  5. Trames corrompues MQTT
  • L labu73
    Youpi, plus rien ne marche 🙂
    J'en conclus que ma ligne est excessivement parasitée et qu'il faut que je revoie le cablage. D'un autre côté, commment cela pouvait il fonctionner?
    Je pense que l'ancien Firmware ne voyait rien.
    00:00:00.052 UFS: FlashFS mounted with 4396 kB free
    00:00:00.076 CFG: Loaded from File, Count 120
    00:00:00.086 QPC: Count 1
    00:00:00.240 BRY: Berry initialized, RAM used=4071 bytes
    00:00:00.314 CFG: Energy loaded from file
    00:00:00.315 NRG: Init driver 15
    00:00:00.325 Project tasmota - Tasmota Version 12.4.0.1(teleinfo)-2_0_7(2023-02-27T16:47:33)
    00:00:00.327 TIC: RX on GPIO8, baudrate 9600
    00:00:00.329 TIC: Raw mode enabled
    00:00:00.340 TIC: Sending only one frame over 14
    00:00:01.201 WIF: Connecting to AP1 LoEtLo Channel 7 BSSId C0:06:C3:69:A2:B2 in mode 11n as Linky-5592...
    00:00:01.992 WIF: Connected
    00:00:02.251 HTP: Web server active on Linky-5592 with IP address 192.168.68.20
    09:49:30.260 MQT: Attempting connection...
    09:49:30.297 MQT: Connected
    09:49:30.301 MQT: tele/Linky/LWT = Online (retained)
    09:49:30.303 MQT: cmnd/Linky/POWER =
    09:49:30.308 MQT: tele/Linky/INFO1 = {"Info1":{"Module":"Denky D4 (v1.1)","Version":"12.4.0.1(teleinfo)","FallbackTopic":"cmnd/DVES_D6D5D8_fb/","GroupTopic":"cmnd/tasmotas/"}}
    09:49:30.323 MQT: tele/Linky/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"Linky-5592","IPAddress":"192.168.68.20","IP6Global":"","IP6Local":"fe80::3283:98ff:fed6:d5d8"}}
    09:49:30.337 MQT: tele/Linky/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":20}}
    09:49:30.350 MQT: stat/Linky/RESULT = {"POWER":"OFF"}
    09:49:30.355 MQT: stat/Linky/POWER = OFF
    09:49:32.492 LibTeleinfo::checkLine frame format error, total=1
    09:49:32.894 QPC: Reset
    09:49:33.902 MQT: tele/Linky/STATE = {"Time":"2023-02-28T09:49:33","Uptime":"0T00:00:07","UptimeSec":7,"Heap":168,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Berry":{"HeapUsed":3,"Objects":45},"POWER":"OFF","Dimmer":0,"Color":"000000","HSBColor":"0,0,0","Channel":[0,0,0],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"LoEtLo","BSSId":"C0:06:C3:69:A2:B2","Channel":7,"Mode":"11n","RSSI":68,"Signal":-66,"LinkCount":1,"Downtime":"0T00:00:03"}}
    09:49:33.956 TIC: bad checksum for SMAXSN
    09:49:33.957 TIC: bad checksum for SMAXSN1
    09:49:33.957 TIC: bad checksum for SMAXSN2
    09:49:33.966 MQT: tele/Linky/SENSOR = {"Time":"2023-02-28T09:49:33","ENERGY":{"TotalStartTime":"2023-01-29T09:53:32","Total":1259.411,"Yesterday":27.862,"Today":15.406,"Period":[0,0,0],"Power":[237,0,0],"ApparentPower":[237,0,238],"ReactivePower":[0,0,238],"Factor":[1.00,0.00,0.00],"Voltage":[237,238,238],"Current":[1.000,0.000,1.000],"Load":1},"TIC":{"ADSC":"022276116693","VTIC":2,"NGTF":"TEMPO","LTARF":"HP  BLANC","EAST":1259411,"EASF01":918154,"EASF02":108799,"EASF03":106299,"EASF04":110144,"EASF05":8101,"EASF06":7914,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1032554,"EASD02":226857,"EASD03":0,"EASD04":0,"IRMS1":1,"IRMS2":0,"IRMS3":1,"URMS1":237,"URMS2":238,"URMS3":238,"PREF":12,"PCOUP":12,"SINSTS":479,"SINSTS1":281,"SINSTS2":38,"SINSTS3":158}}
    09:49:35.442 LibTeleinfo::checkLine frame format error, total=2
    09:49:36.458 TIC: bad checksum for SMAXSN
    09:49:36.459 TIC: bad checksum for SMAXSN1
    09:49:36.460 TIC: bad checksum for SMAXSN2
    09:49:36.461 TIC: bad checksum for SMAXSN3
    09:49:36.472 TIC: bad checksum for SMAXSN-1
    09:49:36.473 TIC: bad checksum for SMAXSN1-1
    09:49:36.474 TIC: bad checksum for SMAXSN2-1
    09:49:36.485 TIC: bad checksum for SMAXSN3-1
    09:49:36.485 TIC: bad checksum for CCASN
    09:49:36.486 TIC: bad checksum for CCASN-1
    09:49:36.487 TIC: bad checksum for UMOY1
    09:49:36.498 TIC: bad checksum for UMOY2
    09:49:36.499 TIC: bad checksum for UMOY3
    09:49:36.500 TIC: bad checksum for FPM1
    09:49:37.615 LibTeleinfo::checkLine frame format error, total=3
    09:49:39.438 TIC: bad checksum for SMAXSN
    09:49:39.439 TIC: bad checksum for SMAXSN1
    09:49:39.440 TIC: bad checksum for SMAXSN2
    09:49:39.441 TIC: bad checksum for SMAXSN3
    09:49:39.452 TIC: bad checksum for SMAXSN-1
    09:49:39.453 TIC: bad checksum for SMAXSN1-1
    09:49:39.454 TIC: bad checksum for SMAXSN2-1
    09:49:39.465 TIC: bad checksum for SMAXSN3-1
    09:49:39.466 TIC: bad checksum for CCASN
    09:49:39.467 TIC: bad checksum for CCASN-1
    09:49:39.468 TIC: bad checksum for UMOY1
    09:49:39.479 TIC: bad checksum for UMOY2
    09:49:39.480 TIC: bad checksum for UMOY3
    09:49:39.482 TIC: bad checksum for FPM1
    09:49:40.094 LibTeleinfo::checkLine frame format error, total=4
    @labu73 j'ai fait un fix vite fait y'a peut être des soucis, tu peux taper dans la console la commande
    EnergyConfing Stats 1 et mettre une copie de l'écran d'accueil après ?
    L 1 Reply Last reply
      labu73
      Il passe une trame de temps en temps, ce qui met à jour mon HA.
      Sinon, voici l'écran et les états depuis 2h
      • L labu73
        @labu73 yes tu as raison je viens de tester chez moi en mode standard j'ai le meme soucis, je vais regarder ça
          labu73
          Merci d'avance, j'aime être le beta testeur moi qui passe mon temps à me faire debugger mes programmes automatismes et robotique industrielle.
          Bon courage,
          Laurent
          • L labu73
            Bon courage,
            Laurent
            @labu73
            Tout est rentré dans l'ordre avec cette PR le temps que ce soit mergé et build dans tasmota-special voici le FW à flasher (ESP32 seulement)
              @labu73
              labu73
              Tout est rentré dans l'ordre, merci.
                NPO
                Bonjour à tous 🙂
                Je rencontre également des problèmes de checksum récurrents bien que j'ai déplacé mon module au plus prés du compteur
                12:13:21.043 TIC: bad checksum for FPM2
                12:13:21.046 TIC: bad checksum for SMAXSN
                12:13:21.048 TIC: bad checksum for DPM2
                12:13:21.050 TIC: bad checksum for SHNSTS
                12:13:21.051 TIC: bad checksum for UMOY1
                12:13:21.063 TIC: bad checksum for EASD02 01203695
                12:13:21.065 TIC: bad checksum for SL@XSN
                12:13:21.070 LibTeleinfo::checkLine Err checksum 0x49 != 0x2E (total errors=3788)
                12:13:21.073 LibTeleinfo::checkLine Err checksum 0x52 != 0x27 (total errors=3789)
                12:13:21.085 LibTeleinfo::checkLine Err checksum 0x23 != 0x33 (total errors=3790)
                12:13:21.287 LibTeleinfo::checkLine Err checksum 0x33 != 0x34 (total errors=3791)
                12:13:21.290 LibTeleinfo::checkLine Err checksum 0x24 != 0x25 (total errors=3792)
                12:13:21.302 LibTeleinfo::checkLine Err checksum 0x39 != 0x3A (total errors=3793)
                12:13:21.304 LibTeleinfo::checkLine Err checksum 0x41 != 0x42 (total errors=3794)
                12:13:21.316 LibTeleinfo::checkLine frame format error, total=879
                12:13:21.318 LibTeleinfo::checkLine Err checksum 0x2D != 0x3F (total errors=3795)
                12:13:21.331 LibTeleinfo::checkLine Err checksum 0x39 != 0x3B (total errors=3796)
                12:13:21.333 LibTeleinfo::checkLine Err checksum 0x2C != 0x3D (total errors=3797)
                12:13:21.346 LibTeleinfo::checkLine Err checksum 0x2C != 0x29 (total errors=3798)
                je viens d'essayer le firmware mais impossible de flasher car erreur suivante "Invalid file signature"
                Merci pour votre aide !!!
                • N NPO
                  Bonjour à tous 🙂
                  @NPO le build est maintenant dispo ici pour toutes les plateformes.
                  tu es bien en ESP32 et tu essaies de flasher via l'interface WEB ?
                  N 2 Replies Last reply
                    NPO
                    @Charles c'est bien une ESP32 😉
                    Par ailleurs j'ai téléchargé le fichier "tasmota32c3-teleinfo.bin" et j'ai une erreur "Upload failed. Enable logging 3" et j'ai tenté avec "tasmota32-teleinfo.factory.bin" et j'ai ""Invalid file signature" en erreur ...
                      NPO
                      @Charles complément ...
                      c'est bien une ESP32 et j'ai tenté la mise a jour par la web UI ... (c'est mieux quand on lis les questions jusqu'au bout !)
                      Finalement j'ai flashé "en dur" et ça a fonctionné mais j'ai toujours des erreurs de checksum ...
                      Y'a t'il un lien avec le fait que les trames MQTT ne sont pas formatées en JSON ?
                      je m'explique la première trame reçue par le broker est bien en JSON mais pas les suivantes ...
                        labu73
                        Vu que je suis en Tempo triphasé, mon compteur cause beaucoup mais avec un bon format json
                        16:20:51.039 MQT: tele/Linky/SENSOR = {"TIC":{"ADSC":"022276116693","VTIC":2,"NGTF":"TEMPO","LTARF":"HP  ROUGE","EAST":1291834,"EASF01":918154,"EASF02":108799,"EASF03":121563,"EASF04":122694,"EASF05":8101,"EASF06":12523,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1047818,"EASD02":244016,"EASD03":0,"EASD04":0,"IRMS1":1,"IRMS2":1,"IRMS3":1,"URMS1":241,"URMS2":241,"URMS3":241,"PREF":12,"PCOUP":12,"SINSTS":518,"SINSTS1":228,"SINSTS2":125,"SINSTS3":162,"SMAXSN":7010,"SMAXSN1":2560,"SMAXSN2":2080,"SMAXSN3":2360,"SMAXSN-1":7010,"SMAXSN1-1":2830,"SMAXSN2-1":2100,"SMAXSN3-1":2330,"CCASN":390,"CCASN-1":504,"UMOY1":240,"UMOY2":241,"UMOY3":239,"STGE":"833A5401","DPM2":0,"FPM2":0,"PRM":2147483647,"RELAIS":0,"NTARF":6,"NJOURF":0,"NJOURF+1":0}}
                        J'ai encore des trames bizarres sur la fin mais il semble que cela reste un json correct voir le tag 30300113310000 en fin de trame après quelques temps
                        16:12:47.687 MQT: tele/Linky/SENSOR = {"TIC":{"ADSC":"022276116693","VTIC":2,"NGTF":"TEMPO","LTARF":"HP  ROUGE","EAST":1291776,"EASF01":918154,"EASF02":108799,"EASF03":121563,"EASF04":122694,"EASF05":8101,"EASF06":12465,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1047818,"EASD02":243958,"EASD03":0,"EASD04":0,"IRMS1":1,"IRMS2":1,"IRMS3":1,"URMS1":240,"URMS2":242,"URMS3":240,"PREF":12,"PCOUP":12,"SINSTS":504,"SINSTS1":205,"SINSTS2":137,"SINSTS3":161,"SMAXSN":7010,"SMAXSN1":2560,"SMAXSN2":2080,"SMAXSN3":2360,"SMAXSN-1":7010,"SMAXSN1-1":2830,"SMAXSN2-1":2100,"SMAXSN3-1":2330,"CCASN":390,"CCASN-1":504,"UMOY1":239,"UMOY2":240,"UMOY3":239,"STGE":"833A5401","DPM2":0,"FPM2":0,"PRM":2147483647,"RELAIS":0,"NTARF":6,"NJOURF":0,"NJOURF+1":0,"30301131000":237}}
                        Je continue de surveiller cela, mais pour le moment je récupère des trames cohérentes.
                        MErci
                        N 1 Reply Last reply
                        • L labu73
                          MErci
                          NPO
                          #24
                          @labu73 Aucune amélioration de mon coté ... il me semble que @Charles a évoqué un probleme sur les trames standard ...
                          68a9ef08-a61e-4689-9e89-ba0e9385ed40-image.png Capture d’écran 2023-03-01 à 18.25.53
                          Et en sortie mes trames ne sont toujours pas correctement formatées en JSON
                            "Time": "2023-03-01T18:28:15",
                            "ENERGY": {
                              "TotalStartTime": "2023-03-01T18:17:53",
                              "Total": 14538.407,
                              "Yesterday": 0,
                              "Today": 0,
                              "Period": 0,
                              "Power": 153,
                              "ApparentPower": 237,
                              "ReactivePower": 181,
                              "Factor": 0.65,
                              "Voltage": 237,
                              "Current": 1,
                              "Load": 3
                            "TIC": {
                              "VTIC": 2,
                              "NGTF": "TEMPO",
                              "EAST": 14538407,
                              "EASF01": 12734205,
                              "EASF02": 1714927,
                              "EASF04": 38258,
                              "EASF05": 15195,
                              "EASF07": 0,
                              "EASF09": 0,
                              "EASF10": 0,
                              "EASD04": 2593655,
                              "IRMS1": 1,
                              "URMS1": 237,
                              "PREF": 6,
                              "PCOUP": 6,
                              "SMAXSN": 287,
                              "PRM": 2147483647,
                              "RELAIS": 0,
                              "NTARF": 6,
                              "NJOURF": 0,
                              "NJOURF+1": 0,
                              "LTARF": "HP  ROUGE",
                              "EASF03": 29956,
                              "EASF06": 5866,
                              "EASD01": 7258333,
                              "EASD02": 3482724,
                              "EASD03": 1203695,
                              "SINSTS": 153,
                              "SMAXSN-1": 2494,
                              "UMOY1": 231,
                              "DPM2": 0,
                              "P@OINTE": "000040 5 06004006 2"004005 NONUTILE NONUTILE NONUTILE NONETILE NONUTILE NONUTILE NONUTILE NONUTILE",
                              "ADSC": "031662280532",
                              "STGE": "83DAD401",
                              "FPM2": 0,
                              "EASF08": 0,
                              "CINSTS": 156
                          J'ai vu qu'une API HTTP existe depuis l'interface web mais je ne trouve pas comment elle fonctionne ... tu aurais une idée ?
                            labu73
                            En tout cas la situation s'est améliorée, mais j'ai effectivement ce matin une nouvelle trame corrompue.
                            Vu que les tags semblent se créer tout seuls à leur découverte, je suppose que mon dernier tag est lié à un problème de mauvaise réception ou de débordement de buffer.
                            Ne faudrait il pas avoir un dictionnaire des tags valides afin de rejeter les mauvais?
                            Une autre hypothèse vérifer que les tags reçus sont dans la table ASCII?
                            07:17:45.160 MQT: tele/Linky/SENSOR = {"TIC":{"ADSC":"022276116693","VTIC":2,"NGTF":"TEMPO","LTARF":"HP  ROUGE","EAST":1316060,"EASF01":918154,"EASF02":108799,"EASF03":121563,"EASF04":122694,"EASF05":28448,"EASF06":16402,"EASF07":0,"EASF08":0,"EASF09":0,"EASF10":0,"EASD01":1068165,"EASD02":247895,"EASD03":0,"EASD04":0,"IRMS1":1,"IRMS2":0,"IRMS3":1,"URMS1":237,"URMS2":238,"URMS3":238,"PREF":12,"PCOUP":12,"SINSTS":408,"SINSTS1":207,"SINSTS2":42,"SINSTS3":159,"SMAXSN":7100,"SMAXSN1":2610,"SMAXSN2":2140,"SMAXSN3":2350,"SMAXSN-1":7010,"SMAXSN1-1":2560,"SMAXSN2-1":2080,"SMAXSN3-1":2490,"CCASN":578,"CCASN-1":316,"UMOY1":236,"UMOY2":238,"UMOY3":237,"STGE":"833A5401","DPM2":0,"FPM2":0,"PRM":2147483647,"RELAIS":0,"NTARF":6,"NJOURF":0,"NJOURF+1":0,"SINSS":605}}
                            Bonne Journée à tous
                            N CharlesC 2 Replies Last reply
                            • L labu73
                              NPO
                              @labu73 merci pour ta réponse !
                              En consultant le forum, je me rend compte que je rencontre exactement le même problème que @Samquad "Tasmota sensor 12.1.1.2 avec linky mode Standard --> Libteleinfo checkline error checksum..." et qui malheureusement n'a pas trouvé de solution et/ou explication au dysfonctionnement ...
                              • L labu73
                                #27
                                @labu73
                                Oui ce serait une solution mais il faut tous les lister et les rentrer. Mais normalement les TAG sont vérifiés avec la checksum avant sauvegarde en mémoire et sont vérifiés à nouveau lors de l'envoi (le fix de ce W.E.) donc je ne comprends pas comment c'est possible ou par le plus grand des malheurs parfois une mauvaise étiquette à une bonne cheksum.
                                Une autre hypothèse vérifier que les tags reçus sont dans la table ASCII?
                                Correct ça peut être une vérification supplémentaire, il faudrait que j'ajoute lors de l'envoi un scan des mauvaises (selon ces 2 principes) pour les supprimer de la liste aussi mais j'ai pas eu le temps ce W.E.
                                Une autre idée serait de tester sur la même installation le Firmware de @Nicolas-Bernaerts aussi pour voir comment ça se comporte.
                                Pour info depuis que j'ai les stats j'ai aussi quelques erreurs parfois, regarde en 48H
                                671 erreurs de checksum sachant qu'il y a 256 possibilité de checksum différentes et que seul 64 sont valides (de mémoire) il y a effectivement possibilité de tomber sur une valide de temps en temps ce qui pourrait expliquer simplement sans forcement de bug dans le code, intéressant
                                • N NPO
                                  @NPO il y a 2 soucis en fait, parfois les Linky sont plus ou moins sensibles et certains nécessitent une correction de résistance sur la carte (les prochains batch ont un potentiomètre pour pallier directement)
                                  Tu peux vérifier aussi avec les soft de test de la libteleinfo pour voir si tes trames sont cohérente dans un 1er temps.
                                  CharlesC N 3 Replies Last reply
                                    #29
                                    @labu73
                                    Pour info j'ai encore ajouté des checks supplémentaires de caractères valides avec cette PR tu me diras si c'est mieux ?
                                    version ESP32 en attendant le prochain autobuild firmware.bin.zip
                                    F L 2 Replies Last reply
                                      @labu73
                                      FredLo
                                      Bonjour Charles et bonjour Messieurs,
                                      Je vais suivre avec attention ce fils de discussion car j'ai constaté le même problème chez moi.
                                      Mon Denky D4 est en batterie depuis seulement quelques jours (sur un Linky en mode Standard), et j'ai déjà été obligé de le redémarrer 2 fois. La cause est toujours la même, un des tags du TIC contient un caractère étrange et la payload MQTT n'est plus considérée comme du JSON valide. Ce TAG est toujours un duplicata d'un TAG valide ce qui me fait également penser qu'il a été corrompu (avant ou après Cheksum) puis ajouté à la liste des TAGs.
                                      Du coup, même si je reçois toujours un flot d'information MQTT sur mon Jeedom, les données ne sont plus dispatchées. J'envisage un scenario Jeedom qui redémarre le Denky si aucune données n'est dispatchée pendant plus d'une minute, mais régler le problème à la source est pas mal non plus 🙂
                                      Je vais donc d'abord vérifier la qualité de réception des informations sur le Denky D4 (volume de checksum NOK) puis tester les firmwares alternatifs proposés.
                                      Bonne journée.
                                        @labu73
                                        labu73
                                        Installée, je vais voir ce que cela donne mais 2 bad checksums par trame.
                                        Par contre les trames sont correctes en json.
                                        J'a remis en Skip 0 pour forcer le trait avec une trame toutes les 5s, a suivre pour voir si le problème réapparait.
                                          NPO
                                          @Charles Merci pour tes réponses; au risque de passer pour un idiot 🙂 pourrais tu me dire quel sketch utiliser pour les tests de trames ? Merci
