  3. Blog articles comments
lifefilesystemcardlogend
    nicklas
    Interesting. I haven't rechecked but I had problems when /tmp wasn't mounted in /etc/fstab as tmpfs. What made me try that was the original blog post that you refer to. In his /etc/fstab is a line for /tmp, but he doesn't mention it in the text.
    I use minibian jessie, so it is not the full raspbian distro. Don't know if that could make a difference.
      Hummmm, minibian?
      just reading the name, I like it, was searching for a minimal distro for long time, I'll try it 😉
        arnt
        Thanks for sharing this post!
        I was able to get it forking with the RASPBIAN JESSIE LITE distro.
        Some minor issues were solved by adding
        tmpfs /tmp tmpfs mode=1777,nosuid,nodev 0 0
        tmpfs /var tmpfs mode=1777,nosuid,nodev 0 0
        to /etc/fstab
        I used the resolvconf package for fixing some issues with dhcpcd
          @arnt
          Thank, for the fixes, I really need to take time to test on jessie 😉
          • I Offline
            I Offline
            icepick
            What arnt wrote works indeed with Jessie (otherwise it won't boot). Does anyone know a way to still make it boot in the graphical interface? I didn't remove the xserver packages as written above.. the box boots to a black screen now (I can still ssh to it)..
            • Petr KlusP Offline
              Petr KlusP Offline
              Petr Klus
              Hello!
              Sorry for being lazy but I would you consider providing pre-built images with all of the work above built-in? Or, alternatively, a script one can use that does all of the above?
                Petr KlusP Offline
                Petr Klus
                @arnt - what did you do with resolvconf?
                  Petr KlusP Offline
                  Petr Klus
                  @arn I've written up instructions for Jessie inspired by this post (and many other). See here:
                  http://petr.io/2015/11/09/read-only-raspberry-pi-with-jessie/
                    @Petr-Klus
                    Since I migrated to Jessie, I've updated the post according to your changes, thanks for that.
                    I also corrected Fancy Prompt (was not working on Jessie) and ro/rw alias to also mount/remount /boot to avoid error when apt-get upgrade was upgrading also bootloader
                    • K Offline
                      K Offline
                      kamikazefish
                      Thanks for the great tutorial. Works great! If I would make a third partition on the SD card, and put the logs there and a fourth partition for the program data, would this still prevent my raspberry pi from not booting? The system files and programs would be read only. If not, would using an usb stick for the logs and program data be better?
                        @kamikazefish
                        yes have more partition for R/W data could be a great idea and would work. but in this case you won't prevent data corruption on power loss 😉
                        • K Offline
                          K Offline
                          kamikazefish
                          Ok that wouldn't be a big deal with the log files. For the program data I think there are some work arounds. I could implement unionfs with 2 partitions, one with a working state and the other as working dir. Then every x minutes I sync the files from the working dir to the working state. These writes are to an temp file, that are renamed after the write, to prevent corrupting the working state files.
                          • H Offline
                            H Offline
                            Harlock
                            Thank you very much for this!
                            Just to add my 2 cents: in Raspbian Jessie (mini) everything was fine except for the DHCP client which after fstab modification it was taking a life to stop waiting for an IP.
                            I solved editing /etc/systemd/system/dhcpcd5 this way:
                            changed the line
                            PIDFile=/run/dhcpcd.pid
                            into
                            PIDFile=/var/run/dhcpcd.pid
                            And now is fine.
                              mefi
                              Thanks for this. It really gives the stability to micro SD card that I need.
                              I have one question that may not be really about this topic, but in some way it is. I developed a Qt application which is basically a dummy application. It receives messages and images over UDP sockets, and shows them on the screen. The problem I have is that when I am in read-only mode application just aborts after about half a second or so. When it is run in read-write mode it works great.
                              After removing chunks of code and testing it in read-only mode I found out that if application don't process received messages, which i really have to since that's the only functionality application has, it doesn't get aborted. I am not that good with Linux to be honest, but what seems logical to me is that when I read that data in application it needs to be stored somewhere, and that somewhere is in read-only part of memory.
                              Does what I wrote make any sense? If yes which parts of file system need to be mounted as tmpfs to fix it? If not what is actually happening and is it possible to fix it somehow?
                              By the way I am using Raspbian Jessie Lite if that means something to you.
                              Thanks in advance
                                @Harlock thanks for the headup I will update the doc
                                @mefi, I'm not specialist of QT, may be related to QT run time or other lib, that's strange, does the application need to write something somewhere ? may be in your homedir ?
                                Would be interesting to know how QT runtime works, I have no idea, sorry.
                                  mefi
                                  @Charles No, the application doesn't write anything to the file system. It only reads settings. I implemented a logging mechanism which I used while developing but it is disabled now. I've also tried other Qt application and they run well in read-only mode. I hope I find solution soon. I'll leave a comment here when I do so others know what to do in similar situation. Thanks for great article once again.
                                    mefi
                                    @Charles Just to let you and everyone know I fixed the problem. The logger class was trying to open file for writing logs, even when there were no logs, so I added some tests, and now it runs fine. It was my mistake after all..
                                    • K Offline
                                      K Offline
                                      kxb3292
                                      hello,
                                      I have a setup of raspberry pi 3 with raspbian jessie installed. On top of it I have installed kodi v16.
                                      I have been able to switch read only/read write mode following this tutorial:
                                      However, when i put the system in read only mode and try to launch kodi I get the following message:
                                      Could not init logging classes. Permission errors on ~/.kodi (/home/pi/.kodi/temp/)
                                      ERROR: Unable to create application. Exiting
                                      Couldn't get a file descriptor referring to the console
                                      Is there a way to make kodi write its logs to a different location (like RAM?) or make it stop writing all logs all together?
                                      I would really appreciate any help!
                                      Thank you so much,
                                        #30
                                        @kxb3292
                                        may be setting kodi temp folder to tmpfs adding this line to /etc/fstab file ?
                                        tmpfs  /home/pi/.kodi/temp  tmpfs  nosuid,nodev  0  0
                                        Or best change kodi temp folder to point to /tmp/kodi in it's config (I don't know if it's possible)
                                        • smartypants_noS Offline
                                          smartypants_no
                                          Trying to make a ro mediaplayer, but when I install omxplayer dbus is a dependency, and dbus do not like a ro filesystem. What are the tricks to make dbus run on a read only filesystem?
