    Use RFM12B, RFM69, Micro SD or Flash EEP using ArduiPi NRF24L01 connector
    arduinoat25512breakoutboardarduipi
    9 Posts 3 Posters 4.8k Views 2 Watching
      Use RFM12B, RFM69CW, RFM69W or RFM69HW, Micro SD or Flash EEP with NRF24L01 connector of ArduiPi board (or other) Updated 2014 September I created 3 other small boards, V1.2 without SD but very small, the V1.2 SMD ultra small (version… Continue Reading
        Gijs
        Do you think this could work with the MySensors Sensebender Micro
          Gijs : It works with RFM69W for me.
            @Gijs
            I'm not sure to understand what you want to try, would you mind add some precision ?
            You want to use the adapter correct ?
              Gijs
              Yes @Charles, I would like to use the adapter card with RFM69W on the MySensors Sensebender instead of the NRF24L01 as is used ont the example on the Mysensors site.
                @Gijs
                If MySensors support RFM69 of course it should works. May be you need to change some pins depending on what default pinout MySensor is using in the lib/sketch, but it should go straightforward since RFM is connected to SPI and IRQ on D2 😉
                Let me know if it works
                  I juste repeat it works for me on Sensebender and with nano gateway or jeelink.
                    @Fab_33
                    Sorry I missed that one, thanks 😉
                      @Charles No problem ! And thank you for this board.
