  5. Denky D4 + Tempo
Denky D4 + Tempo
23 Posts 5 Posters 6.2k Views 3 Watching
    @Nicolas-Bernaerts ah excellent et joli en plus 🙂
    @Charles Merci 😚
      @Tostaky
      C'est pas normal, tu dois avoir une trace de STEG comme c'est codé ici et du dois aussi l'avoir dans la trame MQTT si c'est configuré non?
      Tostaky
        @Tostaky
        Tostaky
        wrote on last edited by Tostaky
        @Charles said in Denky D4 + Tempo:
        @Tostaky
        Pas de MQTT pour moi. Néanmoins, j'ai des gros doigts. STGE != STEG.
        21:03:25.957 RSL: SENSOR = {"Time":"2023-12-06T21:03:25","ENERGY":{"TotalStartTime":"2023-12-06T09:54:49","Total":14623.401,"Yesterday":14.950,"Today":4.984,"Period":[0,0,0],"Power":[0,227,336],"ApparentPower":[0,227,336],"ReactivePower":[0,0,0],"Factor":[0.00,1.00,1.00],"Voltage":[238,224,241],"Current":[0.000,1.000,1.000],"Load":0},"TIC":{"ADSC":"022076***","VTIC":2,"NGTF":"TEMPO","LTARF":"HP  ROUGE","EAST":14623401,"EASF01":6659364,"EASF02":7829254,"EASF03":76043,"EASF04":30388,"EASF05":16803,"EASF06":11549,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":9237921,"EASD02":2600419,"EASD03":1209456,"EASD04":1575605,"EAIT":3127874,"ERQ1":1964972,"ERQ2":362712,"ERQ3":54345,"ERQ4":927425,"IRMS1":0,"IRMS2":1,"IRMS3":1,"URMS1":238,"URMS2":224,"URMS3":241,"PREF":9,"PCOUP":9,"SINSTS":595,"SINSTS1":31,"SINSTS2":227,"SINSTS3":336,"SMAXSN":3380,"SMAXSN1":1090,"SMAXSN2":1030,"SMAXSN3":1300,"SMAXSN-1":6480,"SMAXSN1-1":3090,"SMAXSN2-1":2670,"SMAXSN3-1":1390,"SINSTI":0,"SMAXIN":2710,"SMAXIN-1":260,"CCASN":390,"CCASN-1":426,"CCAIN":0,"CCAIN-1":0,"UMOY1":236,"UMOY2":224,"UMOY3":240,"STGE":"9B3AD501","PRM":****,"RELAIS":0,"NTARF":6,"NJOURF":0,"NJOURF+1":0}}
        STGE = xBxxxxx => B = 1011 => aujourd'hui rouge (3), demain blanc (2).
        L'interface affiche toujours rouge / rouge
        @Nicolas-Bernaerts said in Denky D4 + Tempo:
        @Tostaky @localhost61 @Charles Hello,
        Pour information, je suis en train d'intégrer la lecture des données Tempo de RTE dans mon fork Tasmota Teleinfo.
        Un nouveau topic MQTT sera disponible afin de récupérer les données :
        .../sensor/TEMPO
            {"Time":"2022-10-10T23:51:09", "Tempo":{"J-1":"bleu","J":"blanc","J+1":"rouge"}}
        Pour récupérer ces données, il faudra simplement avoir créé un compte sur le site RTE et généré sa clé privée (même compte que pour Ecowatt).
        Je pense pouvoir publier cette nouvelle version d'ici 1 ou 2 jours.
        Génial.
        Je viens de terminer mon alerting mail en m'appuyant sur l'API publique d'EDF. Pas besoin de compte et de clef d'API.
        Le code est là : https://github.com/sosandroid/Monitoring_Energie/tree/main/src/tempo
          .../sensor/TEMPO
          Je viens de publier une version Teleinfo v13.2 qui gère :
          • Tempo
          • Ecowatt v4 et v5
          Attention, le fichier de configuration sur le littlefs est maintenant rte.cfg (au lieu de ecowatt.cfg).
          Si vous aviez déclaré Ecowatt précédemment, il faudra :
          • redéclarer votre clé privée via rte_key maclebase64
          • activer ecowatt de nouveau via eco_enable 1
          • activer tempo via tempo_enable 1
          • redémarrer l'ESP
          L'aide est disponible en mode console via rte_help.
          WendigogoW 1 Reply Last reply
          • T Tostaky
            @Tostaky
            .../sensor/TEMPO
            Génial.
            @Tostaky said in Denky D4 + Tempo:
            je comprends pas j'ai testé le même code et aucun soucis
            https://onlinegdb.com/_VnKGhRZ5
            #include <stdio.h>
            #include <stdlib.h>
            #include <stdint.h>
            int main()
                uint32_t status_register = strtol("9B3AD501", NULL, 16);
                printf("Status Register is 0x%08X\r\n", status_register);
                if (status_register >> 24) {
                    char txt[32];
                    uint8_t sr = status_register >> 24;
                    uint8_t val = sr & 0x03;
                    if (val) {
                        printf("Jour %s\r\n", val==1?"Bleu":val==2?"Blanc":"Rouge");
                    val = (sr >> 2) & 0x03;
                    if (val) {
                        printf("Demain %s\r\n", val==1?"Bleu":val==2?"Blanc":"Rouge");
                    val = (sr >> 4) & 0x03;
                    if (val) {
                        printf("Préavis pointe mobile %d\r\n", val);
                    val = (sr >> 6) & 0x03;
                    if (val) {
                        printf("Pointe mobile en cours %d\r\n", val);
                return 0;
            La sortie donne bien ça
            Status Register is 0x9B3AD501
            Jour Rouge
            Demain Blanc
            Préavis Pointe mobile 1
            Pointe mobile En cours 2
            peut être essayer cette 2eme méthode au cas ou (avec aussi le strtol changé en strtoul)
            https://onlinegdb.com/ADbvc4273
            #include <stdio.h>
            #include <stdlib.h>
            #include <stdint.h>
            int main()
                uint32_t status_register = strtoul("9B3AD501", NULL, 16);
                    char txt[32];
                    char coul[4][6] = { "----", "Bleu", "Blanc", "Rouge" };
                    if (val) {
                        printf("Jour %s\r\n", coul[val]);
                    if (val) {
                        printf("Demain %s\r\n", coul[val]);
                    if (val) {
                    if (val) {
                return 0;
                return 0;
            qui donne la même chose mais codé différemment, t'as moyen de tester ?
            T 1 Reply Last reply
              • Tempo
              • Ecowatt v4 et v5
              • redémarrer l'ESP
              WendigogoW Offline
              WendigogoW Offline
              Wendigogo
              @Nicolas-Bernaerts : Excellent !
              Je mets à jour le Denky-D4.
              Tu penses inclure le code de @Tostaky pour ne plus avoir à créer de compte EDF ?
              • WendigogoW Wendigogo
                @Wendigogo En fait, le problème est double :
                • les API EDF répondent quand elles veulent ... elles peuvent mettre 10s a répondre et l'ESP reboot en watchdog
                • elles sont très en retard par rapport à RTE : RTE donne l'info vers 9h, EDF souvent après 11h
                  Donc les données RTE sont beaucoup plus fiables sur les 2 aspects.
                  @Wendigogo Je suis en train de voir comment exploiter l'etiquette STGE pour recuperer ces donnees directement depuis le compteur. Mais il reste a verifier la fiabilite et la prevenance.
                    WendigogoW Offline
                    WendigogoW Offline
                    Wendigogo
                    @Nicolas-Bernaerts : Merci pour ces explications. J'ai créé un compte RTE du coup.
                      #include <stdio.h>
                      #include <stdlib.h>
                      #include <stdint.h>
                      int main()
                              char txt[32];
                              if (val) {
                              if (val) {
                              if (val) {
                              if (val) {
                          return 0;
                      Jour Rouge
                      Demain Blanc
                      #include <stdio.h>
                      #include <stdlib.h>
                      #include <stdint.h>
                      int main()
                              char txt[32];
                              if (val) {
                              if (val) {
                              if (val) {
                              if (val) {
                          return 0;
                          return 0;
                      Tostaky
                      #include <stdio.h>
                      #include <stdlib.h>
                      #include <stdint.h>
                      int main()
                              char txt[32];
                              if (val) {
                              if (val) {
                              if (val) {
                              if (val) {
                          return 0;
                      Jour Rouge
                      Demain Blanc
                      #include <stdio.h>
                      #include <stdlib.h>
                      #include <stdint.h>
                      int main()
                              char txt[32];
                              if (val) {
                              if (val) {
                              if (val) {
                              if (val) {
                          return 0;
                          return 0;
                      Je n'ai pas modifié de code coté Denky car j'ai pris un firmware déjà compilé.
                      A la lecture du code, je suis 100% d'accord avec le fonctionnement.
                      Comme le script Berry accède à la valeur STGE et la décode correctement pour la transmettre à EmonCMS, j'en déduis que c'est quelque part entre la libteleinfo et l'affichage.
                      C'est plus à titre informatif que je fais remonter car j'utilise peu l'affichage
                        Tostaky
                        Pour continuer sur ce sujet, j'ai essayé de passer sur le firmware de @Nicolas-Bernaerts. Les différents retours que j'ai pu lire est que cela améliore la comptabilisation de l'énergie entre Enedis, le Denky et EmonCMS.
                        Aujourd'hui j'utilise un firmware "standard" et un script Berry pour alimenter EmonCMS toutes les 8500ms.
                        En passant à la version 14.9beta de @Nicolas-Bernaerts, je n'ai plus de données qui remlontent. Le script Berry ne fonctionne plus.
                        J'ai fait un rollback et tout est rentré dans l'ordre.
                        Néanmoins, je voudrais tester ce firmware. De manière à préparer le script avant (je n'ai pas accès au Denky avant le WE prochain), est-il possible de valider que le script simplifié suivant
                        var payload = {}
                        def rule_tic(value, trigger)
                          payload['IDX_SOUT'] = value['EAST']
                          payload['IDX_SOUT_HP'] = value['EASF02']
                          payload['IDX_SOUT_HC'] = value['EASF01']
                          payload['IDX_INJ'] = value['EAIT']
                          payload['PUI_SOUT'] = value['SINSTS']
                          payload['PUI_INJ'] = value['SINSTI']
                        end
                        def start()
                          # fire first post in 5s
                          tasmota.set_timer(5000, send_emoncms)
                        end
                        def send_emoncms()
                        end
                        devient
                        var payload = {}
                        def rule_meter (value, trigger)
                          payload['PUI_SOUT'] = value['W']
                          payload['PUI_INJ'] = value['PW']
                        end
                        def rule_contract (value, trigger)
                          payload['IDX_SOUT'] = value['CONSO']
                          payload['IDX_INJ'] = value['PROD']
                        end
                        def send_emoncms()
                        end
                        def start()
                          tasmota.add_rule("METER",rule_meter)
                          tasmota.add_rule("CONTRACT",rule_contract)
                        end
                        • T Tostaky
                          var payload = {}
                          end
                          def start()
                          end
                          def send_emoncms()
                          end
                          devient
                          var payload = {}
                          end
                          end
                          def send_emoncms()
                          end
                          def start()
                          end
                          Tostaky
                          Evidement, ces lignes sont en trop
