  3. General Discussion
  4. Node Firmware for Lora Node 1.3 PCB
1 Posts 1 Posters 804 Views 1 Watching
    D Offline
    dennyfmn
    I am using your Lora Node version 1.3 PCB with the current latest version 5 of the Single Channel Gateway and it is working fine. I basically followed Andreas Spiess's video #134 but used the newer firmware. Thanks for the great shield PCB!
    I live in Minnesota and use the usa915 frequency plan. I currently have one node connected to the gateway built with an Arduino UNO and a Dragino LoRa shield per Spiess's video #117.
    I would now like to construct another LoraWan Node with your shield using a Wemos D1 Mini Pro, like I used on the gateway. I see a link to the one channel gateway firmware, but do not see any reference to Node firmware.
    What LoRaWan Node firmware would you suggest for use with your shield?
    Thanks!
