  3. ArduiPi
  4. Single_chan_pkt_fwd.service: status=210/CHROOT
Scheduled Pinned Locked Moved ArduiPi
1 Posts 1 Posters 1.3k Views 1 Watching
    oberon
    After the make install I get the following error:
    ● single_chan_pkt_fwd.service - Lora Packet Forwarder
    Loaded: loaded (/lib/systemd/system/single_chan_pkt_fwd.service; enabled; vendor preset: enabled)
    Active: activating (auto-restart) (Result: exit-code) since Thu 2018-06-07 20:31:22 CEST; 120ms ago
    Process: 704 ExecStart=/home/pi/single_chan_pkt_fwd/single_chan_pkt_fwd (code=exited, status=210/CHROOT)
    Main PID: 704 (code=exited, status=210/CHROOT)
    jun 07 20:31:22 raspberrypi systemd[1]: single_chan_pkt_fwd.service: Failed with result 'exit-code'.
    Makefile:23: recept voor doel 'install' is mislukt
    make: *** [install] Fout 3
    I can start ./single_chan_pkt_fwd without any problem. I just can't load it as as service.
    I'm using an Raspberry Pi 3B.
    Any idea what I'm doing wrong?
    Thnx!
