  3. ArduiPi
  4. ArduiPi_OLED install error
Scheduled Pinned Locked Moved ArduiPi
2 Posts 2 Posters 1.6k Views 1 Watching
    Alain
    J'essaye d'installer la librairie ArduiPi_OLED, sur 3 cartes Raspberry diférentes (B,B+,2B) toutes à jour ( Version 4.14.33+ #1108 Mon Apr 9 17:19:29 BST 2018 armv6l) ou (V 4.14.33-v7+ #1109 SMP Tue Apr 10 17:28:38 BST 2018 armv7l GNU/Linux).
    J'ai toujours l'erreur suivante lors du "make":
    ---- copie d'écran ------
    pi@pi15 ~/ArduiPi_OLED $ sudo make
    g++ -Wall -fPIC -fno-rtti -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c ArduiPi_OLED.cpp
    ArduiPi_OLED.cpp: In member function ‘void ArduiPi_OLED::putSeedChar(char)’:
    ArduiPi_OLED.cpp:635:41: warning: array subscript has type ‘char’ [-Wchar-subscripts]
    ./ArduiPi_OLED_lib.h: At global scope:
    ./ArduiPi_OLED_lib.h:58:21: warning: ‘oled_type_str’ defined but not used [-Wunused-variable]
    g++ -Wall -fPIC -fno-rtti -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c Adafruit_GFX.cpp
    gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c bcm2835.c
    gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c Wrapper.cpp
    Wrapper.cpp: In function ‘int16_t Wrapper_DisplayWidth()’:
    Wrapper.cpp:233:1: warning: no return statement in function returning non-void [-Wreturn-type]
    Wrapper.cpp: In function ‘int16_t Wrapper_DisplayHeight()’:
    Wrapper.cpp:238:1: warning: no return statement in function returning non-void [-Wreturn-type]
    g++ -shared -Wl,-soname,libArduiPi_OLED.so.1 -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -o libArduiPi_OLED.so.1.0 ArduiPi_OLED.o Adafruit_GFX.o bcm2835.o Wrapper.o -li2c
    /usr/bin/ld: ne peut trouver -li2c
    collect2: ld returned 1 exit status
    Makefile:54: recipe for target 'ArduiPi_OLED' failed
    make: *** [ArduiPi_OLED] Error 1
    Puisse une bonne âme me donner une solution ?
      L Offline
      LauriBuell
      wrote on last edited by LauriBuell
      You have to add in detail, exactly (no "the/library/folder" or "the/include/folder " but the correct paths/terms) - unfortunately I have no idea where files are stored ( or not ) after apt-get install.
      But I never use make or makefile or whatever for my C/C++ projects, that's far too weird to me. Geany must do all that automatically, so I need the actual parameters.
      pcb assembly
