    microTI 2.0 - rPI3 - Pas de trame
    2 Posts 2 Posters 905 Views 1 Watching
      godzipab
      je viens d'acquérir un microteleinfo v2 et impossible d'avoir des trames.
      Le context :
      -le compteur EDF : Sagem
      -un RPi 3 avec Raspian Jessie à jour et fresh Install
      -en wifi + ssh server + install picocom
      -les configurations effectuées sont :
      dans /boot/config : enable_uart=1
      dans /boot/config : dtoverlay=pi3-disable-bt + systemctl disable hciuart
      dans RasPi-config : interfacing options/P6 Serial/login Shell accessible over serial : No et serial port hardware enable : Yes
      /var/log/messages donne :
      Apr 13 17:51:03 pi-domoticz kernel: [ 1.466022] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
      Apr 13 17:51:03 pi-domoticz kernel: [ 1.468652] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      Apr 13 17:51:03 pi-domoticz kernel: [ 1.472077] hub 1-1:1.0: USB hub found
      Apr 13 17:51:03 pi-domoticz kernel: [ 1.474696] hub 1-1:1.0: 5 ports detected
      Apr 13 17:51:03 pi-domoticz kernel: [ 1.726559] NET: Registered protocol family 10
      Apr 13 17:51:03 pi-domoticz kernel: [ 1.795806] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
      Apr 13 17:51:03 pi-domoticz kernel: [ 1.936049] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
      Apr 13 17:51:03 pi-domoticz kernel: [ 1.938725] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      Apr 13 17:51:03 pi-domoticz kernel: [ 1.944188] smsc95xx v1.0.5
      Apr 13 17:51:03 pi-domoticz kernel: [ 2.039585] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:13:a9:c1
      Apr 13 17:51:03 pi-domoticz kernel: [ 2.135756] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
      Apr 13 17:51:03 pi-domoticz kernel: [ 2.297552] usb 1-1.4: New USB device found, idVendor=0403, idProduct=6015
      Apr 13 17:51:03 pi-domoticz kernel: [ 2.299596] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      Apr 13 17:51:03 pi-domoticz kernel: [ 2.299608] usb 1-1.4: Product: FT230X Basic UART
      Apr 13 17:51:03 pi-domoticz kernel: [ 2.299616] usb 1-1.4: Manufacturer: FTDI
      Apr 13 17:51:03 pi-domoticz kernel: [ 2.299622] usb 1-1.4: SerialNumber: TINFO-1950
      Apr 13 17:51:03 pi-domoticz kernel: [ 3.298443] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.085015] usbcore: registered new interface driver usbserial
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.085118] usbcore: registered new interface driver usbserial_generic
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.085201] usbserial: USB Serial support registered for generic
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.095941] usbcore: registered new interface driver ftdi_sio
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.096042] usbserial: USB Serial support registered for FTDI USB Serial Device
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.096328] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.096513] usb 1-1.4: Detected FT-X
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.097936] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB0
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.124643] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.362781] usbcore: registered new interface driver brcmfmac
      Apr 13 17:51:03 pi-domoticz kernel: [ 4.522393] brcmfmac: Firmware version = wl0: Aug 7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
      Apr 13 17:51:03 pi-domoticz kernel: [ 5.534912] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
      Apr 13 17:51:03 pi-domoticz kernel: [ 5.534952] brcmfmac: power management disabled
      Apr 13 17:51:03 pi-domoticz kernel: [ 6.093754] Adding 102396k swap on /var/swap. Priority:-1 extents:3 across:208892k SSFS
      Apr 13 17:51:03 pi-domoticz kernel: [ 6.246918] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
      Apr 13 17:51:03 pi-domoticz kernel: [ 6.247131] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
      Apr 13 17:51:04 pi-domoticz kernel: [ 6.820977] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
      Apr 13 17:53:03 pi-domoticz kernel: [ 62.877401] uart-pl011 3f201000.serial: no DMA platform data
      Apr 13 17:53:28 pi-domoticz kernel: [ 87.293799] random: crng init done
      et root@pi-domoticz:~# picocom -b 1200 -d 7 -p e -f n /dev/ttyUSB0
      picocom v1.7
      port is : /dev/ttyUSB0
      flowcontrol : none
      baudrate is : 1200
      parity is : even
      databits are : 7
      escape is : C-a
      local echo is : no
      noinit is : no
      noreset is : no
      nolock is : no
      send_cmd is : sz -vv
      receive_cmd is : rz -vv
      imap is :
      omap is :
      emap is : crcrlf,delbs,
      La LED verte est bien allumée et fixe.
      La LED rouge clignote lentement.
      Je ne vois pas ce que j'ai raté.
      Si quelqu'un a une idée je suis preneur.
      L 1 Reply Last reply Reply Quote
        laurent @godzipab
        @godzipab said in microTI 2.0 - rPI3 - Pas de trame:
        bonjour
        tu as trouvé la solution ? parce que tout a l'air correct dans ta configuration... est ce que tu es bien branché avec les sorties I1 et I2 du compteur (pas beaucoup d'idée, désolé) ...
        Laurent
