  3. Blog articles comments
driver1.30.96i2ciic
    donde
    Screen Never Lights
    New to OLED. Waiting for SSH1306 1.3" display like on Adafruit website. Sent for SH1106 display instead. Pinouts are left to right: VDD VSS SCK SDA D/C CS1 FS0 CS2
    Using Pi Zero. Went through tutorial OK I think. 2 problems:
    root@raspberrypi:~# ls /dev/i2c*
    /dev/i2c-0
    root@raspberrypi:~# ls /dev/spi*
    /dev/spidev0.0 /dev/spidev0.1
    The first check returned /dev/i2c-1 instead of /dev/i2c-0
    The second response was OK.
    Now I wasn't at root when I did commands, but at user.
    Other problem I had to supply sudo for
    ./oled_demo --verbose --oled 6
    I received this:
    pi@raspberrypi:~/ArduiPi_OLED/examples $ ./oled_demo --verbose --oled 6
    oled_demo v1.1
    -- OLED params --
    Oled is : SH1106 I2C 128x64
    -- Other Stuff --
    verbose is : yes
    bcm2835_init: Unable to open /dev/mem: Permission denied
    pi@raspberrypi:~/ArduiPi_OLED/examples $ sudo ./oled_demo --verbose --oled 6
    oled_demo v1.1
    -- OLED params --
    -- Other Stuff --
    verbose is : yes
    x: 9y: 0dy: 3
    x: 30y: 0dy: 2
    x: 111y: 0dy: 2
    x: 81y: 0dy: 4
    x: 41y: 0dy: 2
    x: 85y: 0dy: 5
    x: 7y: 0dy: 5
    x: 76y: 0dy: 2
    x: 72y: 0dy: 3
    x: 76y: 0dy: 4
    Nothing on screen!
    I wired it this way from Pi Zero
    Pi 5 volts to Vdd
    Pi GND to Display VSS
    Pi SCL to Display SCK
    Pi SDA to Display SDA
    IO25 to Display FSO
    No ID on Display, just this description:
    Features
    Self-luminous display for backlight
    High resolution: 128 x 64
    Viewing angle: >160 degree
    Supports many control chip: Fully compatible with Arduino, 51 Series, MSP430 Series, STM32 / 2, CSR IC, etc.
    Ultra-low power consumption: full screen lit 0.08W
    Voltage: 3V ~ 5V DC
    Working Temperature: -30 oC ~ 70 oC
    Module Size: 32.0mm x 35.50mm x 4.1mm
    SPI Interface, need 4 IO only.
    Driver IC: SH1106
    Package Includes
    1 x 1.3" SPI Serial 128X64 OLED LCD LED Display Module for Arduino UNO R3
    Not sure what try next. What turns on screen to see at least something?
    Thanks ... donde
      donde
      I looked closer at box the display came and it said it is for SPI mode. I tried i2C and didn't light up. Then, tried SPI and still no success. Doesn't seem to be a RST pin. I see no pictures of the same pin arrangement on the Net. Looks to be a special display no one knows about. Guess I'll return it and hopefully the SSH1306 will be available soon, Sorry to take up so much room here is this comments section. Moderator, you can delete all I said on first post. donde
      • fiveseven808F Offline
        fiveseven808
        I'm wondering if anyone can help me here... so using I2C, this driver works flawlessly! However, using SPI, I can't get my display to do anything (using the pinouts on the site). I know the display sort of works because the adafruit python library displays something (i think something is wrong with my screen). However, there is zero response with SPI.
        Any ideas?
          shiftleftplusone
          hello,
          can you please provide compile/build parameter settings and examples hw to use this lib with Geany, providing system-wide paths to #include the libs from each proprietary source code program located in any different directory?
            shiftleftplusone
            hello,
            you specified the following types:
            0 Adafruit SPI 128x32
            1 Adafruit SPI 128x64
            2 Adafruit I2C 128x32
            3 Adafruit I2C 128x64
            4 Seeed I2C 128x64
            5 Seeed I2C 96x96
            6 SH1106 I2C 128x64
            the chip of the 6th is obvious, but which chip types are especially 1,3, and 4?
            what about the i2c dev addresses of these OLEDs, and how to change them in the code if needed?
              shiftleftplusone
              another question:
              you wrote
              " Added millis() function"
              But millis() is already provided by Gordon Henderson's WiringPi lib which I always use - I'm afraid that will cause interferences and problems. How can one fix that problem?
                shiftleftplusone
                and 3rd,
                how to optionally the OLEDson i2c-1 or/and on i2c-0 ?
                  shiftleftplusone
                  sorry, typos:
                  and 3rd,
                  how to optionally drive the OLEDs on i2c-1 or/and on i2c-0 ?
                    tito
                    now I'm running into the same issues as the former user:
                    examples are running as sudo from console, but if I load the example source oled_demo.cpp into Geany, it compies, but buils does not work.
                    which are the exact parameters for the library to link to?
                    -I/ArduiPi_OLED ??
                    -L/ArduiPi_OLED ??
                      It's L of "Library" but in lower case
                      so but I do not know if Geany requires the -l switch before or not so you can try
                      -lArduiPi_OLED or ArduiPi_OLED
                        tito
                        oh yes, a lowercase l (L) seems to work, and no -L is required as it seems, and now it also runs started out of different folders, thank you!
                        • Tim
                          tito
                          now I just have to figure out how to start oled type 6 out of the source code without either command line parameters, just screen-out to this static oled type... will see, thanks again!
                            tito
                            ps, in the source code I also exchanged
                            #include "ArduiPi_OLED_lib.h"
                            #include "Adafruit_GFX.h"
                            #include "ArduiPi_OLED.h"
                            by
                            #include <ArduiPi_OLED_lib.h>
                            #include <Adafruit_GFX.h>
                            #include <ArduiPi_OLED.h>
                              tito
                              no, I don't get it: how to call
                              display.init()
                              in order to force oled 6 (i2c) without using any commandline parametes?
                                tito
                                think I got it:
                                // Oled supported display in ArduiPi_SSD1306.h
                                // Get OLED type
                                //parse_args(argc, argv);
                                // SPI
                                if (display.oled_is_spi_proto(opts.oled))
                                	// SPI change parameters to fit to your LCD
                                	if ( !display.init(OLED_SPI_DC,OLED_SPI_RESET,OLED_SPI_CS, opts.oled) )
                                		exit(EXIT_FAILURE);
                                else
                                	// I2C change parameters to fit to your LCD
                                	if ( !display.init(OLED_I2C_RESET, 6) )
                                		exit(EXIT_FAILURE);
                                display.begin();
                                • Y Offline
                                  Y Offline
                                  yanniks
                                  Any solution for the problem that the screen is freezing?
                                  The display is working fine with the Python script we found here so that can't be the problem. The Raspberry Pi is a Raspberry Pi 3.
                                  Thank you for your support.
                                    tito
                                    hello,
                                    if I am using your lib in my own programs I always need sudo to start them.
                                    How can I make them executable by every user (e.g., standard user pi) ?
                                      shyamvnarayanan
                                      Hi Charles,
                                      I am looking to use a 128x96 16-bit color OLED for my project using the SSD1351 controller. Could you help me understand
                                      1. What changes would be needed to your 1306 driver to make it work for the SSD1351
                                      2. Would you have some kind of reference code for that ?
                                      3. How would the wiring look like ?
                                      Whatever help/direction you could offer would be much appreciated. I was thinking of trying out your raspberry pi example for 1306 and start making changes from that point. Not sure if thats the right approach or should I go straight to the 1351.
                                      Regards
                                      Shyam
                                        dennischrist
                                        Hi Charles,
                                        is it possible to hook multiple screens up to the Rasberry Pi?
                                        I have 8 SSD 1306 7pin SPI that I would like to hookup.
                                        best,
                                        D
                                          snapx12
                                          Hi,
                                          So as far as I understand, there is no way to use this driver with a SH1106 SPI 128x64 ?
                                          That's a real shame, and I can't find any other rasppi drivers.
                                          If someone could help, that would be great,
                                          Regards
