  3. TH02
  4. Negative temperature measures
Scheduled Pinned Locked Moved TH02
temperatureth02negativelibrary
4 Posts 2 Posters 2.8k Views 2 Watching
  • K Offline
    K Offline
    kgx123
    Hi Charles-Henri,
    I am using your excellent TH02 library on Moteino. I have one sensor outside my house, with minus degrees celsius. However the TH02 lib reports the absolute value, without the minus prefix. E.g. “6.5” instead of “-6.5″. Please advise on what I am doing wrong.
    Merci beacoup,
    Karim
    From the Arduino sketch:
    int16_t temp, rh, rh_comp;
     //uint8_t status;
     Serial.print(F("Starting Temperature conversion."));
     sensor.startTempConv();
     sensor.waitEndConversion();
     Serial.println(F(".done!"));
     // Get temperature calculated and rounded
     temp = sensor.getConversionValue();
     // Display unrounded value (raw)
     Serial.print(F("Temperature = "));
     // this call does not do any I2C reading, it use last reading
     Serial.print(sensor.getLastRawTemp()/100.0);
     Serial.print(F(" C  =>  "));
     // Display now rounded value returned by 1st call
     Serial.print(temp/10.0);
     Serial.println(F(" C"));
      Karim,
      Would you try to modify the following line (261 to 269) to the library th02.cpp
       if(result >= 5000)
        result -= 5000;
      else
        result -= 5000;
        result = -result;
      by
      result -= 5000;
      Let me know if it works, I don’t understand why I’ve done like that 😉
      • K Offline
        K Offline
        kgx123
        Changes done to th02.cpp. Thanks! Seems to be working fine ::
        NEGATIVE TEMP:
        Starting Temperature conversion..done!
        Temperature = -7.00 C => -7.00 C
        Temperature = -5.82 C => -5.80 C
        Temperature = -2.10 C => -2.10 C
        Temperature = -0.79 C => -0.80 C
        POSITIVE TEMP:
        Temperature = 1.43 C => 1.40 C
        Temperature = 2.87 C => 2.90 C
          Excellent,
          I will modify the lib on github
