  3. Blog articles comments
lifefilesystemcardlogend
    I also updated to avoid the random-seed file problem
      Bruce Aldridge
      I've used this multiple times, great resource.
      One thing that could be made clearer is the tmpfs additions to fstab, I missed them and couldn't ssh in
        Christian Ferbar
        Thanks a lot for this tutorial!
        On debian jessie /usr/lib/tmpfiles.d/var.conf chmods /var/spool to 0755. This means that /tmp is changed to 0755 as well because we changed /var/spool to point to /tmp. So the /var/spool line in /usr/lib/tmpfiles.d/var.conf has to be commented out.
        /run and /run/lock are tmpfs already, maybe they are better softlink targets than /tmp.
        • X Offline
          X Offline
          xproto
          @Bruce Aldridge
          I cannot SSH too, to my RPi. What I did is I created a symlink for sshd
          ln -s /tmp /var/run/sshd
          Great article btw Charles! :). Thanks!
          • X Offline
            X Offline
            xproto
            Update: My mistake I missed the sysmlink for /var/run.
            No need for my first comment.
            v
            v
            v
              J Offline
              Joo
              There is a (rather new) Olimex single board card with onboard 4GB eMMC MLC/SLC Flash
              Do you think this could be an answer to the corruption of data for an always on card ?
              (with regular backup...of cours...) or the problem is not related to SD card ???
              thx.
                notmichael
                I tried this tutorial twice and both times couldn't SSH in after the final reboot. I found this tutorial a little more helpful - http://petr.io/en/blog/2015/11/09/read-only-raspberry-pi-with-jessie/. I susptec the difference was the part they mentione specifically enables SSH after changing these settings. That tutorial also makes it a little more clear that you have to add three lines in /etc/fstab, not just add ro twice.
                • I Offline
                  I Offline
                  Ing.Fernando
                  Hi I successfully made my Pi Zero v 1.3 Read Mode, but a problem came up when I was trying to connect to internet with a 3g usb dongle.
                  First, the modem get connected to internet, but after a minute or less, it losed the connection, and then it reconnects, and the same story was looping forever.
                  After thinking, the problem was the DNS, because when the modem connects to internet, it changes the default DNS and tried to write the new DNS to the default file, here is the problem, the modem didn't notice that he cant write to the SD!
                  I took the solution from here: https://github.com/emoncms/emoncms/blob/master/docs/RaspberryPi/read-only.md
                  touch /tmp/resolv.conf
                  sudo rm /etc/resolv.conf
                  sudo ln -s /tmp/resolv.conf /etc/resolv.conf
                  touch /tmp/resolv.conf.dhclient-new
                  sudo chmod 777 /tmp/resolv.conf.dhclient-new
                  sudo rm /etc/resolv.conf.dhclient-new
                  sudo ln -s /tmp/resolv.conf.dhclient-new /etc/resolv.conf.dhclient-new
                  sudo mv /sbin/dhclient-script /sbin/dhclient-script_original
                  sudo ln -s /home/pi/emonpi/dhclient-script_raspbian_jessielite /sbin/dhclient-script
                  Then rebooted and all worked fine, the 3g modem connected to the internet and never disconnected, then I successfully SSH with weaved.com service.
                  After that another problem came up, my system is a GPS tracker for public transport, so there is a GPS module in my system, and the GPS was not working for the same reason as the 3g modem.
                  I'm using a "Ublox Neo 6m GPS" and GPSD to get the required information.
                  When GPSD run at boot it tryes to write a configuration file to open the stream, but it cant because the Pi is in read mode, so we need to put in that file what GPSD write at boot.
                  To solve this, just edit this file: /etc/default/gpsd
                  Then edit as this:
                  START_DAEMON="true"
                  GPSD_OPTIONS="-n"
                  DEVICES="/dev/ttyAMA0" #My GPS is connected via UART, change if yours is via USB or whatelse
                  USBAUTO="true"
                  GPSD_SOCKET="/var/run/gpsd.sock"
                  Finally reboot and all will work fine.
                  So, if you are having a problem with a sensor or what else, first verify if the program who communicates with it needs to write sometime to the SD.
                  Thank you and greetings from Mexico!!!
                    FBorges
                    Hi !
                    I've tried to complete tour tutorial but when I do the step "Move some system files to temp filesystem", I've detected that it result on a dbus problem that when the Raspberry is rebooted It can resolve the dhcp and hostname service.
                    Can anyone help me please?
                      cfreund
                      need to change UPEX4C_autoconfigfil in /usr/sbin/update-exim4.conf
                        willn
                        Will brick your Pi if you're running the new PIXEL distro. Any idea what's causing this?
                          dgatwood
                          You should really add some commentary about the tmpfs lines in /etc/fstab before the code listing. When I got to that step, I read that we were ready to set the volume to read-only, and thought, "I know how to do that," and stopped reading at that point, resulting in an unbootable system. I'd imagine many other folks with sysadmin experience will do the same. Actually, you should probably add the tmpfs lines first before you start making changes that depend on them, then make the changes, then change fstab a second time to make it read-only. Also, for Jessie, the systemd changes are unnecessary, because /run is already a tmpfs volume. And it might be worth redirecting things from /var/run to /run just for simplicity (on Jessie).
                            Bruno Duarte
                            How to fix this ?
                            pi@raspberrypi(ro):~$ reboot
                            Failed to execute operation: The name org.freedesktop.PolicyKit1 was not provided by any .service files
                            Must be root.
                              you need to be root..
                              use 'sudo'
                                mocart2
                                Hello! Can anybody help me with user crontab file? I have problem: i installed raspbian in Read-only mode, i have some scripts, (cron jobs) that works every 5 minutes, 10 etc. I set it by crontab -e command, but after reboot, system is clean it, i think, because i moved /var/spool dir to tmpfs (like howto), and user cronjob file stored at /var/spool/cron/crontabs dir. How i can fix it for not clearing after system reboot? Thanks!
                                  Cavallonzio
                                  Did anyone figured out how to use crontab? it is wiped after reboot and i really need it 😞
                                    We need to put the system into Read Write Mode before changing the crontab
                                    If you followed this tuto should be something like that
                                    sudo mount -o remount,rw /
                                    Then edit your crontab
                                    sudo crontab -e
                                    put pack in Read Only or reboot
                                    sudo mount -o remount,ro /
                                    • Damian MacD Offline
                                      Damian MacD Offline
                                      Damian Mac
                                      Charles you are going wrong. crontab -e give us file on /tmp which has been deleted on boot. We need to go this way:
                                      rw
                                      sudo su
                                      nano /etc/crontab (dont forget to add user) example below:
                                              • root /usr/bin/vpncheck.sh > /dev/null 2>&1
                                        Neoromantic
                                        Hello Charles,
                                        I was wondering if I don't have entry about /tmp being a mount entry point for tmpfs neither in fstab nor mtab, what would be the point in moving things there? Am I missing something or?
                                        I am playing with Raspberry PI-2 and Raspbian Jessie.
                                          R Offline
                                          ricky
