  5. Compilation ESP Home pour avoir la TIC sur cet ESP
9 Posts 3 Posters 5.6k Views 2 Watching
    mikebzh44
    Bonjour.
    Je viens de recevoir ma carte Denky D4 et je n'arrive pas à compiler un fichier YAML pour Home Assistant
    J'ai cette erreur :
    INFO ESPHome 2024.6.6
    INFO Reading configuration /config/esphome/esphome-web-f5bfa8.yaml...
    Failed config
    uart: [source /config/esphome/esphome-web-f5bfa8.yaml:77]
      - id: uart_bus
        This pin cannot be used on ESP32s and is already used by the flash interface (function: Flash Data 1).
        rx_pin: GPIO8
        baud_rate: 1200
        parity: EVEN
        data_bits: 7
    Et voici mon code YAML :
    substitutions:
      friendly_name: esp-tic-feyree
      device_description: Infos TIC Recharge VE
    esphome:
      friendly_name: ${friendly_name}
      comment: ${device_description}
      min_version: 2024.6.0
      name_add_mac_suffix: false
      project:
        version: '1.0'
    esp32:
    #  board: adafruit_qtpy_esp32
      board: denky_d4
      framework:
        type: esp-idf
    # Enable logging
    logger:
    # Enable Home Assistant API
    api:
    # Allow Over-The-Air updates
    ota:
    - platform: esphome
    # Allow provisioning Wi-Fi via serial
    improv_serial:
    wifi:
      # Set up a wifi access point
      ap: {}
    # In combination with the `ap` this allows the user
    # to provision wifi credentials to the device via WiFi AP.
    captive_portal:
    dashboard_import:
      package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
      import_full_config: true
    # Sets up Bluetooth LE (Only on ESP32) to allow the user
    # to provision wifi credentials to the device.
    esp32_improv:
      authorizer: none
    # To have a "next url" for improv serial
    web_server:
      local: true
      port: 80
    #  auth:
    #    username: !secret esphome_web_server_username
    #    password: !secret esphome_web_server_password
    # Time: https://esphome.io/components/time.html
    time:
      - platform: homeassistant
        timezone: "Europe/Paris"
    # Status Binary Sensor: https://esphome.io/components/binary_sensor/status.html
    binary_sensor:
      - platform: status
    # Restart Button: https://esphome.io/components/button/restart.html
    button:
      - platform: restart
    # https://esphome.io/custom/uart.html
    uart:
      rx_pin: GPIO8 # Pin Rx2
      baud_rate: 1200
      parity: EVEN
      data_bits: 7
      #rx_buffer_size: 512
    # https://esphome.io/components/sensor/teleinfo.html
    teleinfo:
        update_interval: 60s
        historical_mode: true
    # https://esphome.io/components/sensor/index.html
    sensor:
      # WiFi
      - platform: wifi_signal
        name: "WiFi Signal Sensor"
        unit_of_measurement: dB
        accuracy_decimals: 0
        force_update: false
        icon: mdi:wifi
      # Uptime
      - platform: uptime
        unit_of_measurement: s
        force_update: false
        icon: mdi:clock-start
      # Production
      - platform: teleinfo
        tag_name: "BASE"
        unit_of_measurement: kWh
        device_class: energy
        state_class: total_increasing
        icon: mdi:flash
        accuracy_decimals: 2
        filters:
          - multiply: 0.001
          - filter_out: 0
    text_sensor:
      - platform: template
        lambda: |-
          int seconds = (id(uptime_seconds).state);
          int days = seconds / (24 * 3600);
          seconds = seconds % (24 * 3600);
          int hours = seconds / 3600;
          seconds = seconds % 3600;
          int minutes = seconds /  60;
          seconds = seconds % 60;
          if ( days ) {
            return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
          } else if ( hours ) {
            return { (String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
          } else if ( minutes ) {
            return { (String(minutes) +"m "+ String(seconds) +"s").c_str() };
          } else {
            return { (String(seconds) +"s").c_str() };
    Quand j'ai initialisé la carte avec ESPHome, elle était vu comme :
    esp32:
      board: esp32dev
      framework:
        type: arduino
    Mais même avec cette définition, la compilation donne la même erreur.
    • M mikebzh44
      Bonjour.
      J'ai cette erreur :
      Failed config
        - id: uart_bus
          rx_pin: GPIO8
          baud_rate: 1200
          parity: EVEN
          data_bits: 7
      substitutions:
      esphome:
        project:
          version: '1.0'
      esp32:
        board: denky_d4
        framework:
          type: esp-idf
      # Enable logging
      logger:
      api:
      ota:
      - platform: esphome
      improv_serial:
      wifi:
        ap: {}
      captive_portal:
      dashboard_import:
      esp32_improv:
        authorizer: none
      web_server:
        local: true
        port: 80
      #  auth:
      time:
      binary_sensor:
        - platform: status
      button:
        - platform: restart
      uart:
        baud_rate: 1200
        parity: EVEN
        data_bits: 7
      teleinfo:
      sensor:
        # WiFi
          force_update: false
          icon: mdi:wifi
        # Uptime
        - platform: uptime
          force_update: false
        # Production
          tag_name: "BASE"
          icon: mdi:flash
          filters:
            - multiply: 0.001
            - filter_out: 0
      text_sensor:
          lambda: |-
            if ( days ) {
            } else {
      esp32:
        board: esp32dev
        framework:
          type: arduino
      @mikebzh44
      La solution doit se trouver dans ce post https://github.com/esphome/issues/issues/5932 (no testé de mon coté) mais ça devrait fonctionner
      esphome:
        friendly_name: Linky
      esp32:
        board: denky_d4
        framework:
          type: esp-idf
      uart:
        rx_pin: GPIO8
        ignore_pin_validation_error: true
        baud_rate: 9600
        parity: EVEN
        data_bits: 7
        stop_bits: 1
      M 1 Reply Last reply
        @mikebzh44
        esphome:
        esp32:
          board: denky_d4
          framework:
            type: esp-idf
        uart:
          rx_pin: GPIO8
          baud_rate: 9600
          parity: EVEN
          data_bits: 7
          stop_bits: 1
        mikebzh44
        @Charles Merci, je vais tester ça ce WE
        • M mikebzh44
          mikebzh44
          Je confirme, ça marche nickel !!
          Mon YAML au complet :
          substitutions:
            devicename: esp-tic-feyree
            device_description: Infos TIC chargeur VE
          esphome:
            friendly_name: $friendly_name
            project:
              version: '1.0'
          esp32:
            board: denky_d4
            framework:
              type: arduino
          # Enable logging
          logger:
            baud_rate: 0
            level: INFO
            #esp8266_store_log_strings_in_flash: False
          api:
          ota:
            platform: esphome
            password: "472f4e3996e22b5cc959fefe4f46d54e"
          wifi:
            #ssid: !secret wifi_ssid
            #password: !secret wifi_password
            # Enable fallback hotspot (captive portal) in case wifi connection fails
            ap: {}
          # Web Server: https://esphome.io/components/web_server.html
          web_server:
            local: true
            port: 80
          #  auth:
          time:
          captive_portal:
          binary_sensor:
            - platform: status
              name: "Sagem EV Status"
          button:
            - platform: restart
              name: "Sagem EV Restart"
          uart:
            rx_pin:
              number: GPIO8 # Pin Rx2
            baud_rate: 1200
            parity: EVEN
            data_bits: 7
          teleinfo:
          sensor:
            # WiFi
              force_update: false
              icon: mdi:wifi
            # Uptime
            - platform: uptime
              force_update: false
            # Production
              tag_name: "BASE"
              icon: mdi:flash
              filters:
                - multiply: 0.001
                - filter_out: 0
          text_sensor:
              lambda: |-
                if ( days ) {
                } else {
          • M mikebzh44
            substitutions:
            esphome:
              project:
                version: '1.0'
            esp32:
              board: denky_d4
              framework:
                type: arduino
            # Enable logging
            logger:
              baud_rate: 0
              level: INFO
            api:
            ota:
              platform: esphome
            wifi:
              ap: {}
            web_server:
              local: true
              port: 80
            #  auth:
            time:
            captive_portal:
            binary_sensor:
              - platform: status
            button:
              - platform: restart
            uart:
              rx_pin:
              baud_rate: 1200
              parity: EVEN
              data_bits: 7
            teleinfo:
            sensor:
              # WiFi
                force_update: false
                icon: mdi:wifi
              # Uptime
              - platform: uptime
                force_update: false
              # Production
                tag_name: "BASE"
                icon: mdi:flash
                filters:
                  - multiply: 0.001
                  - filter_out: 0
            text_sensor:
                lambda: |-
                  if ( days ) {
                  } else {
            mikebzh44
            @Charles Du coup, je garde la carte et je trouverai bien une utilité pour le PiTInfo que j'ai commandé 😉
            ch_2iC 1 Reply Last reply
            • M mikebzh44
              ch_2iC Offline
              ch_2iC Offline
              @mikebzh44 je peux annuler ta commande du Pitinfo si tu veux ?
              • ch_2iC ch_2i
                mikebzh44
                @ch_2i Si tu peux le faire, je veux bien, merci.
                • M mikebzh44
                  @mikebzh44 C'est fait 🙂
                    mikebzh44
                    @Charles Top, merci !
