    No readings on mode "Standard"
    9 Posts 2 Posters 1.2k Views 1 Watching
      ellipsis
      Hi Charles,
      I've just installed 2 x Denky4 (v1.3a), one to a Linky in mode "Historique", and one to a different Linky in mode "Standard". These are to replace 2 existing Micro Teleinfo units which worked fine but I wanted to move to Tasmota. The mode Historique monitor on Linky #1 works perfectly, correct and consistent.
      But, the installation on the Standard mode on Linky #2 is not working. I believe the physical connection to the Linky is correct, and Wi-fi, MQTT work fine. No TIC monitoring data is being produced {}. No "SENSOR" records are generated. What am I doing wrong?
      Thanks,
      Tony
        Charles @ellipsis
        @ellipsis, does the blue light is blinking (if so TIC signal is seen), if so you can try to turn gently the potentiometer on the board, near the green connector (with a little screwdriver) to adjust TIC signal
        Then may be seeing screenshot of Tasmota device config and teleinfo config may help, but should be okay if you suceeded with legacy mode.
          ellipsis @Charles
          @Charles, thanks for replying. Unfortunately, I'm not onsite currently, so can't change the potentiometer. The blue light was illuminated, but I thought with a different pattern to the Denky connected in Historique mode. Just my impresssion though...
          Hope all relevant information is included below.
          One more info: In all my attempts to get this working, I did try swapping the two Denky units (reconfiguring eachtime), and that did not seem to resolve the issue. I didn't keep logs for that test though...
          Thanks,
          Tony
          Info as requested:
          {"NAME":"Denky D4 (v1.3a)","GPIO":[32,3200,0,3232,1,0,0,0,0,1,1376,1,0,0,0,0,0,640,608,0,0,0,0,0,0,0,5632,0,0,0,0,0,0,0,0,0],"FLAG":0,"BASE":1}
          Current auto-configuration : Current configuration: DenkyD4 V1.3a
          [Console at restart:]
          00:00:00.039 UFS: FlashFS mounted with 4392 kB free
          00:00:00.059 CFG: Loaded from File, Count 22
          00:00:00.069 QPC: Count 1
          00:00:00.075 I2C: Bus1 using GPIO22(SCL) and GPIO21(SDA)
          00:00:00.155 BRY: Berry initialized, RAM used=3933 bytes
          00:00:00.219 CFG: Energy loaded from file
          00:00:00.220 NRG: Init driver 15
          00:00:00.230 Project tasmota - Tasmota Version 13.1.0.1(teleinfo)-2_0_11(2023-08-15T09:04:21)
          00:00:00.232 TIC: RX on GPIO8, baudrate 1200
          00:00:00.513 BRY: Successfully loaded 'autoexec.be'
          00:00:01.305 WIF: Connecting to AP1 Breaghva Channel 5 BSSId XX:XX:XX:XX:XX:XX in mode 11n as AV-AJD-Power-1032...
          00:00:02.293 WIF: Connected
          00:00:02.551 HTP: Web server active on AV-AJD-Power-1032 with IP address 192.168.1.138
          14:47:52.545 MQT: Attempting connection...
          14:47:52.615 MQT: Connected
          14:47:52.619 MQT: AV/AJD_Power/LWT = Online (retained)
          14:47:52.623 MQT: AV/AJD_Power/cmnd/POWER =
          14:47:52.627 MQT: AV/AJD_Power/INFO1 = {"Info1":{"Module":"Denky D4 (v1.3a)","Version":"13.1.0.1(teleinfo)","FallbackTopic":"cmnd/AV_AJD_fb/","GroupTopic":"AV/AJD_Power/cmnd/"}}
          14:47:52.642 MQT: AV/AJD_Power/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"AV-AJD-Power-1032","IPAddress":"192.168.1.138","IP6Global":"","IP6Local":"fe80::4e75:25ff:fef3:6408"}}
          14:47:52.655 MQT: AV/AJD_Power/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":13}}
          14:47:52.669 MQT: AV/AJD_Power/RESULT = {"POWER":"ON"}
          14:47:52.670 MQT: AV/AJD_Power/POWER = ON
          14:47:55.914 QPC: Reset
          14:47:56.914 MQT: AV/AJD_Power/STATE = {"Time":"2025-12-01T14:47:56","Uptime":"0T00:00:08","UptimeSec":8,"Heap":125,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":1,"Berry":{"HeapUsed":3,"Objects":46},"POWER":"ON","Dimmer":10,"Color":"1A1A1A","HSBColor":"0,0,10","Channel":[10,10,10],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Breaghva","BSSId":"XX:XX:XX:XX:XX:XX","Channel":5,"Mode":"11n","RSSI":36,"Signal":-82,"LinkCount":1,"Downtime":"0T00:00:03"}}
          14:47:56.964 MQT: AV/AJD_Power/SENSOR = {"Time":"2025-12-01T14:47:56","ENERGY":{"TotalStartTime":"2025-11-28T12:26:41","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"Current":0.000},"TIC":{}}
          SENSOR = {"Time":"2025-12-01T15:05:05","ENERGY":{"TotalStartTime":"2025-11-28T12:26:41","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"Current":0.000},"TIC":{}}
            Charles @ellipsis
            @ellipsis je parlais plutôt de la page de config de la téléinfo
            Et de la config du module
              ellipsis
              Comment acceder la page config de Teleinfo?
              Ci-joint ma page config pour "Configure Module"
              ...et "Config Other"
              Tony
                Charles @ellipsis
                @ellipsis Tony,
                il faut flasher le firmware de @Nicolas-Bernaerts c'est pour ça 🙂
                cf https://community.ch2i.eu/topic/1450/procedure-de-flash-du-firmware-denky-d4
                puis utiliser ce fichier
                https://github.com/NicolasBernaerts/tasmota/blob/master/teleinfo/binary/tasmota32-teleinfo-denkyd4.bin
                E 2 Replies Last reply Reply Quote
                  ellipsis @Charles
                  @Charles > J'ai flasher, en OTA, avec succes https://github.com/NicolasBernaerts/tasmota/raw/master/teleinfo/binary/tasmota32-teleinfo-denkyd4.bin.
                  Mais tjrs pas de valeurs TIC
                  "Time": "2025-12-03T17:33:21",
                  "ENERGY": {
                  "TotalStartTime": "2025-11-28T12:26:41",
                  "Total": 0,
                  "Yesterday": 0,
                  "Today": 0,
                  "Period": 0,
                  "Power": 0,
                  "Current": 0
                  "TIC": {}
                  En plus, ou bien la cause, je ne trouve pas comment acceder la page config Teleinfo?
                  Tony
                    Charles @ellipsis
                    @ellipsis Menu Configuration puis téléinfo
                    mais moi en bas il m'indique que c'est la version de Nicolas, pas toi ? Jamais vu tes menus on line store, t'es certain d'avoir flashé la bonne version avec le bon processus ?
                    OTA : aller dans Firmware Upgrade puis cliquer sur le bouton Choisir un fichier et choisir le fichier telechargé, puis cliquer sur start upgrade
                      ellipsis @Charles
                      @Charles Trouvé!
                      Je ne sais pas pourquoi, mais flasher sur FireFox (142.0.1 (aarch64, Raspberry pi) ne marche pas pour moi. Changer sur Chromium (Version 142.0.7444.175) et ca marche. Une fois terminé, Firefox peut gerer, a permiere vue, mais je reste sur Chromum our l'instant.
                      En passant, pour moi, le DNS semble figé sur Amazon US (16.100.251.63), et NTP sur ntp.org...
                      Charles, merci beaucoup pour l'assistance!
                      Tony
                        376
