    Teleinfo et Wemos D1 mini : aucun signal
    9 Posts 3 Posters 2.6k Views 1 Watching
      Rabi Yadir
      Je ne reçois aucun signal et ne sais pas comment debugger la situation.
      Auriez-vous une idée d'une erreur que j'aurais pu faire?
      Merci par avance.
      La situation
      • Compte linky en mode historique
      • Wemos D1 mini connecté à un téléinfo 1.1
      • Tasmota Teleinfo installé via https://jason2866.github.io/Tasmota-specials/
      • Fils bien connecté au compteur linky: la diode du shield clignote rouge
      • TInfo RX sur GPIO13
      Console
      Par rapport à d'autre Log que j'ai pu voir, le "always enabled" n'apparait pas.
      00:00:00.001 HDW: ESP8266EX
      00:00:00.050 CFG: Loaded from flash at F4, Count 16
      00:00:00.055 QPC: Count 1
      00:00:00.064 Project tasmota - Teleinfo Version 2022.01.2(teleinfo)-2_7_4_9(2022-01-07T16:41:31)
      00:00:00.064 TIC: RX on GPIO13, baudrate 1200
      00:00:00.701 SNS: Hardware Serial
      00:00:00.701 TIC: using hardware serial
      00:00:00.702 TIC: Raw mode enabled
      00:00:01.233 WIF: Connecting to AP1 RAFIKI Channel 5 BSSId 00:11:32:A5:21:82 in mode 11n as tasmota-55E758-1880...
      00:00:02.752 WIF: Connected
      00:00:03.005 HTP: Web server active on tasmota-55E758-1880 with IP address 10.0.4.79
      18:58:08.024 RSL: INFO1 = {"Info1":{"Module":"Wemos Teleinfo","Version":"2022.01.2(teleinfo)","FallbackTopic":"cmnd/DVES_55E758_fb/","GroupTopic":"cmnd/tasmotas/"}}
      18:58:08.026 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-55E758-1880","IPAddress":"10.0.4.79"}}
      18:58:08.027 RSL: INFO3 = {"Info3":{"RestartReason":"Software/System restart"}}
      18:58:10.724 QPC: Reset
      18:58:12.653 RSL: STATE = {"Time":"2022-01-07T18:58:12","Uptime":"0T00:00:10","UptimeSec":10,"Vcc":3.055,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":26,"MqttCount":0,"Wifi":{"AP":1,"SSId":"RAFIKI","BSSId":"00:11:32:A5:21:82","Channel":5,"Mode":"11n","RSSI":76,"Signal":-62,"LinkCount":1,"Downtime":"0T00:00:04"}}
      18:58:12.659 RSL: SENSOR = {"Time":"2022-01-07T18:58:12","ENERGY":{"TotalStartTime":"2022-01-07T18:39:23","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period": 0,"Power": 0,"Current":0.000},"TIC":{}}
        Charles @Rabi Yadir
        Bonjour @rabi-yadir
        Bon si la led clignote rouge c'est déjà bon signe, visiblement la téléinfo est active dans le firmware puisque tu vois les logs TIC. Peux tu taper la commande energyconfig dans la console et afficher le résultat stp ?
        13:13:23.341 CMD: energyconfig
        13:13:23.346 TIC: Settings Mode:historique, RX:GPIO23, EN:None, Raw:full, Skip:9, Limit:0
        13:13:26.011 TIC: Total counter updated to 201992271 Wh
        Es-tu certain que ta téléinfo est en mode historique et non standard ?
        Tu peux essayer de la passer en mode standard pour voir
        energyconfig standard
        Regarde la doc officielle ici
        Enfin qu'indique la page d'accueil, as tu des information d'énergie dessus ?
        R 1 Reply Last reply Reply Quote
          Rabi Yadir @Charles
          @charles
          Bonjour @Charles,
          Merci pour le retour.
          Voici ce que j'obtiens en tapant energyconfig
          21:50:16.641 CMD: energyconfig
          21:50:16.646 TIC: Settings Mode:historique, RX:GPIO13, EN:None, Raw:full, Skip:0, Limit:0
          21:50:16.648 RSL: RESULT = {"EnergyConfig":"Done"}
          En entrant energyconfig standard
          21:54:03.966 CMD: energyconfig standard
          21:54:03.979 TIC: 'standard' mode
          21:54:03.981 TIC: RX on GPIO13, baudrate 9600
          21:54:03.992 SNS: Hardware Serial
          21:54:03.993 TIC: using hardware serial
          21:54:03.995 TIC: Raw mode enabled
          21:54:03.998 RSL: RESULT = {"EnergyConfig":"Done"}
          21:54:13.409 RSL: STATE = {"Time":"2022-01-19T21:54:13","Uptime":"0T00:11:12","UptimeSec":672,"Vcc":3.074,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"RAFIKI","BSSId":"00:11:32:A5:21:82","Channel":5,"Mode":"11n","RSSI":72,"Signal":-64,"LinkCount":1,"Downtime":"0T00:00:06"}}
          21:54:13.416 RSL: SENSOR = {"Time":"2022-01-19T21:54:13","ENERGY":{"TotalStartTime":"2022-01-07T18:39:23","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period": 0,"Power": 0,"Current":0.000},"TIC":{}}
          21:55:13.403 RSL: STATE = {"Time":"2022-01-19T21:55:13","Uptime":"0T00:12:12","UptimeSec":732,"Vcc":3.060,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"RAFIKI","BSSId":"00:11:32:A5:21:82","Channel":5,"Mode":"11n","RSSI":72,"Signal":-64,"LinkCount":1,"Downtime":"0T00:00:06"}}
          21:55:13.411 RSL: SENSOR = {"Time":"2022-01-19T21:55:13","ENERGY":{"TotalStartTime":"2022-01-07T18:39:23","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period": 0,"Power": 0,"Current":0.000},"TIC":{}}
          21:56:13.413 RSL: STATE = {"Time":"2022-01-19T21:56:13","Uptime":"0T00:13:12","UptimeSec":792,"Vcc":3.074,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"RAFIKI","BSSId":"00:11:32:A5:21:82","Channel":5,"Mode":"11n","RSSI":72,"Signal":-64,"LinkCount":1,"Downtime":"0T00:00:06"}}
          21:56:13.420 RSL: SENSOR = {"Time":"2022-01-19T21:56:13","ENERGY":{"TotalStartTime":"2022-01-07T18:39:23","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period": 0,"Power": 0,"Current":0.000},"TIC":{}}
          Enfin voici la capture d'écran
          Merci encore pour le support
            Charles @Rabi Yadir
            @rabi-yadir clairement tu ne reçois pas le signal téléinfo, si ta téléinfo est en mode standard et que tu as un PITinfo 1.1 (vieux modèle) il est possible qu'il faille changer des resistances.
            Tu peux mettre une photo du montage stp ?
              Rabi Yadir @Charles
              @charles Voici la photo de mon montage
              Ma teleinfo est en mode historique conformément au mode du linky.
              J'ai revu le TInfo Rx sur le GPIO3
              Raccordement Teleinfo <>D1
              • 3v3 <> 3v3
              • GND <> GND
              • Tx <> Rx
                Charles @Rabi Yadir
                @rabi-yadir question bête, pourquoi tu n'as pas plugué le shield sur le D1 c'est justement fait pour et pour éviter la filasse 🙂
                Quoi qu'il en soit ta connectique n'est pas la bonne, le signal téléinfo décodé arrive sur la pin rx et sur ta photo c'est branché sur tx. tu dois relier le rx du shield au rx du D1, c'est le principe d'un shield le mapping des pins est identique sur le shield et la carte mère.
                  Rabi Yadir @Charles
                  @charles
                  J'avais superposé le shield sur la carte mais comme j'avais des problème, j'ai préféré utiliser les fils pour faire des essais.
                  Je continue mes recherches et reviens sur le forum si je m'en sors pas ou si je trouve la solution.
                  Merci encore.
                  E 1 Reply Last reply Reply Quote
                    EliasMM @Rabi Yadir
                    Bonjour @rabi-yadir , j'ai l'impression d'être dans la même situation que toi (pas de décodage de trame Téléinfo) : as-tu trouvé une solution ? 🤞
                      EliasMM @EliasMM
                      @eliasmm Et je me réponds à moi-même : j'avais loupé une info dans la documentation abondante mais dispersée :
                      => La téléinfo arrive sur le pin GPIO23 pour un shield posé sur ESP32 !
                      Or je lisais la doc de Tasmota/Teleinfo, qui indique "any port is OK" mais c'est pour le logiciel, pas pour le câblage sur du matériel 😬
                      En avant les mesures 😄
