    ESP8266-01 auto reset with FT231XS not working
    2 Posts 2 Posters 1.3k Views 2 Watching
      miker
      I created a new design using the FT231XS chip that has RTS and DTR pins to allow me to program an ESP8266-01 module without holding down a button and powering it up. The two NPN transistors used in other designs should take care of things.
      Right now in the Arduino IDE things look fine.
      -power is going where it should
      -the FTDI com port appears
      -programming leds blink for a second but the sketch will not upload
      Can someone take a look at the attached schematic to see if anything obvious was left out? I'll poke around with the oscilloscope over the next few days to find the problem.
      Mike - See more at: http://www.esp8266.com/viewtopic.php?f=13&t=10223#sthash.6nc9Gyd7.dpuf[0_1464802364297_Schematic.1PDF.PDF](Uploading 100%)
        Hi @miker
        Nice to see old OLED board creator there đŸ˜‰
        Your schematic looks good, at which speed did you tried to upload ? Did you programmed the FTDI chip with FT_PROG to see pin setup and functions ?
        With your input, this post could be even better đŸ’—
        • Denky D4 - Lecture donnĂ©es Linky
