  3. Blog articles comments
lifefilesystemcardlogend
    mocart2
    Hello! Can anybody help me with user crontab file? I have problem: i installed raspbian in Read-only mode, i have some scripts, (cron jobs) that works every 5 minutes, 10 etc. I set it by crontab -e command, but after reboot, system is clean it, i think, because i moved /var/spool dir to tmpfs (like howto), and user cronjob file stored at /var/spool/cron/crontabs dir. How i can fix it for not clearing after system reboot? Thanks!
      Cavallonzio
      Did anyone figured out how to use crontab? it is wiped after reboot and i really need it 😞
        We need to put the system into Read Write Mode before changing the crontab
        If you followed this tuto should be something like that
        sudo mount -o remount,rw /
        Then edit your crontab
        sudo crontab -e
        put pack in Read Only or reboot
        sudo mount -o remount,ro /
        • Damian MacD Offline
          Damian MacD Offline
          Damian Mac
          Charles you are going wrong. crontab -e give us file on /tmp which has been deleted on boot. We need to go this way:
          rw
          sudo su
          nano /etc/crontab (dont forget to add user) example below:
                  • root /usr/bin/vpncheck.sh > /dev/null 2>&1
            Neoromantic
            Hello Charles,
            I was wondering if I don't have entry about /tmp being a mount entry point for tmpfs neither in fstab nor mtab, what would be the point in moving things there? Am I missing something or?
            I am playing with Raspberry PI-2 and Raspbian Jessie.
              R Offline
              ricky
              • Rok JarcR Offline
                Rok JarcR Offline
                Rok Jarc
                Great article, thanx! To be able to use sudo i did have to add this line to /etc/fstab as well:
                tmpfs /var/lib/sudo/ts tmpfs nosuid,nodev 0 0
                  dev
                  Has this tutorial worked for anyone? The 1st error is saw was under Move files to temp filesystem after running:
                  touch /tmp/dhcpcd.resolv.conf; ln -s /tmp/dhcpcd.resolv.conf /etc/resolv.conf
                  Failed to create symbolic link ‘etc/resolv.conf’ file exists. Next after reboot see errors regarding “a start job is running for dhcpd on all interfaces..." The raspi fails to boot and see pi@raspberrypi: prompt. Thanks in advance for any insights!
                    Antoine Megens
                    I don't seem to be able to copy/paste from your crayon syntax highlighter widgets? The copy button doesn't work, nor does the button to expand the code.
                      Piotr Mackowiak
                      OK, nice tutorial. But where (I mean about file) I have to place:
                      rm -rf /var/lib/dhcp/ /var/lib/dhcpcd5 /var/run /var/spool /var/lock /etc/resolv.conf
                      ln -s /tmp /var/lib/dhcp
                      ln -s /tmp /var/lib/dhcpcd5
                      ln -s /tmp /var/run
                      ln -s /tmp /var/spool
                      ln -s /tmp /var/lock
                        E Offline
                        Elliott Balsley
                        Nice guide. I used it on Stretch.
                        • I had to symlink /var/lib/sudo/ts to /tmp because it gives an error every time running sudo, then I made a systemd service to make that folder
                        • The /tmp/random-seed file does not get created at startup, even though I added the ExecStartPre line. It says success, but I can't figure out why that file isn't being created:
                          Process: 97 ExecStartPre=/bin/echo a > /tmp/random-seed (code=exited, status=0/SUCCESS)
                        • Stretch uses systemd-timesyncd, so there's no need for ntp and it would conflict.
                        • I like the bash_logout idea to mount ro, but it fails because mount: only root can use "--options" option
                        • Fail2ban isn't working. Anybody know if it's possible to configure that to monitor the busybox ring buffer?
                        • H Offline
                          H Offline
                          HemantJoshi
                          I am following this article in order avoid any/every write to /var/log/ (for example /var/log/wtmp, /var/log/last.log etc.
                          Is it possible?
                          Note that by disabling rsyslog.service, I could suppress write to messages and syslog files.
                          Using systemd mask operation I could mask systemd-update-utmp.service and systemd-update-utmp-runlevel.service. However the wtmp and lastlog files are still updated.
                          Please advise.
                          • H Offline
                            H Offline
                            hernaninf
                            Great article, thanks! Can I use this tip to make a Pi print server for some voucher printers and it stay well when it be turned off? Do you suggest some type of memory to be installed on Pi in order to run this way?
