Tarif Tempo EDF
        Gilles.
        TontonGilou
        Est-ce que les infos transmises suffisent S.V.P.?
        Merci d'avance.
        Gilles.
        Tarif Tempo EDF
          Merci d'avance.
          Gilles.
          #29
          @TontonGilou
          C'est ce contrat Tempo Heures Creuses avec ces etiquettes qui n'est pas géré dans Tasmota, c'est pour ça. Je ne savais même pas que ça existait.
          "BBRHCJB":21603399,
          "BBRHPJB":20499644,
          "BBRHCJW":5465122,
          "BBRHPJW":5397423,
          "BBRHCJR":903746,
          "BBRHPJR":911531
          je pense en revanche que la version de @Nicolas-Bernaerts gère parfaitement ce contrat. Peut être utiliser sa version.
          TontonGilouT Nicolas BernaertsN 2 Replies Last reply
            @TontonGilou
            "BBRHCJB":21603399,
            "BBRHPJB":20499644,
            "BBRHCJW":5465122,
            "BBRHPJW":5397423,
            "BBRHCJR":903746,
            "BBRHPJR":911531
            TontonGilou
            OK, merci pour la réponse.
            Je vais voir avec la version de Nicolas, mais je pense que ce sera plus difficile d'installation.
            Bonne fin de semaine.
            Avec mes amitiés.
            Gilles.
            Tarif Tempo EDF
              @TontonGilou
              "BBRHCJB":21603399,
              "BBRHPJB":20499644,
              "BBRHCJW":5465122,
              "BBRHPJW":5397423,
              "BBRHCJR":903746,
              "BBRHPJR":911531
              @Charles Hello,
              Effectivement la gestion tempo est native sur mon build. Bien que je n'ai pas ce type de contrat, cela a été testé par des utilisateurs de ce forum. Une simple mise a jour web depuis une version denky officielle devrait bien se passer ...
                @Charles Hello,
                TontonGilou
                #32
                @Nicolas-Bernaerts, @Charles
                Voilà, j'ai installé votre version sur un de mes ESP32 MH & LIVE, j'ai pris le bin:
                tasmota32-teleinfo-4m1200k.factory.bin (je pense que c'est le bon ??)
                Et ça a l'air de bien fonctionner.
                Dans la console, je vois qu'il y a quelques erreurs TIC, je pense qu'il faut que j'ajuste une résistance en série dans la ligne Téléinfo, je vais voir.
                Autrement, je récupère les infos dans Jeedom en MQTT sans problème.
                Nicolas, je me permets de vous signaler que sur votre site Github, le lien "Teleinfo protocol is described in this document" n'est plus d'actualité.
                Merci beaucoup pour ce bon boulot.
                Gilles
                Tarif Tempo EDF
                  Gilles
                  TontonGilou
                  rappel: essai avec carte wemos teleinfo, et module ESP32 MH & LIVE câblé sur un compteur ISKRA (ancien compteur électronique EDF)
                  Bonjour.
                  Suite de mes travaux d'installation, En essayant différentes valeurs de résistance en série en ligne, je n'arrive pas à supprimer toutes les erreurs TIC:
                  16:32:54.590 TIC: Error [BBRHCJR 001315975 L Y D]
                  16:33:24.601 MQT: Teleinfo_PAC/tele/STATE = {"Time":"2024-02-03T16:33:24","Uptime":"0T00:09:43","UptimeSec":583,"Heap":141,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Berry":{"HeapUsed":3,"Objects":41},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"22:66:CF:FD:E4:D0","Channel":6,"Mode":"11n","RSSI":74,"Signal":-63,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  16:33:27.553 MQT: Teleinfo_PAC/tele/SENSOR = {"Time":"2024-02-03T16:33:27","ENERGY":{"TotalStartTime":"2024-01-31T18:16:09","Total":0.079,"Yesterday":0.000,"Today":0.008,"Period":0,"Power":6,"ApparentPower":60,"ReactivePower":0,"Factor":0.10,"Voltage":230,"Current":0.3},"ALERT":{"Load":0,"Volt":0,"Preavis":{"Level":0,"Label":""}},"TIC":{"ADCO":"270828004689","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"050001199","BBRHPJB":"050980660","BBRHCJW":"014591904","BBRHPJW":"016452155","BBRHCJR":"001315975","BBRHPJR":"001982722","PTEC":"HPJB","DEMAIN":"----","IINST":"000","IMAX":"062","PAPP":"00060","HHPHC":"Y","MOTDETAT":"000000"},"Eth":"00:00:00:00:00:00"}
                  16:33:32.476 TIC: Error [ADJW 014591904 S]
                  16:34:02.487 MQT: Teleinfo_PAC/tele/STATE = {"Time":"2024-02-03T16:34:02","Uptime":"0T00:10:21","UptimeSec":621,"Heap":141,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Berry":{"HeapUsed":3,"Objects":41},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"22:66:CF:FD:E4:D0","Channel":6,"Mode":"11n","RSSI":74,"Signal":-63,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  16:34:05.438 MQT: Teleinfo_PAC/tele/SENSOR = {"Time":"2024-02-03T16:34:05","ENERGY":{"TotalStartTime":"2024-01-31T18:16:09","Total":0.079,"Yesterday":0.000,"Today":0.008,"Period":0,"Power":3,"ApparentPower":60,"ReactivePower":0,"Factor":0.05,"Voltage":230,"Current":0.3},"ALERT":{"Load":0,"Volt":0,"Preavis":{"Level":0,"Label":""}},"TIC":{"ADCO":"270828004689","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"050001199","BBRHPJB":"050980660","BBRHCJW":"014591904","BBRHPJW":"016452155","BBRHCJR":"001315975","BBRHPJR":"001982722","PTEC":"HPJB","DEMAIN":"----","IINST":"000","IMAX":"062","PAPP":"00060","HHPHC":"Y","MOTDETAT":"000000"},"Eth":"00:00:00:00:00:00"}
                  Peut-être que c'est des erreurs dues à une interruption CPU ?
                  Autrement, je vois que comme avec la version de Charles, les valeurs de compteurs journaliers et total sont fausses. (c'est pas grave, je gère çà sous Jeedom, c'est juste pour l'info.)
                  Amicalement.
                  Gilles
                  Tarif Tempo EDF
                    Bonjour.
                    Amicalement.
                    Gilles
                    TontonGilou
                    #34
                    @Nicolas-Bernaerts @Charles
                    Bonjour à tous.
                    Bon à partir d'aujourd'hui, sans rien changer, les compteurs semblent fonctionner convenablement!!!
                    Enfin, rien changer, sinon l'ordre de mise en place entre l'alim de l'Esp et le branchement de la ligne téléinfo!!
                    C'est le cas de le dire, "Va comprendre, Charles" 😅 😅
                    Gilles
                    Tarif Tempo EDF
                      Bonjour à tous.
                      Gilles
                      @TontonGilou C'est sans doute le signe d'une faiblesse de l'alimentation utilisée.
                        TontonGilou
                        Bonjour, non, pas de soucis de ce côté là, quand je mets au point un nouveau modèle de la sorte, j'utilise une alim de laboratoire pendant la mise au point (10A disponible 😊 )
                        Une petite question, j'aimerais faire un essai avec un module ESP32 Lolin C3 mini.
                        Quel binaire je peux utiliser ?, J'ai essayé tasmota32-teleinfo-4m1200k.bin , il reboot sans arrêt.
                        Merci d'avance.
                        Gilles
                        Tarif Tempo EDF
                          Merci d'avance.
                          Gilles
                          @TontonGilou Il faudrait utiliser un build spécifique esp32 C3. Je n'en fournit pas a l'heure actuelle. Je vais voir pour en ajouter un.
                            TontonGilou
                            @Nicolas-Bernaerts Ok, merci, je vais attendre.
                            Amitiés.
                            Gilles.
                            Tarif Tempo EDF
                              Amitiés.
                              Gilles.
                              @TontonGilou Je viens de publier une version ESP32C3.
                              Tenez moi au courant ...
                                TontonGilou
                                Bonjour Nicolas.
                                Je viens de mettre en place mon ESP32C3, cà a l'air de fonctionner.👍
                                Je laisse tourner un moment cet après-midi et je tâche de vous en dire plus tout à l'heure.
                                Gilles.😊
                                Tarif Tempo EDF
                                  TontonGilou
                                  Bonjour Nicolas,
                                  Confirmation, la version pour esp32 C3 est opérationnelle.
                                  Toujours une petite erreur de lecture téléinfo qui semble due au traitement je pense. Sa fréquence d'apparition est proportionnelle à la fréquence de parution des messages MQTT.
                                  Période de 30 secondes:
                                  07:07:11.307 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T07:07:11","Uptime":"0T18:06:33","UptimeSec":65193,"Heap":170,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":15,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":13,"Downtime":"0T00:02:56"}}
                                  07:07:14.252 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:07:14","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":23.300,"Yesterday":11.566,"Today":11.734,"Period":3,"Power":341,"ApparentPower":500,"ReactivePower":366,"Factor":0.68,"Voltage":230,"Current":2.2}}
                                  07:07:16.217 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:07:16","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  07:07:17.207 TIC: Error [DEMABR( S]
                                  07:07:18.261 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:07:18","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020709564","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020709564","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----"}}
                                  07:07:48.236 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T07:07:48","Uptime":"0T18:07:10","UptimeSec":65230,"Heap":170,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":15,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":13,"Downtime":"0T00:02:56"}}
                                  07:07:51.182 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:07:51","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":23.304,"Yesterday":11.566,"Today":11.738,"Period":4,"Power":422,"ApparentPower":490,"ReactivePower":249,"Factor":0.86,"Voltage":230,"Current":2.1}}
                                  07:07:53.153 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:07:53","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  07:07:54.145 TIC: Error [BBRHPJR 00091775864074148 E]
                                  07:07:55.203 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:07:55","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020709567","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020709568","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754"}}
                                  07:08:25.177 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T07:08:25","Uptime":"0T18:07:47","UptimeSec":65267,"Heap":170,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":15,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":13,"Downtime":"0T00:02:56"}}
                                  07:08:28.123 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:08:28","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":23.315,"Yesterday":11.566,"Today":11.748,"Period":11,"Power":1199,"ApparentPower":1230,"ReactivePower":274,"Factor":0.97,"Voltage":230,"Current":5.3}}
                                  07:08:30.095 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:08:30","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  07:08:31.086 TIC: Error [BB A ,]
                                  07:08:32.140 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:08:32","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020709580","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","MOTDETAT":"000000"}}
                                  07:09:01.127 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T07:09:01","Uptime":"0T18:08:23","UptimeSec":65303,"Heap":170,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":15,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":13,"Downtime":"0T00:02:56"}}
                                  07:09:04.073 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:09:04","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":23.325,"Yesterday":11.566,"Today":11.759,"Period":10,"Power":423,"ApparentPower":490,"ReactivePower":247,"Factor":0.86,"Voltage":230,"Current":2.1}}
                                  07:09:06.044 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:09:06","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  07:09:07.036 TIC: Error [MOTDETAT 000008870 []
                                  07:09:08.095 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:09:08","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020709588","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"002","IMAX":"090","PAPP":"00490","HHPHC":"A","MOTDETAT":"000000","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"002","IMAX":"090","PAPP":"00490","HHPHC":"A","MOTDETAT":"000000"}}
                                  07:09:12.031 TIC: Error [MOTDETAT 000000 529414 ]]
                                  07:09:39.054 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T07:09:39","Uptime":"0T18:09:01","UptimeSec":65341,"Heap":170,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":15,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":13,"Downtime":"0T00:02:56"}}
                                  07:09:41.000 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:09:41","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":23.330,"Yesterday":11.566,"Today":11.763,"Period":4,"Power":420,"ApparentPower":500,"ReactivePower":271,"Factor":0.84,"Voltage":230,"Current":2.2}}
                                  07:09:43.972 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:09:43","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  07:09:44.963 TIC: Error [BBRHPJB 020N ---- "]
                                  07:09:46.016 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:09:46","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020709592","IINST":"002","IMAX":"090","PAPP":"00490","HHPHC":"A","MOTDETAT":"000000"}}
                                  07:10:15.004 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T07:10:14","Uptime":"0T18:09:36","UptimeSec":65377,"Heap":168,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":15,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":13,"Downtime":"0T00:02:56"}}
                                  07:10:17.949 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:10:17","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":23.334,"Yesterday":11.566,"Today":11.767,"Period":4,"Power":397,"ApparentPower":490,"ReactivePower":287,"Factor":0.81,"Voltage":230,"Current":2.1}}
                                  07:10:19.921 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:10:19","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  07:10:20.969 TIC: Error [IINST 002 YRHCJB 021802530 2]
                                  07:10:21.996 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:10:21","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020709595","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"002","BBRHPJB":"020709595","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"002","IMAX":"090"}}
                                  07:10:52.045 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T07:10:52","Uptime":"0T18:10:14","UptimeSec":65414,"Heap":166,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":15,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":13,"Downtime":"0T00:02:56"}}
                                  07:10:54.991 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:10:54","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":23.338,"Yesterday":11.566,"Today":11.771,"Period":4,"Power":355,"ApparentPower":480,"ReactivePower":323,"Factor":0.74,"Voltage":230,"Current":2.1}}
                                  07:10:56.955 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:10:56","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  07:10:57.962 TIC: Error [USC 60 <]
                                  07:10:59.000 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T07:10:58","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020709598","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"002","BBRHCJB":"021802530","BBRHPJB":"020709599","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"002"}}
                                  07:11:02.991 TIC: Error [DEMAIN ---- JB 021802530 2]
                                  Période de 5 minutes:
                                  08:28:47.269 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:28:47","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020710550","IINST":"003","IMAX":"090","PAPP":"00610","HHPHC":"A","MOTDETAT":"000000"}}
                                  08:33:46.278 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T08:33:46","Uptime":"0T19:33:08","UptimeSec":70388,"Heap":166,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":17,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":15,"Downtime":"0T00:03:22"}}
                                  08:33:49.225 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:33:49","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":24.395,"Yesterday":11.566,"Today":12.828,"Period":58,"Power":774,"ApparentPower":790,"ReactivePower":158,"Factor":0.98,"Voltage":230,"Current":3.4}}
                                  08:33:51.196 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:33:51","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  08:33:52.204 TIC: Error [ADCO 031 005529414 ]]
                                  08:33:53.242 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:33:53","TIC":{"ADCO":"031864074148","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"005","IMAX":"090","PAPP":"01100","HHPHC":"A","MOTDETAT":"000000"}}
                                  08:38:52.265 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T08:38:52","Uptime":"0T19:38:14","UptimeSec":70694,"Heap":165,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":17,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":60,"Signal":-70,"LinkCount":15,"Downtime":"0T00:03:22"}}
                                  08:38:55.211 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:38:55","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":24.531,"Yesterday":11.566,"Today":12.965,"Period":137,"Power":1900,"ApparentPower":1900,"ReactivePower":0,"Factor":1.00,"Voltage":230,"Current":8.3}}
                                  08:38:57.183 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:38:57","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  08:38:58.208 TIC: Error [IINST 008 BRHCJB 021802530 2]
                                  08:38:59.230 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:38:59","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020710742","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"008","BBRHPJB":"020710744","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"008","IMAX":"090"}}
                                  08:43:58.254 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T08:43:58","Uptime":"0T19:43:20","UptimeSec":71000,"Heap":166,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":17,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":15,"Downtime":"0T00:03:22"}}
                                  08:44:01.202 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:44:01","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":24.604,"Yesterday":11.566,"Today":13.037,"Period":73,"Power":413,"ApparentPower":590,"ReactivePower":421,"Factor":0.70,"Voltage":230,"Current":2.6}}
                                  08:44:03.172 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:44:03","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  08:44:05.257 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:44:05","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020710811","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534"}}
                                  08:49:03.291 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T08:49:03","Uptime":"0T19:48:25","UptimeSec":71305,"Heap":166,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":17,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":15,"Downtime":"0T00:03:22"}}
                                  08:49:06.238 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:49:06","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":24.644,"Yesterday":11.566,"Today":13.078,"Period":40,"Power":387,"ApparentPower":470,"ReactivePower":267,"Factor":0.82,"Voltage":230,"Current":2.0}}
                                  08:49:08.209 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:49:08","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  08:49:09.236 TIC: Error [IMAX 21802530 2]
                                  08:49:10.254 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:49:10","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020710848","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"002","IMAX":"090","BBRHPJB":"020710848","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"002","IMAX":"090"}}
                                  08:49:14.216 TIC: Error [IMAX 0B 020710848 H]
                                  08:54:11.238 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T08:54:11","Uptime":"0T19:53:33","UptimeSec":71613,"Heap":166,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":17,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":15,"Downtime":"0T00:03:22"}}
                                  08:54:14.184 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:54:14","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":24.670,"Yesterday":11.566,"Today":13.103,"Period":26,"Power":282,"ApparentPower":470,"ReactivePower":376,"Factor":0.60,"Voltage":230,"Current":2.0}}
                                  08:54:16.156 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:54:16","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  08:54:17.164 TIC: Error [BBRHCJW 005]
                                  08:54:18.201 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:54:18","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020710873","BBRHCJW":"005588870","IMAX":"090","PAPP":"00470","HHPHC":"A","MOTDETAT":"000000"}}
                                  08:59:17.229 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T08:59:17","Uptime":"0T19:58:39","UptimeSec":71919,"Heap":165,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":17,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":15,"Downtime":"0T00:03:22"}}
                                  08:59:20.175 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:59:20","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":24.715,"Yesterday":11.566,"Today":13.149,"Period":46,"Power":395,"ApparentPower":580,"ReactivePower":425,"Factor":0.68,"Voltage":230,"Current":2.5}}
                                  08:59:22.147 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:59:22","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  08:59:23.157 TIC: Error [ADCO 031864074148  ]]
                                  08:59:24.192 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T08:59:24","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","BBRHPJR":"000917754","PTEC":"HPJB","DEMAIN":"----","IINST":"003","IMAX":"090","PAPP":"00580","HHPHC":"A","MOTDETAT":"000000"}}
                                  09:04:22.221 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T09:04:22","Uptime":"0T20:03:44","UptimeSec":72224,"Heap":166,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":17,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":15,"Downtime":"0T00:03:22"}}
                                  09:04:25.167 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T09:04:25","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":24.744,"Yesterday":11.566,"Today":13.177,"Period":28,"Power":373,"ApparentPower":590,"ReactivePower":457,"Factor":0.63,"Voltage":230,"Current":2.6}}
                                  09:04:27.139 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T09:04:27","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  09:04:28.151 TIC: Error [BBRHCJW 005588MAX 090 H]
                                  09:04:29.184 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T09:04:29","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020710942","BBRHCJW":"005588870","PAPP":"00590","HHPHC":"A","MOTDETAT":"000000"}}
                                  09:09:27.219 MQT: teleinfoC3/STATE = {"Time":"2024-02-15T09:09:27","Uptime":"0T20:08:49","UptimeSec":72529,"Heap":165,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":17,"Berry":{"HeapUsed":4,"Objects":39},"Wifi":{"AP":1,"SSId":"Freebox-863316","BSSId":"8C:97:EA:C7:52:68","Channel":6,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":15,"Downtime":"0T00:03:22"}}
                                  09:09:30.165 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T09:09:30","ENERGY":{"TotalStartTime":"2024-02-14T11:31:41","Total":24.887,"Yesterday":11.566,"Today":13.320,"Period":143,"Power":2630,"ApparentPower":2630,"ReactivePower":0,"Factor":1.00,"Voltage":230,"Current":11.4}}
                                  09:09:32.128 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T09:09:32","ALERT":{"Load":0,"Volt":0,"Preavis":0,"Label":""}}
                                  09:09:33.137 TIC: Error [PTEC HPJBPTARIF BBR( S]
                                  09:09:34.174 MQT: teleinfoC3/SENSOR = {"Time":"2024-02-15T09:09:34","TIC":{"ADCO":"031864074148","OPTARIF":"BBR(","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020711081","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB","ISOUSC":"60","BBRHCJB":"021802530","BBRHPJB":"020711085","BBRHCJW":"005588870","BBRHPJW":"005529414","BBRHCJR":"000916534","BBRHPJR":"000917754","PTEC":"HPJB"}}
                                  Erreurs sans gravité apparemment.
                                  Bonne journée.
                                  Gilles
                                  Tarif Tempo EDF
                                  T TontonGilouT 2 Replies Last reply
                                    Bonjour Nicolas,
                                    Bonne journée.
                                    Gilles
                                    Tigrou
                                    Chère communauté,
                                    Je sollicite humblement votre assistance. Je me trouve actuellement dans l'impasse et je serais infiniment reconnaissant envers quiconque pourrait m'offrir son aide. Malgré mes efforts, je suis incapable de déterminer l'origine de l'erreur que j'ai commise.
                                    J'ai procédé à la soudure de ma carte Webmos V1.1 sur un ESP8266 conformément aux instructions fournies (Veuillez consulter les photos ci-jointes). Ensuite, j'ai installé Tasmota Teleinfo sur la puce. J'ai suivi scrupuleusement les étapes de configuration de Tasmota telles qu'elles sont décrites, puis j'ai assigné le RX au GPIO3, tout en activant le mode standard (Veuillez trouver le code ci-dessous). Bien que la LED clignote, je ne reçois aucune information dans Tasmota.
                                    Je sollicite donc vos précieuses suggestions quant à la source potentielle de ce problème. Je vous remercie chaleureusement pour votre aide.
                                    Cordialement,
                                    Tigrou
                                    code_text
                                    00:00:00.001 HDW: ESP8266EX
                                    00:00:00.054 CFG: Loaded from flash at F4, Count 72
                                    00:00:00.059 SER: Set to 8N1 9600 bit/s
                                    00:00:00.060 QPC: Count 2
                                    00:00:00.071 NRG: Init driver 15
                                    00:00:00.077 Project tasmota - Tasmota Version 13.4.0.2(f7ae60a-teleinfo)-2_7_6(2024-03-12T07:42:01)
                                    00:00:00.078 TIC: RX on GPIO3, baudrate 9600
                                    00:00:00.080 SNS: Hardware Serial
                                    00:00:00.080 TIC: using hardware serial
                                    00:00:01.001 WIF: Connecting to AP1 XXXXXXXX Channel 4 BSSId 3C:84:6A:01:A9:A5 in mode 11n as tasmota-D01E70-7792...
                                    00:00:01.754 WIF: Connected
                                    00:00:02.006 HTP: Web server active on tasmota-D01E70-7792 with IP address 10.34.40.220
                                    00:00:09.285 MQT: Attempting connection...
                                    00:00:09.303 MQT: Connected
                                    00:00:09.306 MQT: tele/tasmota_D01E70/LWT = Online (retained)
                                    00:00:09.308 MQT: cmnd/tasmota_D01E70/POWER =
                                    00:00:09.314 MQT: tele/tasmota_D01E70/INFO1 = {"Info1":{"Module":"Wemos Teleinfo","Version":"13.4.0.2(f7ae60a-teleinfo)","FallbackTopic":"cmnd/DVES_D01E70_fb/","GroupTopic":"cmnd/tasmotas/"}}
                                    00:00:09.316 MQT: tele/tasmota_D01E70/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-D01E70-7792","IPAddress":"10.34.40.220"}}
                                    00:00:09.318 MQT: tele/tasmota_D01E70/INFO3 = {"Info3":{"RestartReason":"External System","BootCount":33}}
                                    00:00:09.320 MQT: stat/tasmota_D01E70/RESULT = {"POWER":"OFF"}
                                    00:00:09.321 MQT: stat/tasmota_D01E70/POWER = OFF
                                    00:00:09.382 QPC: Reset
                                    00:00:10.447 MQT: stat/tasmota_D01E70/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":" ","RestartReason":"External System","Uptime":"0T00:00:09","StartupUTC":"","Sleep":50,"CfgHolder":4617,"BootCount":32,"BCResetTime":"1970-01-01T00:00:00","SaveCount":72,"SaveAddress":"F4000"}}
                                    00:00:10.502 MQT: stat/tasmota_D01E70/STATUS11 = {"StatusSTS":{"Time":"1970-01-01T00:00:10","Uptime":"0T00:00:09","UptimeSec":9,"Vcc":3.050,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":213,"MqttCount":1,"POWER":"OFF","Dimmer":10,"Color":"1A1A1A","HSBColor":"0,0,10","Channel":[10,10,10],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Full Throttle","BSSId":"3C:84:6A:01:A9:A5","Channel":4,"Mode":"11n","RSSI":42,"Signal":-79,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                                    00:00:10.552 MQT: stat/tasmota_D01E70/RESULT = {"Time":"1970-01-01T00:00:10","Uptime":"0T00:00:09","UptimeSec":9,"Vcc":3.050,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":204,"MqttCount":1,"POWER":"OFF","Dimmer":10,"Color":"1A1A1A","HSBColor":"0,0,10","Channel":[10,10,10],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Full Throttle","BSSId":"3C:84:6A:01:A9:A5","Channel":4,"Mode":"11n","RSSI":42,"Signal":-79,"LinkCount":1,"Downtime":"0T00:00:03"}}
                                    00:00:10.600 MQT: stat/tasmota_D01E70/STATUS10 = {"StatusSNS":{"Time":"1970-01-01T00:00:10","ENERGY":{"TotalStartTime":"1970-01-01T00:00:00","Total":0.000,"Yesterday":0.000,"Today":0.000,"Power":0,"Current":0.000},"TIC":{}}}
                                    00:00:13.289 MQT: tele/tasmota_D01E70/STATE = {"Time":"1970-01-01T00:00:13","Uptime":"0T00:00:12","UptimeSec":12,"Vcc":3.050,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":24,"MqttCount":1,"POWER":"OFF","Dimmer":10,"Color":"1A1A1A","HSBColor":"0,0,10","Channel":[10,10,10],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Full Throttle","BSSId":"3C:84:6A:01:A9:A5","Channel":4,"Mode":"11n","RSSI":46,"Signal":-77,"LinkCount":1,"Downtime":"0T00:00:03"}}
                                    00:00:13.299 MQT: tele/tasmota_D01E70/SENSOR = {"Time":"1970-01-01T00:00:13","ENERGY":{"TotalStartTime":"1970-01-01T00:00:00","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"Current":0.000},"TIC":{}}
                                    00:05:23.293 MQT: tele/tasmota_D01E70/STATE = {"Time":"1970-01-01T00:05:23","Uptime":"0T00:05:12","UptimeSec":312,"Vcc":3.065,"Heap":22,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":1,"POWER":"OFF","Dimmer":10,"Color":"1A1A1A","HSBColor":"0,0,10","Channel":[10,10,10],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Full Throttle","BSSId":"3C:84:6A:01:A9:A5","Channel":4,"Mode":"11n","RSSI":42,"Signal":-79,"LinkCount":1,"Downtime":"0T00:00:03"}}
                                    00:05:23.306 MQT: tele/tasmota_D01E70/SENSOR = {"Time":"1970-01-01T00:05:23","ENERGY":{"TotalStartTime":"1970-01-01T00:00:00","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"Current":0.000},"TIC":{}}
                                    00:08:29.451 CMD: EnergyConfig
                                    00:08:29.457 TIC: Settings Mode:standard, RX:GPIO3, EN:None, Raw:noraw, Skip:0, Limit:0, Stats:0
                                    00:08:29.461 MQT: stat/tasmota_D01E70/RESULT = {"EnergyConfig":"Done"}
                                    CharlesC 3 Replies Last reply
                                    • T Tigrou
                                      Chère communauté,
                                      Cordialement,
                                      Tigrou
                                      code_text
                                      • T Tigrou
                                        Chère communauté,
                                        Cordialement,
                                        Tigrou
                                        code_text
                                        • T Tigrou
                                          Chère communauté,
                                          Cordialement,
                                          Tigrou
                                          code_text
                                          @Tigrou tu as tout bien fait jusqu'à ce point
                                          RX c'est GPIO13 c'est indiqué ici, tu n'as pas appliqué le templates esp8266 tout prêt ?
